path: root/cpukit/libdl/rtl-mdreloc-m68k.c (follow)
* libdl: Do not access the ELF file while the allocator is locked.Chris Johns2019-05-031-87/+87
| | | | | | | | | | | | | - Load symbols before allocation. - Parse reloc records and place any reloc recs in a cache to use while the allocator is locked. - Relocate symbols after section allocation. - Split section loading into allocation/locating and loading. - Update all arch back-ends with a new reloc interface to control tramp handling. - Add `-a` and `-t` to the object list shell command. Closes #3741
* libdl: Add powerpc large memory and small data support.Chris Johns2019-02-091-2/+34
| | | | | | | | | | | | | | | | | - Add support for architecure sections that can be handled by the architecture back end. - Add trampoline/fixup support for PowerPC. This means the PowerPC now supports large memory loading of applications. - Add a bit allocator to manage small block based regions of memory. - Add small data (sdata/sbss) support for the PowerPC. The support makes the linker allocated small data region of memory a global resource available to libdl loaded object files. Updates #3687 Updates #3685
* libdl: Add support for trampolinesChris Johns2019-02-091-2/+52
| | | | | | | | | | | | | - Trampolines or fixups for veneers provide long jump support for instruciton sets that implement short relative address branches. The linker provides trampolines when creating a static image. This patch adds trampoline support to libdl and the ARM architecture. - The dl09 test requires enough memory so modules are outside the relative branch instruction ranges for the architecture. Updates #3685
* libdl: Remove _t from all structures as this is reserved for the standardsChris Johns2018-04-121-20/+20
* libdl: Include <rtems/rtl/rtl-*.h>Sebastian Huber2017-12-131-1/+1
| | | | | | Prepare for header file move to common include directory. Update #3254.
* libdl: Add C++ exception support to loaded modules.Chris Johns2016-12-141-0/+29
| | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767.
* cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns2014-10-311-0/+148
This is a merge of the RTL project.
