* libcsupport/include/rtems/libio.h: Use rtems_id for semaphores.
Use char* for buffer.
* backward/ftpd.h: New.
* Makefile.am: Reflect having added backward/ftpd.h.
* libblock/include/rtems/bdbuf.h,
libblock/include/rtems/ide_part_table.h, libblock/src/blkdev.c,
libcsupport/include/rtems/termiostypes.h, libcsupport/src/termios.c,
posix/macros/rtems/posix/cond.inl,
posix/macros/rtems/posix/mutex.inl : Remove warnings.
* libcsupport/include/inttypes.h: New header guard.
Fix doxygen preamble.
* itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am:
Remove AM_CPPFLAGS += -I$(top_builddir).
* libcsupport/src/lstat.c, libcsupport/src/readdir_r.c:
Include config.h.
* libcsupport/include/tar.h: New (SUSv3).
* Makefile.am: Integrate newlib-specific headers.
Add libcsupport/include/tar.h.
* libcsupport/Makefile.am: Remove newlib-specific headers.
* libcsupport/include/stdint.h: Use __PTRDIFF_TYPE for intptr_t.
* libcsupport/src/termios.c: Remove unnecessary type casts.
Ralf Corsepius <ralf.corsepius@rtems.org>
* libcsupport/src/gxx_wrapper.c: Reflect GCC-4.0's gthr-rtems.h.
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* libcsupport/src/mallocfreespace.c, rtems/Makefile.am,
rtems/include/rtems/rtems/region.h, score/Makefile.am,
score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add
capability to return information about just the free blocks in a
region or heap. Also changed the semantics of free space available
to be the largest block of memory that can be allocated.
* rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files.
: score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove warning.
* libcsupport/src/ttyname_r.c: Remove warning for using _fstat.
* libcsupport/include/stdint.h: Move mal-placed comment.
* libcsupport/include/stdint.h: Fixed name in @file.
* libcsupport/include/sys/_stdint.h: Remove.
* libcsupport/include/sys/_inttypes.h: Remove.
* libcsupport/include/stdint.h: Replace with former sys/_stdint.h.
Add INT<N>_C, various additions.
* libcsupport/include/inttypes.h: Replace with former
sys/_inttypes.h.
* libcsupport/Makefile.am: Reflect changes above.
sys/_inttypes.h.
sys/_inttypes.h.
* libcsupport/include/sys/_stdint.h: Special-case int64_t (GCC has
__LONG_LONG_MAX__, while POSIX mandates LLONG_MAX. This break
__EXP(LONG_LONG_MAX)).
* configure.ac: Remove RTEMS_USES_INTTYPES_H. Require inttypes.h.
* include/rtems/stdint.h: Remove "wild guesses", require inttypes.h.
* libcsupport/include/inttypes.h: Cleanup.
* libcsupport/include/stdint.h: Cleanup.
* include/sys/_stdint.h: Various changes.
Add *leastN_t types. Add INTN_{MIN|MAX} macros.
Add doxygen preamble.
* include/sys/_inttypes.h: Add doxygen preamble.
* libcsupport/include/stdint.h: Add doxygen preamble.
* libcsupport/include/inttypes.h: Add doxygen preamble.
* configure.ac: Add doxygen preamble to cpuopts.h.
* configure.ac: Remove -ansi (Cygwin breaks with it).
* libcsupport/include/stdint.h: Use sys/_stdint.h to setup fixed
size types.
* libcsupport/include/sys/_inttypes.h: Add SCN*N macros.
* libcsupport/src/utsname.c: Revert yesterdays patch.
* libcsupport/src/utsname.c: Fix typo.
* libcsupport/include/inttypes.h: #include <sys/_inttypes.h>
* libcsupport/src/utsname.c: Don't include sptables.h.
Include <inttypes.h>. Use PRId32 instead of "%d".
* libcsupport/include/rtems/_inttypes.h: Remove.
* libcsupport/include/rtems/_stdint.h: Remove.
* libcsupport/include/sys/_inttypes.h: New.
* libcsupport/include/sys/_stdint.h: New.
* libcsupport/include/rtems/_inttypes.h: Undefine __PRIN defines.
* libcsupport/include/rtems/_stdint.h: Apply GNUC-limits to GCC >= 3.3, only.
Add _rtems_*_t_defined defines. Add extern "C".
* libcsupport/rtems/_stdint.h: New.
* libcsupport/rtems/_inttypes.h: New.
* libcsupport/include/sys/ioctl.h: Cosmetical update from FreeBSD.
Remove sys/compat_ioctl.h section (Meaningless with RTEMS).
* libcsupport/include/sys/ioccom.h: Cosmetical update from FreeBSD.
* libcsupport/include/stdint.h: Add intptr_t uintptr_t.
* libcsupport/Makefile.am: Install include_sys_HEADERS for NEWLIB
only. Merge sys/cdefs.h into general include_sys_HEADERS.
* configure.ac: Rework stdint.h/inttypes.h support.
Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H.
Remove NEED_STDINT_H. Remove NEED_INTTYPES_H.
Remove termios-flag detection.
* libcsupport/Makefile.am: Install include/stdint.h and
include/inttypes.h for NEWLIB only.
* libcsupport/include/stdint.h: Rework; Now newlib specific.
* libcsupport/src/termios.c: Make newlib specific.
* include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>.
* libblock/Makefile.am: Build libblock for !UNIX only.
* libcsupport/Makefile.am: Build $(TERMIOS_C_FILES) for !UNIX only.
* libcsupport/Makefile.am: Install sys/ioccom.h for NEWLIB only.
* libcsupport/Makefile.am: Remove $(LIBC_DEFINES) (Unsupported).
Install motorola-headers to $(includedir)/rtems/motorola.
Install zilog-header $(includedir)/rtems/zilog.
