* libfs/src/dosfs/msdos_format.c: Address Coverity issue 183 which was
where an expression evaluated to a constant and issue 185 which was a
potential (although unlikely in expected usage) time-of-check,
time-of-use race condition.
* libfs/src/dosfs/msdos_misc.c: Don't include <strings.h>.
* libfs/src/dosfs/msdos_conv.c: Fixed convertion of half seconds to
seconds.
* libfs/src/dosfs/msdos_misc.c: Create short file names acceptable for
Windows.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_misc.c,
libfs/src/dosfs/msdos_create.c: Create valid create and modfied date
and time.
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libcsupport/src/ioctl.c, libfs/src/dosfs/fat_file.c: Add va_end().
CID 99
CID 100
CID 101
CID 102
* libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_misc.c: Resolve invalid use of const identified
by Coverity scanner.
* libcsupport/include/rtems/libio.h: Removed file_info and handlers
fields in rtems_libio_t.
* libcsupport/src/close.c, libcsupport/src/fcntl.c,
libcsupport/src/fdatasync.c, libcsupport/src/fstat.c,
libcsupport/src/fsync.c, libcsupport/src/ftruncate.c,
libcsupport/src/getdents.c, libcsupport/src/ioctl.c,
libcsupport/src/libio_sockets.c, libcsupport/src/lseek.c,
libcsupport/src/open.c, libcsupport/src/read.c,
libcsupport/src/readv.c, libcsupport/src/write.c,
libcsupport/src/writev.c, libfs/src/devfs/devclose.c,
libfs/src/devfs/devioctl.c, libfs/src/devfs/devopen.c,
libfs/src/devfs/devread.c, libfs/src/devfs/devwrite.c
libfs/src/dosfs/msdos_dir.c libfs/src/dosfs/msdos_file.c
libfs/src/imfs/deviceio.c libfs/src/imfs/imfs_directory.c
libfs/src/imfs/imfs_fifo.c libfs/src/imfs/memfile.c
libfs/src/nfsclient/src/nfs.c libfs/src/rfs/rtems-rfs-rtems-file.c
libfs/src/rfs/rtems-rfs-rtems.h libnetworking/lib/ftpfs.c: Reflect
changes above.
* libcsupport/include/rtems/libio.h: Changed
rtems_filesystem_node_types_t to an enum. Declare
rtems_filesystem_handlers_default,
rtems_filesystem_operations_default,
rtems_filesystem_default_evalpath(),
rtems_filesystem_default_evalformake, and
rtems_filesystem_default_node_type().
* libfs/src/dosfs/msdos.h: Fixed msdos_node_type() prototype.
* libfs/src/defaults/default_evalformake.c,
libfs/src/defaults/default_handlers.c,
libfs/src/defaults/default_node_type.c,
libfs/src/defaults/default_ops.c: New files.
* libfs/Makefile.am: Reflect changes above.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libfs/src/dosfs/msdos_handlers_dir.c,
libfs/src/dosfs/msdos_handlers_file.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/imfs_handlers_device.c,
libfs/src/imfs/imfs_handlers_directory.c,
libfs/src/imfs/imfs_handlers_link.c,
libfs/src/imfs/imfs_handlers_memfile.c,
libfs/src/imfs/miniimfs_init.c, libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c: Turn NULLs into default
handlers.
* libcsupport/include/rtems/libio.h, libfs/Makefile.am,
libfs/src/defaults/default_chown.c,
libfs/src/defaults/default_evalpath.c,
libfs/src/defaults/default_freenode.c,
libfs/src/defaults/default_fsmount.c,
libfs/src/defaults/default_link.c,
libfs/src/defaults/default_mount.c,
libfs/src/defaults/default_rename.c,
libfs/src/defaults/default_statvfs.c,
libfs/src/defaults/default_symlink.c,
libfs/src/defaults/default_unlink.c,
libfs/src/defaults/default_utime.c, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/rfs/rtems-rfs-rtems.c,
wrapup/Makefile.am: Fixed typo in default names. Added default
methods into filesystem tables.
* libfs/src/defaults/default_close.c,
libfs/src/defaults/default_evaluate_link.c,
libfs/src/defaults/default_fpathconf.c,
libfs/src/defaults/default_fsunmount.c,
libfs/src/defaults/default_open.c,
libfs/src/defaults/default_unmount.c: New files.
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_eval.c:
Use size_t instead of int for pathnamelen.
* libfs/src/dosfs/msdos_format.c: Added missing va_end().
* libfs/src/dosfs/msdos_misc.c: Fix PR1491.
* libfs/src/dosfs/msdos_misc.c: Part fix to PR1491.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* libcsupport/include/rtems/libio.h, libcsupport/src/_rename_r.c:
Add a rename file op and have rename use it.
* libfs/Makefile.am, libfs/src/dosfs/msdos_rename.c,
libfs/src/imfs/imfs_rename.c: New files to support the rename file
op.
* libfs/src/imfs/imfs.h: Add rename interface.
* libfs/src/imfs/imfs_init.c: Add rename handler.
* libfs/src/imfs/miniimfs_init.c: Fix up ops struct.
* libfs/src/dosfs/msdos.h: Add msdos_rename and remove
msdos_file_link.
* libfs/src/dosfs/msdos_create.c: Remove the link call.
* libfs/src/dosfs/msdos_eval.c: Fix a path parsing bug.
* libfs/src/dosfs/msdos_init.c: Add rename handler and clean up
the struct naming.
* libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h:
Change the link call to allow linking of directories if told to
and change the unlink to handle unlink directories that are not
empty so rename can be supported.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Fix the link/unlink calls.
* libfs/src/rfs/rtems-rfs-rtems.c: Add a rename handler. Fix the
link/unlink calls.
* libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, httpd/asp.c,
libfs/src/nfsclient/src/nfs.c: Work around a newlib warning when
using the is*() family of calls.
* libmisc/shell/main_msdosfmt.c, libmisc/shell/shellconfig.h: Fix
the alias as I did understand how it worked.
* libfs/src/dosfs/msdos_format.c: Test for a block device.
* libfs/src/dosfs/fat.c, libfs/src/rfs/rtems-rfs-buffer.c: Block
devices are now block device nodes and not character device
nodes.
* libcsupport/src/termios.c, libfs/src/dosfs/msdos_format.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/pipe/fifo.c,
libnetworking/lib/rtems_bsdnet_ntp.c, libnetworking/lib/tftpDriver.c,
libnetworking/rtems/rtems_glue.c, libnetworking/rtems/rtems_select.c:
Eliminate uses of deprecated rtems_clock_get() and replace with
properly typed routine.
* libfs/src/dosfs/msdos_format.c: Rework to avoid overflow on 16-bit
targets.
16bit targets.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
libblock/src/ramdisk.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/msdos_format.c: Eliminate using the GNU/Linux
specific error numbers EBADRQC and ENOTBLK. Switch to EINVAL and
ENOTTY as appropriate.
* libblock/src/bdbuf.c: Update comments.
* libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the
device from the rdev field of the stat buf.
* libcsupport/include/rtems/libio.h: Add a path length to evalpath
handler. Add parent locations to rmmod and unlink handlers.
* libcsupport/include/rtems/libio_.h: Add a path length to
rtems_filesystem_evaluate_path. Add
rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname,
and rtems_filesystem_prefix_separators. Remove
rtems_filesystem_evaluate_parent.
* libcsupport/src/base_fs.c, libcsupport/src/chdir.c,
libcsupport/src/chmod.c, libcsupport/src/chown.c,
libcsupport/src/chroot.c, libcsupport/src/fchdir.c,
libcsupport/src/link.c, libcsupport/src/mount.c,
libcsupport/src/open.c, libcsupport/src/privateenv.c,
libcsupport/src/readlink.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c,
libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c,
libnetworking/lib/ftpfs.c: Add the length parameter to the eval
call.
* libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators,
rtems_filesystem_evaluate_relative_path. Add the length parameter
to the eval call.
* libcsupport/src/rmdir.c: Find the parent pathloc then the node
pathloc from that node. Remove the call to find the parent given
the node pathloc.
* libcsupport/src/stat.c: Add the length parameter to the eval
call. Set the device into the rdev field.
* libcsupport/src/unlink.c: Find the parent pathloc then the node
the node pathloc.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the
disk device number from the stat rdev field.
* libfs/src/dosfs/msdos.h: Add the length parameter to the eval
call. Add the parent pathloc to the rmnod handler.
* libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod
handler.
* libfs/src/dosfs/msdos_eval.c: Add the length parameter to the
eval and token call.
* libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the
rmnod handler.
* libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for
only the allowed flags. Add the missing flags spec'ed in the POSIX
standard.
* libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c,
libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the
parent node. Currently ignored in the IMFS.
* libfs/src/imfs/imfs_stat.c: Return the device number in the rdev
field.
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add
the length parameter to the token call.
* libfs/src/nfsclient/src/nfs.c: Add the length parameter to the
eval call and parent node to the rmnod and unlink command.
* libmisc/shell/internal.h: Remove the libc mounter decl to make
public.
* libmisc/shell/main_mount.c: Add support for hooking external
mount support for new file systems.
* libmisc/shell/shell.h: Add helper functions for the mount
command.
* libcsupport/include/rtems/libio.h: Add rtems_off64_t for
internal use. Update the internal off_t to the 64bit offset.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/deviceio.c: Change off_t to
rtems_off64_t.
* libmisc/shell/main_msdosfmt.c: Add an info level so the format
code can tell the user what is happening. Add more options to
control the format configuration.
* libfs/src/dosfs/msdos_format.c: Add a print function to display
the format progress and print statements. Select a better default
cluster size depending on the size of the disk. This lowers the
size of the FAT on large disks. Read and maintain the MRB
partition information.
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Add
long file name support. Change off_t to rtems_off64_t.
PR 1376/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fifo.c, libfs/src/imfs/memfile.c,
libfs/src/nfsclient/src/nfs.c: lseek handlers should return off_t.
PR 1363/filesystem
* libfs/src/dosfs/fat.h: Fix issue where 32 bit values are not written
correctly in FAT f/s data.
* libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/stackchk/internal.h,
rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h,
score/include/rtems/score/bitfield.h, score/src/mpci.c,
score/src/objectextendinformation.c, score/src/threadmp.c: Remove
extraneous spaces.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
* libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c,
libfs/src/imfs/imfs_debug.c: Remove warnings.
* libfs/src/dosfs/msdos_misc.c: Revert to vers. 1.9.
PR 828/filesystems
* libfs/src/dosfs/msdos_misc.c: Problem retracted. Revert patch.
PR 744/filesystem
* libcsupport/src/unlink.c, libfs/src/dosfs/msdos_eval.c: DOSFS did not
support permissions on directories so the check performed by unlink
would always fail. The unlink code was modified to support a not
supported status being returned.
* libblock/src/blkdev.c, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c:
Removed warnings.
* libfs/src/dosfs/msdos_format.c, librpc/src/xdr/xdr.c: Added
initialization to remove warnings.
* libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c:
Eliminate warnings.
