path: root/cpukit/libdl/rtl-sym.h (follow)
* Replace www.rtems.com with www.rtems.orgSebastian Huber2015-03-201-1/+1
* libdl: Add a local symbol table to the object module.Chris Johns2014-11-041-1/+8
| | | | | | Adding a local symbol lets the relocator find local symbols referenced in relocation records. The local symbol table is erased once the object module has been loaded.
* cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns2014-10-311-0/+128
This is a merge of the RTL project.
