The driver manager lock may be used before the executing thread is
initialized.
Update #2408.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Fixes #2930
Implement the Processor_mask via <sys/bitset.h>. Provide
_Processor_mask_To_uint32_t() to enable its use in device specific
routines, e.g. interrupt affinity register in an interrupt controller.
Update #3059.
The driver is limited to the access protection bit-vector. It
currently does not support the IOMMU page-table functionality.
Update #2408.
The --enable-drvmgr configure option controls the driver manager startup
and not if the driver manager is present or not. Presence of the driver
manager is determined by the architecture (only available on sparc so
far).
This reverts commit 61bbf9194ff4bdbc1b48e6ac9919c02b358e5701.
Interrupts have not been test yet
This patch adds a new driver for the GRSPW SpaceWire AMBA
interface family. The new driver does not implement a standard
RTEMS driver, instead it provides only a library interface to
the GRSPW devices. This driver can be used to implement a
RTEMS I/O driver or used directly.
New features compared with old GRSPW driver:
* zero-copy packet interface
* possibility to send/receive mulitple packets per call
* optional interrupt awaken work-task to process TX/RX queues
* DMA channels support. Before only first DMA channel supported
* Separate DMA and link control
* Packet based error flags
