* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | libdl: Update comment with details about the error fix. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | See refs #2192. | ||||
* | libdl: Fix possible 16-bit overflow (Coverity 1255339) refs #2192. | Chris Johns | 2014-11-20 | 1 | -1/+1 |
| | | | | | On a 16-bit target the section value could result in a sign-extension overflow. | ||||
* | libdl: Add a local symbol table to the object module. | Chris Johns | 2014-11-04 | 1 | -81/+154 |
| | | | | | | Adding a local symbol lets the relocator find local symbols referenced in relocation records. The local symbol table is erased once the object module has been loaded. | ||||
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+882 |
This is a merge of the RTL project. |
