* | Fixing warning obtained by some users. | Joel Sherrill | 2000-06-15 | 1 | -0/+4 |
* | Moved <sys/cdefs.h> from libnetworking to lib/include so non-networking | Joel Sherrill | 2000-06-14 | 1 | -0/+177 |
| | | | | | configurations could see it while including <sys/ioctl.h> and <sys/ioccom.h>. | ||||
* | *** empty log message *** | Joel Sherrill | 2000-06-14 | 12 | -28/+108 |
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 1 | -22/+0 |
| | | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | ||||
* | Temporary hack to compile. Need to probably address definition | Joel Sherrill | 2000-06-13 | 1 | -0/+1 |
| | | | | of all FIO constants and conflict with libnetworking code. | ||||
* | Temporary hack to compile. | Joel Sherrill | 2000-06-13 | 1 | -1/+0 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 3 | -1/+30 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | ||||
* | Added printk as a generic, shared routine. | Joel Sherrill | 2000-06-12 | 1 | -0/+144 |
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 11 | -25/+260 |
* | New file added on 4.5 branch | Joel Sherrill | 2000-05-08 | 1 | -0/+0 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 4 | -0/+8 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+13 |
* | Removed warnings. | Joel Sherrill | 1999-12-13 | 1 | -1/+1 |
* | Warning removal patch from Philip A. Prindeville <philipp@zembu.com>. | Joel Sherrill | 1999-12-13 | 1 | -1/+1 |
* | Added RTEMS_IO_ERROR. | Joel Sherrill | 1999-12-13 | 1 | -0/+1 |
* | Removed duplicate definition of rtems_filesystem_umask. | Joel Sherrill | 1999-11-30 | 1 | -6/+0 |
* | Corrected so they would compile with POSIX disabled. | Joel Sherrill | 1999-11-30 | 2 | -2/+3 |
* | Fixed spacing. | Joel Sherrill | 1999-11-29 | 1 | -1/+1 |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 79 | -158/+79 |
* | Fixed bug. | Jennifer Averett | 1999-11-16 | 1 | -3/+3 |
* | Removed start subdirectory and distributed contents to the appropriate | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
| | | | | places under the libbsp tree. | ||||
* | Works now. | Joel Sherrill | 1999-11-16 | 1 | -19/+12 |
| | | | | | Removed times() since the version in the C Library support code is fine. | ||||
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+113 |
* | Added. | Joel Sherrill | 1999-11-16 | 5 | -0/+205 |
* | Source and destination arguments to strncpy were swapped. This mistake | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
| | | | | was made in the conversion of bcopy() to strncpy(). | ||||
* | Following comments from Eric Norum <eric@cls.usask.ca>, a fairly | Joel Sherrill | 1999-11-05 | 3 | -285/+260 |
| | | | | | | | substantial upgrade of newlibc.c occurred. Now the user extension data area is used rather than notepads and as many routines as possible were split into other files further reducing the minimum footprint of an RTEMS executable. | ||||
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 1 | -2/+1 |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | Fixed F_SETFL to properly convert between internal | Joel Sherrill | 1999-11-02 | 1 | -2/+3 |
| | | | | libio flags and external fcntl.h style flags. | ||||
* | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 1999-11-02 | 1 | -17/+41 |
| | | | | | | a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | ||||
* | Check for NULL being passed in. | Joel Sherrill | 1999-11-02 | 4 | -2/+17 |
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 2 | -7/+7 |
* | Joel added a table of mount entry requests to be processed during | Jennifer Averett | 1999-10-29 | 1 | -0/+14 |
| | | | | initialization. | ||||
* | Added include of libio.h so this would compile when posix is disabled. | Joel Sherrill | 1999-10-26 | 1 | -0/+1 |
* | Added initial cut at miniIMFS which leaves out memfile and directory | Joel Sherrill | 1999-10-26 | 2 | -1/+8 |
| | | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level. | ||||
* | idir=/opt/tmp/opt/rtems | Joel Sherrill | 1999-10-26 | 1 | -5/+1 |
| | | | | | | | | | | | | rdir=/opt/rtems cd $idir find . -type f | while read file do if [ ! -f ${file} ] ; then echo ${file} missing fi done | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move | Joel Sherrill | 1999-10-26 | 1 | -1/+1 |
| | | | | c/src/lib/libmisc to c/src/libmisc. | ||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 2 | -72/+74 |
| | | | | process. | ||||
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 2 | -64/+5 |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 15 | -88/+55 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 1 | -1/+1 |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 1 | -0/+97 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 14 | -64/+211 |
| | | | | node used to manage file access. | ||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 1 | -1/+1 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to move librdbg | Joel Sherrill | 1999-10-11 | 1 | -5/+1 |
| | | | | to its own top level package. | ||||
* | New file. | Joel Sherrill | 1999-10-06 | 2 | -0/+28 |
* | Removed go32 ifdefs | Joel Sherrill | 1999-10-05 | 1 | -3/+0 |
* | Patch from Wayne Bullaughey <wayne@wmi.com>. Comments follow: | Joel Sherrill | 1999-10-05 | 1 | -1/+1 |
| | | | | | | | | | | | | I'm working on code to mount my host based file system on the base file system (imfs) and have a suggestion for a change to eval.c in the c/src/lib/libc directory of the 8/20/1999 snapshot. The current version does not test the result value returned from the evalpath callback (line 47) in the case where follow_link is true. Attached is my suggested change. Without this test the node_type callback may be called after evalpath failed. node_type could set the type to some value other then RTEMS_FILESYSTEM_HARD_LINK or RTEMS_FILESYSTEM_SYM_LINK but it seems cleaner to add the check on result. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 1 | -3/+3 |
| | | | | where wrapup left pieces out of the librtemsall.a. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 1 | -1/+1 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make libnetworking | Joel Sherrill | 1999-10-04 | 1 | -8/+1 |
| | | | | a top level more independently configured package. |
