path: root/cpukit/libcsupport (follow)
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-142-59/+1
| | | | | * libcsupport/src/no_libc.c: Remove. * libcsupport/Makefile.am: Remove no_libc.c.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-4/+0
| | | | * libcsupport/src/newlibc_reent.c: Eliminate RTEMS_UNIX.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-4/+1
| | | | * libcsupport/src/newlibc_exit.c: Eliminate RTEMS_UNIX.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-3/+0
| | | | * libcsupport/src/base_fs.c: Eliminate RTEMS_UNIX.
| | | | * libcsupport/src/stat.c: Eliminate RTEMS_UNIX.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-10/+4
| | | | | * libcsupport/include/rtems/libcsupport.h: Remove RTEMS_UNIX, hpux. Fix extern "C" {}.
* Remove libcsupport/src/unixlibc.c, libcsupport/src/unixlibc_io.c, ↵Ralf Corsepius2009-10-141-4/+0
| | | | libcsupport/src/hosterr.c.
* Remove.Ralf Corsepius2009-10-143-120/+0
* Reflect having introduced rtems_error_code_t.Ralf Corsepius2009-10-121-2/+2
* Introduce rtems_error_code_t.Ralf Corsepius2009-10-121-2/+6
| | | | Minor portability code-massaging.
* 2009-10-08 Chris Johns <chrisj@rtems.org>Chris Johns2009-10-084-1/+113
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, preinstall.am: Added statvfs.h. * libcsupport/Makefile.am: Add statvfs.c. * libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c: New. * libcsupport/include/rtems/libio.h: Add a file system handler for the statvfs call. * libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the statvfs handler to NULL. * include/rtems/fs.h: Add a second node access field for the RFS file system to hold a directory offset while the existing field holds the inode number. This save a rescan of the directory when working with directories. * libblock/include/rtems/bdbuf.h: Added references and user fields to the buffer descriptor. * libblock/src/bdbuf.c: Added dynamic buffer support for different block sizes. Fixed a number of bugs. * libblock/src/blkdev.c: Release the disk device on an error. * libblock/src/diskdevs.c: Set the block size to the media block size during initialisation of the disk device. * libblock/src/flashdisk.c, libblock/src/nvdisk.c, libblock/src/ramdisk.c: Updated the drivers to handle variable block sizes. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any buffers when an error occurs. The FAT buffer layer hangs onto a single buffer while mounted. This should be fixed. * sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain, rtems_chain_is_node_off_chain, and rtems_chain_previous. * score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain, and _Chain_Is_node_off_chain. * libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c, libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h: New shell commands. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and mknod commands. * libmisc/shell/hexdump-display.c: Fixed the reopen bug which showed up as a free with a bad pointer. * libmisc/shell/main_mount.c: List the user adding file system when listing the available file systems to mount. * libmisc/shell/utils-cp.c: Remove the fixed static copy buffer and use a large dynamic buffer. * score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c, score/src/objectallocate.c, score/src/objectfree.c: Remove warnings.
* Rework autoconf defines.Ralf Corsepius2009-09-308-7/+9
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-10/+6
| | | | | * libcsupport/src/_rename_r.c: Rework autoconf defines. Remove unused includes.
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-14/+10
| | | | | * libcsupport/src/__gettod.c: Rework autoconf defines. Eliminate RTEMS_UNIX.
* Rework autoconf defines.Ralf Corsepius2009-09-304-4/+4
* Remove unused includes.Ralf Corsepius2009-09-301-8/+1
* Eliminate RTEMS_UNIX.Ralf Corsepius2009-09-301-2/+1
* Rework autoconf defines.Ralf Corsepius2009-09-302-2/+2
* Comment out checkMallocArena (unused).Ralf Corsepius2009-09-301-2/+5
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-2/+3
| | | | * libcsupport/src/__assert.c: Rework autoconf defines.
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-2/+1
| | | | | * libcsupport/src/__brk.c: Eliminate RTEMS_UNIX. Remove unused includes.
* Remove unused includes.Ralf Corsepius2009-09-302-13/+2
* Remove stray whitespace.Ralf Corsepius2009-09-301-1/+0
* Remove #include <inttypes.h>.Ralf Corsepius2009-09-301-1/+0
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-2/+2
| | | | | | * libcsupport/src/termios_setinitialbaud.c: Include rtems/termiostypes.h. Rename termios_set_initial_baud into rtems_termios_set_initial_baud.
| | | | | | * libcsupport/src/termios_num2baud.c: Include rtems/termiostypes.h. Rename termios_number_to_baud into rtems_number_to_baud.
| | | | | | * libcsupport/src/termios_baud2num.c: Include rtems/termiostypes.h. Rename termios_baud_to_number into rtems_termios_baud_to_number.
| | | | | | * libcsupport/src/termios_baud2index.c: Include rtems/termiostypes.h. Rename termios_baud_to_index into rtems_termios_baud_to_index.
* 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-301-4/+10
| | | | | | | | * libcsupport/include/rtems/termiostypes.h: Include stdlib.h. Add rtems_termios_baud_t. Rename termios_number_to_baud into rtems_termios_number_to_baud, termios_baud_to_number into rtems_termios_baud_to_number, termios_baud_to_index into rtems_termios_baud_to_index.
* 2009-09-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-262-4/+4
| | | | | | * libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc_reent.c: Eliminate use of deprecated rtems_extension.
* 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-09-241-4/+2
| | | | | | * libcsupport/src/getpagesize.c, posix/Makefile.am: Eliminate one copy of getpagesize() and make it return an int. * posix/src/getpagesize.c: Removed.
* Rely upon uintmax_t and PRIuMAX being provided.Ralf Corsepius2009-09-151-9/+0
* Reflect rtems_libio_number_iops being uint32_t.Ralf Corsepius2009-09-152-4/+4
* Remove extern uint32_t rtems_libio_number_iops.Ralf Corsepius2009-09-151-1/+0
* Add __attribute__((unused)) to function arguments.Ralf Corsepius2009-09-1512-14/+22
* Add __attribute__((unused)) to function arguments.Ralf Corsepius2009-09-1521-24/+28
* 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-152-10/+4
| | | | | | | | | PR 1441/cpukit * libcsupport/src/tcgetprgrp.c: Remove. * libcsupport/src/tcgetpgrp.c: New (Renamed from libcsupport/src/tcgetprgrp.c). * libcsupport/Makefile.am: Add libcsupport/src/tcgetpgrp.c. Remove libcsupport/src/tcgetprgrp.c.
* 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-151-2/+2
| | | | * libcsupport/src/getpwent.c: Ansify.
* 2009-09-14 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-149-75/+88
| | | | | | | | | | | | | | | | | | * score/src/wkspace.c: Removed work space area consistency checks. * libblock/include/rtems/ide_part_table.h: Functions are now deprecated. * libcsupport/include/rtems/libcsupport.h, libcsupport/src/calloc.c, libcsupport/src/malloc_boundary.c, libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_report_statistics_plugin.c, libcsupport/src/malloc_statistics_helpers.c, libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c, rtems/inline/rtems/rtems/region.inl: Update for heap API changes. 2009-09-14 Christian Mauderer <christian.mauderer@embedded-brains.de> * libcsupport/src/vprintk.c: Fixed warnings. Print nothing in case the pointer to the string is NULL.
* 2009-09-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-062-1/+16
| | | | | | | * libcsupport/src/issetugid.c: New (relocated from libnetworking). * libnetworking/rtems/issetugid.c: Remove. * libnetworking/Makefile.am: Reflect changes above. * libcsupport/Makefile.am: Reflect changes above.
* 2009-09-06 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-09-061-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/free.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapgetsize.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: Update for heap API changes. * score/include/rtems/score/apimutex.h, score/include/rtems/score/object.h: Documentation. * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/inline/rtems/score/heap.inl, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c: Overall cleanup. Added boundary constraint to allocation function. More changes follow.
* 2009-08-28 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-281-1/+0
| | | | | | * libcsupport/src/malloc_initialize.c, sapi/src/exinit.c, score/src/threadstartmultitasking.c: Fix spacing. * libmisc/stackchk/check.c: Move variable into compiler specific conditional.
* 2009-08-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-151-1/+1
| | | | * libcsupport/src/termios_baud2num.c: B134 should return 134 not 135.
* 2009-08-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-121-1/+4
| | | | | | | * libcsupport/src/malloc_boundary.c: This is currently non-funcitonal. Do not build it when doing coverage until it works again. * sapi/include/confdefs.h: Address linking errors when building for configuration.
* 2009-08-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-122-7/+0
| | | | | * libcsupport/Makefile.am: Obsolete coverage file. * libcsupport/src/end_profile.c: Removed.
* 2009-08-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-122-16/+1
| | | | | | | * libcsupport/Makefile.am, libcsupport/preinstall.am, posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am, rtems/preinstall.am, score/Makefile.am, score/preinstall.am: Revert modifications accidentally committed.
* 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-101-1/+1
| | | | | | * libcsupport/src/__times.c, libfs/src/nfsclient/src/nfsTest.c, libfs/src/nfsclient/src/rpcio.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* 2009-08-09 Xi Yang <hiyangxi@gmail.com>Joel Sherrill2009-08-091-0/+2
| | | | | | | | * libcsupport/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, score/include/rtems/score/heap.h: HEAP_BLOCK_USED_OVERHEAD was under by one uint32_t. This showed up in the unlimited and heapwalk tests on ARM targets.
* Fix commentJoel Sherrill2009-08-061-1/+1
* Revert.Joel Sherrill2009-08-061-2/+0
