* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -19/+19 |
* | libdl: Include <rtems/rtl/rtl-*.h> | Sebastian Huber | 2017-12-13 | 1 | -1/+1 |
| | | | | | | Prepare for header file move to common include directory. Update #3254. | ||||
* | Include missing <string.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | Update #2133. | ||||
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -4/+22 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | libdl: Update the comments. | Chris Johns | 2014-11-20 | 1 | -1/+2 |
| | | | | See refs #2191. | ||||
* | libdl: Add a comment. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | See ref #2191. | ||||
* | libdl: Add a comment to the previous fix. | Chris Johns | 2014-11-20 | 1 | -0/+3 |
| | | | | The fix is ref #2191. | ||||
* | libdl: Fix allocator NULL check (Coverity 1255328) refs #2191 | Chris Johns | 2014-11-20 | 1 | -1/+1 |
| | | | | | The address returned from the allocator call was not checked when zeroing the memory. | ||||
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+210 |
This is a merge of the RTL project. |
