* Makefile.am: Eliminate OBJS.
* include/rtems/libio.h: Rename __dev_t to __rtems_dev_t to avoid
conflict with GNU/Linux header files.
* ChangeLog, base_fs.c, getpwent.c, privateenv.c
Per PR303, Fix violation of node_access copy syemantics
2002-12-26 Till Straumann <strauman@slac.stanford.edu
* src/fchdir.c: PR302 fix violation of FS node object copy semantics.
* src/fchdir.c - PR302 fix violation of FS node object copy semantics
* src/malloc.c: Fixed code that incorrected did a disable dispatch
instead of locking and unlocking the allocator mutex.
* configure.ac: Add various checks to enhance portability.
* src/termios.c: Reflect changes to configure.ac.
* include/rtems/libio.h: Internally use a union of an unsigned64
and major/minor device so we don't get into trouble shifting.
The h8300 seemed to be impossible to remove warnings otherwise.
Eventually the structure definition of a dev_t might be better anyway.
* include/sys/ioccom.h: Added casts to remove warnings on 16 bit
targets.
* configure.ac: Cosmetical fixes.
* configure.ac: Fix package name.
* configure.ac: Check for sys/cdefs.h, Add NEED_SYS_CDEFS_H.
Add check for CHAR_BIT.
* Makefile.am: Conditionally install sys/cdefs.h iff using newlib or
if the host does not provide sys/cdefs.h (Fixes Linux/posix).
* configure.ac: Remove -ansi -fasm.
Add checks to diagnose potential system header conflicts.
* Makefile.am: Unconditionally install sys/cdefs.h.
* src/mount.c: Per PR297, correct fs_mountme failure paths.
paths.
* ChangeLog: Corrected.
* src/mallocfreespace.c: Corrected sense of status check to
match change inside RTEMS.
* src/newlibc.c: Removed warning.
which have already obtained the va_list pointer.
* include/rtems/libio.h: Change rtems_filesystem_node_types_t from
enumeration to int to eliminate warnings when values are overridden.
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* src/eval.c: Per PR293, added freenode calls for evaluate
link failures.
link failures.
* src/mount.c per PR290, add check for ops->node_type_h
* src/mknod.c per PR291, remove erroneous call to freenod
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* src/getpwent.c: Per PR283, reimplement to address reentrancy problems.
* src/getgrent.c: Removed as functionality is now just a wrapper for
common routines in src/getpwent.c.
* Makefile.am: Reflect file removal.
* include/rtems/libio.h: Change rtems_filesystem_read_t and
rtems_filesystem_write_t to return ssize_t to match read(2)
and write(2) respectively.
* src/readdir_r.c: New file.
* Makefile.am: Reflect above.
* src/write.c (_write_r): Change prototype to match newlib's reent.h.
* include/sys/utime.h: Removed as file is now part of the RTEMS
newlib support.
* include/rtems/termiostypes.h: Avoid use of __P.
newlib support.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Eliminate LIBNAME. Use AM_CPPFLAGS instead of
INCLUDES (Upcoming automake standard).
* configure.ac: RTEMS_TOP(../..).
* src/__times.c: Corrected from previous attempt to cleanup.
* src/__times.c: Cleaned up comments, return more information,
and eliminated the fatal error on clock not set since it cannot
occur.
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
Use ../aclocal.
* src/.cvsignore: New file.
Relocate libcsupport from c/src/lib to c/src/exec/libcsupport.
* configure.ac: Use ENV_RTEMSCPU. Reflect changed paths.
* Makefile.am: Reflect changed paths.
* src/Makefile.am: Reflect changed paths.
* libc/envlock.c: Implemented code to let newlib's envlock share
the libio open/close mutex. Since both should be lightly used,
this should not lead to problems and saves resources.
* libc/newlibc.c: Per PR141, move the C library re-enterrant
support directly into the thread dispatch code. RTEMS needs
libc and so requiring libc to use a user extension with its
overhead is not the best solution. This patch lowers the
overhead to 2 pointer moves.
* include/sys/utsname.h: Added, removed times (now in newlib).
* Makefile.am: Merge include/Makefile.am
* libc/utsname.c: Relocated from posix/src.
* libc/Makefile.am: Reflect changes above.
* configure.ac: Remove include/Makefile
* Per PR212, added envlock support for newlib. This is used
by at least getenv()/putenv() to avoid race conditions.
* libc/envlock.c: New file.
* libc/Makefile.am: Modified to reflect above.
* include/sys/ioctl.h: Relocated from libnetworking/sys.
* include/sys/filio.h: Relocated from libnetworking/sys.
* include/sys/sockio.h: Relocated from libnetworking/sys.
* include/Makefile.am: Reflect changes above.
* configure.ac: Take out *NETWORKING*.
* libc/gxx_wrappers.c: Fix to keep prototype same as in gcc and
remove warning.
* libc/scandir.c: Initialize nitems = 0.
* include/Makefile.am: Add stdint.h and inttypes.h.
(reported by Mike Siers <mikes@poliac.com>)
* include/stdint.h: New file.
* include/inttypes.h: New file.
* libc/stat.c: include <string.h>.
* libc/printk.c: Remove libcpu/cpu.h.
