POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
Reduce size of pthread_once_t and make it zero-initialized.
Update #3142.
Update #3122.
This member was apparently unused.
Close #3133.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Update #3132.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Rename rtems_libio_check_permissions_with_error() in
rtems_libio_check_permissions().
Update #3132.
Remove rtems_libio_check_permissions() and convert single user to
rtems_libio_check_permissions_with_error().
Update #3132.
This simplifies error handling later.
Update #3132.
Remove the file descriptor validation. This is the job of
rtems_libio_check_fd(). Use an inline function instread of a macro.
Update #3132.
Close #3134.
The top-level IO library structures should contain no special-case data.
Update #2859.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Newlib uses _times_r() in clock(). The problem is that the _times_r()
clock frequency is defined by sysconf(_SC_CLK_TCK). The clock frequency
of clock() is the constant CLOCKS_PER_SEC.
FreeBSD uses getrusage() for clock(). Since RTEMS has only one process,
the implementation can be simplified.
Update #3121.
An integer overflow may still happen, however, only after 68 years of
system uptime.
Close #2135.
Update #2133.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Move RTEMS specifics to <rtems/rtems_bsdnet.h>.
Introduce rtems_tap_ifreq. The interface tap support is RTEMS-specific
and only available in the legacy network stack.
Update #2833.
Update #2833.
Remove obsolete support for OFILL, OFDEL, NLDLY, CRDLY, BSDLY, VTDLY,
and FFDLY which is not present on FreeBSD and not implemented in Linux.
Update #2833.
Update #2833.
Update #2833.
Update #2859.
updates #2897.
Update #2897.
Update #2897.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Perform a context-dependent deferred location release to avoid a
deadlock on the file system instance locks, for example during a
chdir().
Update #2936.
Use __restrict just like in <devctl.h> to avoid compiler errors with
older GCC, e.g. 4.8 or 4.9.
Use the modular arithmetic addition rule.
Currently only blocking read/write operations are implemented. A
blocking write must transfer at least one character. It should not wait
for the device for the second character and so on.
Close #2917.
Call rtems_termios_puts() only once. Adjust column in one place.
In canonical mode, the raw input buffer or the canonical buffer may
overflow without an end of line. Avoid an infinite loop in this case.
Close #2915.
