#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- Load symbols before allocation.
- Parse reloc records and place any reloc recs in a cache to use
while the allocator is locked.
- Relocate symbols after section allocation.
- Split section loading into allocation/locating and loading.
- Update all arch back-ends with a new reloc interface to control
tramp handling.
- Add `-a` and `-t` to the object list shell command.
Closes #3741
Coverity 1399717
Updates #3686
- Add support for architecure sections that can be handled by the
architecture back end.
- Add trampoline/fixup support for PowerPC. This means the PowerPC
now supports large memory loading of applications.
- Add a bit allocator to manage small block based regions of memory.
- Add small data (sdata/sbss) support for the PowerPC. The support
makes the linker allocated small data region of memory a global
resource available to libdl loaded object files.
Updates #3687
Updates #3685
- Add trampolines to support relocs that are out of range on
support architectures.
- Support not loading separate text/data sections in an object
file if the symbol provided in the section is a duplicate.
A base image may have pulled in part of an object and another
part needs to be dynamically loaded.
- Refactor the unresolved handling to scale to hundreds of
unresolved symbols when loading large number of files.
Updates #3685
- Fix the handling of pending objects.
- Add a constructor flags in objects to track then being called.
Closes #2921
- Load archive symbol tables to support searching of archives
for symbols.
- Search archive symbols and load the object file that contains
the symbol.
- Search the global and archives until all remaining unresolved symbols
are not found. Group the loaded object files in the pending queue.
- Run the object file and loaded dependents as a group before adding to the
main object list.
- Remove orphaned object files after references are removed.
Updates #3686
Username: deuteriumoxide Email: jacobshin313@gmail.com
Tracking references lets us manage when an object file can be
unloaded. If an object file has references to it, it cannot be
unloaded.
Modules that depend on each other cannot be unloaded.
Updates #3605
Updates #3194
Prepare for header file move to common include directory.
Update #3254.
Update #2133.
This is a merge of the RTL project.
