* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 1 | -24/+25 |
| | | | | Updates #3053. | ||||
* | cpukit/libdl Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 |
* | libdl: Do not access the ELF file while the allocator is locked. | Chris Johns | 2019-05-03 | 1 | -0/+94 |
- Load symbols before allocation. - Parse reloc records and place any reloc recs in a cache to use while the allocator is locked. - Relocate symbols after section allocation. - Split section loading into allocation/locating and loading. - Update all arch back-ends with a new reloc interface to control tramp handling. - Add `-a` and `-t` to the object list shell command. Closes #3741 |
