This was flagged as an empty for statement by CodeSonar but is actually
unreachable code that should be removed.
This was flagged by CodeSonar.
Coverity Id 1255518. mkdir() could fail. Check return value and return
on failure. Behavior is similar to if open() failed while writing the
files.
Make sure also the size is cache aligned since otherwise we may have
some overlap with the next allocation block. A cache invalidate on this
area would be fatal.
Move system state check to malloc_is_system_state_OK().
Coverity spotted that we were ignoring a return value. But ignoring
it is intentional. Adding (void) clearly indicates it is being ignored
explicitly.
Create a minimal /etc/passwd and /etc/group with user root and group
root only with no passwords.
Avoid NULL pointer access in IMFS_is_imfs_instance(). File systems
mounted via mount() always have a valid type string.
Move interrupt lock to device context and expose only this structure to
the read, write and set attributes device handler. This makes these
device handler independent of the general Termios infrastructure
suitable for direct use in printk() support.
Do not call rtems_termios_refill_transmitter() in case a PPP line
discipline is present. This is similar to
rtems_termios_dequeue_characters().
This rippled into the handful of files that should have been using
<rtems/tod.h>.
output.
Renamed startXmit(), nToSend is unsigned, just check FL_ORCVXOF, no (void) cast anymore, compute nToSend in single if/else if/else.
Add a new low-level device API to Termios that passes the TTY structure
to the low-level device functions. This greatly simplifies the
low-level device drivers since they are no longer forced to derive their
private data from the minor number.
It makes it possible to use the TTY low-level lock in the device driver
low-level functions which is necessary for proper SMP support. For
example to set the attributes it is often necessary to perform a
read-modify-write operation on a control register used also by interrupt
routines.
A compatibility layer is provided to support device drivers using the
old callback functions so it is not necessary to modify existing device
drivers.
The thread control block contains fields that point to application
configuration dependent memory areas, like the scheduler information,
the API control blocks, the user extension context table, the RTEMS
notepads and the Newlib re-entrancy support. Account for these areas in
the configuration and avoid extra workspace allocations for these areas.
This helps also to avoid heap fragementation and reduces the per thread
memory due to a reduced heap allocation overhead.
Use allocator mutex for objects allocate/free. This prevents that the
thread dispatch latency depends on the workspace/heap fragmentation.
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
With this patch C++ applications now eventually need additional POSIX-keys and
POSIX-key-value-pairs configured.
The rtems_gxx_key_dtor function is not longer used by gcc.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
Rename _Internal_error_Occurred() into _Terminate().
Rename rtems_internal_error_description() to
rtems_internal_error_text(). Rename rtems_fatal_source_description() to
rtems_fatal_source_text(). Rename rtems_status_code_description() to
rtems_status_text(). Remove previous implementation of
