path: root/cpukit/libdl/rtl-bit-alloc.h (follow)
* libdl: Add powerpc large memory and small data support.Chris Johns2019-02-091-0/+82
- Add support for architecure sections that can be handled by the architecture back end. - Add trampoline/fixup support for PowerPC. This means the PowerPC now supports large memory loading of applications. - Add a bit allocator to manage small block based regions of memory. - Add small data (sdata/sbss) support for the PowerPC. The support makes the linker allocated small data region of memory a global resource available to libdl loaded object files. Updates #3687 Updates #3685
