* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -4/+4 |
* | libdl: Fix potential overwrite of dest buffer | Sebastian Huber | 2018-02-07 | 1 | -1/+1 |
| | | | | Update #2843. | ||||
* | Include missing <string.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | Update #2133. | ||||
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -5/+12 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+47 |
This is a merge of the RTL project. |
