* | libdebugger: Fixes to debugging, ARM support, locking, and gcc-7.1 warnings. | Chris Johns | 2017-08-15 | 1 | -1/+20 |
| | | | | | | | | | | | | | | - Add `printk` support to aid multi-core debugging. - Add lock trace to aid lock debugging. - Fixes to gcc-7.1 warnings. - Fixes from ticket #2879. - Add verbose command controls. - Change using the RTEMS sys/lock.h API to manage exception threads. - ARM hardware breakpoint fixes. Support for SMP stepping is not implemented, this requires use of the context id register. Closes #2879. | ||||
* | cpukit: Add libdebugger, a remote debugger agent for GDB. | Chris Johns | 2016-11-29 | 1 | -0/+208 |
