path: root/cpukit/libfs/src/imfs/imfs_initsupp.c (follow)
* Patch from Chris Johns <cjohns@cybertec.com.au> andJoel Sherrill2000-06-261-1/+1
| | | | | Jennifer Averett <jennifer.averett@oarcorp.com> to make sure "/" is created with S_IFDIR set.
* Fixed typo where memfile_handlers set twice and directory_handlersJoel Sherrill1999-11-021-3/+3
| | | | was not set.
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-87/+10
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* Split null handlers table to own file and renamed.Joel Sherrill1999-10-121-1/+1
| | | | Renamed IMFS handler tables to include IMFS prefix.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+158
