* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -19/+19 |
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -1/+1 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | libdl: Fix warnings | Sebastian Huber | 2017-10-06 | 1 | -2/+3 |
| | | | | Update #3155. | ||||
* | libdl: Fix warning | Sebastian Huber | 2017-02-15 | 1 | -1/+2 |
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -0/+43 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | libdl/rtl-mdreloc-powerpc.c: Fix warnings | Joel Sherrill | 2014-11-20 | 1 | -2/+1 |
| | | | | | | This patch addresses the following warnings: + The variable "target" was unused. + The parentheses in the expression around line 72 were ambiguous. | ||||
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+186 |
This is a merge of the RTL project. |
