* | leon, l4stat: Initial driver commit | Javier Jalle | 2017-05-02 | 1 | -0/+4 |
* | leon, memscrub: add GR740 memory scrubber driver | Javier Jalle | 2017-05-02 | 1 | -0/+4 |
* | leon, griommu: add GR740 IOMMU driver | Javier Jalle | 2017-05-02 | 1 | -0/+4 |
| | | | | | The driver is limited to the access protection bit-vector. It currently does not support the IOMMU page-table functionality. | ||||
* | leon, l2cache: add GR740 L2-Cache driver | Javier Jalle | 2017-05-02 | 1 | -0/+4 |
* | drvmgr: ability to configure IRQ affinity | Daniel Hellstrom | 2017-05-02 | 2 | -0/+33 |
* | leon, GR-CPCI-GR740: Added peripheral PCI driver | Javier Jalle | 2017-05-02 | 1 | -0/+4 |
* | libdrvmgr: remove braces | Daniel Cederman | 2017-03-06 | 1 | -1/+1 |
* | libdrvmgr: added default BSP init level hook | Daniel Hellstrom | 2017-03-06 | 1 | -0/+9 |
* | Make rtems/print.h independent of rtems/bspIo.h | Sebastian Huber | 2016-06-22 | 1 | -0/+2 |
* | Use linker set for driver manager initialization | Sebastian Huber | 2016-02-03 | 1 | -0/+90 |
| | | | | Update #2408. | ||||
* | Revert "drvmgr: Move bsp_driver_level_hook() calls" | Sebastian Huber | 2016-01-26 | 1 | -7/+6 |
| | | | | | | | | | The --enable-drvmgr configure option controls the driver manager startup and not if the driver manager is present or not. Presence of the driver manager is determined by the architecture (only available on sparc so far). This reverts commit 61bbf9194ff4bdbc1b48e6ac9919c02b358e5701. | ||||
* | drvmgr: Move bsp_driver_level_hook() calls | Sebastian Huber | 2016-01-26 | 1 | -6/+7 |
* | DRVMGR: remove struct driver registration func | Daniel Hellstrom | 2015-04-17 | 3 | -117/+44 |
* | DRVMGR: clean-up DRV_OPS_NUM | Daniel Hellstrom | 2015-04-17 | 2 | -3/+4 |
* | DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | DRVMGR: KEY_TYPE now a enum drvmgr_kt | Daniel Hellstrom | 2015-04-17 | 3 | -15/+19 |
* | DRVMGR: renamed info_dev to get_info_dev | Daniel Hellstrom | 2015-04-17 | 2 | -4/+5 |
* | DRVMGR: change name of freq_get to get_freq | Daniel Hellstrom | 2015-04-17 | 2 | -3/+3 |
* | DRVMGR: renamed private drv_mgr and its struct name | Daniel Hellstrom | 2015-04-17 | 9 | -35/+35 |
* | DRVMGR: updated README | Daniel Hellstrom | 2015-04-17 | 1 | -3/+4 |
* | DRVMGR: only build on SPARC platform | Daniel Hellstrom | 2015-04-17 | 1 | -0/+4 |
* | DRVMGR: updated license to rtems.org | Daniel Hellstrom | 2015-04-17 | 22 | -22/+22 |
* | DRVMGR: removed a goto and added comments | Daniel Hellstrom | 2015-04-17 | 1 | -3/+5 |
* | DRVMGR: clean-up Makefile.am | Daniel Hellstrom | 2015-04-17 | 1 | -4/+0 |
* | DRVMGR: use RTEMS_INLINE_ROUTINE | Daniel Hellstrom | 2015-04-17 | 1 | -2/+4 |
* | DRVMGR: updated copyright into one line only | Daniel Hellstrom | 2015-04-17 | 22 | -44/+22 |
* | GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device | Daniel Hellstrom | 2015-04-17 | 1 | -0/+6 |
| | | | | Interrupts have not been test yet | ||||
* | GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA | Daniel Hellstrom | 2015-04-17 | 1 | -0/+6 |
| | | | | | | | | | | | | | | | | This patch adds a new driver for the GRSPW SpaceWire AMBA interface family. The new driver does not implement a standard RTEMS driver, instead it provides only a library interface to the GRSPW devices. This driver can be used to implement a RTEMS I/O driver or used directly. New features compared with old GRSPW driver: * zero-copy packet interface * possibility to send/receive mulitple packets per call * optional interrupt awaken work-task to process TX/RX queues * DMA channels support. Before only first DMA channel supported * Separate DMA and link control * Packet based error flags | ||||
* | DRVMGR: add LEON BSPs driver registration | Daniel Hellstrom | 2015-04-17 | 1 | -3/+215 |
* | DRVMGR: added driver manager to cpukit/libdrvmgr | Daniel Hellstrom | 2015-04-17 | 24 | -0/+3563 |
