* | libdl/rtl-obj-cache.c: Fix printf() format warning | Joel Sherrill | 2017-04-25 | 1 | -2/+3 |
* | libdl/rtl-obj-cache.c: Use PRIdoff_t to avoid printf() format warnings on ↵ | Joel Sherrill | 2017-04-24 | 1 | -2/+3 |
| | | | | some architectures | ||||
* | libdl/rtl-obj-cache.c: Using inttypes macros fixes 4 format warnings | Cillian O'Donnell | 2017-04-07 | 1 | -9/+12 |
* | libdl: Fix cache corruption bugs. | Chris Johns | 2016-08-15 | 1 | -17/+70 |
| | | | | | | | | | This patch fixes a number of bugs in the cache when requests are made to read close to the end of the file and the data is copied from the top of the cache buffer to the bottom of the buffer. This was compounded by attempting to read past the end of the file. Closes #2754. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+197 |
This is a merge of the RTL project. |
