* | libdl: Back port C++ exception throw and catch from 4.12. | Chris Johns | 2017-04-04 | 1 | -90/+243 |
| | | | | Closes #2956. | ||||
* | libdl/rtl-obj.c: synchronize cache should not depend on CPU_CACHE_LINE_BYTES. | Pavel Pisa | 2016-10-03 | 1 | -3/+6 |
| | | | | | | | | | | The CPU_CACHE_LINE_BYTES has been introduced after 4.11 branch fork and is not available for all architectures on RTEMS 4.11. Use of rtems_cache_get_maximal_line_size() is more descriptive choice. The min/max data/instruction cache line size is not critical there, value is used for optimization only to use single operation for decently following sections. | ||||
* | libdl/rtl-obj.c: synchronize cache after code relocation. | Pavel Pisa | 2016-10-02 | 1 | -0/+63 |
| | | | | | | | | | Memory content changes caused by relocation has to be propagated to memory/cache level which is used/snooped during instruction cache fill. Closes #2438 Updates #2782 | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+1031 |
This is a merge of the RTL project. |
