path: root/cpukit/libdl/rtl-error.c (follow)
* cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright)Joel Sherrill2022-03-221-7/+8
| | | | Updates #3053.
* cpukit/libdl Change license to BSD-2Joel Sherrill2022-03-221-3/+22
| | | | Updates #3053.
* libdl: Add powerpc large memory and small data support.Chris Johns2019-02-091-0/+1
| | | | | | | | | | | | | | | | | - Add support for architecure sections that can be handled by the architecture back end. - Add trampoline/fixup support for PowerPC. This means the PowerPC now supports large memory loading of applications. - Add a bit allocator to manage small block based regions of memory. - Add small data (sdata/sbss) support for the PowerPC. The support makes the linker allocated small data region of memory a global resource available to libdl loaded object files. Updates #3687 Updates #3685
* libdl: Remove _t from all structures as this is reserved for the standardsChris Johns2018-04-121-4/+4
* libdl: Fix potential overwrite of dest bufferSebastian Huber2018-02-071-1/+1
| | | | Update #2843.
* Include missing <string.h>Sebastian Huber2017-08-251-0/+1
| | | | Update #2133.
* libdl: Add C++ exception support to loaded modules.Chris Johns2016-12-141-5/+12
| | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767.
* Replace www.rtems.com with www.rtems.orgSebastian Huber2015-03-201-1/+1
* cpukit: Add libdl with the Runtime Loader (RTL) code.Chris Johns2014-10-311-0/+47
This is a merge of the RTL project.
