#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- The archive command lists archives, symbols and any duplicate
symbols.
- Change the RTL shell commands to the rtems_printer to allow
the output to be captured.
- Load archive symbol tables to support searching of archives
for symbols.
- Search archive symbols and load the object file that contains
the symbol.
- Search the global and archives until all remaining unresolved symbols
are not found. Group the loaded object files in the pending queue.
- Run the object file and loaded dependents as a group before adding to the
main object list.
- Remove orphaned object files after references are removed.
Updates #3686
Prepare for header file move to common include directory.
Update #3254.
This patch fixes a number of bugs in the cache when requests are
made to read close to the end of the file and the data is copied
from the top of the cache buffer to the bottom of the buffer. This
was compounded by attempting to read past the end of the file.
Closes #2754.
This is a merge of the RTL project.
