Close #3320.
Update #2840.
Update #2840.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
The previous rtems_panic() implementation was quite heavy weight. It
depended on _exit() which calls the global destructors. It used
fprintf(stderr, ...) for output which depends on an initialized console
device and the complex fprintf().
Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic()
and output via vprintk().
Update #3244.
Add a default implementation of _arc4random_getentropy_fail with an
internal error.
Update #3239.
This assert helps to detect an invalid reference counting in RTEMS_DEBUG
configurations.
Update #3132.
Move basic timecounter API shared with BSD network stack to
<machine/_timecounter.h>.
Update #3185.
In canonical mode, input is made available line by line. We must stop
the canonical buffer filling upon reception of an end-of-line character.
Close #3218.
Update #3170.
Update #3199.
The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
Update #2740.
Close #3179.
Hide the boottime and bootimebin globals, provide the getboottime(9) and getboottimebin(9) KPI. Change consumers of boottime to use the KPI. The variables were renamed to avoid shadowing issues with local variables of the same name.
Issue is that boottime* should be adjusted from tc_windup(), which
requires them to be members of the timehands structure. As a
preparation, this commit only introduces the interface.
Some uses of boottime were found doubtful, e.g. NLM uses boottime to
identify the system boot instance. Arguably the identity should not
change on the leap second adjustment, but the commit is about the
timekeeping code and the consumers were kept bug-to-bug compatible.
Tested by: pho (as part of the bigger patch)
Reviewed by: jhb (same)
Discussed with: bde
Sponsored by: The FreeBSD Foundation
MFC after: 1 month
X-Differential revision: https://reviews.freebsd.org/D7302
Update #3175.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
Reduce size of pthread_once_t and make it zero-initialized.
Update #3142.
Update #3122.
This member was apparently unused.
Close #3133.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Update #3132.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Rename rtems_libio_check_permissions_with_error() in
rtems_libio_check_permissions().
Update #3132.
Remove rtems_libio_check_permissions() and convert single user to
rtems_libio_check_permissions_with_error().
Update #3132.
This simplifies error handling later.
Update #3132.
Remove the file descriptor validation. This is the job of
rtems_libio_check_fd(). Use an inline function instread of a macro.
Update #3132.
Close #3134.
The top-level IO library structures should contain no special-case data.
Update #2859.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Newlib uses _times_r() in clock(). The problem is that the _times_r()
clock frequency is defined by sysconf(_SC_CLK_TCK). The clock frequency
of clock() is the constant CLOCKS_PER_SEC.
FreeBSD uses getrusage() for clock(). Since RTEMS has only one process,
the implementation can be simplified.
Update #3121.
An integer overflow may still happen, however, only after 68 years of
system uptime.
Close #2135.
Update #2133.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Move RTEMS specifics to <rtems/rtems_bsdnet.h>.
Introduce rtems_tap_ifreq. The interface tap support is RTEMS-specific
and only available in the legacy network stack.
Update #2833.
Update #2833.
