* | DRVMGR: remove struct driver registration func | Daniel Hellstrom | 2015-04-17 | 3 | -117/+44 |
* | DRVMGR: clean-up DRV_OPS_NUM | Daniel Hellstrom | 2015-04-17 | 2 | -3/+4 |
* | DRVMGR: renamed RES_EMPTY to DRVMGR_RES_EMPTY | Daniel Hellstrom | 2015-04-17 | 1 | -1/+1 |
* | DRVMGR: KEY_TYPE now a enum drvmgr_kt | Daniel Hellstrom | 2015-04-17 | 3 | -15/+19 |
* | DRVMGR: renamed info_dev to get_info_dev | Daniel Hellstrom | 2015-04-17 | 2 | -4/+5 |
* | DRVMGR: change name of freq_get to get_freq | Daniel Hellstrom | 2015-04-17 | 2 | -3/+3 |
* | DRVMGR: renamed private drv_mgr and its struct name | Daniel Hellstrom | 2015-04-17 | 9 | -35/+35 |
* | DRVMGR: updated README | Daniel Hellstrom | 2015-04-17 | 1 | -3/+4 |
* | DRVMGR: only build on SPARC platform | Daniel Hellstrom | 2015-04-17 | 1 | -0/+4 |
* | DRVMGR: updated license to rtems.org | Daniel Hellstrom | 2015-04-17 | 22 | -22/+22 |
* | DRVMGR: removed a goto and added comments | Daniel Hellstrom | 2015-04-17 | 1 | -3/+5 |
* | DRVMGR: clean-up Makefile.am | Daniel Hellstrom | 2015-04-17 | 1 | -4/+0 |
* | DRVMGR: use RTEMS_INLINE_ROUTINE | Daniel Hellstrom | 2015-04-17 | 1 | -2/+4 |
* | DRVMGR: updated copyright into one line only | Daniel Hellstrom | 2015-04-17 | 22 | -44/+22 |
* | GR-CPCI-LEON4-N2X: added PCI peripheral driver for PCI device | Daniel Hellstrom | 2015-04-17 | 1 | -0/+6 |
| | | | | Interrupts have not been test yet | ||||
* | GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA | Daniel Hellstrom | 2015-04-17 | 1 | -0/+6 |
| | | | | | | | | | | | | | | | | This patch adds a new driver for the GRSPW SpaceWire AMBA interface family. The new driver does not implement a standard RTEMS driver, instead it provides only a library interface to the GRSPW devices. This driver can be used to implement a RTEMS I/O driver or used directly. New features compared with old GRSPW driver: * zero-copy packet interface * possibility to send/receive mulitple packets per call * optional interrupt awaken work-task to process TX/RX queues * DMA channels support. Before only first DMA channel supported * Separate DMA and link control * Packet based error flags | ||||
* | DRVMGR: add LEON BSPs driver registration | Daniel Hellstrom | 2015-04-17 | 1 | -3/+215 |
* | DRVMGR: added driver manager to cpukit/libdrvmgr | Daniel Hellstrom | 2015-04-17 | 24 | -0/+3563 |
