* | libdl/alloc: Add a locking interface to the allocator. | Chris Johns | 2019-02-20 | 1 | -0/+34 |
| | | | | | | | | | | | | | - Allow an allocator to lock the allocations. This is needed to lock the heap allocator so the text and trampoline table are as close together as possible to allow for the largest possible object file size. - Update the default heap allocator to lock the heap allocator. - Update ELF loading to lock the allocator. Updates #3685 | ||||
* | libdl: Allocator does not unlock and lock memory on loading. | Chris Johns | 2019-02-15 | 1 | -10/+74 |
| | | | | Close #3692 | ||||
* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -19/+19 |
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -1/+1 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | Include missing <string.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | Update #2133. | ||||
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -4/+22 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | libdl: Update the comments. | Chris Johns | 2014-11-20 | 1 | -1/+2 |
| | | | | See refs #2191. | ||||
* | libdl: Add a comment. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | See ref #2191. | ||||
* | libdl: Add a comment to the previous fix. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | The fix is ref #2191. | ||||
* | libdl: Fix allocator NULL check (Coverity 1255328) refs #2191 | Chris Johns | 2014-11-20 | 1 | -1/+1 |
| | | | | | The address returned from the allocator call was not checked when zeroing the memory. | ||||
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+210 |
This is a merge of the RTL project. |
