* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 1 | -9/+10 |
| | | | | Updates #3053. | ||||
* | cpukit/libdl Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 |
* | libdl/rap: Correctly check the return enum from rela calls | Chris Johns | 2020-05-05 | 1 | -4/+13 |
| | | | | | | | | - The change from bool to an enum did not trip a compiler warning and only the rel path was changed. The rela path was missed so archs like SPARC failed. Updates #3969 | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | libdl/rap: fix RAP file load error. | zhengxiaojun | 2019-06-12 | 1 | -2/+2 |
* | libdl/rap: Add the section alloc call after section load was split | Chris Johns | 2019-02-15 | 1 | -0/+6 |
| | | | | Updates #3687 | ||||
* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -70/+70 |
* | libdl: RAP format fixes. | Chris Johns | 2018-04-12 | 1 | -8/+10 |
| | | | | | | | | | | - Do not error if a RAP section is not found. - Free a symbol table via the RTL allocator interface. - Add the symbols to the global symbol table. Update #2769 | ||||
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -3/+3 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | libdl: Fix warnings | Sebastian Huber | 2017-10-06 | 1 | -23/+27 |
| | | | | Update #3155. | ||||
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -20/+35 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | libdl/rtl-obj.c: synchronize cache after code relocation. | Pavel Pisa | 2016-07-21 | 1 | -0/+2 |
| | | | | | | | | Memory content changes caused by relocation has to be propagated to memory/cache level which is used/snooped during instruction cache fill. Closes #2438 | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+980 |
This is a merge of the RTL project. |
