The type of ino_t is unsigned long, so it can store a pointer. Avoid a
potential integer overflow.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
The introduction of reference counting of nodes avoids the removal of
open nodes and potential usage of freed memory.
Other threads may add or remove directory entries during a read of the
directory. Use the file system instance lock for protection.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
PR1945/cpukit
* libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c: Replace rtems_off64_t with off_t.
* libcsupport/include/rtems/libio_.h: Added
rtems_filesystem_is_root_location().
* libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_eval.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c: Use
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
* libcsupport/include/rtems/libio.h: Removed file_info and handlers
fields in rtems_libio_t.
* libcsupport/src/close.c, libcsupport/src/fcntl.c,
libcsupport/src/fdatasync.c, libcsupport/src/fstat.c,
libcsupport/src/fsync.c, libcsupport/src/ftruncate.c,
libcsupport/src/getdents.c, libcsupport/src/ioctl.c,
libcsupport/src/libio_sockets.c, libcsupport/src/lseek.c,
libcsupport/src/open.c, libcsupport/src/read.c,
libcsupport/src/readv.c, libcsupport/src/write.c,
libcsupport/src/writev.c, libfs/src/devfs/devclose.c,
libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c,
libfs/src/devfs/devread.c, libfs/src/devfs/devwrite.c
libfs/src/dosfs/msdos_dir.c libfs/src/dosfs/msdos_file.c
libfs/src/imfs/deviceio.c libfs/src/imfs/imfs_directory.c
libfs/src/imfs/imfs_fifo.c libfs/src/imfs/memfile.c
libfs/src/nfsclient/src/nfs.c libfs/src/rfs/rtems-rfs-rtems-file.c
libfs/src/rfs/rtems-rfs-rtems.h libnetworking/lib/ftpfs.c: Reflect
changes above.
* libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_getchild.c,
libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/ioman.c,
libfs/src/imfs/memfile.c: Evaluate all assert calls in IMFS. Either
made them conditional on RTEMS_DEBUG or eliminated them.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_rmnod.c: Added and use
IMFS_create_orphan() and IMFS_check_node_remove().
* libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fifo.c: Use IMFS_create_orphan() and
* libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/memfile.c:
Use IMFS_rmnod() and IMFS_check_node_remove() instead of
memfile_rmnod() and memfile_check_rmnod().
* libblock/src/bdbuf.c: Update comments.
* libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the
device from the rdev field of the stat buf.
* libcsupport/include/rtems/libio.h: Add a path length to evalpath
handler. Add parent locations to rmmod and unlink handlers.
* libcsupport/include/rtems/libio_.h: Add a path length to
rtems_filesystem_evaluate_path. Add
rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname,
and rtems_filesystem_prefix_separators. Remove
rtems_filesystem_evaluate_parent.
* libcsupport/src/base_fs.c, libcsupport/src/chdir.c,
libcsupport/src/chmod.c, libcsupport/src/chown.c,
libcsupport/src/chroot.c, libcsupport/src/fchdir.c,
libcsupport/src/link.c, libcsupport/src/mount.c,
libcsupport/src/open.c, libcsupport/src/privateenv.c,
libcsupport/src/readlink.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c,
libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c,
libnetworking/lib/ftpfs.c: Add the length parameter to the eval
call.
* libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators,
rtems_filesystem_evaluate_relative_path. Add the length parameter
to the eval call.
* libcsupport/src/rmdir.c: Find the parent pathloc then the node
pathloc from that node. Remove the call to find the parent given
the node pathloc.
* libcsupport/src/stat.c: Add the length parameter to the eval
call. Set the device into the rdev field.
* libcsupport/src/unlink.c: Find the parent pathloc then the node
the node pathloc.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the
disk device number from the stat rdev field.
* libfs/src/dosfs/msdos.h: Add the length parameter to the eval
call. Add the parent pathloc to the rmnod handler.
* libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod
handler.
* libfs/src/dosfs/msdos_eval.c: Add the length parameter to the
eval and token call.
* libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the
rmnod handler.
* libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for
only the allowed flags. Add the missing flags spec'ed in the POSIX
standard.
* libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c,
libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the
parent node. Currently ignored in the IMFS.
* libfs/src/imfs/imfs_stat.c: Return the device number in the rdev
field.
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add
the length parameter to the token call.
* libfs/src/nfsclient/src/nfs.c: Add the length parameter to the
eval call and parent node to the rmnod and unlink command.
* libmisc/shell/internal.h: Remove the libc mounter decl to make
public.
* libmisc/shell/main_mount.c: Add support for hooking external
mount support for new file systems.
* libmisc/shell/shell.h: Add helper functions for the mount
command.
* libcsupport/include/rtems/libio.h: Add rtems_off64_t for
internal use. Update the internal off_t to the 64bit offset.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/deviceio.c: Change off_t to
rtems_off64_t.
* libmisc/shell/main_msdosfmt.c: Add an info level so the format
code can tell the user what is happening. Add more options to
control the format configuration.
* libfs/src/dosfs/msdos_format.c: Add a print function to display
the format progress and print statements. Select a better default
cluster size depending on the size of the disk. This lowers the
size of the FAT on large disks. Read and maintain the MRB
partition information.
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_handlers_dir.c,
libfs/src/dosfs/msdos_handlers_file.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Add
long file name support. Change off_t to rtems_off64_t.
PR 1376/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fifo.c, libfs/src/imfs/memfile.c,
libfs/src/nfsclient/src/nfs.c: lseek handlers should return off_t.
* cpukit/libcsupport/include/chain.h: Removed. Use the SAPI
interface that is supported.
* cpukit/libcsupport/Makefile.am,
cpukit/libcsupport/preinstall.am: Remove chain.h header
references.
* cpukit/sapi/include/rtems/chain.h,
cpukit/sapi/inline/rtems/chain.inl: New. A supported chains
interface.
* cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to
include the new chains interface.
* cpukit/libfs/src/imfs/imfs.h,
cpukit/libfs/src/imfs/imfs_creat.c,
cpukit/libfs/src/imfs/imfs_debug.c,
cpukit/libfs/src/imfs/imfs_directory.c,
cpukit/libfs/src/imfs/imfs_fsunmount.c,
cpukit/libfs/src/imfs/imfs_getchild.c,
cpukit/libfs/src/imfs/imfs_load_tar.c,
cpukit/libfs/src/imfs/imfs_rmnod.c,
cpukit/libfs/src/imfs/memfile.c,
cpukit/libfs/src/nfsclient/src/nfs.c,
cpukit/libcsupport/include/rtems/libio.h,
cpukit/libcsupport/src/malloc_deferred.c,
cpukit/libcsupport/src/mount.c,
cpukit/libcsupport/src/privateenv.c,
cpukit/libcsupport/src/unmount.c: Change to the new chains
interface.
* cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
* libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>.
* libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>.
* sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>.
* sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>.
* itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>.
* sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c,
libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
* src/dosfs/dosfs.h, src/dosfs/fat.h, src/dosfs/fat_fat_operations.h,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c,
src/dosfs/msdos_file.c, src/dosfs/msdos_free.c,
src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c,
src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c,
src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c,
src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c,
src/imfs/deviceio.c, src/imfs/imfs.h, src/imfs/imfs_chown.c,
src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c,
src/imfs/imfs_fchmod.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_fdatasync.c, src/imfs/imfs_free.c,
src/imfs/imfs_fsunmount.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_gtkn.c, src/imfs/imfs_handlers_device.c,
src/imfs/imfs_handlers_directory.c, src/imfs/imfs_handlers_link.c,
src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_ntype.c,
src/imfs/imfs_readlink.c, src/imfs/imfs_rmnod.c,
src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c,
src/imfs/linearfile.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c:
URL for license changed.
* src/dosfs/fat.c, src/imfs/deviceio.c, src/imfs/imfs.h,
src/imfs/imfs_directory.c, src/imfs/imfs_fchmod.c,
src/imfs/memfile.c: Eliminated warnings. A lot of this focus
was on changing read and write entry points to return ssize_t
as read(2) and write(2) now do.
* src/imfs/imfs_eval.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* src/imfs/memfile.c: Include <rtems/seterr.h>.
* src/imfs/imfs_readlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_unlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_link.c: Include <rtems/seterr.h>.
* src/imfs/imfs_chown.c: Include <rtems/seterr.h>.
* src/imfs/ioman.c: Include <rtems/seterr.h>.
* src/imfs/imfs_mount.c: Include <rtems/seterr.h>.
* src/imfs/imfs_directory.c: Include <rtems/seterr.h>.
* src/imfs/imfs_stat.c: Include <rtems/seterr.h>.
* src/imfs/imfs_fchmod.c: Include <rtems/seterr.h>.
* src/imfs/imfs_symlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_mknod.c: Include <rtems/seterr.h>.
* src/imfs/linearfile.c: Include <rtems/seterr.h>.
* src/imfs/imfs_unmount.c: Include <rtems/seterr.h>.
* src/imfs/imfs.h: Apply rtems_set_errno_and_return_minus_one.
Comment out increment_and_check_linkcounts.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR49.
* src/imfs/imfs_directory.c: Do not calculate the offset twice.
* configure.in: Add src/imfs/config.h
* src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h
* src/imfs/.cvsignore: Add config.h and stamp-h
* src/imfs/*.c: Add config.h support.
* src/imfs/Makefile.am, src/imfs/deviceio.c, src/imfs/imfs_chown.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_free.c, src/imfs/imfs_fsunmount.c, src/imfs/imfs_gtkn.c,
src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_readlink.c,
src/imfs/imfs_rmnod.c, src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
<rtems/XXX.h>. Now we do not have to reach up and over to
libc to pick them up.
* libc/isatty.c, libc/imfs_handlers_directory.c, libc/creat.c,
libc/imfs_directory.c: Fixed style issues.
read function in the IMFS properly returns the inode number.
should not have been. This required that IMFS_rmnod be split into
three separate (per file type) routines to avoid dependencies.
In the end, a miniIMFS application is 6K smaller than one using the
full IMFS.
PROBLEMS
can/will be fixed.
