brains GmbH.
Updates #3053.
Updates #4625.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
This is a cosmetic fix. There was no bug.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
