path: root/cpukit/libfs/src/imfs/imfs_handlers_device.c (unfollow)
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-11-05Unmount was failing as a side-effect of splitting the rmnod handlerJoel Sherrill1-1/+1
and not handling every case properly.
1999-11-02The object memfile.o was being included in the miniIMFS even though itJoel Sherrill1-1/+1
should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
1999-10-29Moved the rmnod callback from the operations table to the handler table.Jennifer Averett1-1/+2
1999-10-26New files created by split of old imfs_handlers.c.Joel Sherrill1-0/+37
