2001-01-22 | 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: Add src/imfs/config.h * src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/imfs/.cvsignore: Add config.h and stamp-h * src/imfs/*.c: Add config.h support. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1999-11-05 | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1 | -1/+1 | |
and not handling every case properly. | |||||
1999-11-02 | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1 | -1/+1 | |
should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | |||||
1999-10-29 | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1 | -1/+2 | |
1999-10-26 | New files created by split of old imfs_handlers.c. | Joel Sherrill | 1 | -0/+37 | |
