Change error indication to ESPIPE in rtems_filesystem_default_lseek().
PR1945/cpukit
* libfs/src/defaults/default_ftruncate.c,
libfs/src/defaults/default_lseek.c:
Replace rtems_off64_t with off_t.
* libfs/src/defaults/default_chown.c,
libfs/src/defaults/default_evalpath.c,
libfs/src/defaults/default_fchmod.c,
libfs/src/defaults/default_fcntl.c,
libfs/src/defaults/default_fdatasync.c,
libfs/src/defaults/default_freenode.c,
libfs/src/defaults/default_fsmount.c,
libfs/src/defaults/default_fstat.c,
libfs/src/defaults/default_fsync.c,
libfs/src/defaults/default_ioctl.c,
libfs/src/defaults/default_link.c,
libfs/src/defaults/default_lseek.c,
libfs/src/defaults/default_mount.c,
libfs/src/defaults/default_read.c,
libfs/src/defaults/default_readlink.c,
libfs/src/defaults/default_rename.c,
libfs/src/defaults/default_rmnod.c,
libfs/src/defaults/default_statvfs.c,
libfs/src/defaults/default_symlink.c,
libfs/src/defaults/default_unlink.c,
libfs/src/defaults/default_utime.c,
libfs/src/defaults/default_write.c: Add include of rtems/seterr.h
* libcsupport/include/rtems/libio.h, libfs/Makefile.am: Added default
filesystem handlers.
libfs/src/defaults/default_write.c: New files.
