* | cpukit/libdl: Manual file header reordering (SPDX, Doxygen, Copyright) | Joel Sherrill | 2022-03-22 | 1 | -16/+17 |
| | | | | Updates #3053. | ||||
* | cpukit/libdl Change license to BSD-2 | Joel Sherrill | 2022-03-22 | 1 | -3/+22 |
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | libdl/debugger: Fix the broken list delete when unloading an object module. | Chris Johns | 2019-08-12 | 1 | -13/+13 |
| | | | | Closes #3777 | ||||
* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -3/+3 |
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -2/+2 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -6/+8 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+96 |
This is a merge of the RTL project. |
