Synchronize all file descriptors and not just the ones associated with a FILE
object.
Close #4656.
This file had no header, copyright, or license. Based on git history,
added appropriate copyright and license.
These files had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
This was requested to be executed prior to relicensing to BSD-2.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Use _fwalk_reent() instead of _fwalk(), since _fwalk() was removed from Newlib.
Include <sys/reent.h> and remove local declarations.
Updates #4625.
At the moment the line discipline start function (l_start) has no
possibility to get feedback about the number of characters that have
been sent. This patch passes that information via an additional
parameter.
The change might trigger a warning on existing code because of a pointer
mismatch but it shouldn't break it. An existing function with the old
API will just ignore the additional parameter.
Update #4493
GCC versions prior to 6.1 used a RTEMS thread model based on
rtems_gxx_*() functions. GCC version 6.1 or later uses the
self-contained synchronization objects of Newlib <sys/lock.h> for the
RTEMS thread model.
Remove the obsolete implementation.
Close #3143.
The BSPs provide memory for the separate C Program Heap initialization
via _Memory_Get(). Most BSPs provide exactly one memory area. Only two
BSPs provide more than one memory area (arm/altera-cyclone-v and
bsps/powerpc/mpc55xxevb). Only if more than one memory area is
provided, there is a need to use _Heap_Extend(). Provide two
implementations to initialize the separate C Program Heap and let the
BSP select one of the implementations based on the number of provided
memory areas. This gets rid of a dependency on _Heap_Extend(). It
also avoids dead code sections for most BSPs.
Change licence to BSD-2-Clause according to file history.
Update #3053.
The rate monotonic period statistics were affected by
rtems_cpu_usage_reset(). The logic to detect and work around a CPU
usage reset was broken.
The Thread_Contol::cpu_time_used is changed to contain the processor
time used throughout the entire lifetime of the thread. The new member
Thread_Contol::cpu_time_used_at_last_reset is added to contain the
processor time used at the time of the last reset through
rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and
the rate monotonic period statistics.
Update #4528.
psxdevctl is supposed to return the value in errno. Before, it was
returning -1 and setting errno. Changed the tests to reflect these
changes. Added code from RRADE's posix_devctl.c.
Closes #4506
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Place the group into the I/O Manager group. Add all source files to the
group.
Update #3899.
Update #3993.
Update #4482.
Use the same function to output the '\r\n' combination produced by
rtems_putc(). Fix the format.
Change licence according to file history.
Update #3053.
Use the same function pointer value to check against NULL and call the
function (if non-NULL).
Fix format, add Doxygen comments, and reduce includes.
Also updated licenses.
Closes #4400
Updates #3899
utimes() now calls utimensat() to update file access
and modification timestamps.
Updated license.
Closes #4398
utime() now calls utimensat() to update file access
Updated license.
Closes #4397
Created futimens.c and utimensat.c to add support for the POSIX
methods futimens() and utimensat().
utime() and utimes() are considered obsolote by POSIX, but RTEMS
will continue to support them.
Closes #4396
This change eliminates a system initialization dependentcy which resulted
in an application without a file system or console referencing errno being
forced to include the code to open(/dev/console), close(), atexit(),
and the unmount infrastructure.
Closes #4439.
Make sure all conditions to do a proper memory allocation are satisfied
before a zero size memory allocation is performed.
Update #4390.
In POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Return NULL on RTEMS to more likely catch the use of a
zero size memory area by erroneous applications.
Update #4390.
Move all error checks into posix_memalign() so that the returned memory
pointer is set to NULL under all error conditions except
memptr == NULL.
Use parameter names of POSIX documentation.
The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
The 'sc' variable was originally storing the return value of mkdir().
This was causing an issue, so it was changed to make it to where we
ignored the return value with (void). The 'sc' variable was left in
by mistake.
The multiplication to calculate the length of the memory area to
allocate may overflow. Return NULL in case of an overflow.
Close #4389.
Move RTEMS_Malloc_Sbrk_amount to the only implementation file which uses
it and make it private to hide implementation-details from an API
header.
Move rtems_calloc() since it only depends on rtems_malloc(). This may
make it easier to customize the heap allocator.
Update #3053.
At this point in time, /etc can be created in multiple ways. There
is a discussion (#4354) that would define a mechanism for
instantiating a base file system with some flexibility for the
set of directories included. For now, this particular mkdir()
call can fail because /etc could already have been created by
at least an initial filesystem image, the shell, or libbsd.
closes #4382.
Removed the _Assert_unused_variable_equals macro due to /etc
having already been created by the network stack initialization
or an initial filesystem image.
Closes #4282
CID 1255518: Unchecked return value from library in pwdgrp_init().
Closes #4282
CID 1459004: Unchecked return value in endgrent().
Closes #4261
CID 1399710: Unchecked return value in printer_task().
CID 1472764: Unchecked return value in rtems_print_printer_task().
Closes #4258
CID 1437625: Unchecked return value from call to rtems_task_create().
CID 1472765: Unchecked return value from call to rtems_task_start().
Closes #4237.
- Move the heap sbrk code into a separate routnine.
- Update heap and workspace greedy allocators to use the common
sbrk greedy support.
Closes #3982
- Call the heap extend handler until all memory has been
requested.
Closes #3982
- Add the bool flag no_regular_file_mknod to the mount table so a file
system can indicate creating regular files is not done by
use the mknod handler. The file system will handle creating a
file node in the open handler.
- Note, the mount option is an enum which means there is only one
exclusive option supported. As a result no encapsulation is
provided and file systems need to set no_regular_file_mknod directly.
Closes #4222
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Fix linker errors in the minimum test program on some BSPs introduced by
ced28f2cfcee6d32ad7bb72e16b235212eb2eaaf.
This mutex is used to maintain termios internal data structures.
Only include the deferred free support if free() is actually used by the
application.
The free() implementation in RTEMS supports that allocated memory is
freed in interrupt context. Since the heap is protected by a mutex, the
frees issued in interrupt context cannot immediately be freed to the
heap, instead they are placed on a deferred free list. This list is
emptied by the core allocation function
rtems_heap_allocate_aligned_with_boundary(). This adds a dependency to
free() in rtems_heap_allocate_aligned_with_boundary(). In order to
better support applications which only allocate memory and never free
it, this dependency should be avoided. Provide a weak default
implementation of _Malloc_Process_deferred_frees() for
rtems_heap_allocate_aligned_with_boundary(). In the free() module
provide the strong implementation.
Close #4032.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
