- Parse the ROM taables if present to find the component base for
the debug hardware. This lets the RPi2 run dl09.exe.
- Fix destorying the target and thread parts.
- Fix the ARM backend to support Cortex-A8 and ARM mode code.
- Use the DBGDSCR interrupt mask when single stepping.
- Use the DBGDSCR method of entry to debug mode to filter the
execptions.
- Add support for BSPs to control the ARM backend.
Add and use _Thread_Get_unmapped_real_priority().
Adding support for a register offset table lets FPU registers
be supported if added to the backend.
Closes #3733.
Update #3598.
Update #3530.
Update #3533.
Always build remote TCP support since it depends only on the POSIX
socket API. It works with the legacy network stack and libbsd. Move it
to a separate libdebugger.a library to allow an easy use with libbsd via
"-ldebugger -lbsd" otherwise we would have a cyclic dependency between
libbsd.a and librtemscpu.a.
Update #3419.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Closes #3097.
- Add `printk` support to aid multi-core debugging.
- Add lock trace to aid lock debugging.
- Fixes to gcc-7.1 warnings.
- Fixes from ticket #2879.
- Add verbose command controls.
- Change using the RTEMS sys/lock.h API to manage exception threads.
- ARM hardware breakpoint fixes. Support for SMP stepping
is not implemented, this requires use of the context id
register.
Closes #2879.
Closes #2976.
Using _Thread_Executing with RTEMS_DEBUG results in an `assert` if
the server accesses invalid memory.
Updates #2993.
Replace STATES_DELAYING with STATES_WAITING_FOR_TIME.
There is no need for separate timeout thread states. The
Thread_Control::Timer::header and Watchdog_Control::cpu members can be
used to figure out the kind of timeout.
Add thread state bit to identify thread queues that are embedded in an
object with identifier.
