Update #2929.
Implement ctime and mtime updates according to POSIX. The ctime is
mapped to the FAT create time and date. The mtime is mapped to the FAT
last modified time and date. For the atime use the mtime for
simplicity.
User interface and backwards compatibility for UTF-8 support in the FAT
file system. Purpose of UTF-8 support is to permit file names and
directory names with characters from all kinds of languages (Czech,
Chinese, Arabian, Hebrew, Korean, ...). This commit does not yet
support multibyte characters. It only contains the user interface and
the backwards compatibility.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_misc.c,
libfs/src/dosfs/msdos_create.c: Create valid create and modfied date
and time.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libcsupport/include/rtems/libio.h, libcsupport/src/_rename_r.c:
Add a rename file op and have rename use it.
* libfs/Makefile.am, libfs/src/dosfs/msdos_rename.c,
libfs/src/imfs/imfs_rename.c: New files to support the rename file
op.
* libfs/src/imfs/imfs.h: Add rename interface.
* libfs/src/imfs/imfs_init.c: Add rename handler.
* libfs/src/imfs/miniimfs_init.c: Fix up ops struct.
* libfs/src/dosfs/msdos.h: Add msdos_rename and remove
msdos_file_link.
* libfs/src/dosfs/msdos_create.c: Remove the link call.
* libfs/src/dosfs/msdos_eval.c: Fix a path parsing bug.
* libfs/src/dosfs/msdos_init.c: Add rename handler and clean up
the struct naming.
* libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h:
Change the link call to allow linking of directories if told to
and change the unlink to handle unlink directories that are not
empty so rename can be supported.
* libfs/src/rfs/rtems-rfs-rtems-dir.c: Fix the link/unlink calls.
* libfs/src/rfs/rtems-rfs-rtems.c: Add a rename handler. Fix the
link/unlink calls.
* libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, httpd/asp.c,
libfs/src/nfsclient/src/nfs.c: Work around a newlib warning when
using the is*() family of calls.
* libblock/src/bdbuf.c: Update comments.
* libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the
device from the rdev field of the stat buf.
* libcsupport/include/rtems/libio.h: Add a path length to evalpath
handler. Add parent locations to rmmod and unlink handlers.
* libcsupport/include/rtems/libio_.h: Add a path length to
rtems_filesystem_evaluate_path. Add
rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname,
and rtems_filesystem_prefix_separators. Remove
rtems_filesystem_evaluate_parent.
* libcsupport/src/base_fs.c, libcsupport/src/chdir.c,
libcsupport/src/chmod.c, libcsupport/src/chown.c,
libcsupport/src/chroot.c, libcsupport/src/fchdir.c,
libcsupport/src/link.c, libcsupport/src/mount.c,
libcsupport/src/open.c, libcsupport/src/privateenv.c,
libcsupport/src/readlink.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c,
libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c,
libnetworking/lib/ftpfs.c: Add the length parameter to the eval
call.
* libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators,
rtems_filesystem_evaluate_relative_path. Add the length parameter
to the eval call.
* libcsupport/src/rmdir.c: Find the parent pathloc then the node
pathloc from that node. Remove the call to find the parent given
the node pathloc.
* libcsupport/src/stat.c: Add the length parameter to the eval
call. Set the device into the rdev field.
* libcsupport/src/unlink.c: Find the parent pathloc then the node
the node pathloc.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the
disk device number from the stat rdev field.
* libfs/src/dosfs/msdos.h: Add the length parameter to the eval
call. Add the parent pathloc to the rmnod handler.
* libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod
handler.
* libfs/src/dosfs/msdos_eval.c: Add the length parameter to the
eval and token call.
* libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the
rmnod handler.
* libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for
only the allowed flags. Add the missing flags spec'ed in the POSIX
standard.
* libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c,
libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the
parent node. Currently ignored in the IMFS.
* libfs/src/imfs/imfs_stat.c: Return the device number in the rdev
field.
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add
the length parameter to the token call.
* libfs/src/nfsclient/src/nfs.c: Add the length parameter to the
eval call and parent node to the rmnod and unlink command.
* libmisc/shell/internal.h: Remove the libc mounter decl to make
public.
* libmisc/shell/main_mount.c: Add support for hooking external
mount support for new file systems.
* libmisc/shell/shell.h: Add helper functions for the mount
command.
* libcsupport/include/rtems/libio.h: Add rtems_off64_t for
internal use. Update the internal off_t to the 64bit offset.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/deviceio.c: Change off_t to
rtems_off64_t.
* libmisc/shell/main_msdosfmt.c: Add an info level so the format
code can tell the user what is happening. Add more options to
control the format configuration.
* libfs/src/dosfs/msdos_format.c: Add a print function to display
the format progress and print statements. Select a better default
cluster size depending on the size of the disk. This lowers the
size of the FAT on large disks. Read and maintain the MRB
partition information.
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_handlers_dir.c,
libfs/src/dosfs/msdos_handlers_file.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Add
long file name support. Change off_t to rtems_off64_t.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c,
libfs/src/imfs/imfs_debug.c: Remove warnings.
* libblock/src/blkdev.c, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c:
Removed warnings.
* libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c:
Eliminate warnings.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c,
libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
* src/dosfs/dosfs.h, src/dosfs/fat.h, src/dosfs/fat_fat_operations.h,
src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c,
src/dosfs/msdos_file.c, src/dosfs/msdos_free.c,
src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c,
src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c,
src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c,
src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c,
src/imfs/deviceio.c, src/imfs/imfs.h, src/imfs/imfs_chown.c,
src/imfs/imfs_config.c, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_directory.c, src/imfs/imfs_eval.c,
src/imfs/imfs_fchmod.c, src/imfs/imfs_fcntl.c,
src/imfs/imfs_fdatasync.c, src/imfs/imfs_free.c,
src/imfs/imfs_fsunmount.c, src/imfs/imfs_getchild.c,
src/imfs/imfs_gtkn.c, src/imfs/imfs_handlers_device.c,
src/imfs/imfs_handlers_directory.c, src/imfs/imfs_handlers_link.c,
src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_link.c,
src/imfs/imfs_mknod.c, src/imfs/imfs_mount.c, src/imfs/imfs_ntype.c,
src/imfs/imfs_readlink.c, src/imfs/imfs_rmnod.c,
src/imfs/imfs_stat.c, src/imfs/imfs_symlink.c,
src/imfs/imfs_unixstub.c, src/imfs/imfs_unlink.c,
src/imfs/imfs_unmount.c, src/imfs/imfs_utime.c, src/imfs/ioman.c,
src/imfs/linearfile.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c:
URL for license changed.
* msdos_create.c: Remove unused variable warning.
PR 441/filesystem
*src/dosfs/msdos.h: add rename support to DOSFS
*src/dosfs/msdos_create.c: add rename support to DOSFS
*src/dosfs/msdos_file.c: add rename support to DOSFS
*src/dosfs/msdos_init.c: add rename support to DOSFS
*src/dosfs/msdos_mknod.c: add rename support to DOSFS
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in,
src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c,
src/dosfs/fat.h, src/dosfs/fat_fat_operations.c,
src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c,
src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c,
src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c,
src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c,
src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c,
src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c,
src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files.
* configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
