* | libdl: Support link ordered loading of ELF sections. | Chris Johns | 2017-03-31 | 1 | -3/+7 |
| | | | | | | | | | | | | | The ARM C++ exception ABI uses an address ordered index table to locate the correct frame data and this requires the EXIDX sections are loaded in the order the order the matching text is loaded. The EXIDX sections set the SHF_LINK_ORDER flag and link field. This patch adds support to load those flagged sections in the linked-to section order. Updates #2955. Closes #2959 | ||||
* | libdl: Add ARM C++ relocation record support. | Chris Johns | 2016-09-08 | 1 | -1/+2 |
| | | | | Closes #2767 | ||||
* | Remove M32R architecture | Joel Sherrill | 2016-01-04 | 1 | -39/+0 |
| | | | | updates #2446. | ||||
* | libdl/.../mips/machine/elf_machdep.h: Fix typo so compiles | Joel Sherrill | 2014-11-20 | 1 | -2/+5 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 17 | -0/+2302 |
This is a merge of the RTL project. |
