* | libdl: Remove _t from all structures as this is reserved for the standards | Chris Johns | 2018-04-12 | 1 | -11/+11 |
* | libdl: Add C++ exception support to loaded modules. | Chris Johns | 2016-12-14 | 1 | -1/+1 |
| | | | | | | This has been tested on SPARC, i386, PowerPC and ARM. Closes #2767. | ||||
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 1 | -1/+1 |
* | libdl: RTLD_DEFAULT searches the global symbol table. | Chris Johns | 2014-11-04 | 1 | -6/+15 |
* | cpukit: Add libdl with the Runtime Loader (RTL) code. | Chris Johns | 2014-10-31 | 1 | -0/+153 |
This is a merge of the RTL project. |
