path: root/cpukit/libdrvmgr/drvmgr.c (follow)
* cpukit: occured -> occurredSebastian Huber2021-07-161-1/+1
* drvmgr: Remove bsp_driver_level_hook()Sebastian Huber2018-04-201-9/+0
| | | | | | Use RTEMS_SYSINIT_ITEM() instead. Update #2408.
* drvmgr: Use API mutexSebastian Huber2017-12-061-6/+1
* libdrvmgr: added default BSP init level hookDaniel Hellstrom2017-03-061-0/+9
* Use linker set for driver manager initializationSebastian Huber2016-02-031-0/+90
| | | | Update #2408.
* Revert "drvmgr: Move bsp_driver_level_hook() calls"Sebastian Huber2016-01-261-7/+6
| | | | | | | | | The --enable-drvmgr configure option controls the driver manager startup and not if the driver manager is present or not. Presence of the driver manager is determined by the architecture (only available on sparc so far). This reverts commit 61bbf9194ff4bdbc1b48e6ac9919c02b358e5701.
* drvmgr: Move bsp_driver_level_hook() callsSebastian Huber2016-01-261-6/+7
* DRVMGR: remove struct driver registration funcDaniel Hellstrom2015-04-171-3/+3
* DRVMGR: renamed private drv_mgr and its struct nameDaniel Hellstrom2015-04-171-13/+13
* DRVMGR: updated license to rtems.orgDaniel Hellstrom2015-04-171-1/+1
* DRVMGR: removed a goto and added commentsDaniel Hellstrom2015-04-171-3/+5
* DRVMGR: updated copyright into one line onlyDaniel Hellstrom2015-04-171-2/+1
* DRVMGR: added driver manager to cpukit/libdrvmgrDaniel Hellstrom2015-04-171-0/+643
