* | Added functions to access the errno of the native system when using the | Joel Sherrill | 1995-08-11 | 2 | -1/+50 |
| | | | | | | | newlib C library. Fixed bug where length did not take into account amount added for alignment requirements. | ||||
* | Added functions to access the errno of the native system when using the | Joel Sherrill | 1995-08-11 | 1 | -7/+2 |
| | | | | newlib C library. | ||||
* | moved ringbuf.h to a shared include directory | Joel Sherrill | 1995-08-01 | 1 | -0/+42 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -1/+1 |
* | incorporate Tony's patches: | Joel Sherrill | 1995-06-05 | 1 | -0/+1 |
| | | | | | | | | | | + c/src/lib/libc/support/generic/malloc.c did not initialize the sbrk amount + _Thread_Handler in c/src/exec/rtems/thread.c left a window during the begin extension which could result in a context switch fixed places which did not correctly distinguish between an CPU_isr and a CPU_isr_entry. | ||||
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 3 | -22/+45 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 15 | -0/+1175 |
