* src/getpwent.c: Per PR283, reimplement to address reentrancy problems.
* src/getgrent.c: Removed as functionality is now just a wrapper for
common routines in src/getpwent.c.
* Makefile.am: Reflect file removal.
* include/rtems/libio.h: Change rtems_filesystem_read_t and
rtems_filesystem_write_t to return ssize_t to match read(2)
and write(2) respectively.
* src/readdir_r.c: New file.
* Makefile.am: Reflect above.
* src/write.c (_write_r): Change prototype to match newlib's reent.h.
* include/sys/utime.h: Removed as file is now part of the RTEMS
newlib support.
* include/rtems/termiostypes.h: Avoid use of __P.
newlib support.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Eliminate LIBNAME. Use AM_CPPFLAGS instead of
INCLUDES (Upcoming automake standard).
* configure.ac: RTEMS_TOP(../..).
* src/__times.c: Corrected from previous attempt to cleanup.
* src/__times.c: Cleaned up comments, return more information,
and eliminated the fatal error on clock not set since it cannot
occur.
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
Use ../aclocal.
* src/.cvsignore: New file.
Relocate libcsupport from c/src/lib to c/src/exec/libcsupport.
* configure.ac: Use ENV_RTEMSCPU. Reflect changed paths.
* Makefile.am: Reflect changed paths.
* src/Makefile.am: Reflect changed paths.
* libc/envlock.c: Implemented code to let newlib's envlock share
the libio open/close mutex. Since both should be lightly used,
this should not lead to problems and saves resources.
* libc/newlibc.c: Per PR141, move the C library re-enterrant
support directly into the thread dispatch code. RTEMS needs
libc and so requiring libc to use a user extension with its
overhead is not the best solution. This patch lowers the
overhead to 2 pointer moves.
* include/sys/utsname.h: Added, removed times (now in newlib).
* Makefile.am: Merge include/Makefile.am
* libc/utsname.c: Relocated from posix/src.
* libc/Makefile.am: Reflect changes above.
* configure.ac: Remove include/Makefile
* Per PR212, added envlock support for newlib. This is used
by at least getenv()/putenv() to avoid race conditions.
* libc/envlock.c: New file.
* libc/Makefile.am: Modified to reflect above.
* include/sys/ioctl.h: Relocated from libnetworking/sys.
* include/sys/filio.h: Relocated from libnetworking/sys.
* include/sys/sockio.h: Relocated from libnetworking/sys.
* include/Makefile.am: Reflect changes above.
* configure.ac: Take out *NETWORKING*.
* libc/gxx_wrappers.c: Fix to keep prototype same as in gcc and
remove warning.
* libc/scandir.c: Initialize nitems = 0.
* include/Makefile.am: Add stdint.h and inttypes.h.
(reported by Mike Siers <mikes@poliac.com>)
* include/stdint.h: New file.
* include/inttypes.h: New file.
* libc/stat.c: include <string.h>.
* libc/printk.c: Remove libcpu/cpu.h.
* libc/ctermid.c: Include <string.h>.
* libc/ttyname.c: Ditto.
* libc/ttyname_r.c: Ditto.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR143
* lib/include/rtems/termiostypes.h: Removed unneeded volatile on
"theBuf" since no byte is read more than once anyway.
* libc/gxx_wrappers.c: Task is not preemptable while running a
pthread_once init function. This is slightly less heavy handed
than disabling dispatching and seems better than consuming a mutex.
* Nice Update of PPPD support which eliminates the
requiremetn that drivers be in the termios TASK_DRIVEN mode.
Mike did significant testing and reports that it seems to be
more stable and handle larger packets better. This patch
replaces the termios tasks with more general pppd network
driver tasks. The functions pppinput() and pppstart() get
called from the interrupt service routine.
* libc/termios.c: Added PPCDISC.
* include/rtems/libio.h: Add #include <rtems/fs.h>.
Reflect changes due to using rtems/fs.h.
* include/rtems/libio_.h: Reworked.
* libc/gxx_wrappers.c: Add #include <rtems/error.h>.
* libc/Makefile.am: Add MULTISUBDIR support.
* libc/fcntl.c: Add #include <stdarg.h>.
* libc/privateenv.c: Add #include <stdlib.h>.
* include/rtems/libio_.h: Remove set_errno_and_return_minus_one.
* libc/cfsetispeed.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* libc/cfsetospeed.c: Include <rtems/seterr.h>.
* libc/chdir.c: Include <rtems/seterr.h>.
* libc/chmod.c: Include <rtems/seterr.h>.
* libc/chown.c: Include <rtems/seterr.h>.
* libc/chroot.c: Include <rtems/seterr.h>.
* libc/closedir.c: Include <rtems/seterr.h>.
* libc/eval.c: Include <rtems/seterr.h>.
* libc/fchdir.c: Include <rtems/seterr.h>.
* libc/fchmod.c: Include <rtems/seterr.h>.
* libc/fdatasync.c: Include <rtems/seterr.h>.
* libc/fpathconf.c: Include <rtems/seterr.h>.
* libc/fstat.c: Include <rtems/seterr.h>.
* libc/fsync.c: Include <rtems/seterr.h>.
* libc/ftruncate.c: Include <rtems/seterr.h>.
* libc/getdents.c: Include <rtems/seterr.h>.
* libc/ioctl.c: Include <rtems/seterr.h>.
* libc/link.c: Include <rtems/seterr.h>.
* libc/lseek.c: Include <rtems/seterr.h>.
* libc/mknod.c: Include <rtems/seterr.h>.
* libc/open.c: Include <rtems/seterr.h>.
* libc/read.c: Include <rtems/seterr.h>.
* libc/readlink.c: Include <rtems/seterr.h>.
* libc/rmdir.c: Include <rtems/seterr.h>.
* libc/stat.c: Include <rtems/seterr.h>.
* libc/symlink.c: Include <rtems/seterr.h>.
* libc/tcsetattr.c: Include <rtems/seterr.h>.
* libc/telldir.c: Include <rtems/seterr.h>.
* libc/ttyname.c: Include <rtems/seterr.h>.
* libc/ttyname_r.c: Include <rtems/seterr.h>.
* libc/unlink.c: Include <rtems/seterr.h>.
* libc/unmount.c: Include <rtems/seterr.h>.
* libc/utime.c: Include <rtems/seterr.h>.
* libc/write.c: Include <rtems/seterr.h>.
* src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one.
* src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/killinfo.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one.
* src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one.
* src/sched.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one.
* src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one.
* src/seminit.c: Apply rtems_set_errno_and_return_minus_one.
* src/semopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/sempost.c: Apply rtems_set_errno_and_return_minus_one.
* src/semunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/setpgid.c: Apply rtems_set_errno_and_return_minus_one.
* src/setsid.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaction.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigismember.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigpending.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one.
* src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* libc/printk.c: Include rtems/bspIo.h instead of bspIo.h.
* include/Makefile.am: Remove bspIo.h.
* include/bspIo.h: Removed.
This was tracked as PR88.
* libc/scandir.c: Fixed to perform cleanup on error conditions.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63.
* libc/chdir.c: Check for search/execute permissions on chdir.
This requires passing RTEMS_LIBIO_PERMS_SEARCH to
rtems_filesystem_evaluate_path().
* libc/libio.c: Cleanup of initialization per suggestion from
Eric Norum.
* libc/unmount.c: Primarily restructuring and clean up to address
procedures which did not do what their name implied. Also addressed
problem situation where unmount fails and the filesystem was
inconsistent. The mounted filesystem could have been left hanging.
* libc/libio.c: Initialize more fields to NULL/0 during initialiation.
* include/rtems/libio_.h: Fix freenode macro so it works for sockets
which do not have the full set of filesystem operations and are
initialized via something other than open().
* libc/open.c, libc/close.c: Moved freenode from open to
close.
* These changes were discussed and reviewed by many people but the
primary people were Jennifer Averett <jennifer@OARcorp.com>
and Eugeny Mints <jack@oktet.ru>.
* libc/utime.c: Add missing call to rtems_filesystem_freenode()
at verification that utime is supported by the filesystem.
* libc/link.c: Remove calls to freenode when the node was
not successfully allocated.
* libc/unmount.c: In the method file_systems_below_this_mountpoint()
added calls to correctly free fs_root_loc when a failure occurs.
* libc/open.c: Add freenode calls upon failure.
* libc/open.c, lib/libc/close.c: (PENDING -- NOT INCLUDED THIS TIMER)
Modifications the move the freenode from open() to close() (also part
of this patch) are pending further discussion.
* include/zilog/Makefile.am: Remove.
* include/motorola/Makefile.am: Remove.
* include/sys/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs, require automake-1.5
* include/chain.h: Fixed typo.
* configure.in: Remove.
* libc/termios.c: Fixed a memory leak in the termios
software. Basically the tty open function was allocating an input
raw buffer, an output raw buffer, and a cooked buffer that were
not getting released. I have attached a patch for the latest
snapshot. The patch also has a fix to ensure the tty link list
is updated correctly when a tty is closed.
