* | libdebugger: Fix for ARMv7-M with -O0 optimization | Chris Johns | 2019-04-09 | 1 | -4/+20 |
* | libdebugger: Use an offset table to format GDB `g` packets. | Chris Johns | 2019-04-09 | 1 | -84/+197 |
| | | | | | | | Adding support for a register offset table lets FPU registers be supported if added to the backend. Closes #3733. | ||||
* | libdebugger: Avoid use of <bsp/linker-symbols.h> | Sebastian Huber | 2017-12-13 | 1 | -2/+4 |
| | | | | Update #3254. | ||||
* | libdebugger: Fixes to debugging, ARM support, locking, and gcc-7.1 warnings. | Chris Johns | 2017-08-15 | 1 | -90/+155 |
| | | | | | | | | | | | | | | - Add `printk` support to aid multi-core debugging. - Add lock trace to aid lock debugging. - Fixes to gcc-7.1 warnings. - Fixes from ticket #2879. - Add verbose command controls. - Change using the RTEMS sys/lock.h API to manage exception threads. - ARM hardware breakpoint fixes. Support for SMP stepping is not implemented, this requires use of the context id register. Closes #2879. | ||||
* | libdebugger: Work around assert when using _Thread_Executing. | Chris Johns | 2017-04-15 | 1 | -1/+2 |
| | | | | | | | Using _Thread_Executing with RTEMS_DEBUG results in an `assert` if the server accesses invalid memory. Updates #2993. | ||||
* | libdebugger: Build for ARM's without a CP15. | Chris Johns | 2016-12-02 | 1 | -40/+114 |
* | cpukit: Add libdebugger, a remote debugger agent for GDB. | Chris Johns | 2016-11-29 | 1 | -0/+1193 |
