path: root/cpukit/libcsupport (follow)
* 2007-06-20 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-06-202-1/+53
| | | | | * libcsupport/Makefile.am: * libcsupport/src/open_dev_console.c: New file.
* 2007-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-171-1/+25
| | | | | | | | | | | | | | | | | | | | * ChangeLog, configure.ac, libcsupport/src/__times.c, libmisc/cpuuse/cpuuse.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c, rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c, rtems/src/ratemontimeout.c, score/Makefile.am, score/include/rtems/score/thread.h, score/include/rtems/score/timespec.h, score/src/threaddispatch.c, score/src/threadinitialize.c, score/src/threadtickletimeslice.c, score/src/timespecdivide.c: Add nanoseconds granularity to the rate monotonic period statistics and CPU usage statistics. This capability is enabled by default although may be conditionally disabled by the user. It could be too much overhead on small targets but it does not appear to be bad in early testing. Its impact on code size has not been evaluated either. It is possible that both forms of statistics gathering could be disabled with further tweaking of the conditional compilation. * score/src/timespecdividebyinteger.c: New file.
* 2007-05-14 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-143-22/+38
| | | | | | * libcsupport/Makefile.am, libcsupport/src/unixlibc.c: Split off dummry rtems_io_register_name for use on unix. * libcsupport/src/unixlibc_io.c: New file.
* Remove.Ralf Corsepius2007-05-102-363/+0
* Regenerate.Ralf Corsepius2007-05-101-4/+0
* 2007-05-10 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-05-101-1/+1
| | | | * libcsupport/Makefile.am: Remove include/rtems/cdefs.h.
* Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>.Ralf Corsepius2007-05-101-1/+1
* 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-092-114/+59
| | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c, sapi/Makefile.am, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/userext.h, score/src/chain.c, score/src/userext.c: Switch to newlib reentrancy extension being installed in the initial set instead of using rtems_extension_create. While implementing this, noticed that user extensions and chain code had multiple functions in a single file which is not desirable in the SuperCore and API portions of RTEMS, so split these into multiple files with one function per file. Also noticed that some of user extension code was inlined for no particular reason so moved that to C bodies. Split executive shutdown from initialization since not every application shuts down. Moved __fini call to executive shutdown to be more symmetrical with where it is called at startup. * sapi/src/exshutdown.c, score/src/chainappend.c, score/src/chainextract.c, score/src/chainget.c, score/src/chaininsert.c, score/src/userextaddapiset.c, score/src/userextaddset.c, score/src/userextremoveset.c, score/src/userextthreadbegin.c, score/src/userextthreadcreate.c, score/src/userextthreaddelete.c, score/src/userextthreadrestart.c, score/src/userextthreadstart.c, score/src/userextthreadswitch.c: New files. * score/inline/rtems/score/userext.inl: Removed.
* 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-091-1/+3
| | | | | * libcsupport/src/error.c, sapi/include/rtems/config.h: Do not reference _Configuration_MP_table if multiprocessing is disabled.
* Include <rtems/stdint.h> instead of <stdint.h>.Ralf Corsepius2007-05-091-1/+1
* 2007-05-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-05-032-85/+43
| | | | | | | | | | | | | | | | | * ChangeLog, libcsupport/src/malloc.c, libcsupport/src/mallocfreespace.c, sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: malloc never blocks so the Region Manager is quite heavy for implementing this. This patch implements the C Program Heap directly in terms of the new Protected Heap handler. This handler is a direct use of a SuperCore Heap in conjunction with the Allocator Mutex used internally by RTEMS. This saves 3184 bytes on most SPARC test executables. * score/include/rtems/score/protectedheap.h, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: New files.
* 2007-05-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-05-034-103/+148
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/rmdir.c: Fixed spacing. * libcsupport/Makefile.am, libcsupport/src/newlibc.c: Split _exit from newlibc.c. It is not required for minimum executing and drops 624 from SPARC minimum executable. * libcsupport/src/newlibc_exit.c: New file. 2007-04-17 Joel Sherrill <joel@OARcorp.com> * itron/Makefile.am, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronintr.c, itron/src/itrontime.c, itron/src/network.c, itron/src/port.c, itron/src/sysmgmt.c, itron/src/task.c, itron/src/vmempool.c, posix/Makefile.am, posix/src/pthread.c, rtems/src/taskinitusers.c, rtems/src/tasks.c, sapi/include/confdefs.h, sapi/src/io.c: Various modification to reduce executable size. Most were refactoring of files. Split ITRON API files. Implemented mechanism to avoid initialization task/thread loop being linked in when that style of task initialization was not being used. * itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c, itron/src/chg_iXX.c, itron/src/clr_flg.c, itron/src/cre_flg.c, itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c, itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c, itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c, itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c, itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_int.c, itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c, itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c, itron/src/loc_cpu.c, itron/src/nget_nod.c, itron/src/nget_ver.c, itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c, itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c, itron/src/pol_flg.c, itron/src/ref_alm.c, itron/src/ref_cfg.c, itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c, itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c, itron/src/ref_sys.c, itron/src/rel_blf.c, itron/src/rel_blk.c, itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c, itron/src/rpl_rdv.c, itron/src/set_flg.c, itron/src/set_tim.c, itron/src/tacp_por.c, itron/src/tcal_por.c, itron/src/tget_blf.c, itron/src/tget_blk.c, itron/src/twai_flg.c, itron/src/unl_cpu.c, itron/src/wai_flg.c, posix/src/pthreadinitthreads.c: New files. 2007-04-17 Ralf Corsépius <ralf.corsepius@rtems.org> * score/include/rtems/score/thread.h: Use Context_Control_fp* instead of void* for fp_contexts. 2007-04-16 Joel Sherrill <joel@OARcorp.com> PR 1240/filesystem * libfs/src/imfs/imfs_rmnod.c: Fix link when removing a symlink. Memory for filename was not being freed. 2007-04-16 Ralf Corsépius <ralf.corsepius@rtems.org> * pppd/utils.c: Use uintptr_t instead of unsigned long. 2007-04-16 Joel Sherrill <joel@OARcorp.com> * itron/src/rsm_tsk.c: Correct error returned. 2007-04-14 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Redefine LIBPOSIX to !UNIX. * posix/src/usleep.c, libcsupport/src/readlink.c: Update API to SUSv3. 2007-04-13 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/Makefile.am: Unconditionally build src/sleep.c, src/usleep.c. * posix/src/clockgettime.c: #ifdef CLOCK_MONOTONIC the CLOCK_MONOTONIC case. * score/inline/rtems/score/tod.inl: Include <sys/time.h>. 2007-04-13 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/Makefile.am: Cosmetics. * configure.ac: Add AM_CONDITIONAL(HAS_PTHREADS). * httpd/Makefile.am: Use HAS_PTHREADS instead of LIBPOSIX. 2007-04-13 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/Makefile.am, wrapup/Makefile.am, configure.ac: Rename AM_CONDITIONAL(HAS_POSIX) into LIBPOSIX. * posix/src/clockgettime.c, posix/src/clocksettime.c: Don't include rtems/posix/time.h. * posix/src/nanosleep.c: Include rtems/score/timespec.h instead of rtems/posix/time.h. * score/include/rtems/score/object.h: Use size_t for byte sizes. 2007-04-12 Joel Sherrill <joel@OARcorp.com> * itron/src/rsm_tsk.c: Correct error returned. 2007-04-09 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de> * include/rtems/pci.h: Added device ID for MOTOROLA_HAWK 2007-04-09 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/src/newlibc.c: Add __ATTRIBUTE_IMPURE_PTR__ (Fixes "relocation truncated to fit: R_MIPS_GPREL16" against _impure_ptr bug). Fix abuse of _REENT_INIT(). 2007-04-05 Joel Sherrill <joel@OARcorp.com> * itron/src/itrontime.c: Fix typo. * score/include/rtems/score/tod.h: Add TOD_TICKS_PER_SECOND macro. * score/src/iterateoverthreads.c: Safely take NULL as argument. * score/src/threaddispatch.c: Formatting. 2007-04-05 Joel Sherrill <joel@OARcorp.com> * posix/Makefile.am: Fix formatting. 2007-04-05 Joel Sherrill <joel@OARcorp.com> * posix/Makefile.am, posix/include/rtems/posix/time.h, posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c, posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c, posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c, posix/src/pthread.c, posix/src/pthreadcreate.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/sched.c, posix/src/semtimedwait.c, posix/src/sigtimedwait.c, posix/src/ualarm.c, rtems/src/clocktodtoseconds.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c, score/src/coretodget.c, score/src/coretodgetuptime.c, score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec manipulation routines in the SuperCore. Use them everywhere possible. This lead to significant cleanup in the API routines and eliminated some of the same code from the POSIX API. At this point, the SuperCore keeps time in POSIX timespec format properly from 1970. You just cannot set it before 1988 in keeping with RTEMS traditional behavior. * score/include/rtems/score/timespec.h, score/src/timespecaddto.c, score/src/timespecfromticks.c, score/src/timespecisvalid.c, score/src/timespeclessthan.c, score/src/timespecsubtract.c, score/src/timespectoticks.c: New files. * posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c: Removed. 2007-04-04 Joel Sherrill <joel@OARcorp.com> * score/Makefile.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl: Make _TOD_Tickle_ticks a real non-inlined routine. It should only be used once so there is little advantage to inlining it. * score/src/coretodtickle.c: New file. 2007-04-02 Joel Sherrill <joel@OARcorp.com> * posix/Makefile.am, score/src/objectgetnoprotection.c: Eliminate some dead code. * posix/src/time.c: Removed. 2007-04-02 Joel Sherrill <joel@OARcorp.com> * posix/include/rtems/posix/timer.h, posix/src/alarm.c, posix/src/posixtimespectointerval.c, posix/src/ptimer1.c, posix/src/sysconf.c, posix/src/ualarm.c, rtems/src/clockget.c, rtems/src/clocktodvalidate.c, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c: Eliminate TOD_Ticks_per_second variable. 2007-04-02 Joel Sherrill <joel@OARcorp.com> * itron/src/itrontime.c, libcsupport/src/__gettod.c, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/src/clockgettime.c, posix/src/clocksettime.c, posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c, posix/src/ptimer1.c, posix/src/sleep.c, rtems/Makefile.am, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c, score/Makefile.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c, score/src/coretodset.c: Convert from Classic API style TOD_Control as fundamental time structure to POSIX struct timespec. Add clock_get_uptime(). * rtems/src/clockgetuptime.c, score/src/coretodget.c, score/src/coretodgetuptime.c: New files. * score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c: Removed. 2007-04-02 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/printk.c: Add %p support. 2007-04-02 Joel Sherrill <joel@OARcorp.com> * libmisc/stackchk/check.c: Add code to check validity of frame pointer in addition to the pattern area being overwritten. Also do some cleanup. 2007-03-31 Ralf Corsépius <ralf.corsepius@rtems.org> * include/rtems/pci.h: Further stdint.h fixed-size types. 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org> * include/rtems/pci.h: Use stdint.h fixed size-types. 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/Makefile.am: Move libc/send.c to libc_a_SOURCES. * libnetworking/Makefile.am: Move libc/recv.c to libc_a_SOURCES. * libnetworking/Makefile.am: Move libc/res_config.h to libc_a_SOURCES (File is being used). * libnetworking/libc/iso_addr.c, libnetworking/libc/iso_addr.3: Remove (Unused). * libnetworking/Makefile.am: Remove libc/iso_addr.c, libc/iso_addr.3. * libnetworking/net/ppp-deflate.c, libnetworking/net/bsd-comp.c: Remove (Unused). * libnetworking/Makefile.am: Remove net/ppp-deflate.c, net/bsd-comp.c. 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/libc/addr2ascii.c, libnetworking/libc/ascii2addr.c, libnetworking/libc/base64.c, libnetworking/libc/ether_addr.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostbynis.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/gethostname.c, libnetworking/libc/getnetbydns.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetbynis.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/getproto.c, libnetworking/libc/getprotoent.c, libnetworking/libc/getprotoname.c, libnetworking/libc/getservbyname.c, libnetworking/libc/getservbyport.c, libnetworking/libc/getservent.c, libnetworking/libc/herror.c, libnetworking/libc/inet_addr.c, libnetworking/libc/inet_lnaof.c, libnetworking/libc/inet_makeaddr.c, libnetworking/libc/inet_net_ntop.c, libnetworking/libc/inet_net_pton.c, libnetworking/libc/inet_neta.c, libnetworking/libc/inet_netof.c, libnetworking/libc/inet_network.c, libnetworking/libc/inet_ntoa.c, libnetworking/libc/inet_ntop.c, libnetworking/libc/inet_pton.c, libnetworking/libc/iso_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_addr.c, libnetworking/libc/ns_name.c, libnetworking/libc/ns_netint.c, libnetworking/libc/ns_ntoa.c, libnetworking/libc/ns_parse.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/recv.c, libnetworking/libc/res_comp.c, libnetworking/libc/res_data.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_init.c, libnetworking/libc/res_mkquery.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_stubs.c, libnetworking/libc/res_update.c, libnetworking/libc/send.c, libnetworking/libc/strsep.c: Eliminate SCCS, LINT. Add HAVE_CONFIG_H. * libcsupport/src/__assert.c: Add HAVE_CONFIG_H. 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> * rtems/include/rtems/rtems/tasks.h: Change rtems_task_argument to uintptr_t. 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/netinet/ip_icmp.c, libnetworking/netinet/ip_input.c, libnetworking/netinet/ip_output.c: Further _IP_VHL removal preps. 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/netinet/ip.h: Add FreeBSD's alignment macros. * libnetworking/net/netisr.h: Partial update from FreeBSD. * libcsupport/src/getpwent.c: Remove bogus cast to long. * libnetworking/libc/strsep.c: Don't build if provided by libc. * libnetworking/libc/rcmd.c: Eliminate __P(). Cosmetics. * libnetworking/sys/select.h: Remove selrecord, selwakeup (Unused). * libnetworking/netinet/ip_output.c: Preps to eliminate _IP_VHL (Abandoned in FreeBSD). Misc mergers from upstream FreeBSD. * libnetworking/netinet/ip_input.c: Preps to eliminate _IP_VHL (Abandoned in FreeBSD). Misc mergers from upstream FreeBSD. * libnetworking/netinet/ip_icmp.c: Preps to eliminate _IP_VHL (Abandoned in FreeBSD). * libnetworking/netinet/tcp_subr.c: Preps to eliminate _IP_VHL (Abandoned in FreeBSD). * libnetworking/netinet/raw_ip.c: Preps to eliminate _IP_VHL (Abandoned in FreeBSD). * libnetworking/netinet/ip_output.c: Partial update from FreeBSD. * libnetworking/netinet/ip_fw.c: Eliminate __P(). 2007-03-28 Chris Johns <chrisj@rtems.org> * rtems/Makefile.am, rtems/include/rtems/rtems/clock.h, score/include/rtems/score/watchdog.h: Add support for a handler to obtain the number of nanoseconds since the last clock tick. The primary interface for this is rtems_clock_set_nanoseconds_extension. Subsequent commits from Joel will redo the TOD support to use this capability. * rtems/src/clocksetnsecshandler.c: New file. 2007-03-28 Joel Sherrill <joel@OARcorp.com> PR 1234/cpukit * libcsupport/Makefile.am: Provide printk() based implementation of __assert() to reduce dependencies in executables. * libcsupport/src/__assert.c: New file. 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> * librpc/src/rpc/clnt_tcp.c (clnttcp_create): Use uintptr_t for "disrupt". Remove bogus (long) cast. * libnetworking/net/ppp-comp.h: Remove (Unused). * libnetworking/Makefile.am: Remove net/ppp-comp.h. * libnetworking/sys/buf.h: Remove (Unused). * libnetworking/Makefile.am: Remove sys/buf.h. * libnetworking/kern/kern_sysctl.c, libnetworking/kern/uipc_socket2.c: Include <sys/queue.h> instead of <sys/buf.h>. * libcsupport/include/sys/sockio.h: Partial update from FreeBSD. 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/netinet/ip_output.c: Use uint32_t optlen. * libnetworking/netinet/igmp.c: Eliminate __P(). * libnetworking/netinet/in.c: Eliminate __P(). * libnetworking/netinet/tcp_subr.c: Eliminate __P(). * libnetworking/netinet/in_pcb.c: Eliminate __P(). * libnetworking/netinet/ip_output.c: Eliminate __P(). 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/protosw.h (pr_usrreqs.pru_attach, pr_usrreqs.pru_control, pr_usrreqs.pru_rcvd, pr_usrreqs.pru_rcvoob): Change int args to intptr_t because they are casted to pointers. * libnetworking/netinet/tcp_usrreq.c, libnetworking/kern/uipc_socket2.c: Reflect changes to sys/protosw.h. 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/rtems/rtems_glue.c: Cast to intptr_t instead of "long", because long is not guaranteed to be castable to char*. * libnetworking/netinet/ip_input.c: Eliminate __P(). Change "int next" to "int32_t next" for 16bit targets. * libnetworking/netinet/tcp_input.c: Eliminate __P(). * libnetworking/netinet/in_rmx.c: Eliminate __P(). * libnetworking/netinet/tcp_usrreq.c: Eliminate __P(). * libnetworking/netinet/udp_usrreq.c: Eliminate __P(). * libnetworking/nfs/bootp_subr.c: Eliminate __P(). * libnetworking/rtems/rtems_bsdnet_internal.h: Eliminate __P(). * libnetworking/kern/uipc_domain.c: Eliminate __P(). 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/net/pppcompress.h, libnetworking/net/pppcompress.c: Remove (Abandoned in FreeBSD). * libnetworking/Makefile.am: Remove net/pppcompress.c, net/pppcompress.h. * libnetworking/net/if_ppp.c: Use net/slcompress.h instead of net/pppcompress.h. * libnetworking/net/slcompress.h: Cosmetics from FreeBSD. * libnetworking/net/ppp_tty.c: Use net/slcompress.h instead of net/pppcompress.h. 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/net/pppcompress.h: Eliminate __P(). * libnetworking/net/if_pppvar.h: Cosmetics from FreeBSD. * libnetworking/net/if_llc.h: Update from FreeBSD. 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> * pppd/ccp.c, pppd/options.c: Include <net/ppp_comp.h> instead of <net/ppp-comp.h>. * libnetworking/net/ppp-comp.h: Include <net/ppp_comp.h>. Warn about using it. * libnetworking/Makefile.am: Add net/ppp_comp.h. * libnetworking/net/ppp_comp.h: New (copy of ppp-comp.h). * libnetworking/net/ppp-comp.h: Eliminate __P(). Cosmetics from FreeBSD. * libnetworking/machine/in_cksum.h: Eliminate __P(). * pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/chap.c, pppd/chap_ms.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/ipcp.c, pppd/lcp.c, pppd/options.c, pppd/rtemsmain.c, pppd/sys-rtems.c, pppd/upap.c, pppd/utils.c: Eliminate __P(). * libcsupport/src/scandir.c: Eliminate __P(). * pppd/chap.h, pppd/chap_ms.h, pppd/fsm.h, pppd/ipcp.h, pppd/lcp.h, pppd/magic.h, pppd/md4.h, pppd/pppd.h, pppd/upap.h: Eliminate __P(). * libnetworking/netinet/ip_mroute.c: Eliminate __P(). * libnetworking/netinet/ip_mroute.h: Partial update from FreeBSD. * libnetworking/net/raw_cb.c: Sync with FreeBSD. 2007-03-26 Joel Sherrill <joel@OARcorp.com> PR 1231/cpukit * posix/src/adasupp.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexmp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/ptimer1.c, posix/src/sched.c, posix/src/time.c: Remove unneeded includes of assert.h 2007-03-26 Joel Sherrill <joel@OARcorp.com> * libcsupport/include/rtems/assoc.h: Pick up the include file changes associated with the file splitting. 2007-03-26 Joel Sherrill <joel@OARcorp.com> * libcsupport/Makefile.am: Pick up the Makefile changes associated with the file splitting. 2007-03-26 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/assoc.c, libcsupport/src/libio.c, libcsupport/src/write.c: Split files to shrink minimum.exe. Hopefully this will not be deemed necessary to commit to the 4.7 branch. * libcsupport/src/assoclocalbyname.c, libcsupport/src/assoclocalbyremote.c, libcsupport/src/assoclocalbyremotebitfield.c, libcsupport/src/assocnamebylocal.c, libcsupport/src/assocnamebylocalbitfield.c, libcsupport/src/assocnamebyremote.c, libcsupport/src/assocnamebyremotebitfield.c, libcsupport/src/assocptrbylocal.c, libcsupport/src/assocptrbyname.c, libcsupport/src/assocptrbyremote.c, libcsupport/src/assocremotebylocal.c, libcsupport/src/assocremotebylocalbitfield.c, libcsupport/src/assocremotebyname.c, libcsupport/src/libio_init.c, libcsupport/src/write_r.c: New files. 2007-03-26 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/__gettod.c: Replace incorrect comment about timezone support and remove deadcode. Replace with comment explaining that behavior is compatible with GNU/Linux per Eric Norum. 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/net/ppp_defs.h, libnetworking/net/if_ppp.h: Partial update from FreeBSD. * libnetworking/netinet/if_ether.h: Eliminate __P(). * libnetworking/netinet/ip_var.h: Eliminate __P(). * libnetworking/netinet/in.h: Eliminate __P(). * libnetworking/netinet/tcp_var.h: Eliminate __P(). 2007-03-25 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/netinet/udp_var.h: Cosmetics from FreeBSD. Remove __P(); * libnetworking/netinet/in_pcb.h: More partial updates from FreeBSD. 2007-03-25 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/netinet/in_var.h: Remove __P(). * libnetworking/netinet/in_systm.h: Remove __P(). * libnetworking/netinet/in_pcb.h: Partial updates from FreeBSD. * libnetworking/sys/socketvar.h: Cosmetics from FreeBSD. * libnetworking/netinet/if_ether.c: Remove __P(). * libnetworking/net/raw_cb.h, libnetworking/net/raw_usrreq.c: More updates from FreeBSD. * libnetworking/net/raw_cb.h, libnetworking/net/raw_usrreq.c, libnetworking/net/route.h: Partial update from FreeBSD. 2007-03-24 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/Makefile.am: Remove nfs/krpc.h. * libnetworking/nfs/krpc.h: Remove (Unused). * libnetworking/kern/kern_subr.c: Remove #ifdef'ed vax code. * libnetworking/Makefile.am: Remove nfs/nfs.h. * libnetworking/nfs/nfs.h: Remove (Unused). 2007-03-19 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/buf.h: Remove unused/non-implemented bsd kernel symbols. * libnetworking/sys/conf.h: Don't include machine/conf.h. Update copyright notice. Remove unused/non-implemented declarations. * libnetworking/Makefile.am: Remove machine/conf.h. * libnetworking/machine/conf.h: Remove. 2007-03-19 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/systm.h: Update copyright notice from FreeBSD. Remove many non-supported/unused declarations. 2007-03-18 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/ucred.h: Remove crcopy, crdup, crfree, crget, crhold (Unused/non-implemented). 2007-03-18 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/ucred.h: Remove __P(). * libnetworking/sys/callout.h: Remove __P(). * libnetworking/sys/domain.h: Remove __P(). * libnetworking/sys/socketvar.h: Remove __P(). * libnetworking/sys/socket.h: Remove __P(). * libnetworking/sys/select.h: Remove __P(). * libnetworking/sys/kernel.h: Remove __P(). * libnetworking/sys/protosw.h: Remove __P(). * libnetworking/sys/conf.h: Remove bdevsw, cdevsw, swdevt (Unused). * libnetworking/sys/systm.h: Remove nblkdev, nchrdev, swdevt, nswdev, nswap (Unused). 2007-03-18 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/conf.h: Remove non-implemented/unused symbols. * libnetworking/net/ppp_tty.c: Use struct rtems_termios_linesw instead of struct linesw (PR 1229) * libnetworking/sys/systm.h: Comment out copyin/copyout to work around clash with defines from rtems_bsdnet_internal.h. * score/src/heapwalk.c: include stdlib.h. 2007-03-17 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/buf.h, libnetworking/sys/conf.h: Remove __P(). * libnetworking/net/if.h, libnetworking/net/if_ppp.h, libnetworking/sys/signalvar.h, libnetworking/sys/systm.h: Remove __P(). * libcsupport/include/rtems/termiostypes.h, libcsupport/src/termios.c: Prefix linesw, struct linesw, nwlinesw with rtems_termios_*. * libnetworking/sys/conf.h: Remove linesw, struct linesw, nlinesw. (Clash with termiostypes.h - PR 1229). 2007-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> * score/include/rtems/score/wkspace.h, score/inline/rtems/score/wkspace.inl, score/src/wkspace.c: Change _Workspace_Handler_initialization and _Workspace_Allocate_or_fatal_error to using size_t. * libnetworking/sys/rtprio.h: Remove (Unused). * libnetworking/Makefile.am: Remove sys/rtprio.h. 2007-03-14 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/sys/mbuf.h, libnetworking/sys/rtprio.h: Remove __P(). 2007-03-13 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/src/assocnamebad.c: Remove dead code. Use PRI* macros to fix warnings. * score/include/rtems/score/stack.h: Use size_t for stack sizes. * score/include/rtems/score/chain.h, score/src/chain.c: Change _Chain_Initialize to using size_t. 2007-03-12 Joel Sherrill <joel@OARcorp.com> * libmisc/dumpbuf/dumpbuf.c, libmisc/dumpbuf/dumpbuf.h: Rename Dump_Buffer to rtems_print_buffer. 2007-03-12 Joel Sherrill <joel@OARcorp.com> * score/src/heapallocatealigned.c, score/src/threadqrequeue.c: Correct license URL and/or fix mistake in copyright notice. Both of these mistakes appear to be from code submitted after these changes were made previously. 2007-03-10 Joel Sherrill <joel@OARcorp.com> PR 1226/cpukit * sapi/include/confdefs.h: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE not CONFIGURE_HAS_OWN_MULTIPROCESING_TABLE. 2007-03-08 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/imfs.h: Fix comment. 2007-03-08 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/imfs.h: Fix comment. 2007-03-08 Joel Sherrill <joel@OARcorp.com> * libmisc/stackchk/check.c, libmisc/stackchk/internal.h, libmisc/stackchk/stackchk.h: Change dump usage to report usage. 2007-03-08 Joel Sherrill <joel@OARcorp.com> * rtems/Makefile.am, rtems/src/msgqsend.c, rtems/src/msgqurgent.c: Remove wrapper for message queue send and urgent and implement them directly. There was an unnecessary function call layer in addition to conditions in the shared routine. Directly coding both directives is simpler and should result in smaller code. * rtems/src/msgqsubmit.c: Removed. 2007-03-05 Joel Sherrill <joel@OARcorp.com> PR 1222/cpukit * score/Makefile.am, score/include/rtems/score/coremutex.h, score/include/rtems/score/threadq.h, score/inline/rtems/score/coremutex.inl, score/src/coremsgsubmit.c, score/src/coremutexsurrender.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadsetstate.c: Enhance so that when the prioirity of a thread that is blocked on a priority based thread queue is changed, that its placement in the queue is reevaluated based upon the new priority. This enhancement includes modifications to the SuperCore as well as new test cases. * score/src/threadqrequeue.c: New file. 2007-03-05 Joel Sherrill <joel@OARcorp.com> * sapi/src/exinit.c: Fix spacing. 2007-03-05 Joel Sherrill <joel@OARcorp.com> PR 1221/cpukit * posix/src/pthreadequal.c: Fix critical section nesting. 2007-02-22 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/Makefile.am: Move getpagesize.c to newlib-only compiled files. 2007-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * wrapup/Makefile.am: Use MKDIR_P instead of mkdir_p. 2007-02-16 Ralf Corsepius <ralf.corsepius@rtems.org> * score/Makefile.am: Remove macros/README. 2007-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> * score/include/rtems/score/heap.h, score/src/heap.c, score/src/heapallocatealigned.c, score/src/heapresizeblock.c: More size_t for heap-sizes. * score/include/rtems/score/heap.h, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c: Use size_t for heap-sizes. * libnetworking/resolv.h: Typo fixes. Remove __P(). 2007-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> * rtems/include/rtems/rtems/tasks.h, rtems/src/taskcreate.c: Use size_t for stack-sizes. 2007-02-07 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/vm/vm_extern.h: Remove non-implemented/unused functions. * configure.ac: Check for intmax_t, uintptr_t, intptr_t, pthread.h, pthread_rwlock_t, pthread_barrier_t, pthread_spinlock_t. 2007-02-06 Till Straumann <strauman@slac.stanford.edu> * libcsupport/src/gxx_wrappers.c: fix PR#690. Supply taskvar dtor to plug memory leak. Applied patch attached to PR#690. 2007-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/src/getpagesize.c: New (moved from posix/src). * posix/src/getpagesize.c: Removed. * posix/Makefile.am: Remove references to getpagesize.c. * libcsupport/Makefile.am: Add getpagesize.c. 2007-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/src/sysconf.c: Add support for _SC_PAGESIZE (PR 1215). * posix/src/mqueuesendsupp.c: Remove cast to make broken const cast visible. * score/inline/rtems/score/coremsg.inl: More size_t and consts. 2007-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> * rtems/src/msgqsend.c: Use size_t for sizes. * rtems/src/msgqurgent.c: Use size_t for sizes. * rtems/src/msgqbroadcast.c: Use size_t for sizes. * rtems/src/msgmp.c: Use size_t for sizes. * rtems/src/msgqsubmit.c: Use size_t for sizes. * rtems/include/rtems/rtems/msgmp.h: Use size_t for sizes. * rtems/include/rtems/rtems/message.h: Use size_t for sizes. * score/inline/rtems/score/coremsg.inl: Use size_t for sizes. 2007-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> * itron/src/trcv_mbf.c: Use size_t for sizes. * libmisc/monitor/mon-object.c: Use size_t for sizes. * libmisc/monitor/mon-server.c: Use size_t for sizes. * libmisc/monitor/monitor.h: Use size_t for sizes. * libmisc/mw-fb/mw_uid.c: Use size_t for sizes. * rtems/include/rtems/rtems/message.h: Use size_t for sizes. * rtems/src/msgqreceive.c: Use size_t for sizes. * posix/src/mqueuerecvsupp.c: Use size_t for sizes. * score/src/coremsgseize.c: Use size_t for sizes. 2007-02-05 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/include/rtems/posix/mqueue.h: Use size_t for sizes. * posix/src/mqueuesendsupp.c: Use size_t for sizes. * score/include/rtems/score/coremsg.h: Use size_t for sizes. * score/src/coremsgbroadcast.c: Use size_t for sizes. * score/src/coremsgsubmit.c: Use size_t for sizes. 2007-01-30 Ralf Corsépius <ralf.corsepius@rtems.org> * libblock/src/show_bdbuf.c: Use inttypes.h macros. 2007-01-29 Ralf Corsépius <ralf.corsepius@rtems.org> * libmisc/mw-fb/mw_fb.h: Eliminate __u32, __u16. 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/libc/gethostbyht.c: Remove warning on unused vars. Remove isblank (supposed to be provided by libc). 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> * libblock/src/show_bdbuf.c: Convert from DOS to UNIX. 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> * score/include/rtems/system.h: Remove __RTEMS_MAJOR__, __RTEMS_MINOR__, __RTEMS_REVISION__ (moved to cpuopt.h). * configure.ac: Dynamically derive __ __RTEMS_MAJOR__, __RTEMS_MINOR__, __RTEMS_REVISION__ from _RTEMS_VERSION. Add __RTEMS_MAJOR__, __RTEMS_MINOR__,__RTEMS_REVISION__ to cpuopt.h. 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> * score/include/rtems/system.h: #define __RTEMS_MINOR__ 7 (BZ 1206). 2007-01-20 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de> * libblock/src/bdbuf.c, libblock/include/bdbuf.h: export some internal variables to make them available in "show_bdbuf" monitor add-on 2007-01-16 Till Straumann <strauman@slac.stanford.edu> * libnetworking/rtems/rtems_mii_ioctl.c, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c, libi2c/libi2c.c, libi2c/libi2c.h: Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer. 2007-01-09 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/error.c: rtems_progname is no longer defined in the BSP startup since it never held a meaningful value. 2007-01-02 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/include/aio.h: s/aoi_lio_opcode/aio_lio_opcode/ (BZ 1203). 2006-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> * backward/rtc.h, backward/vmeintr.h, backward/confdefs.h, backward/clockdrv.h, backward/itron.h, backward/console.h, backward/imfs.h, backward/iosupp.h, backward/chain.h, backward/motorola/mc68681.h, backward/motorola/mc68230.h, backward/spurious.h, backward/rtemspppd.h, backward/zilog/z8536.h, backward/zilog/z8030.h, backward/zilog/z8036.h, backward/dosfs.h, backward/rtemsdialer.h, backward/asm.h, backward/timerdrv.h, backward/ringbuf.h, backward/ftpd.h: Abandon. 2006-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> * rtems/include/rtems/rtems/types.h: Abandon backward compatibility types. * include/rtems/stdint.h: Abandon DEPRECATED_TYPES. * configure.ac: Abandon DEPRECATED_TYPES/--enable-deprecated. * Makefile.am: Abandon DEPRECATED_TYPES. 2006-12-13 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/rtems-ampolish.m4: Use am_aux_dir/ampolish3. 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/rtems-ampolish.m4: Require AM_MAINTAINER_MODE. * aclocal/rtems-top.m4: Remove RTEMS_AMPOLISH3. * configure.ac: Add RTEMS_AMPOLISH3. * rtems/src/barrierrelease.c: Remove stray rtems_unsigned32. 2006-12-12 Ralf Corsépius <ralf.corsepius@rtems.org> * libfs/src/imfs/imfs.h: Remove increment_and_check_linkcounts (unused), decrement_linkcounts (unused, broken). 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/net/route.c, libnetworking/netinet/ip_input.c, libnetworking/sys/domain.h: Cosmetics from FreeBSD. 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/rtems/rtems_glue.c: Remove local extern strdup. 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/include/rtems/libio.h, libcsupport/src/read.c, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/memfile.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/rtems/rtems_syscall.c: Use size_t instead of uint32_t for read/write count-args. 2006-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> * rtems/src/timerserverfirewhen.c: Remove local extern _Timer_Seconds_chain. * rtems/src/timerserverfireafter.c: Remove local extern _Timer_Ticks_chain. 2006-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> * score/include/rtems/score/object.h, score/src/objectclearname.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Add const qualifiers, use size_t where appropriate. 2006-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> * score/inline/rtems/score/thread.inl: Add const qualifiers to work around aliasing effects. 2006-12-04 Ralf Corsépius <ralf.corsepius@rtems.org> * score/inline/rtems/score/chain.inl: Add const qualifiers (works around 651 aliasing bugs). 2006-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> * posix/src/prwlockunlock.c, rtems/Makefile.am, rtems/src/barrierrelease.c, rtems/src/barrierwait.c, score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c: Complete implementation of barrier as the rest of the test code is now implemented. Also add blocking code to rwlock. 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: New BUG-REPORT address. 2006-11-27 Ralf Corsépius <ralf.corsepius@rtems.org> * score/src/threadget.c: Remove (Unused). * score/Makefile.am: Removing score/src/threadget.c. 2006-11-21 Ralf Corsépius <ralf.corsepius@rtems.org> * libblock/Makefile.am: Don't include preinstall.am. * libblock/preinstall.am: Remove. 2006-11-20 Ralf Corsépius <ralf.corsepius@rtems.org> * Makefile.am: Remove ampolish3. 2006-11-18 Joel Sherrill <joel@OARcorp.com> * score/src/heapwalk.c: Do not use printk yet since many BSPs do not prove the hooks for printk yet. This will require enough BSP changes to delay until 4.8. 2006-11-18 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Add check for uintmax_t. * libcsupport/src/malloc.c: Use uintmax_t instead of uint64_t for MALLOC_STATS statistics. Use inttypes.h PRIxXXX macros for printing. 2006-11-18 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/check-networking.m4: Integrate type checks. * configure.ac: Use rtems_cv_HAS_NETWORKING instead of HAS_NETWORKING. 2006-11-18 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/check-itron.m4: Integrate ITRON-type checks. * configure.ac: Remove ITRON-type checks. Move RTEMS_CHECK* after type-checks. 2006-11-18 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Remove $LIBRPC. * configure.ac: Check for uint64_t, int64_t. * configure.ac, Makefile.am, configure.ac, ftpd/Makefile.am, httpd/Makefile.am, libnetworking/Makefile.am, pppd/Makefile.am, telnetd/Makefile.am, wrapup/Makefile.am: Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). 2006-11-17 Joel Sherrill <joel@OARcorp.com> * score/inline/rtems/score/object.inl, score/src/objectnametoid.c: Properly honor searching only local node even when on single CPU system. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * score/src/coresemseize.c: Add missing ISR enable. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * score/src/heapwalk.c: Use printk not printf. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * libmisc/rtmonuse/rtmonuse.c: Do not use float for calculations. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/sync.c: Do not dereference NULL reent. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * posix/src/semtimedwait.c: Used wrong constant for blocking with bad timeout value. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * posix/src/semtimedwait.c: Reverse accidentally included semtimedwait.c. 2006-11-17 Joel Sherrill <joel@OARcorp.com> * posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/semtimedwait.c: Correct indexing of key data to use api and index NOT class and index. Class is always 1. 2006-11-17 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Suppress itron if int8/int16_t are not provided. * configure.ac, Makefile.am, itron/Makefile.am, wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBITRON). Remove AM_CONDITIONAL(HAS_ITRON). 2006-11-17 Ralf Corsépius <ralf.corsepius@rtems.org> * wrapup/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS). * configure.ac, Makefile.am, libfs/Makefile.am: Introduce AM_CONDITIONAL(LIBDOSFS). 2006-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/libc/gethostbydns.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c: Cosmetic updates from FreeBSD. Eliminate bcopy in favor of memcpy. 2006-11-16 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/rtems/rtems_bsdnet_internal.h: Add timeout() define. * libnetworking/rtems/rtems_glue.c: Rename timeout() into rtems_bsdnet_timeout(). * libnetworking/sys/malloc.h: Remove contigmalloc (non-implemented). Remove __P-guards from malloc, free. 2006-11-15 Joel Sherrill <joel@OARcorp.com> * sapi/src/io.c: Fix spacing. * sapi/include/confdefs.h: Enable includes needed for new objects. 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com> * sapi/include/confdefs.h: Enable memory for new objects. 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com> * posix/Makefile.am: Add file missed in previous commit. * posix/src/posixtimespecabsolutetimeout.c: New file. 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Remove RTEMS_AMPOLISH3. Add checks for uint8_t, int8_t, uint16_t, int16_t, uint32_t, int32_t. * aclocal/rtems-ampolish.m4: Pick up ampolish3 from ac_aux_dir. * aclocal/rtems-top.m4: Add RTEMS_AMPOLISH3. * ampolish3: Remove. 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com> * score/inline/rtems/score/threadq.inl, score/src/corerwlocktimeout.c: New files. 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com> * libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h, sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/corerwlock.h, score/include/rtems/score/threadq.h, score/src/corerwlockobtainread.c, score/src/threadqenqueue.c, score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks, and partial implementation of POSIX rwlocks. * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/spinlock.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/spinlock.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/pbarrier.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlock.c, posix/src/prwlockdestroy.c, posix/src/prwlockinit.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspin.c, posix/src/pspindestroy.c, posix/src/pspininit.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files. 2006-11-14 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Require inttypes.h, check for stdint.h. 2006-11-12 Ralf Corsépius <ralf.corsepius@rtems.org> * Makefile.am, configure.ac: Remove RTEMS_PROVIDES_STDINT_H, RTEMS_PROVIDES_INTTYPES_H. 2006-11-12 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/include/stdint.h, libcsupport/include/inttypes.h: Remove. 2006-11-12 Ralf Corsépius <ralf.corsepius@rtems.org> * score/Doxyfile: Remove RTEMS_INLINES. 2006-11-09 Ralf Corsépius <ralf.corsepius@rtems.org> * librpc/src/xdr/xdr_float.c: Add bfin. 2006-11-09 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Remove redundant AC_CHECK_HEADER([stdint.h]), AC_CHECK_HEADER([inttypes.h]). Now implicitly checked. 2006-11-02 Steven Johnson <sjohnson@sakuraindustries.com> * libnetworking/netdb.h, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c: This patch adds a functional gethostbyname_r to RTEMS. We were having problems with multiple threads calling gethostbyname, so we decided the best way to deal with it was to do it properly, rather than kludge up our code to make gethostbyname safe. We have found several slightly different parameter lists for this function, it does not seem to be standard. The one we used has the linux interface. In RTEMS there was an existing gethostbyname_r inside a #ifdef _THREAD_SAFE which was NOT Threadsafe, as this just called gethostbyname. So we have placed all of the additional code inside the #ifdef _THREAD_SAFE. 2006-10-30 Joel Sherrill <joel@OARcorp.com> PR 841/rtems * itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c, posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/semaphore.inl, posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c, posix/src/semwait.c, rtems/src/semobtain.c, rtems/src/semtranslatereturncode.c, score/include/rtems/score/coresem.h, score/src/coresemseize.c: Make sem_timedwait more conformant to Open Group specification. 2006-10-25 Jennifer Averett <jennifer@oarcorp.com> * libcsupport/src/termios.c: Change attribute of semaphore. It was counting interrupts not acting as a condition synchronization mutex. Since the caller did not always need to obtain the semaphore, it was not being decremented until there was no data. This could occur after hours of running a system and thousands of interrupts. The code in fillBufferQueue would spin until it had consumed all of those semaphore counts. 2006-10-23 Joel Sherrill <joel@OARcorp.com> * configure.ac, score/cpu/Makefile.am: Add bfin. 2006-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/enable-inlines.m4, aclocal/prog-gnat.m4: Remove (Unused). 2006-10-19 Joel Sherrill <joel@OARcorp.com> * score/Makefile.am, score/preinstall.am: Add pieces missed in previous commit. 2006-10-19 Joel Sherrill <joel@OARcorp.com> * configure.ac, itron/Makefile.am, itron/preinstall.am, posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am, rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am, score/Makefile.am, score/preinstall.am, score/include/rtems/system.h, score/include/rtems/score/chain.h, score/include/rtems/score/thread.h, score/src/chain.c, score/src/coremutexseize.c, score/src/threadget.c: Remove all macro implementations and use only the static inline. Static inline functions are now well supported so there is no reason for duplicate maintenance. * itron/macros/rtems/itron/eventflags.inl, itron/macros/rtems/itron/fmempool.inl, itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl, itron/macros/rtems/itron/msgbuffer.inl, itron/macros/rtems/itron/network.inl, itron/macros/rtems/itron/port.inl, itron/macros/rtems/itron/semaphore.inl, itron/macros/rtems/itron/sysmgmt.inl, itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl, itron/macros/rtems/itron/vmempool.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl, posix/macros/rtems/posix/mqueue.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/priority.inl, posix/macros/rtems/posix/pthread.inl, posix/macros/rtems/posix/semaphore.inl, posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl, rtems/macros/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/barrier.inl, rtems/macros/rtems/rtems/dpmem.inl, rtems/macros/rtems/rtems/event.inl, rtems/macros/rtems/rtems/eventset.inl, rtems/macros/rtems/rtems/message.inl, rtems/macros/rtems/rtems/modes.inl, rtems/macros/rtems/rtems/options.inl, rtems/macros/rtems/rtems/part.inl, rtems/macros/rtems/rtems/ratemon.inl, rtems/macros/rtems/rtems/region.inl, rtems/macros/rtems/rtems/sem.inl, rtems/macros/rtems/rtems/status.inl, rtems/macros/rtems/rtems/support.inl, rtems/macros/rtems/rtems/tasks.inl, rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl, score/macros/README, score/macros/rtems/score/address.inl, score/macros/rtems/score/chain.inl, score/macros/rtems/score/corebarrier.inl, score/macros/rtems/score/coremsg.inl, score/macros/rtems/score/coremutex.inl, score/macros/rtems/score/corerwlock.inl, score/macros/rtems/score/coresem.inl, score/macros/rtems/score/corespinlock.inl, score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl, score/macros/rtems/score/mppkt.inl, score/macros/rtems/score/object.inl, score/macros/rtems/score/objectmp.inl, score/macros/rtems/score/priority.inl, score/macros/rtems/score/stack.inl, score/macros/rtems/score/states.inl, score/macros/rtems/score/sysstate.inl, score/macros/rtems/score/thread.inl, score/macros/rtems/score/threadmp.inl, score/macros/rtems/score/tod.inl, score/macros/rtems/score/tqdata.inl, score/macros/rtems/score/userext.inl, score/macros/rtems/score/watchdog.inl, score/macros/rtems/score/wkspace.inl: Removed. 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> * sapi/include/confdefs.h: s/STACK_CHECKER_EXTENSION/RTEMS_STACK_CHECKER_EXTENSION/ (Reflect 2006-09-13's changes to libmisc/stackchk). 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/rtems-top.m4: Bump RTEMS_API to 4.8. 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> * libmisc/capture/capture-cli.c: Use size_t instead of int. 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/version.m4: Bump version to 4.7.99.0. 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Require autoconf-2.60. Require automake-1.10. 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac: Require autoconf-2.60. 2006-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> * configure.ac, aclocal/multi.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4 automake/compile.am: Adaptations to automake-1.10. 2006-09-29 Chris Johns <chrisj@rtems.org> * libmisc/monitor/mon-command.c: Flush stdout after updating the command line. 2006-09-14 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. 2006-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> * sapi/include/confdefs.h, sapi/src/posixapi.c, sapi/src/rtemsapi.c: Add Classic API Barriers and commented out hooks to initialize . 2006-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> * rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/config.h, rtems/inline/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/attr.inl: Add Classic API Barriers. * rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/barriermp.h, rtems/inline/rtems/rtems/barrier.inl, rtems/macros/rtems/rtems/barrier.inl, rtems/src/barrier.c, rtems/src/barriercreate.c, rtems/src/barrierdelete.c, rtems/src/barrierident.c, rtems/src/barrierrelease.c, rtems/src/barriertranslatereturncode.c, rtems/src/barrierwait.c: New files. 2006-09-25 Joel Sherrill <joel@oarcorp.com> * score/Makefile.am, score/preinstall.am, score/include/rtems/score/coresem.h, score/include/rtems/score/object.h, score/include/rtems/score/states.h, score/inline/rtems/score/coresem.inl: Add SuperCore Barriers, SpinLocks and a partial implementation of RWLocks. * score/include/rtems/score/corebarrier.h, score/include/rtems/score/corerwlock.h, score/include/rtems/score/corespinlock.h, score/inline/rtems/score/corebarrier.inl, score/inline/rtems/score/corerwlock.inl, score/inline/rtems/score/corespinlock.inl, score/macros/rtems/score/corebarrier.inl, score/macros/rtems/score/corerwlock.inl, score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c: New files. 2006-09-14 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. 2006-09-14 Joel Sherrill <joel@OARcorp.com> * libmisc/cpuuse/cpuuse.c, libmisc/cpuuse/cpuuse.h: Promote CPU Usage to first class citizen. Rename to start with rtems_ and include documentation in user guide. 2006-09-13 Joel Sherrill <joel@OARcorp.com> * libnetworking/rtems/rtems_malloc_mbuf.c: Removed warning by adding prototype of malloc. 2006-09-13 Joel Sherrill <joel@OARcorp.com> * libmisc/stackchk/check.c, libmisc/stackchk/internal.h, libmisc/stackchk/stackchk.h: Move stack to first class citizen status. Include it in User Manual and rename to start with rtems_. 2006-09-11 Joel Sherrill <joel@OARcorp.com> * libmisc/mw-fb/mw_fb.c, libmisc/mw-fb/mw_fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: Remove warning. 2006-09-11 Jerry Needell <jerry.needell@unh.edu> * libnetworking/netinet/in_cksum.c: Joel should have used int32_t not uint32_t when removing warnings. 2006-09-08 Ken Peters <ken.peters@jpl.nasa.gov> PR 1170/rtems * rtems/src/timerserver.c: Timer Server created the TIME task with a hard-coded hexadecimal number instead of using rtems_build_name. This resulted in a byte-swapped name on some platforms. 2006-09-06 Chris Johns <chrisj@rtems.org> * pppd/pppd.h: Fix the bug in name change. The UNTIMEOUT macro did not use the ppp version. 2006-09-01 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/if_loop.c: Remove warning. 2006-09-01 Till Straumann <strauman@slac.stanford.edu> * pppd/rtems.main.c, pppd/pppd.h: renamed 'untimeout' to 'pppuntimeout' to avoid name clash with [future] bsdnet kernel routine. 2006-09-01 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/malloc.c, libnetworking/rtems/rtems_glue.c, libnetworking/sys/mbuf.h: Remove warnings -- use uintptr_t or properly sized integers. 2006-08-30 Joel Sherrill <joel@OARcorp.com> * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. 2006-08-30 Joel Sherrill <joel@OARcorp.com> * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement. 2006-08-30 Joel Sherrill <joel@OARcorp.com> * libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c, libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c, libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf format warnings. 2006-08-30 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/utsname.c, libnetworking/libc/res_debug.c, libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c, librpc/src/rpc/svc_simple.c: Remove printf format warnings. 2006-08-29 Joel Sherrill <joel@OARcorp.com> * libmisc/capture/capture-cli.c: Remove printf format warnings. 2006-08-29 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/score/object.h: _Objects_Local_node is a uint16_t so cast the _Objects_Local_node constant to 1. 2006-08-29 Joel Sherrill <joel@OARcorp.com> * libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c, libfs/src/imfs/imfs_debug.c: Remove warnings. 2006-08-21 Till Straumann <strauman@slac.stanford.edu> * libnetworking/net/if_ethersubr.c: (ether_ioctl) Return error for unknown/unsupported ioctl command. (Change merged from freeBSD). 2006-08-15 Joel Sherrill <joel@OARcorp.com> * libnetworking/kern/kern_sysctl.c: Change int to int32_t. * libnetworking/net/if_loop.c: Add cast to long. These plus a patch to machine/param.h let the h8300 build multilib. 2006-08-10 Till Straumann <strauman@slac.stanford.edu> * libnetworking/rtems/rtems_mii_ioctl_kern.c: fixed wrong calculation of 1000baseTx autonegotiation result. 2006-08-09 Kolja Waschk <waschk@telos.de> * configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: New port to Altera NIOS II. 2006-08-08 Till Straumann <strauman@slac.stanford.edu> * libnetworking/rtems/rtems_mii_ioctl_kern.c: read ANER and include partner's autoneg capability when determining active link parameters. 2006-07-12 Till Straumann <strauman@slac.stanford.edu> PR 1110/networking * libnetworking/machine/in_cksum.h: Replaced PPC and i386 assembly algorithms (must not assume carry bit is preserved across multiple asms). Added packet header as a 'm' input operand for all CPU variants. Added carry bit to clobber list. 2006-07-12 Till Straumann <strauman@slac.stanford.edu> * pppd/sys-rtems.c: fixed error message so that the correct ioctl is reported. 2006-07-11 Joel Sherrill <joel@OARcorp.com> PR 1124/rtems * score/include/rtems/score/threadq.h, score/src/coremutexseize.c, score/src/coremutexsurrender.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c: The placement of the changing a thread's priority when using priority ceiling should be on the successful transfer of the mutex -- not when the thread tries to acquire. Plus the lack of a dispatch disable point lead to the potential for a thread timing out and already having inherited the ceiling priority. 2006-07-09 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de> * libblock/src/bdbuf.c: * libblock/include/bdbuf.h: (PR1118) fetch priority for swapout task from a variable, not a fixed configuration value. * libfs/src/imfs/imfs.h: * libfs/src/imfs/imfs_initsupp.c: (PR1118) fetch bytes_per_block value from a configuration variable, not from a preprocessor macro * sapi/include/confdefs.h: (PR1118) add configuration mechanisms for: - ATA task priority - swapout task priority - libblock basic configuration conditionally add ata driver to device driver table conditionally add ide driver to device driver table * libcsupport/include/sys/cdefs.h: * libnetworking/include/sys/linker_set.h: (PR1119) change attribute "unused" to "used" for sysctl data structures * libmisc/shell/shell.c: (PR1120) adapt stdio redirection to current newlib behaviour 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> * Makefile.am: Add ampolish3. 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> * ampolish3: New. * aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3. 2006-06-24 Ralf Corsépius <ralf.corsepius@rtems.org> * libnetworking/net/if_var.h: #include <sys/queue.h>. Cosmetics from FreeBSD. 2006-06-23 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/include/rtems/cdefs.h: Partial update from freebsd. 2006-06-22 Joel Sherrill <joel@OARcorp.com> PR 1101/rtems * libcsupport/src/base_fs.c: Remove extra endif. 2006-06-22 Joel Sherrill <joel@OARcorp.com> PR 1101/rtems * libcsupport/src/base_fs.c, rtems/src/taskcreate.c, rtems/src/tasks.c, score/src/coremutex.c: Remove dead code. 2006-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> * libcsupport/include/rtems/libio.h: Add extern "C" {}. 2006-06-18 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/src/mqueue.c: Remove duplicate #include <limits.h>. PR 1088/rtems * posix/src/ptimer.c: Add missing #include <limits.h>. 2006-06-08 Joel Sherrill <joel@OARcorp.com> * posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/timer.h, posix/src/ptimer.c, posix/src/ptimer1.c, sapi/src/posixapi.c, score/include/rtems/score/object.h: 2006-06-02 Joel Sherrill <joel@OARcorp.com> * itron/src/trcv_mbf.c, posix/src/semopen.c, rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix warnings. 2006-05-31 Eric Norum <norume@aps.anl.gov> * libnetworking/netinet/ip_icmp.c: Update icps_allecho counter. 2006-05-30 Eric Norum <norume@aps.anl.gov> * libnetworking/netinet/icmp_var.h, libnetworking/netinet/ip_icmp.c, libnetworking/rtems/rtems_showicmpstat.c: Add flag to inhibit ICMP replies. 2006-05-25 Eric Norum <norume@aps.anl.gov> * libnetworking/Makefile.am, libnetworking/Makefile.in, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c, libnetworking/rtems/rtems_malloc_mbuf.c: Provide customisable mbuf allocation. Patch from Steven Johnson <sjohnson@sakuraindustries.com> 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> * aclocal/rtems-ampolish.m4: New. * configure.ac: Use RTEMS_AMPOLISH3. 2006-04-27 Eric Norum <norume@aps.anl.gov> * telnetd/pty.c: Accept <CR><NUL> as equivalent to <CR><LF>. 2006-04-27 Eric Norum <norume@aps.anl.gov> * libmisc/capture/capture.h, libmisc/capture/capture.c Add ability to free information on task delete. 2006-04-18 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-4.6.99.3. 2006-04-13 Joel Sherrill <joel@OARcorp.com> PR 949/networking * libnetworking/sys/socket.h: GNU/Linux is wrong in making MSG_DONTWAIT public. It is strictly BSD and not SUSV. See http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html for clarification. 2006-04-12 Lars Munch <lars@segv.dk> PR 949/networking * libnetworking/sys/socket.h: Make MSG_DONTWAIT public as in GNU/Linux. 2006-04-06 Joel Sherrill <joel@OARcorp.com> * posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/timer.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/timer.inl: Fix warnings. * score/inline/rtems/score/threadmp.inl, score/macros/rtems/score/threadmp.inl: Fix compile error. 2006-04-05 Joel Sherrill <joel@OARcorp.com> Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru> * score/include/rtems/score/mpci.h, score/include/rtems/score/threadmp.h, score/inline/rtems/score/threadmp.inl, score/macros/rtems/score/threadmp.inl, score/src/threadmp.c, score/src/threadqenqueue.c: Victor spotted the problem that _MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate variables and needed to be set to the same value. I took that idea and just removed _Thread_MP_Receive. All uses are now _MPCI_Receive_server_tcb. 2006-03-27 Eric Norum <norume@aps.anl.gov> * libmisc/monitor/prmisc.c: Eliminate undesired sign-extension. 2006-03-08 Joel Sherrill <joel@OARcorp.com> PR 761/rtems * score/src/threadhandler.c: Add volatile cast so test is weak function is present will do something. Otherwise, it can be assume by gcc to always be a true condition. 2006-03-08 Joel Sherrill <joel@OARcorp.com> * itron/macros/rtems/itron/semaphore.inl, itron/macros/rtems/itron/task.inl: Fix warnings. * posix/macros/rtems/posix/cond.inl: Fix typo. * score/macros/rtems/score/heap.inl: Fix missed type change. 2006-03-07 Till Strauman <strauman@slac.stanford.edu> PR 830/filesystem * libcsupport/src/termios.c: termios ioctl(FIONREAD) reported wrong number of characters. So add chars in low-level/raw buffer to total count. 2006-03-07 Steven Johnson <sjohnson@sakuraindustries.com> PR 850/rtems * score/src/watchdogtickle.c: A Watchdog (used to timeout an event) with a delay of 1 sometimes does not seem to timeout. The problem occurs, because for whatever reason when the watchdog tickle function executes, the watchdog->delta_interval is 0. it is then decremented before being tested, becomes huge and so doesnt time out. It is thought there is a race condition where the watchdog->delta_interval is calculated by reference to a head (also with a delay of 1). But before it can be added after the head, the head is removed, so the new head now has a delay of 0. 2006-03-07 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de> PR 852/filesystem * libblock/src/bdbuf.c: Increase performance of MSDOS file accesses by using a simple read-ahead and write-combining scheme. Improvement is dramatic. 2006-03-07 Till Strauman <strauman@slac.stanford.edu> PR 886/filesystem * libcsupport/src/libio.c: fcntl(fd,F_GETFL) fails to set O_NONBLOCK if the descriptor is in non-blocking mode. 2006-03-07 Joel Sherrill <joel@OARcorp.com> PR 866/rtems * score/include/rtems/system.h, score/include/rtems/score/isr.h, score/inline/rtems/score/thread.inl, score/macros/rtems/score/thread.inl: Added memory barriers to enter and exit of dispatching and interrupt critical sections so GCC will not optimize and reorder code out of a critical section. 2006-02-08 Thomas Rauscher <trauscher@loytec.com> PR 890/networking * httpd/webs.c: The webservers enters an infinite loop when a POST request with less data than indicated in the Content-Length header is received. It also consumes additional heap memory and a file descriptor for each invalid POST. 2006-02-01 Joel Sherrill <joel@OARcorp.com> * posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl, posix/src/conddestroy.c: Remove warnings. 2006-02-01 Joel Sherrill <joel@OARcorp.com> * rtems/src/tasks.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c: Remove warnings. 2006-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/include/intr.h, posix/include/rtems/posix/intr.h posix/inline/rtems/posix/intr.inl. posix/macros/rtems/posix/intr.inl, posix/src/intr.c: Remove (Unused, dead). * posix/Makefile.am: Reflect changes above. Rework. 2006-01-18 Ralf Corsépius <ralf.corsepius@rtems.org> * posix/Makefile.am: Build devctl. 2006-01-16 Ralf Corsépius <ralf.corsepius@rtems.org> * rtems/Makefile.am: Rework. * score/Makefile.am: Rework. 2006-01-16 Joel Sherrill <joel@OARcorp.com> Large patch to improve Doxygen output. As a side-effect, grammar and spelling errors were corrected, spacing errors were address, and some variable names were improved. * libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h: Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS. * score/Doxyfile: Set output directory. Predefine some macro values. Turn on graphical output. * score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/tqdata.inl, score/macros/README, score/src/heap.c, score/src/threadmp.c, score/src/threadready.c, score/src/threadstartmultitasking.c: Improve generated Doxygen output. Fix spelling and grammar errors in comments. Correct names of some variables and propagate changes. 2006-01-16 Joel Sherrill <joel@OARcorp.com> Large patch to improve Doxygen output. As a side-effect, grammar and spelling errors were corrected, spacing errors were address, and some variable names were improved. * libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h: Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS. * score/Doxyfile: Set output directory. Predefine some macro values. Turn on graphical output. * score/cpu/arm/rtems/score/cpu.h, score/cpu/avr/rtems/score/cpu.h, score/cpu/c4x/rtems/score/cpu.h, score/cpu/h8300/rtems/score/cpu.h, score/cpu/m68k/rtems/score/cpu.h, score/cpu/mips/rtems/score/cpu.h, score/cpu/no_cpu/rtems/asm.h, score/cpu/no_cpu/rtems/score/cpu.h, score/cpu/no_cpu/rtems/score/types.h, score/cpu/powerpc/rtems/new-exceptions/cpu.h, score/cpu/powerpc/rtems/old-exceptions/cpu.h, score/cpu/powerpc/rtems/score/cpu.h, score/cpu/sh/rtems/score/cpu.h, score/cpu/sparc/rtems/score/cpu.h, score/cpu/unix/rtems/score/cpu.h, score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/tqdata.inl, score/macros/README, score/src/heap.c, score/src/threadmp.c, score/src/threadready.c, score/src/threadstartmultitasking.c: Improve generated Doxygen output. Fix spelling and grammar errors in comments. Correct names of some variables and propagate changes. 2006-01-15 Eric Norum <norume@aps.anl.gov> * posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mutex.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/mutex.inl: Keep compiler happy by making some casts explicit. 2006-01-13 Ralf Corsepius <ralf.corsepius@rtems.org> * Makefile.am: Remove doxygen support having accidentially slipped into, though yesterday's patch. 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> * Makefile.am, ftpd/Makefile.am, httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, score/cpu/arm/Makefile.am, score/cpu/avr/Makefile.am, score/cpu/c4x/Makefile.am, score/cpu/h8300/Makefile.am, score/cpu/i386/Makefile.am, score/cpu/m68k/Makefile.am, score/cpu/mips/Makefile.am, score/cpu/no_cpu/Makefile.am, score/cpu/powerpc/Makefile.am, score/cpu/sh/Makefile.am, score/cpu/sparc/Makefile.am, score/cpu/unix/Makefile.am, telnetd/Makefile.am, zlib/Makefile.am: Remove all-local:. 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/src/error.c: include and use inttypes.h. 2006-01-08 Joel Sherrill <joel@OARcorp.com> * libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting. 2006-01-08 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/unixlibc.c, libfs/src/imfs/ioman.c: Change rtems_io_register_name to take a const char *. 2006-01-08 Joel Sherrill <joel@OARcorp.com> * sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name to take a const char *. 2005-12-09 Till Straumann <strauman@slac.stanford.edu> PR 849/networking * librpc/src/rpc/rtems_portmapper.c: Increased stack size by ARGSIZE to prevent overrun. 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: New header guard for cpuopts.h. 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/Makefile.am: Re-add rtems/rtems_mii_ioctl.h, rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c. Add dev/mii/mii.h, net/if_media.h (Moved from c/src/libchip). * libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h: New (Moved from c/src/libchip). * libnetworking/rtems/rtems_mii_ioctl.h: Reflect mii.h and if_media.h having moved. 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> * automake/local.am: Remove depend. 2005-11-10 Ralf Corsepius <ralf.corsepius@rtems.org> * include/rtems/stdint.h: Disable RTEMS proprietary fixed-size types. 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Add RTEMS_NETWORKING to cpuopts.h. Add RTEMS_DEPRECATED_TYPES to config.h. Add AC_CONFIG_COMMANDS(preinstall-stamp) magic. Misc. cleanups. 2005-11-08 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/if.h: Add forward reference declaration to struct mbuf so ifru_tap callback is properly typed. * libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE which needs to be defined so various pieces of the .h files are visible to device drives. 2005-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/Makefile.am: Comment out using rtems/rtems_mii_ioctl.h, rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c. 2005-11-07 Michael Siers <mikes@poliac.com> * pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add missing copyright notice. 2005-11-06 Ralf Corsepius <ralf.corsepius@rtems.org> * libi2c/libi2c.c: Include config.h. * libi2c/libi2c.c, libi2c/libi2c.h, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c, score/src/heap.c: Eliminate obsolete types. 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org> * httpd/Makefile.am: Remove bogus noinst_LIBRARIES. 2005-11-02 Till Straumann <strauman@slac.stanford.edu> * libnetworking/Makefile.am, libnetworking/preinstall.am: Added simple implementation of ethernet media ioctl SIOCSIFMEDIA/SIOCGIFMEDIA for mii compliant phys. * libnetworking/rtems/rtems_mii_ioctl.c, libnetworking/rtems/rtems_mii_ioctl.h, libnetworking/rtems/rtems_mii_ioctl_kern.c: New files. 2005-11-02 Till Straumann <strauman@slac.stanford.edu> * libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c, libi2c/libi2c.h: New files. * Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a simple API/library for i2c devices and drivers for i2c 2-byte eeproms and a ds1621 temperature sensor; API is documented in libi2c.h 2005-11-02 Fredic Praca <freebsd-fr.org> PR 842/networking * libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename dprintf to debugprintf(). 2005-11-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/zlib.c: Remove. * libnetworking/net/zlib.h: Remove. * libnetworking/Makefile.am: Reflect changes above. 2005-11-01 Ralf Corsepius <ralf.corsepius@rtems.org> * pppd/Makefile.am: Fix typo. 2005-10-31 Ralf Corsepius <ralf.corsepius@rtems.org> PR 840/rtems: * include/rtems/irq.h: Fix several typos. 2005-10-30 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Add zlib. * Makefile.am: Add zlib. 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/zlib.h, libnetworking/net/zlib.c: Update from FreeBSD. * libnetworking/opt_ppp.h: New. * libnetworking/net/ppp.h: Remove. * libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c: Reflect changes above. Cosmetics from FreeBSD. * libnetworking/Makefile.am: Don't install loop.h. Add opt_ppp.h, remove net/ppp.h. * include/rtems/concat.h: Add EXPAND0, CONCAT0. 2005-10-27 Ralf Corsepius <ralf.corsepius@rtems.org> * telnetd/Makefile.am: Only build if LIBSHELL is available. 2005-10-26 Ralf Corsepius <ralf.corsepius@rtems.org> * pppd/Makefile.am, pppd/auth.c, pppd/chap.c, pppd/md5.c, pppd/md5.h, pppd/pppd.h: Misc. minor fixes. 2005-10-26 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Add pppd. * Makefile.am: Add pppd. 2005-10-26 Ralf Corsepius <ralf.corsepius@rtems.org> * pppd/Makefile.am: Install rtemsdialer.h, rtemspppd.h to $(includedir)/rtems. * pppd/ipxcp.c, pppd/ipxcp.h: Remove (Unused). * backward/rtemspppd.h, backward/rtemsdialer.h: New. * Makefile.am: Add backward/rtemspppd.h, backward/rtemsdialer.h. 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> * telnet/Makefile.am: Install libtelnetd.a. 2005-10-25 Eric Norum <norume@aps.anl.gov> * libnetworking/rtems/rtems_showifstat.c: Don't sign-extend address components. 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> * Makefile.am: Add telnetd. * configure.ac: Add telnetd. 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> * telnetd/icmds.c: Rename register_icmds to _rtems_telnet_register_icmds. Make main_* functions static. * telnetd/pty.c: Make many functions static. Rename rtems_telnetd_maximum_ptys to rtems_pty_maximum_ptys. * telnetd/pty.h: Reflect changes above. Rename get_pty to rtems_pty_get. New header guards. * telnetd/telnetd.c: Reflect changes above. * telnetd/telnetd.h: New header guards. 2005-10-25 Ralf Corsepius <ralf.corsepius@rtems.org> * telnet/telnet.h, telnet/telnet.c: Rename rtems_initialize_telnetd to rtems_telnetd_initialize, main_telnetd to rtems_telnetd_main, register_telnetd to rtems_telnetd_register. 2005-10-25 Joel Sherrill <joel@OARcorp.com> * sapi/include/confdefs.h, telnetd/pty.c, telnetd/pty.h: Attempt to fix MAX_PTYS and provide a real configuration entry. This should make telnetd some suitable for inclusion in cpukit. 2005-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/src/dosfs/msdos_misc.c: Revert to vers. 1.9. 2005-10-06 Joel Sherrill <joel@OARcorp.com> PR 828/filesystems * libfs/src/dosfs/msdos_misc.c: Problem retracted. Revert patch. 2005-10-04 Till Straumann <strauman@slac.stanford.edu> PR 829/rtems * rtems/src/tasks.c, rtems/src/taskvariabledelete.c: If task variables are deleted from a different context (i.e., executing context != owner of the task variable. The owner meaning the task that registered the dtor in question) the argument passed to the task variable dtor must be tvar and not *ptr which yields the executing task's value of the task variable instead of the owner's. 2005-09-29 Eric Norum <norume@aps.anl.gov> PR 835/rtems_misc * libmisc/cpuuse/cpuuse.c: Remove floating point calculations and the C preprocessor conditions which enabled them. 2005-09-25 Joel Sherrill <joel@OARcorp.com> * sapi/include/rtems/init.h, sapi/src/exinit.c: Remove unused and obsolete rtems_initialize_executive. 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/mount.h: Cosmetical update from FreeBSD. Remove non-implemented interfaces (vfs, nfs, fsstat, etc.). * configure.ac: Check for sys/errno.h. 2005-09-16 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/Makefile.am: Cosmetics. * libnetworking/nfs/rpcv2.h: Update from FreeBSD. * libnetworking/nfs/bootp_subr.c: Remove superfluous includes. * libnetworking/nfs/xdr_subs.h: Partial update from FreeBSD. * libnetworking/netinet/in.h: Partial update from FreeBSD. * libnetworking/nfs/nfsproto.h: Partial update from FreeBSD. 2005-09-02 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-4.6.99.2. 2005-09-01 Joel Sherrill <joel@OARcorp.com> PR 820/rtems * score/inline/rtems/score/coremsg.inl, score/macros/rtems/score/coremsg.inl, score/src/coremsginsert.c: Increment of pending message count should be atomic with insertion on the pending message chain. Determination of the need to call the notification handler should also be in this atomic section of code. 2005-09-01 Joel Sherrill <joel@OARcorp.com> PR 796/rtems * posix/src/semtimedwait.c: sem_timedwait is supposed to use absolute time for timeout specification. This patch is a modified version of the one suggested by Peter Dufault. 2005-09-01 Nuno Costa <nuno-costa@iol.pt> PR 804 * sapi/include/confdefs.h: Memory for POSIX timers not accounted for. Patch adapted from edit comment in PR filed. 2005-08-31 Ralf Corsepius <ralf.corsepius@rtems.org> PR 819/filesystem * libcsupport/src/ttyname_r.c: Remove. * libcsupport/src/ttyname.c: Partial update from FreeBSD. * libcsupport/Makefile.am: Reflect changes above. 2005-08-18 Andrew Sinclair <Andrew.Sinclair@elprotech.com> PR 807/rtems * rtems/src/timerfireafter.c, rtems/src/timerserverfireafter.c: First patch returned without exitting dispatching critical section. 2005-08-17 Nuno Costa <nuno-costa@iol.pt> PR 805/rtems * posix/include/rtems/posix/timer.h: Due to bad choice of error constants by original submitter, it was impossible to create more than 10 POSIX timers. 2005-08-17 Andrew Sinclair <Andrew.Sinclair@elprotech.com> PR 807/rtems * rtems/src/timerfireafter.c, rtems/src/timerserverfireafter.c, score/src/watchdoginsert.c: Tighten critical section checks on an ISR using the same timer being inserted by a lower priority ISR or interupt task. 2005-08-17 Nickolay Semyonov <snob@oktetlabs.ru> PR 744/filesystem * libcsupport/src/unlink.c, libfs/src/dosfs/msdos_eval.c: DOSFS did not support permissions on directories so the check performed by unlink would always fail. The unlink code was modified to support a not supported status being returned. 2005-08-15 Ralf Corsepius <ralf.corsepius@rtems.org> * posix/include/mqueue.h, posix/src/mqueuetimedreceive.c: ssize_t mq_timedreceive() (POSIX compliance). * wrapup/Makefile.am: Use librtemscpu_a_LIBRARIES. 2005-08-12 Chris Johns <chrisj@rtems.org> PR 808/rtems_misc * libcsupport/src/printk.c: Fix bug where specifying field width crashed on pc386 BSP. 2005-08-06 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/nfs/bootp_subr.c: Don't include nfs/nfs.h, nfs/krpc.h. 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Introduce msdos_status_t (dosfs statii are at least 32bit, not int). 2005-08-05 Ralf Corsepius <ralf.corsepius@rtems.org> * Makefile.am: Add libnetworking/memory.h * libnetworking/Makefile.am: Remove memory.h 2005-08-02 Ralf Corsepius <ralf.corsepius@rtems.org> PR 817/rtems * libcsupport/src/gxx_wrappers.c: Rename rtems_gxx_recursive_mutex_init_function to rtems_gxx_recursive_mutex_init. 2005-08-01 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/syslog.h: Partial update from FreeBSD. 2005-07-08 Eric Norum <norume@aps.anl.gov> * libcsupport/src/open.c: Pass along errno from failed ftruncate(). 2005-07-06 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/lib/syslog.c: Fix spelling mistake. * libnetworking/sys/uio.h: Partial update from FreeBSD. * libnetworking/kern/kern_subr.c: Reflect changes above. 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> PR 810/rtems * libblock/include/rtems/ide_part_table.h: Add C++ guards. 2005-06-17 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended dependencies added by the RTEMS specific tap interface. 2005-06-09 Jacques Seronie Vivien <jacques.seronievivien@astrium.eads.net> PR 790/rtems * sapi/src/extensioncreate.c, sapi/src/extensionident.c: Correct use of name. This was missed when the other ident services in rtems/src where changed. 2005-05-27 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if.h: Partial update from FreeBSD. * libnetworking/netinet/if_ether.h: Remove BYTE_PACK. * libnetworking/netinet/ip_var.h: Remove BYTE_PACK. * libnetworking/netinet/ip_divert.c: Fix broken comment. 2005-05-26 Joel Sherrill <joel@OARcorp.com> * libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/clnt.h, librpc/include/rpc/svc.h, src/rpc/pmap_rmt.c: Use void* instead of caddr_t. Cosmetics from FreeBSD. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/auth_des.h: Remove (Unused, unsupported). * librpc/include/rpc/rpc.h, librpc/Makefile.am: Reflect removing auth_des.h. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/rpc_com.h, librpc/include/rpc/rpc_msg.h, librpc/src/rpc/svc_simple.c: Minor fixes. * include/rpc/clnt.h, include/rpc/svc.h, librpc/include/rpc/clnt.h, librpc/include/rpc/clnt_soc.h, src/rpc/clnt_perror.c: More updates from FreeBSD. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/svc.h: Partial update from FreeBSD. * librpc/include/rpc/clnt.h: Partial update from FreeBSD. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/clnt_soc.h, librpc/include/rpc/svc_soc.h: New (Partial update from FreeBSD). * librpc/Makefile.am: Reflect changes above. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/des_crypt.h: Remove (Unused, unsupported). * librpc/Makefile.am: Reflect changes above. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/des.h: Remove (Unused, unsupported). * librpc/Makefile.am: Reflect changes above. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_time.c, librpc/src/rpc/authdes_prot.c, librpc/src/rpc/clnt_unix.c, librpc/src/rpc/crypt_client.c, librpc/src/rpc/des_crypt.c, librpc/src/rpc/des_soft.c, librpc/src/rpc/getpublickey.c, librpc/src/rpc/key_call.c, librpc/src/rpc/key_prot_xdr.c, librpc/src/rpc/svc_auth_des.c, librpc/src/rpc/svc_unix.c: Remove (Unused, obsolete). * librpc/Makefile.am: Reflect changes above. 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/src/rpc/PSD.doc/rpc.prog.ms, librpc/src/rpc/PSD.doc/rpcgen.ms, librpc/src/rpc/PSD.doc/nfs.rfc.ms, librpc/src/rpc/PSD.doc/xdr.rfc.ms, librpc/src/rpc/PSD.doc/rpc.rfc.ms, librpc/src/rpc/PSD.doc/xdr.nts.ms: Remove (Unused, obsolete). * librpc/Makefile.am: Reflect changes above. 2005-05-24 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/arpa/telnet.h: Remove (Unused, Non-POSIX/SUSV3). * libnetworking/Makefile.am: Reflect removing arpa/telnet.h. 2005-05-24 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/arpa/nameser.h: Update from FreeBSD. * libnetworking/libc/ns_parse.c: Reflect changes above. * libnetworking/netinet/ip.h: Remove BYTE_PACK. Add __packed. Partial update from FreeBSD. * libnetworking/netinet/ip_divert.c: Cosmetics from FreeBSD. 2005-05-23 Eric Norum <norume@aps.anl.gov> * libnetworking/rtems/rtems_showicmpstat.c * libnetworking/netinet/ip_icmp.c: note that a panic has been avoided 2005-05-23 Ralf Corsepius <ralf.corsepius@rtems.org> PR rtems_misc/795 * Makefile.am: Remove ada. * configure.ac: Remove ada. 2005-05-21 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/netinet/ip_icmp.c: Partial update from FreeBSD. * libnetworking/sys/mbuf.h: Partial update from FreeBSD. * libnetworking/netinet/ip_icmp.h: Update from FreeBSD. Abandon BYTE_PACK. * libnetworking/netdb.h: Update from FreeBSD. 2005-05-20 Sergei Organov <osv@javad.ru> PR networking/772. * libnetworking/rtems/rtems_select.c (socket_select): fixed bug setting SB_WAIT flag of so_rcv instead of so_snd when FWRITE. 2005-05-20 Sergei Organov <osv@topconrd.ru> PR 749/networking * libnetworking/rtems/rtems_showroute.c: Avoid NULL dereference. 2005-05-14 Sergei Organov <osv@topconrd.ru> PR 746/rtems Optimize realloc(). The problem is that realloc() can neither grow nor shrink efficiently the current memory region without support from underlying heap/region modules. The patch introduces one new routine for each of heap and region modules, _Heap_Resize_block(), and rtems_region_resize_segment(), respectively, and uses the latter to optimize realloc(). The implementation of _Heap_Resize_block() lead to changing of the heap allocation strategy: now the heap manager, when splits larger free block into used and new free parts, makes the first part of the block used, not the last one as it was before. Due to this new strategy, _Heap_Resize_block() never needs to change the user pointer. Caveat: unlike previous heap implementation, first few bytes of the contents of the memory allocated from the heap are now almost never all zero. This can trigger bugs in client code that have not been visible before this patch. * libcsupport/src/malloc.c (realloc): try to resize segment in place using new rtems_region_resize_segment() routine before falling back to the malloc()/free() method. * score/src/heap.c: (_Heap_Initialize): change initial heap layout to reflect new allocation strategy of using of the lower part of a previously free block when splitting it for the purpose of allocation. (_Heap_Block_allocate): when split, make the lower part used, and leave the upper part free. Return type changed from Heap_Block* to uint32_t. * score/include/rtems/score/heap.h: (Heap_Statistics): added 'resizes' field. (Heap_Resize_status): new enum. (_Heap_Resize_block): new routine. (_Heap_Block_allocate): return type changed from Heap_Block* to uint32_t. * score/src/heapwalk.c: reflect new heap layout in checks. * score/src/heapsizeofuserarea.c: more assertions added. * score/src/heapresizeblock.c: new file. (_Heap_Resize_block): new routine. * score/src/heapfree.c: reverse the checks _Heap_Is_block_in() and _Heap_Is_prev_used() on entry to be in this order. * score/src/heapallocate.c, score/src/heapallocatealigned.c: ignore return value of _Heap_Block_allocate(). * score/Makefile.am (HEAP_C_FILES): added src/heapresizeblock.c. * rtems/include/rtems/rtems/region.h: (rtems_region_resize_segment): new interface routine. (_Region_Process_queue): new internal routine called from rtems_region_resize_segment() and rtems_region_return_segment(). * rtems/src/regionreturnsegment.c: move queue management code into the new internal routine _Region_Process_queue() and call it. * rtems/src/regionresizesegment.c: new file. (rtems_region_resize_segment): new interface routine. * rtems/src/regionprocessqueue.c: new file. (_Region_Process_queue): new internal routine containing queue management code factored out from 'regionreturnsegment.c'. * rtems/Makefile.am (REGION_C_FILES): Added src/regionresizesegment.c, and src/regionprocessqueue.c. * ada/rtems.adb, ada/rtems.ads: Added Region_Resize_Segment. 2005-05-20 Eric Norum <norume@aps.anl.gov> PR 793/networking * libnetworking/netinet/ip_icmp.c: Malicious ICMP packet causes panic. Just ignore it. 2005-05-18 Chris Johns <chrisj@rtems.org> * libmisc/capture/capture-cli.c: Fix the output of ctload when there exists a large number of tasks. 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com> * Makefile.am, preinstall.am: Added a common irq.h * include/rtems/irq.h: New file. 2005-05-14 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/netinet/tcp_usrreq.c: Cosmetics from FreeBSD. * libnetworking/netinet/tcp_subr.c: Partical update from FreeBSD. 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Let --enable-deprecated default to "no". * libnetworking/net/if_arp.h: Remove BYTE_PACK. * libnetworking/net/if_llc.h: Update from FreeBSD, add __packed. * libnetworking/net/route.h: Partial update from FreeBSD. * libnetworking/netinet/if_ether.c: Partial update from FreeBSD. * libnetworking/netinet/tcp_var.h: Partial update from FreeBSD. * libnetworking/netinet/tcp_input.c: Reflect changes to tcp_var.h. * libnetworking/netinet/tcp.h: Partial update from FreeBSD. Remove BYTE_PACK. * libnetworking/netinet/ip_var.h: Partial update from FreeBSD. Remove some useless BYTE_PACKs. 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> PR 784/networking * libnetworking/net/if_arp.h, libnetworking/netinet/if_ether.h, libnetworking/netinet/ip_icmp.h, libnetworking/netinet/ip_var.h, libnetworking/netinet/tcp.h: Define BYTE_PACK. 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/rtsock.c: Abandon AF_NS. * libnetworking/sys/socket.h: Abandon AF_NS, PF_NS. 2005-05-10 Ralf Corsepius <ralf.corsepius@rtems.org> * httpd/socket.c: socklen_t. * librpc/include/rpc/svc.h: Cosmetical update from FreeBSD. * librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtime.c, librpc/src/rpc/svc_tcp.c, librpc/src/rpc/svc_udp.c: socklen_t. * ftpd/ftpd.c: socklen_t. * libnetworking/lib/rtems_bsdnet_ntp.c: socklen_t. * libnetworking/libc/rcmd.c: socklen_t. * libnetworking/libc/res_send.c: socklen_t. 2005-05-10 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if.h: Remove IFI_* (obsolete, unused). * libnetworking/net/if_var.h: Remove if_ipending (obsolete, unused). 2005-05-09 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/un.h: Partial update from FreeBSD. Remove non-implemented functions/variables. 2005-05-09 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/rtems/bsdnet/_types.h: New. * Makefile.am: Add rtems_bsdnet_HEADERS. * libnetworking/Makefile.am: Remove rtems_bsdnet_HEADERS. * preinstall.am, libnetworking/preinstall.am: Regenerate. * libcsupport/include/sys/cdefs.h: Partial update from FreeBSD. * libnetworking/arpa/inet.h: Partial update from FreeBSD. * libnetworking/netinet/in.h: Partial update from FreeBSD. * libnetworking/sys/socket.h: Partial update from FreeBSD. * librpc/src/rpc/bindresvport.c: socklen_t. * libnetworking/sys/mbuf.h: Ansification. * libnetworking/kern/uipc_mbuf.c: Partial update from FreeBSD. * libnetworking/libc/inet_addr.c: in_addr_t. * libnetworking/lib/tftpDriver.c: socklen_t. * libnetworking/libc/inet_lnaof.c: in_addr_t. * libnetworking/libc/inet_makeaddr.c: in_addr_t. * libnetworking/libc/inet_netof.c: in_addr_t. * libnetworking/libc/inet_network.c: in_addr_t. * libnetworking/libc/inet_ntop.c: Ansify, socklen_t. * libnetworking/lib/ftpfs.c: socklen_t, PRIu32. 2005-05-08 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/arpa/inet.h: Add in_addr_t, in_port_t. * libnetworking/netinet/in.h: Sync in_port_t with arpa/inet.h. * libnetworking/sys/socket.h: Include <sys/types.h>. Remove in_port_t. Misc. updates from FreeBSD. 2005-05-08 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/netinet/in.h: Partial update from FreeBSD. Remove BYTE_PACK. * libnetworking/netinet/ip.h: Add BYTE_PACK. * libnetworking/sys/socket.h: Partial update from FreeBSD. 2005-05-08 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/netinet/if_ether.c: Cosmetics from FreeBSD. * libnetworking/libc/inet_addr.c: Cosmetics from FreeBSD. * libnetworking/netinet/in.h: Cosmetics from FreeBSD. * libnetworking/sys/socket.h: Cosmetics from FreeBSD. 2005-05-07 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/un.h: Cosmetical updates from FreeBSD. * libnetworking/net/if_var.h: More partial updates from FreeBSD. * libnetworking/rtems/rtems_bsdnet.h: Eliminate rtems_* fixed size types. 2005-05-06 Joel Sherrill <joel@OARcorp.com> * libnetworking/rtems/rtems_showifstat.c: Remove warning. * libnetworking/net/if.h: Revert include of sys/mbuf.h in this .h file since it causes other problems. 2005-05-06 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/termios.c: Removed warnings. 2005-05-06 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/if.h, libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c: Removed warnings. 2005-05-06 Joel Sherrill <joel@OARcorp.com> * libblock/src/blkdev.c, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c: Removed warnings. 2005-05-04 Jennifer Averett <jennifer.averett@oarcorp.com> * include/rtems/pci.h: Name change to support common PCI interface 2005-05-03 Joel Sherrill <joel@OARcorp.com> * libcsupport/include/ringbuf.h: Use uint8_t instead of char for raw data buffer. 2005-05-03 Joel Sherrill <joel@OARcorp.com> PR 775/core * rtems/src/regiongetfreeinfo.c: Return RTEMS_SUCCESSFUL instead of RTEMS_INVALID_ADDRESS on success path. 2005-05-03 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c: Use uint8_t instead of char for raw data buffer. 2005-05-01 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/kern/kern_mib.c, libnetworking/sys/libkern.h: Update from FreeBSD. 2005-04-30 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: fix evaluating --enable-ada. 2005-04-29 Jennifer Averett <jennifer.averett@oarcorp.com> * score/src/objectidtoname.c: Removed warnings 2005-04-28 Joel Sherrill <joel@OARcorp.com> * libnetworking/kern/kern_sysctl.c, libnetworking/libc/inet_ntop.c, libnetworking/net/if_ppp.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/ip_output.c, libnetworking/netinet/udp_usrreq.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_select.c, libnetworking/rtems/rtems_showifstat.c, libnetworking/rtems/rtems_showroute.c, libnetworking/rtems/rtems_syscall.c: Fixed type mismatch and uninitialized variable warnings. 2005-04-28 Joel Sherrill <joel@OARcorp.com> * score/src/objectidtoname.c: Fixed spacing. 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com> * score/src/objectidtoname.c: Add enable dispatch 2005-04-28 Jennifer Averett <jennifer.averett@oarcorp.com> * configure.ac: Remove or32-rtems 2005-04-23 Ralf Corsepius <ralf.corsepius@rtems.org> * score/cpu/Makefile.am: Remove or32 (target abandoned). 2005-04-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if.h: Update from FreeBSD. * libnetworking/net/if_loop.c: Reflect updates. * libnetworking/net/if_ppp.c: Reflect updates. * libnetworking/net/if_types.h: Update from FreeBSD. * libnetworking/net/ethernet.h: Add RTEMS outdated either_input. * libnetworking/net/if.c: Partial update from FreeBSD. * libnetworking/net/if_ethersubr.c: Partial update from FreeBSD. * libnetworking/net/if_var.h: New (extracted from net/if.h). * libnetworking/Makefile.am: Add net/if_var.h. 2005-04-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if.c, libnetworking/net/if.h, libnetworking/sys/mbuf.h: Cosmetics from FreeBSD. 2005-04-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/mount.h: More updates from FreeBSD. Remove ufs, mfs, dosfs, isofs. * libnetworking/nfsclient/nfsargs.h: More updates from FreeBSD. 2005-04-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/rtsock.c: More updates from FreeBSD. 2005-04-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/mount.h: Remove nfs_args. * libnetworking/nfsclient/nfsargs.h: New (extracted from sys/mount.h). * libnetworking/nfsclient/nfsdiskless.h: New (Relocated from nfs/). * libnetworking/nfs/nfsdiskless.h: Remove. * libnetworking/net/netisr.h: Partial update from FreeBSD. * libnetworking/net/rtsock.c: Cosmetical update from FreeBSD. * libnetworking/sys/socket.h: Cosmetical update from FreeBSD. * libnetworking/sys/queue.h: Cosmetical update from FreeBSD. Remove special casing of arm/mips. * libnetworking/nfs/bootp_subr.c: Reflect having introduced nfsclient/. * libnetworking/Makefile.am: Remove changes above. 2005-04-15 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if_arp.h, libnetworking/netinet/ip.h, libnetworking/netinet/ip_icmp.c: Partial updates from FreeBSD. 2005-04-14 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if_arp.h, libnetworking/net/if_ethersubr.c, libnetworking/netinet/if_ether.h, libnetworking/netinet/in.h: Partial updates from FreeBSD. 2005-04-14 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/arpa/inet.h, libnetworking/net/if_dl.h: Cosmetical update from FreeBSD. 2005-04-09 Ralf Corsepius <ralf.corsepius@rtems.org> * libmisc/monitor/mon-symbols.c: size_t. 2005-03-14 Joel Sherrill <joel@OARcorp.com> * include/rtems/pci.h: Continue PCI API unification. All use pci_find_device(). 2005-03-14 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> * libnetworking/netinet/in_cksum_m68k.h: Change back to lcsum[12]_lbl to temporary labels. 2005-03-10 Joel Sherrill <joel@OARcorp.com> * libnetworking/netinet/in_cksum_m68k.h: Change back to lcsum[12]_lbl since my fix did not fix all issues. 2005-03-05 Joel Sherrill <joel@OARcorp.com> * libnetworking/netinet/in_cksum_m68k.h: Change lcsum[12]_lbl to temporary inline assembly labels to remove compilation error. 2005-03-04 Joel Sherrill <joel@OARcorp.com> * include/rtems/pci.h: Clean up and reformatting. Make PCI initialize function part of the unified PCI API. 2005-03-04 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Check for newlib with stdint.h/inttypes.h. * Makefile.am: Conditionally use external stdint.h/inttypes.h for newlib. 2005-02-22 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/rtems-top.m4: Rework rtems_updir handling to work around ash cd'ing to '/' for 'cd .//'. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> PR 764/networking * libnetworking/sys/sysctl.h: include <rtems/stdint.h>. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/mppkt.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/objectmp.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/states.inl, score/inline/rtems/score/sysstate.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/threadmp.inl, score/inline/rtems/score/tod.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/watchdog.inl, score/inline/rtems/score/wkspace.inl, score/macros/rtems/score/address.inl, score/macros/rtems/score/chain.inl, score/macros/rtems/score/coremsg.inl, score/macros/rtems/score/coremutex.inl, score/macros/rtems/score/coresem.inl, score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl, score/macros/rtems/score/mppkt.inl, score/macros/rtems/score/object.inl, score/macros/rtems/score/objectmp.inl, score/macros/rtems/score/priority.inl, score/macros/rtems/score/stack.inl, score/macros/rtems/score/states.inl, score/macros/rtems/score/sysstate.inl, score/macros/rtems/score/thread.inl, score/macros/rtems/score/threadmp.inl, score/macros/rtems/score/tod.inl, score/macros/rtems/score/tqdata.inl, score/macros/rtems/score/userext.inl, score/macros/rtems/score/watchdog.inl, score/macros/rtems/score/wkspace.inl: New header guards. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * rtems/inline/rtems/rtems/asr.inl, rtems/inline/rtems/rtems/attr.inl, rtems/inline/rtems/rtems/dpmem.inl, rtems/inline/rtems/rtems/event.inl, rtems/inline/rtems/rtems/eventset.inl, rtems/inline/rtems/rtems/message.inl, rtems/inline/rtems/rtems/modes.inl, rtems/inline/rtems/rtems/options.inl, rtems/inline/rtems/rtems/part.inl, rtems/inline/rtems/rtems/ratemon.inl, rtems/inline/rtems/rtems/region.inl, rtems/inline/rtems/rtems/sem.inl, rtems/inline/rtems/rtems/status.inl, rtems/inline/rtems/rtems/support.inl, rtems/inline/rtems/rtems/tasks.inl, rtems/inline/rtems/rtems/timer.inl, rtems/macros/rtems/rtems/asr.inl, rtems/macros/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/dpmem.inl, rtems/macros/rtems/rtems/event.inl, rtems/macros/rtems/rtems/eventset.inl, rtems/macros/rtems/rtems/message.inl, rtems/macros/rtems/rtems/modes.inl, rtems/macros/rtems/rtems/options.inl, rtems/macros/rtems/rtems/part.inl, rtems/macros/rtems/rtems/ratemon.inl, rtems/macros/rtems/rtems/region.inl, rtems/macros/rtems/rtems/sem.inl, rtems/macros/rtems/rtems/status.inl, rtems/macros/rtems/rtems/support.inl, rtems/macros/rtems/rtems/tasks.inl, rtems/macros/rtems/rtems/timer.inl: New header guards. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * itron/inline/rtems/itron/eventflags.inl, itron/inline/rtems/itron/fmempool.inl, itron/inline/rtems/itron/intr.inl, itron/inline/rtems/itron/mbox.inl, itron/inline/rtems/itron/msgbuffer.inl, itron/inline/rtems/itron/network.inl, itron/inline/rtems/itron/port.inl, itron/inline/rtems/itron/semaphore.inl, itron/inline/rtems/itron/sysmgmt.inl, itron/inline/rtems/itron/task.inl, itron/inline/rtems/itron/time.inl, itron/inline/rtems/itron/vmempool.inl, itron/macros/rtems/itron/eventflags.inl, itron/macros/rtems/itron/fmempool.inl, itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl, itron/macros/rtems/itron/msgbuffer.inl, itron/macros/rtems/itron/network.inl, itron/macros/rtems/itron/port.inl, itron/macros/rtems/itron/semaphore.inl, itron/macros/rtems/itron/sysmgmt.inl, itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl, itron/macros/rtems/itron/vmempool.inl: New header guards. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/intr.inl, posix/inline/rtems/posix/key.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/intr.inl, posix/macros/rtems/posix/key.inl, posix/macros/rtems/posix/mqueue.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/priority.inl, posix/macros/rtems/posix/pthread.inl, posix/macros/rtems/posix/semaphore.inl, posix/macros/rtems/posix/timer.inl: New header guards. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * posix/include/aio.h, posix/include/devctl.h, posix/include/intr.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/condmp.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mqueuemp.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/mutexmp.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/pthreadmp.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/semaphoremp.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h: New header guards. 2005-02-21 Ralf Corsepius <ralf.corsepius@rtems.org> * backward/asm.h, backward/chain.h, backward/clockdrv.h, backward/confdefs.h, backward/console.h, backward/dosfs.h, backward/ftpd.h, backward/imfs.h, backward/iosupp.h, backward/itron.h, backward/ringbuf.h, backward/rtc.h, backward/spurious.h, backward/timerdrv.h, backward/vmeintr.h, backward/motorola/mc68230.h, backward/motorola/mc68681.h, backward/zilog/z8030.h, backward/zilog/z8036.h, backward/zilog/z8536.h: New header guards. 2005-02-19 Joel Sherrill <joel@OARcorp.com> PR doc/763 * score/Doxyfile: Fixed path to no_cpu. 2005-02-19 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Check for external ampolish3. 2005-02-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/vm/vm_extern.h, libnetworking/vm/vm_kern.h: Update from FreeBSD. 2005-02-17 Joel Sherrill <joel@OARcorp.com> * include/rtems/pci.h: Merge differences from libbsp/powerpc/shared/pci/pci.h. 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/vm/vm_param.h: Update from FreeBSD. 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libblock/include/rtems/diskdevs.h: Use uint32_t for ictrl req argument (16bit target compliance). 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libblock/include/rtems/ramdisk.h: size_t rtems_ramdisk_configuration_size. * libblock/src/ramdisk.c: Adaptations for 16bit target compliance. 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/sys/sysctl.h (struct sysctl_oid): uint32_t oid_kind (16bit target compliance). 2005-02-12 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Remove LIBSCORECPU. * wrapup/Makefile.am: Reflect changes above. 2005-02-10 Joel Sherrill <joel@OARcorp.com> PR 753/rtems * score/include/rtems/score/object.h, score/src/objectinitializeinformation.c: Configured number of objects needs to be of a type with more bits than Objects_Maximum to support configuring unlimited objects. The type for configuring the maximum number of objects should probably always be the same fundamental type as Object Id. For 16-bit Id configurations, the constant OBJECTS_UNLIMITED_OBJECTS was changed to 0x8000 to move in this direction. 2005-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> * libmisc/untar/untar.c (_rtems_octal2ulong): Replace. 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * ftpd/Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * ftpd/preinstall.am: New (Generated from corresponding Makefile.am). 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * librpc/preinstall.am: New (Generated from corresponding Makefile.am). 2005-02-08 Eric Norum <norum@aps.anl.gov> * libfs/Makefile.am, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/memfile.c, libfs/src/imfs/miniimfs_init.c: Add 'copy-on-write' semantics to rtems_tarfs_load(). 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * httpd/Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * httpd/preinstall.am: New (Generated from corresponding Makefile.am). 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * itron/Makefile.am, libcsupport/Makefile.am, libnetworking/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, wrapup/Makefile.am, Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * itron/preinstall.am, libcsupport/preinstall.am, libnetworking/preinstall.am, posix/preinstall.am, rtems/preinstall.am, sapi/preinstall.am, score/preinstall.am, wrapup/preinstall.am, preinstall.am: New (Generated from corresponding Makefile.ams). * configure.ac: Add AM_CONDITIONAL(AMPOLISH3)-stub. 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * configure.ac: Add new header guard to cpuopts.h. * Makefile.am: Add libfs, libblock, ftpd header install rules. * libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove header install rules. 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/rtems-top.m4 (rtems_updir): Quote sed args. 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h: Ansification, cosmetics from FreeBSD. 2005-02-07 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.c, libmisc/untar/untar.h: Various generalizations and fixes. 2005-02-07 Ralf Corsepius <ralf.corsepius@rtems.org> * Makefile.am: Add include/rtems/tar.h. Merge-in header rules from libmisc/Makefile.am * libmisc/Makefile.am: Remove header rules. Remove lib-specific CPPFLAGS. * configure.ac: Add checks for <tar.h> 2005-02-07 Ralf Corsepius <ralf.corsepius@rtems.org> * include/rtems/tar.h: New. 2005-02-05 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/Makefile.am: Build libfs/src/imfs/imfs_load_tar.c. 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/libc/res_init.c, libnetworking/netinet/in.h, libnetworking/netinet/in_pcb.c, libnetworking/netinet/raw_ip.c: Misc. part. updates from FreeBSD. 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> * automake/compile.am: Remove depend: (Redundant). 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> * rtems/include/rtems/rtems/sem.h, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semobtain.c, rtems/src/semrelease.c: Use rtems_id for semaphores. 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/rtems/libio.h: Use rtems_id for semaphores. Use char* for buffer. * backward/ftpd.h: New. * Makefile.am: Reflect having added backward/ftpd.h. 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> PR 756/rtems * ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from /c/src/libnetworking/ftpd) * ftpd/ftd.h: New header guards. * ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h. * configure.ac: Add ftpd/Makefile. * Makefile.am: Add ftpd. 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/clnt_stat.h, librpc/include/rpc/rpcent.h: New (From FreeBSD). * librpc/include/rpc/rpc.h: Partial update from FreeBSD. * librpc/Makefile.am: Reflect changes above. 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/types.h: Partial update from FreeBSD. Use stdint.h types instead of sys/types.h. * librpc/src/rpc/bindresvport.c: Partial update from FreeBSD. 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> PR 755/rtems * libnetworking/libc/res_init.c, libnetworking/lib/rtems_bsdnet_ntp.c, libnetworking/nfs/bootp_subr.c: Include <rtems/bsdnet/servers.h>. 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> PR 755/rtems * libnetworking/rtems_glue.c: Rename rtems_bsdnet_nameservers to _rtems_bsdnet_nameservers. Rename rtems_bsdnet_ntpservers to _rtems_bsdnet_ntpservers. Add new rtems_bsdnet_nameservers, rtems_bsdnet_ntpservers as pointers to _rtems_bsdnet_*servers arrays. * libnetworking/rtems/rtems_bsdnet_internal.h: Remove rtems_bsdnet_nameserver, rtems_bsdnet_nameserver_count. * libnetworking/rtems/rtems_bsdnet.h: Remove rtems_bsdnet_ntpserver, rtems_bsdnet_ntp_count. * libnetworking/rtems/bsdnet/servers.h: New. * libnetworking/opt_ipsec.h: New (BSD compatibility). * libnetworking/Makefile.am: Reflect changes above. 2005-02-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/rtems/ftpfs.h, libnetworking/rtems/mkrootfs.h, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/tftp.h: New header guards. 2005-02-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/rtems/issetugid.c, libnetworking/rtems/mkrootfs.c, libnetworking/rtems/rtems_bootp.c, libnetworking/rtems/rtems_bsdnet_malloc_starvation.c, libnetworking/rtems/rtems_glue.c, libnetworking/rtems/rtems_select.c, libnetworking/rtems/rtems_showicmpstat.c, libnetworking/rtems/rtems_showifstat.c, libnetworking/rtems/rtems_showipstat.c, libnetworking/rtems/rtems_showmbuf.c, libnetworking/rtems/rtems_showroute.c, libnetworking/rtems/rtems_showtcpstat.c, libnetworking/rtems/rtems_showudpstat.c, libnetworking/rtems/rtems_syscall.c, libnetworking/rtems/sghostname.c: Include config.h. 2005-02-01 Joel Sherrill <joel@OARcorp.com> * libblock/include/rtems/bdbuf.h, libblock/include/rtems/ide_part_table.h, libblock/src/blkdev.c, libcsupport/include/rtems/termiostypes.h, libcsupport/src/termios.c, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/mutex.inl : Remove warnings. 2005-02-01 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/prog-cc.m4: Remove refs to gcc-isystem.m4. * aclocal/gcc-isystem.m4: Remove (Unused). 2005-01-28 Eric Norum <norume@aps.anl.gov> * libnetworking/rtems/rtems_glue.c: Remove dead variable. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * itron/include/itron.h, itron/include/itronsys/eventflags.h, itron/include/itronsys/fmempool.h, itron/include/itronsys/intr.h, itron/include/itronsys/mbox.h, itron/include/itronsys/msgbuffer.h, itron/include/itronsys/network.h, itron/include/itronsys/port.h, itron/include/itronsys/semaphore.h, itron/include/itronsys/status.h, itron/include/itronsys/sysmgmt.h, itron/include/itronsys/task.h, itron/include/itronsys/time.h, itron/include/itronsys/types.h, itron/include/itronsys/vmempool.h, itron/include/rtems/itron/config.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/intr.h, itron/include/rtems/itron/itronapi.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/network.h, itron/include/rtems/itron/object.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/sysmgmt.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/time.h, itron/include/rtems/itron/vmempool.h: New header guards. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * libblock/include/rtems/bdbuf.h, libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h, libblock/include/rtems/ide_part_table.h, libblock/include/rtems/ramdisk.h, libfs/src/dosfs/dosfs.h, libfs/src/imfs/imfs.h: New header guards. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/inttypes.h: New header guard. Fix doxygen preamble. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/motorola/mc68230.h, libcsupport/include/motorola/mc68681.h, libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/ringbuf.h, libcsupport/include/rtc.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/rtems/cdefs.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h: New header guards. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/fs.h, include/rtems/pci.h, include/rtems/stdint.h, include/rtems/userenv.h: New header guards. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h, rtems/include/rtems/rtems/eventmp.h, rtems/include/rtems/rtems/eventset.h, rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/options.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h, rtems/include/rtems/rtems/signalmp.h, rtems/include/rtems/rtems/status.h, rtems/include/rtems/rtems/support.h, rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/include/rtems/mptables.h, sapi/include/rtems/sptables.h, score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/copyrt.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h: New header guard. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * automake/compile.am: Remove RTEMS_CPPFLAGS. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if_pppvar.h: Ansify. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * include/rtems/userenv.h: Set up LOGIN_NAME_MAX iff not having been defined before. 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> * sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c: Include config.h. 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/src/lstat.c, libcsupport/src/readdir_r.c: Include config.h. 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org> * libmisc/untar/untar.h: New prototype to eleminate warnings. * libmisc/untar/untar.c: Cosmetics, add symlinks. 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/tar.h: New (SUSv3). * Makefile.am: Integrate newlib-specific headers. Add libcsupport/include/tar.h. * libcsupport/Makefile.am: Remove newlib-specific headers. 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org> * libmisc/fsmount/fsmount.c: Include config.h. 2005-01-27 Ralf Corsepius <ralf.corsepius@rtems.org> * score/src/apiext.c, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/coremutexsurrender.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemseize.c, score/src/coresemsurrender.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c, score/src/interr.c, score/src/isr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadcreateidle.c, score/src/threaddelayended.c, score/src/threaddispatch.c, score/src/threadevaluatemode.c, score/src/threadget.c, score/src/threadhandler.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqtimeout.c, score/src/threadready.c, score/src/threadreset.c, score/src/threadresettimeslice.c, score/src/threadrestart.c, score/src/threadresume.c, score/src/threadrotatequeue.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/threadstart.c, score/src/threadstartmultitasking.c, score/src/threadsuspend.c, score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c, score/src/userext.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c, score/src/wkspace.c: Include config.h. 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> * include/rtems/stdint.h: Add signed8, signed16, signed32, unsigned8, unsigned16, unsigned32. 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> * score/include/rtems/score/heap.h: Use uintptr_t for _H_uptr_t. * score/inline/rtems/score/address.inl: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES. Use uintptr_t for void* to address casts. 2005-01-24 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/stdint.h: Use __PTRDIFF_TYPE__ for intptr_t. 2005-01-23 Ralf Corsepius <ralf.corsepius@rtems.org> * sapi/src/fatal.c, score/src/interr.c: Remove volatile on return type. 2005-01-20 Sergei Organov <osv@topconrd.ru> PR 536/rtems Heap manager re-implementation to consume less memory and still satisfy alignment requirements. * score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetinfo.c, score/src/heapgetfreeinfo.c, core/src/heapsizeofuserarea.c, score/src/heapwalk.c, core/macros/rtems/score/heap.inl, score/inline/rtems/score/heap.inl, score/include/rtems/score/heap.h: Reimplemented. * score/src/heapallocatealigned.c: new file * score/Makefile.am: HEAP_C_FILES: add score/src/heapallocatealigned.c 2005-01-20 Joel Sherrill <joel@OARcorp.com> PR 745/rtems * rtems/src/ratemoncreate.c, rtems/src/timercreate.c: Make sure internal timer structures are initialized so object control reuse is safe. 2005-01-20 Joel Sherrill <joel@OARcorp.com> PR 740/rtems * score/src/heapgetfreeinfo.c: Return size of largest not of last block. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/src/dosfs/fat.c (fat_init_volume_info): Reflect fs_info->sec_buf being a uint8_t. * libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c: Eliminate warnings. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/src/dosfs/msdos_misc.c (msdos_get_dotdot_dir_info_cluster_num_and_offset): Remove cur_node (Unused). 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/src/termios.c: Remove unnecessary type casts. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * sapi/include/rtems/io.h : size_t device_name_length. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * sapi/include/rtems/fatal.h, score/include/rtems/score/interr.h: Remove volatile on return type. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * itron/inline/rtems/itron/task.inl (_ITRON_Task_Priority_to_Core, _ITRON_tasks_Core_to_Priority): Correct return types. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * rtems/src/attr.c, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/clocktick.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/intr.c, rtems/src/intrbody.c, rtems/src/intrcatch.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqsubmit.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionreturnsegment.c, rtems/src/rtclock.c, rtems/src/rtemsidtoname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmode.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserver.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c: Include config.h. 2005-01-18 Ralf Corsepius <ralf.corsepius@rtems.org> * score/inline/rtems/score/userext.inl: Include <string.h>. 2005-01-14 Ralf Corsepius <ralf.corsepius@rtems.org> PR 742/rtems * score/include/rtems/system.h: Remove stringify(). 2005-01-13 Joel Sherrill <joel@oarcorp.com> Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/src/gxx_wrapper.c: Reflect GCC-4.0's gthr-rtems.h. 2005-01-09 Joel Sherrill <joel@oarcorp.com> * librpc/include/rpc/clnt.h, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/pmap_prot2.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc_simple.c: Fix warnings. 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/auth_des.h, librpc/include/rpc/xdr.h, librpc/src/rpc/auth_des.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/rpc_prot.c, librpc/src/xdr/xdr.c: Misc. ansi-fications, misc. updates from FreeBSD. 2005-01-07 Joel Sherrill <joel@OARcorp.com> * libnetworking/libc/res_debug.c: Added const to eliminate warnings. 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/xdr.h: Remove questionable comments. * librpc/include/rpc/auth.h: Remove __P, ansi-fy. * librpc/src/rpc/auth_none.c: Reflect changes above. Partial update from FreeBSD. 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> * posix/include/rtems/posix/cond.h, posix/include/rtems/posix/mutex.h: Cosmetics. 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/svc.h, librpc/include/rpc/xdr.h: Remove __P(xx). 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> * httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/rtems-flags.m4: Remove (Unused). 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/prog-ccas.m4: Remove $(GCCSPECS). 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> * rtems/src/eventsurrender.c: Remove bogus type casts. * sapi/Makefile.am: Eliminate *_FILES. 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V. Remove CPU_CFLAGS. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE. Cleanup comments. 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/env-rtemscpu.m4: Remove CFLAGS_DEBUG_V. * aclocal/prog-cc.m4: Remove RTEMS_USE_GCC. * automake/compile.am: Cleanup comments. Remove ASFLAGS. 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> * automake/compile.am, httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, wrapup/Makefile.am: Remove build-variant support. 2004-12-30 Ralf Corsepius <ralf.corsepius@rtems.org> * httpd/Makefile.am: Remove -DOS="RTEMS". * httpd/rtems_webserver.h: Add doxygen preamble. Add C++ guards. 2004-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> * score/include/rtems/score/chain.h: Use uint32_t instead of unsigned32. * score/src/chain.c: Remove superfluous type cast. 2004-12-10 Ralf Corsepius <ralf.corsepius@rtems.org> * posix/include/aio.h, posix/include/devctl.h, posix/include/intr.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/src/ptimer.c, posix/src/ptimer1.c: Include <unistd.h> instead of <sys/features.h> to pick up _POSIX_* defines (Mandated by POSIX). 2004-12-09 Ralf Corsepius <ralf.corsepius@rtems.org> * score/include/rtems/system.h: Don't define NULL, include <stddef.h>. 2004-12-03 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/if_ethersubr.c, libnetworking/net/radix.h, libnetworking/netinet/if_ether.h, libnetworking/netinet/igmp_var.h, libnetworking/netinet/in_var.h, libnetworking/netinet/tcp_timer.h, libnetworking/netinet/udp_usrreq.c, libnetworking/rtems/rtems_glue.c: Misc. updates from FreeBSD and bugfixes tripped by GCC-4.0.0. 2004-12-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/kern/kern_sysctl.c, libnetworking/sys/sysctl.h: Add SYSCTL_CHILDREN_SET. (Update from FreeBSD for GCC-4.0.0). 2004-12-02 Joel Sherrill <joel@OARcorp.com> * libnetworking/kern/kern_sysctl.c, libnetworking/netinet/ip_mroute.c, libnetworking/sys/socketvar.h: Remove warnings. 2004-12-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/net/radix.c, libnetworking/net/radix.h, libnetworking/net/route.h, libnetworking/netinet/if_ether.h, libnetworking/netinet/in_var.h, libnetworking/netinet/tcp_timer.h, libnetworking/netinet/udp_usrreq.c, libnetworking/netinet/udp_var.h, libnetworking/sys/callout.h, libnetworking/sys/socketvar.h, libnetworking/sys/sysctl.h: Cosmetics from FreeBSD. 2004-12-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/monitor/monitor.h, libmisc/rtmonuse/rtmonuse.h, libmisc/shell/shell.h: Partial doxygenification. * libmisc/capture/capture.h: Use INT32_C for constants. 2004-12-02 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/ringbuf.h, libcsupport/include/rtc.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/motorola/mc68681.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/cdefs.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h: Add doxygen preamble. 2004-11-29 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/mallocfreespace.c, rtems/Makefile.am, rtems/include/rtems/rtems/region.h, score/Makefile.am, score/include/rtems/score/heap.h, score/src/heapgetinfo.c: Add capability to return information about just the free blocks in a region or heap. Also changed the semantics of free space available to be the largest block of memory that can be allocated. * rtems/src/regiongetfreeinfo.c, score/src/heapgetfreeinfo.c: New files. : score/include/rtems/score/object.h, score/src/objectinitializeinformation.c: Remove warning. 2004-11-22 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/score/object.h, score/src/objectclearname.c, score/src/objectcopynamestring.c: Fixing warning led to making changes to multiple prototypes for object support routines. 2004-11-22 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/ttyname_r.c: Remove warning for using _fstat. 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> * aclocal/enable-itron.m4, aclocal/check-itron.m4: Allow building itron for unix. 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> * libnetworking/Makefile.am: Don't install bpfilter.h (Private header). 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> * libblock/include/rtems/bdbuf.h, libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h, libblock/include/rtems/ide_part_table.h, libblock/include/rtems/ramdisk.h: Add doxygen preamble. 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/include/rtems/sptables.h, sapi/inline/rtems/extension.inl, sapi/macros/rtems/extension.inl: Add doxygen preamble. 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/copyrt.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/mppkt.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/objectmp.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/states.inl, score/inline/rtems/score/sysstate.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/threadmp.inl, score/inline/rtems/score/tod.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/watchdog.inl, score/inline/rtems/score/wkspace.inl, score/macros/rtems/score/object.inl: Adjust doxygen @file. 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * posix/include/aio.h, posix/include/devctl.h, posix/include/intr.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/condmp.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mqueuemp.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/mutexmp.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/pthreadmp.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/semaphoremp.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/intr.inl, posix/inline/rtems/posix/key.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/intr.inl, posix/macros/rtems/posix/key.inl, posix/macros/rtems/posix/mqueue.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/priority.inl, posix/macros/rtems/posix/pthread.inl, posix/macros/rtems/posix/semaphore.inl, posix/macros/rtems/posix/timer.inl: Add doxygen preamble. 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * itron/include/itron.h, itron/include/itronsys/eventflags.h, itron/include/itronsys/fmempool.h, itron/include/itronsys/intr.h, itron/include/itronsys/mbox.h, itron/include/itronsys/msgbuffer.h, itron/include/itronsys/network.h, itron/include/itronsys/port.h, itron/include/itronsys/semaphore.h, itron/include/itronsys/status.h, itron/include/itronsys/sysmgmt.h, itron/include/itronsys/task.h, itron/include/itronsys/time.h, itron/include/itronsys/types.h, itron/include/itronsys/vmempool.h, itron/include/rtems/itron/config.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/intr.h, itron/include/rtems/itron/itronapi.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/network.h, itron/include/rtems/itron/object.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/sysmgmt.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/time.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/eventflags.inl, itron/inline/rtems/itron/fmempool.inl, itron/inline/rtems/itron/intr.inl, itron/inline/rtems/itron/mbox.inl, itron/inline/rtems/itron/msgbuffer.inl, itron/inline/rtems/itron/network.inl, itron/inline/rtems/itron/port.inl, itron/inline/rtems/itron/semaphore.inl, itron/inline/rtems/itron/sysmgmt.inl, itron/inline/rtems/itron/task.inl, itron/inline/rtems/itron/time.inl, itron/inline/rtems/itron/vmempool.inl, itron/macros/rtems/itron/eventflags.inl, itron/macros/rtems/itron/fmempool.inl, itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl, itron/macros/rtems/itron/msgbuffer.inl, itron/macros/rtems/itron/network.inl, itron/macros/rtems/itron/port.inl, itron/macros/rtems/itron/semaphore.inl, itron/macros/rtems/itron/sysmgmt.inl, itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl, itron/macros/rtems/itron/vmempool.inl: Add doxygen preamble. 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/types.h: Include <rtems/stdint.h>. * librpc/src/rpc/clnt_raw.c, librpc/src/rpc/rpcdname.c, librpc/src/rpc/rtems_portmapper.c, librpc/src/rpc/svc.c, librpc/src/rpc/svc_simple.c: Misc. cast-related fixes. Convert to ANSI. 2004-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> * librpc/include/rpc/rpc.h (struct _rtems_rpc_task_variables): Use pointers to types instead of void* to avoid casts. * librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c, librpc/src/rpc/svc.c, librpc/src/rpc/svc_auth.c, librpc/src/rpc/svc_simple.c: Eliminate lvalue casts gcc-3.4 warns about. 2004-11-20 Ralf Corsepius <ralf.corsepius@rtems.org> * libfs/src/dosfs/dosfs.h: Add doxygen preamble. * libfs/src/dosfs/msdos.h: Remove RC_OK. * libfs/src/dosfs/msdos_format.c: Remove unnecessary casts. 2004-11-20 Ralf Corsepius <ralf.corsepius@rtems.org> PR 720/filesystem: * libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos_format.c: Adaptations to msdos_format. (From Thomas Doerfler <Thomas.Doerfler@imd-systems.de>). * libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos_format.c: Adaptations to RTEMS-4.7. 2004-11-20 Ralf Corsepius <ralf.corsepius@rtems.org> PR 720/filesystem: * libfs/src/dosfs/msdos_format.c: New (From Thomas Doerfler <Thomas.Doerfler@imd-systems.de>). * libfs/Makefile.am: Reflect changes above: 2004-11-20 Ralf Corsepius <ralf.corsepiu@rtems.org> * libcsupport/include/stdint.h: Move mal-placed comment. 2004-11-10 Joel Sherrill <joel@oarcorp.com> * include/rtems/pci.h: BSPs use the name BSP_pci_configuration not pci. Also need to address that this largely duplicates libbsp/powerpc/pci/pci.h but that file is not used when both are included due to the same double inclusion protection. 2004-11-09 Joel Sherrill <joel@OARcorp.com> * libcsupport/include/stdint.h: Fixed name in @file. 2004-11-08 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/sys/_stdint.h: Remove. * libcsupport/include/sys/_inttypes.h: Remove. * libcsupport/include/stdint.h: Replace with former sys/_stdint.h. Add INT<N>_C, various additions. * libcsupport/include/inttypes.h: Replace with former sys/_inttypes.h. * libcsupport/Makefile.am: Reflect changes above. 2004-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> * backward/asm.h: Add doxygen preamble. * backward/chain.h: Add doxygen preamble. * backward/clockdrv.h: Add doxygen preamble. * backward/confdefs.h: Add doxygen preamble. * backward/console.h: Add doxygen preamble. * backward/dosfs.h: Add doxygen preamble. * backward/imfs.h: Add doxygen preamble. * backward/iosupp.h: Add doxygen preamble. * backward/itron.h: Add doxygen preamble. * backward/ringbuf.h: Add doxygen preamble. * backward/rtc.h: Add doxygen preamble. * backward/spurious.h: Add doxygen preamble. * backward/timerdrv.h: Add doxygen preamble. * backward/vmeintr.h: Add doxygen preamble. * backward/motorola/mc68230.h: Add doxygen preamble. * backward/motorola/mc68681.h: Add doxygen preamble. * backward/zilog/z8030.h: Add doxygen preamble. * backward/zilog/z8036.h: Add doxygen preamble. * backward/zilog/z8536.h: Add doxygen preamble. 2004-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> * libcsupport/include/sys/_stdint.h: Special-case int64_t (GCC has __LONG_LONG_MAX__, while POSIX mandates LLONG_MAX. This break __EXP(LONG_LONG_MAX)). 2004-11-05 Joel Sherrill <joel@OARcorp.com> * libnetworking/machine/endian.h: Protect BYTE_ORDER from double definition. 2004-11-05 Ralf Corsepius <ralf_corsepiu@rtems.org> * configure.ac: Remove RTEMS_USES_INTTYPES_H. Require inttypes.h. * include/rtems/stdint.h: Remove "wild guesses", require inttypes.h. * libcsupport/include/inttypes.h: Cleanup. * libcsupport/include/stdint.h: Cleanup. 2004-11-04 Ralf Corsepius <ralf_corsepius@rtems.org> * include/sys/_stdint.h: Various changes. Add *leastN_t types. Add INTN_{MIN|MAX} macros. Add doxygen preamble. * include/sys/_inttypes.h: Add doxygen preamble. Reflect changes above. * libcsupport/include/stdint.h: Add doxygen preamble. * libcsupport/include/inttypes.h: Add doxygen preamble. * configure.ac: Add doxygen preamble to cpuopts.h. 2004-11-02 Joel Sherrill <joel@OARcorp.com> * posix/src/mqueueunlink.c, posix/src/semunlink.c, score/inline/rtems/score/object.inl, score/macros/rtems/score/object.inl: _Objects_Is_local_id() should be avoided in single CPU configurations but always available in the Objects Handlers API. 2004-11-02 Ralf Corsepius <ralf_corsepius@rtems.org> * rtems/include/rtems.h, rtems/inline/rtems/rtems/asr.inl, rtems/inline/rtems/rtems/attr.inl, rtems/inline/rtems/rtems/dpmem.inl, rtems/inline/rtems/rtems/event.inl, rtems/inline/rtems/rtems/eventset.inl, rtems/inline/rtems/rtems/message.inl, rtems/inline/rtems/rtems/modes.inl, rtems/inline/rtems/rtems/options.inl, rtems/inline/rtems/rtems/part.inl, rtems/inline/rtems/rtems/ratemon.inl, rtems/inline/rtems/rtems/region.inl, rtems/inline/rtems/rtems/sem.inl, rtems/inline/rtems/rtems/status.inl, rtems/inline/rtems/rtems/support.inl, rtems/inline/rtems/rtems/tasks.inl, rtems/inline/rtems/rtems/timer.inl, rtems/macros/rtems/rtems/asr.inl, rtems/macros/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/dpmem.inl, rtems/macros/rtems/rtems/event.inl, rtems/macros/rtems/rtems/eventset.inl, rtems/macros/rtems/rtems/message.inl, rtems/macros/rtems/rtems/modes.inl, rtems/macros/rtems/rtems/options.inl, rtems/macros/rtems/rtems/part.inl, rtems/macros/rtems/rtems/ratemon.inl, rtems/macros/rtems/rtems/region.inl, rtems/macros/rtems/rtems/sem.inl, rtems/macros/rtems/rtems/status.inl, rtems/macros/rtems/rtems/support.inl, rtems/macros/rtems/rtems/tasks.inl, rtems/macros/rtems/rtems/timer.inl: Add doxygen preamble. 2004-11-02 Ralf Corsepius <ralf_corsepius@rtems.org> * rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h, rtems/include/rtems/rtems/eventmp.h, rtems/include/rtems/rtems/eventset.h, rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/options.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h, rtems/include/rtems/rtems/signalmp.h, rtems/include/rtems/rtems/status.h, rtems/include/rtems/rtems/support.h, rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h: Add doxygen preamble. 2004-11-01 Joel Sherrill <joel@OARcorp.com> * libmisc/monitor/mon-manager.c, libmisc/monitor/mon-object.c: Remove references to _Object_Is_local in single processor configurations. 2004-11-01 Joel Sherrill <joel@OARcorp.com> * score/src/coresemsurrender.c, score/src/objectnametoid.c: All _Objects_Is_Local... should only be called if multiprocessing is enabled. 2004-11-01 Ralf Corsepius <ralf_corsepius@rtems.org> * rtems/include/rtems/rtems/tasks.h, rtems/src/taskstart.c: rtems_task_start(..., rtems_task_argument argument ); 2004-11-01 Joel Sherrill <joel@oarcorp.com> * score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/copyrt.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/mppkt.inl, score/inline/rtems/score/objectmp.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/states.inl, score/inline/rtems/score/sysstate.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/threadmp.inl, score/inline/rtems/score/tod.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/watchdog.inl, score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working modifications which are not complete and may have broken code. Committing so work and testing can proceed. * score/Doxyfile, score/mainpage.h: New files. 2004-11-01 Joel Sherrill <joel@oarcorp.com> * score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/macros/rtems/score/object.inl: Add first cut of optional 16 bit object Id as space reduction for small systems (TinyRTEMS). 2004-11-01 Ralf Corsepius <ralf_corsepius@rtems.org> * monitor/monitor.h: Let rtems_monitor_config_dump return int. * monitor/mon-config.c: Ditto. Use PRI*N macros. * monitor/mon-itask.c, monitor/mon-prmisc.c: Use PRI*N macros. 2004-11-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/monitor/monitor.h: Let rtems_monitor_config_dump return int. * libmisc/monitor/mon-config.c: Ditto. Use PRI*N macros. * libmisc/monitor/mon-itask.c, libmisc/monitor/mon-prmisc.c: Use PRI*N macros. 2004-11-01 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Remove -ansi (Cygwin breaks with it). * libcsupport/include/stdint.h: Use sys/_stdint.h to setup fixed size types. * libcsupport/include/sys/_inttypes.h: Add SCN*N macros. 2004-11-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/src/utsname.c: Revert yesterdays patch. 2004-10-31 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/utsname.c: Fix typo. 2004-10-29 Ralf Corsepius <ralf_corsepius@rtems.org> * score/src/coremsg.c: Eliminate unsigned32. * score/include/rtems/system.h: Set __RTEMS_REVISION__ to 99. * librpc/include/rpc/xdr.h: Use elipsis in xdrproc_t prototype. 2004-10-28 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/inttypes.h: #include <sys/_inttypes.h> * libcsupport/src/utsname.c: Don't include sptables.h. Include <inttypes.h>. Use PRId32 instead of "%d". 2004-10-28 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/rtems/_inttypes.h: Remove. * libcsupport/include/rtems/_stdint.h: Remove. * libcsupport/include/sys/_inttypes.h: New. * libcsupport/include/sys/_stdint.h: New. * libcsupport/Makefile.am: Reflect changes above. * configure.ac: Reflect changes above. 2004-10-28 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Remove RTEMS_CPUOPT([RTEMS_MULTILIBS],..). (Unused). 2004-10-27 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/monitor/mon-prmisc.c, libmisc/monitor/monitor.h: Let rtems_monitor_dump return int's not uint32_t (They are printf return values). 2004-10-27 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Add score/cpu/no_cpu/Makefile. 2004-10-27 Ralf Corsepius <ralf_corsepius@rtems.org> * Makefile.am, configure.ac: Add httpd. * httpd/asp.c, httpd/balloc.c, httpd/cgi.c, httpd/default.c, httpd/ej.h, httpd/ejIntrn.h, httpd/ejlex.c, httpd/ejparse.c, httpd/emfdb.c, httpd/emfdb.h, httpd/form.c, httpd/handler.c, httpd/h.c, httpd/license.txt, httpd/Makefile.am, httpd/md5c.c, httpd/md5.h, httpd/mime.c, httpd/misc.c, httpd/NOTES, httpd/ringq.c, httpd/rom.c, httpd/rtems_webserver.h, httpd/security.c, httpd/sock.c, httpd/socket.c, httpd/sockGen.c, httpd/sym.c, httpd/uemf.c, httpd/uemf.h, httpd/um.c, httpd/um.h, httpd/umui.c, httpd/url.c, httpd/value.c, httpd/wbase64.c, httpd/webcomp.c, httpd/webmain.c, httpd/webpage.c, httpd/webrom.c, httpd/webs.c, httpd/websda.c, httpd/websda.h, httpd/webs.h, httpd/websSSL.c, httpd/websSSL.h, httpd/websuemf.c, httpd/wsIntrn.h: New (Moved from c/src/libnetworking/rtems_webserver). * httpd/Makefile.am: Install libhttpd.a. 2004-10-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/rtems/_inttypes.h: Undefine __PRIN defines. * libcsupport/include/rtems/_stdint.h: Apply GNUC-limits to GCC >= 3.3, only. Add _rtems_*_t_defined defines. Add extern "C". 2004-10-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/rtems/_stdint.h: New. * libcsupport/include/rtems/_inttypes.h: New. * libcsupport/Makefile.am: Reflect changes above. 2004-10-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libfs/src/dosfs/msdos_conv.c: Replace BSD fixed-size types with POSIX fixed-size types. Replace SECONDSTO1980 with DAYSTO1980. Make macros 16bit clean. 2004-10-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/sys/ioccom.h: Cosmetical update from FreeBSD. * libcsupport/include/sys/ioctl.h: Cosmetical update from FreeBSD. Remove sys/compat_ioctl.h section (Meaningless with RTEMS). 2004-10-25 Eric Norum <norume@aps.anl.gov> * libnetworking/net/if_ethersubr.c: Working version of ether_sprintf(). * cpukit/librpc/include/rpc/xdr.h: No kernel/user distinction. 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/Makefile.am: Reflect changes below. * libnetworking/net/slcompress.h: New (from FreeBSD). * libnetworking/net/slcompress.c: New (from FreeBSD). 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/stdint.h: Add intptr_t uintptr_t. * libnetworking/kern/kern_sysctl.c: Remove uintptr_t. Cosmetics. * libnetworking/opt_compat.h: New. 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/opt_atalk.h, libnetworking/opt_bdg.h, libnetworking/opt_inet.h, libnetworking/opt_inet6.h, libnetworking/opt_ipx.h, libnetworking/opt_mac.h, libnetworking/opt_netgraph.h: New (Stubs). * libnetworking/net/if_loop.c: Cosmetical update from FreeBSD. * libnetworking/net/if_ethersubr.c: Update from FreeBSD. * libnetworking/net/if.h: Update from FreeBSD. 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/net/ethernet.h: Remove BYTE_PACK. 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/net/if.h; Cosmetical updates from FreeBSD. Remove if_poll* (Not implemented in RTEMS, abandoned by FreeBSD). * libnetworking/net/if_ethersubr.c: Cosmetical updates from FreeBSD. Add ether_sprintf. * libnetworking/net/ethernet.h: Update from FreeBSD. 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/monitor/mon-prmisc.c, libmisc/monitor/monitor.h: rtems_monitor_dump_char(char ch). 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> * automake/compile.am: Remove RTEMS_CFLAGS_*_V. 2004-10-15 Joel Sherrill <joel@OARcorp.com> PR 692/rtems * rtems/src/regiongetsegment.c, rtems/src/regionreturnsegment.c: The Region Manager did not follow the proper protocol when blocking and unblocking tasks waiting on buffers. This was a bug introduced with the transition to an Allocation Mutex. 2004-09-29 Joel Sherrill <joel@OARcorp.com> * configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am, score/include/rtems/score/mppkt.h: i960 obsoleted and all references removed. 2004-09-29 Joel Sherrill <joel@OARcorp.com> * score/cpu/i960/.cvsignore, score/cpu/i960/ChangeLog, score/cpu/i960/Makefile.am, score/cpu/i960/asm.h, score/cpu/i960/cpu.c, score/cpu/i960/cpu_asm.S, score/cpu/i960/rtems/score/cpu.h, score/cpu/i960/rtems/score/i960.h, score/cpu/i960/rtems/score/types.h: Removed. 2004-09-27 Joel Sherrill <joel@OARcorp.com> PR 294/rtems * posix/src/pthread.c: POSIX thread exit handler now confirms that it created the executing thread before implicitly exitting it. 2004-09-27 Joel Sherrill <joel@OARcorp.com> * libmisc/stackchk/check.c: Spacing. 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Require automake > 1.9. 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Add score/cpu/avr/Makefile.am. * score/cpu/Makefile.am: Add avr. * libnetworking/Makefile.am: Don't include subdirs.am. 2004-09-23 Ralf Corsepius <ralf_corsepius@rtems.org> * librpc/src/xdr/xdr_float.c: Add __AVR__. 2004-09-21 Ralf Corsepius <ralf_corsepius@rtems.org> * aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac). * configure.ac: Add RTEMS_CHECK_GCC_WEAK. 2004-09-17 Joel Sherrill <joel@OARcorp.com> PR 677/misc * libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h, libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h, libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add extern C wrappers. 2004-09-17 Till Strauman <strauman@slac.stanford.edu> PR 676/networking * libnetworking/nfs/bootp_subr.c: /etc/resolv.conf contains NTP instead of DNS servers. 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org> PR 673/make_build * aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes. 2004-07-28 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-4.6.99.1. 2004-07-25 Till Straumann <strauman@slac.stanford.edu> PR 620/networking * libnetworking/lib/rtems_bsdnet_ntp.c, libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API. 2004-07-25 Thomas Rauscher <trauscher@loytec.com> PR 609/rtems * score/src/threaddispatch.c: Close race condition between _Thread_Dispatch and _Thread_Tickle_timeslice. 2004-07-25 Victor Vengerov <Victor.Vengerov@oktetlabs.ru> PR 654/rtems * score/src/threadinitialize.c: Initialize the per thread watchdog timer. When the thread control block is reused, we cannot depend on it being zeroed. 2004-07-24 Mick Davis <mickd@microsol.iinet.net.au> PR 641/rtems * rtems/src/eventsurrender.c: The problem here is that events may be lost when sent to a task which enters rtems_event_receive() with options set to wait with a timeout and to return on receipt of any event. The events are sent from an interrupt source such as a timer service routine. If more than one set of events is sent to the task before it returns, the first event set may be overwritten. 2004-07-24 Joel Sherrill <joel@OARcorp.com> PR 661/rtems * score/src/objectmp.c: Fix invalid dereference. 2004-07-24 Joel Sherrill <joel@OARcorp.com> PR 660/rtems * score/cpu/m68k/rtems/score/m68k.h, score/cpu/mips/cpu_asm.S, score/src/threadinitialize.c, score/src/threadstackallocate.c: Check for overflow when allocating stack. 2004-07-24 Joel Sherrill <joel@OARcorp.com> PR 659/rtems * score/src/heapsizeofuserarea.c: Check that address specified is in the heap. 2004-07-24 Joel Sherrill <joel@OARcorp.com> PR 652/rtems * rtems/src/signalsend.c: Return RTEMS_INVALID_NUMBER when sending an empty signal set. 2004-07-14 Joel Sherrill <joel@OARcorp.com> PR 650/rtems * score/src/coremsg.c: Check for mathemathical overflow when calculating amount of memory to allocate for message buffers. 2004-07-14 Joel Sherrill <joel@OARcorp.com> PR 651/core * rtems/src/taskident.c: Add NULL check for id. 2004-06-29 Joel Sherrill <joel@OARcorp.com> PR 631/rtems * rtems/src/msgqcreate.c: Return unsatisfied from message_queue_create when unable to allocate message buffer memory. 2004-05-21 Joel Sherrill <joel@OARcorp.com> PR 628/rtems * posix/src/killinfo.c, posix/src/pthreadkill.c, posix/src/ptimer1.c, posix/src/sigaction.c, posix/src/sigaddset.c, posix/src/sigsuspend.c: Signal set of 0 is supposed to return EINVAL. In addition timer_create needed to return an error if the clock was not CLOCK_REALTIME. 2004-05-21 Joel Sherrill <joel@OARcorp.com> PR 629/rtems * cpukit/src/mqueuecreatesupp.c: Return EINVAL is mq_maxmsg is <= 0, not <. 2004-05-21 Till Strauman <strauman@slac.stanford.edu> PR 626/networking * libnetworking/rtems/rtems_showifstat.c: Use unsigned char to avoid printing leading FFFFFF for byte values > 127. 2004-05-06 Joel Sherrill <joel@OARcorp.com> PR 618/rtems * rtems/include/rtems/rtems/status.h, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/dpmemcreate.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventsend.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c, rtems/src/msgqsubmit.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionreturnsegment.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/taskcreate.c, rtems/src/taskgetnote.c, rtems/src/taskmode.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasksetnote.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/taskwakewhen.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, score/include/rtems/score/object.h, score/src/coretodvalidate.c, score/src/objectnametoid.c: Add NULL checks. 2004-04-30 Joel Sherrill <joel@OARcorp.com> * libnetworking/kern/kern_sysctl.c: sysctl_register_all cannot be static with RTEMS. 2004-04-30 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/netinet/in.c: Partial update from FreeBSD. 2004-04-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/kern/kern_sysctl.c: Partial updates from FreeBSD. 2004-04-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/netinet/igmp_var.h: Cosmetic updates from FreeBSD. * libnetworking/sys/sysctl.h: Update from FreeBSD. * libnetworking/sys/socketvar.h: Update from FreeBSD. 2004-04-24 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/sys/protosw.h: More partial updates from FreeBSD. 2004-04-24 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/net/route.c: Reflect changes to radix.h. 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/net/radix.h, libnetworking/net/radix.c: Partial update from FreeBSD. 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/sys/socket.h: Further update from FreeBSD (Add sa_family_t). 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/sys/protosw.h: Partial update from FreeBSD. * libnetworking/sys/socket.h: Partial update from FreeBSD. * libnetworking/rtems/rtems_syscall.c: Reflect changes to socket.h. 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/kern/uipc_socket.c: Partial update from FreeBSD (Remove adv-clause from copyright notice). * libnetworking/netinet/igmp_var.h: Partial update from FreeBSD. 2004-04-20 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/net/bpf.h, libnetworking/net/if.h, libnetworking/net/if_dl.h, libnetworking/net/if_ppp.h, libnetworking/net/netisr.h, libnetworking/net/pppcompress.c, libnetworking/net/radix.c, libnetworking/net/radix.h, libnetworking/net/raw_cb.h, libnetworking/net/route.h, libnetworking/netinet/icmp_var.h, libnetworking/netinet/if_ether.h, libnetworking/netinet/igmp_var.h, libnetworking/netinet/in.h, libnetworking/netinet/in_pcb.h, libnetworking/netinet/in_systm.h, libnetworking/netinet/in_var.h, libnetworking/netinet/ip_fw.h, libnetworking/netinet/ip_icmp.h, libnetworking/netinet/ip_mroute.h, libnetworking/netinet/ip_var.h, libnetworking/netinet/tcp_debug.h, libnetworking/netinet/tcp_seq.h, libnetworking/netinet/tcp_timer.h, libnetworking/netinet/tcp_var.h, libnetworking/netinet/udp_var.h, libnetworking/nfs/nfs.h, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/buf.h, libnetworking/sys/callout.h, libnetworking/sys/conf.h, libnetworking/sys/domain.h, libnetworking/sys/malloc.h, libnetworking/sys/mbuf.h, libnetworking/sys/mount.h, libnetworking/sys/protosw.h, libnetworking/sys/queue.h, libnetworking/sys/rtprio.h, libnetworking/sys/select.h, libnetworking/sys/signalvar.h, libnetworking/sys/socket.h, libnetworking/sys/socketvar.h, libnetworking/sys/sysctl.h, libnetworking/sys/syslog.h, libnetworking/sys/ucred.h, libnetworking/sys/uio.h, libnetworking/vm/vm.h, libnetworking/vm/vm_extern.h, libnetworking/vm/vm_param.h: Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance. 2004-04-20 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/Makefile.am: Add -D_KERNEL to CPPFLAGS. 2004-04-20 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/net/bpf.h: Partial update from FreeBSD. 2004-04-19 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/sys/sysctl.h: Partial update from FreeBSD. * libnetworking/kern/kern_sysctl.c: Partial update from FreeBSD. 2004-04-17 Ralf Corsepius <ralf_corsepius@rtems.org> * libfs/src/imfs/imfs_debug.c, libfs/src/imfs/memfile.c: Use fprintf(stdout,...) instead of printf. 2004-04-17 Ralf Corsepius <ralf_corsepius@rtems.org> * libblock/src/ide_part_table.c: Use fprintf(stdout,...) instead of printf. 2004-04-17 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c, libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c, libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c, libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c, libmisc/untar/untar.c: Use fprintf(stdout,...) instead of printf. 2004-04-14 Ralf Corsepius <ralf_corsepius@rtems.org> * sapi/include/rtems/sptables.h: Remove _RTEMS_version. 2004-04-14 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/Makefile.am: Install include_sys_HEADERS for NEWLIB only. Merge sys/cdefs.h into general include_sys_HEADERS. 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org> * rtems/include/rtems/rtems/types.h: Include <rtems/stdint.h> instead of <stdint.h>. Conditionally typedef rtems*signed64 types. * score/include/rtems/system.h: Include <rtems/stdint.h> instead of <stdint.h>. 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Rework stdint.h/inttypes.h support. Add RTEMS_USES_STDINT_H. Add RTEMS_USES_INTTYPES_H. Remove NEED_STDINT_H. Remove NEED_INTTYPES_H. Remove termios-flag detection. * libcsupport/Makefile.am: Install include/stdint.h and include/inttypes.h for NEWLIB only. * libcsupport/include/stdint.h: Rework; Now newlib specific. * libcsupport/src/termios.c: Make newlib specific. * include/rtems/stdint.h: Rework; Now wrapper to <stdint.h>. 2004-04-12 Ralf Corsepius <ralf_corsepius@rtems.org> * acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED. * backward/motorola/mc68681.h, backward/motorola/mc68230.h, backward/zilog/z8536.h, backward/zilog/z8036.h, backward/zilog/z8030.h: New. * Makefile.am: Reflect having added new files above. 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> * wrapup/Makefile.am: Add libblock for !UNIX only. 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> * libblock/Makefile.am: Build libblock for !UNIX only. * libcsupport/Makefile.am: Build $(TERMIOS_C_FILES) for !UNIX only. 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> * libblock/Makefile.am: Remove LIBC_DEFINES (Unsupported). * libfs/Makefile.am: Remove LIBC_DEFINES (Unsupported). 2004-04-08 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/Makefile.am: Install sys/ioccom.h for NEWLIB only. 2004-04-08 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/Makefile.am: Remove $(LIBC_DEFINES) (Unsupported). Install motorola-headers to $(includedir)/rtems/motorola. Install zilog-headers to $(includedir)/rtems/zilog. 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> * score/cpu/Makefile.am: Add unix to DIST_SUBDIRS. 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> * aclocal/rtems-cpu-subdirs.m4: Remove (Unused). * configure.ac: Remove RTEMS_CPU_SUBDIRS([score/cpu]). Add RTEMS_CHECK_SYSV_UNIX. Add score/cpu/*/Makefile. * score/cpu/Makefile.am: Add DIST_SUBDIRS. 2004-04-05 Ralf Corsepius <ralf_corsepius@rtems.org> * configure.ac: Add AC_CHECK_SIZEOF([CPU_CONTEXT]..). Add SIZEOF_CPU_CONTEXT to cpuopts.h. Add RTEMS_PROG_CCAS. * acinclude.m4: Use unquoted "here" document to propagate $3 to cpuopts.tmp. 2004-04-02 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/Makefile.am: AM_CPPFLAGS += -I$(srcdir). * libnetworking/rtems/rtems_bsdnet_internal.h: Remove USHRT_MAX. 2004-04-02 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/Makefile.am: Fix typo. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/poll.h: Replace with sys/poll.h wrapper. * libnetworking/sys/poll.h: New (Original FreeBSD file). * libnetworking/Makefile.am: Don't install opt_ipfw.h, opt_mrouting.h, opt_tcpdebug.h. Add sys/poll.h. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/serdbg/serdbgcnf.h: Include <rtems/serdbg.h> instead of <serdbg.h> * libmisc/serdbg/termios_printk_cnf.h: Include <rtems/termios_printk.h> instead of <termios_printk.h>. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/Makefile.am: Install serdbg.h, serdbgcnf.h, termios_printk.h, termios_printk_cnf.h to $(includedir)/rtems. * libmisc/serdbg/serdbg.c: Include <rtems/serdbg.h> instead of <serdbg.h>. * libmisc/serdbg/serdbgio.c: Include <rtems/serdbg.h> instead of <serdbg.h>. * libmisc/serdbg/termios_printk.c: Include <rtems/termios_printk.h> instead of <termios_printk.h>. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/dummy/dummy.c: Include <rtems/confdefs.h> instead of <confdefs.h>. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * backward/confdefs.h: New. * Makefile.am: Add backward/confdefs.h. Add conditional DEPRECATED. * configure.ac: Add --enable-deprecated. Add conditional DEPRECATED. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * sapi/Makefile.am: Install confdefs.h to $(includedir)/rtems. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * Makefile.am: Add backward/*.h headers. * itron/Makefile.am: Install itron.h to $(includedir)/rtems. * libcsupport/Makefile.am: Install RTEMS specific headers to $(includedir)/rtems. * libfs/Makefile.am: Install imfs.h and dosfs.h to $(includedir)/rtems. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>. * libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>. * libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>. * libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>. * sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>. * libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>. * libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>. * libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>. * sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>. * itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>. * itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>. * sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>. * sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>. * sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>. 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> * backward/asm.h, backward/chain.h, backward/clockdrv.h, backward/console.h, backward/dosfs.h, backward/imfs.h, backward/iosupp.h, backward/itron.h, backward/ringbuf.h, backward/rtc.h, backward/spurious.h, backward/timerdrv.h, backward/vmeintr.h: New. 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> * rtems/include/rtems/rtems/region.h: Include stddef.h for size_t. (rtems_region_get_segment_size): Use size_t instead of uint32_t for "size" (3rd arg). * rtems/src/regiongetsegmentsize.c: Reflect changes above. * libcsupport/src/malloc.c: Reflect changes above. 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> * aclocal/rtems-top.m4: Don't AC_SUBST(PROJECT_ROOT). Add project_libdir, project_include and libdir. * aclocal/env-rtemscpu.m4: Remove all references to RTEMS_BSP. Remove project_libdir, project_include and libdir. Unconditionally use CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V. 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> * libnetworking/lib/ftpfs.c, libnetworking/lib/rtems_bsdnet_ntp.c, libnetworking/lib/tftpDriver.c, libnetworking/machine/endian.h, libnetworking/net/if_ppp.c, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/rtems/rtems_glue.c, libnetworking/rtems/rtems_syscall.c: Convert to using c99 fixed size types. 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> * score/include/rtems/debug.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/wkspace.inl, score/macros/rtems/score/address.inl, score/macros/rtems/score/heap.inl, score/macros/rtems/score/object.inl, score/macros/rtems/score/priority.inl, score/macros/rtems/score/userext.inl: Convert to using c99 fixed size types. 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> * sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c, sapi/src/io.c: Convert to using c99 fixed size types. 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> * rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/eventset.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/options.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/support.h, rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/part.inl, rtems/inline/rtems/rtems/region.inl, rtems/macros/rtems/rtems/part.inl, rtems/src/attr.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmeminternal2external.c, rtems/src/eventseize.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqsubmit.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/ratemon.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionmp.c, rtems/src/regionreturnsegment.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semtranslatereturncode.c, rtems/src/taskcreate.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/taskstart.c, rtems/src/timerserver.c: Convert to using c99 fixed size types. 2004-04-29 Ralf Corsepius <ralf_corsepius@rtems.org> * score/src/Unlimited.txt, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coretod.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapsizeofuserarea.c, score/src/interr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadcreateidle.c, score/src/threadget.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueuepriority.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadreset.c, score/src/threadrestart.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstart.c, score/src/userext.c, score/src/watchdoginsert.c, score/src/wkspace.c: Convert to using c99 fixed size types. 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> PR 561/rtems * include/rtems/concat.h: New. * Makefile.am: Add include/rtems/concat.h. PR 589/rtems * Makefile.am: Add include/rtems/pci.h. * Makefile.am: Include automake/compile.am. * configure.ac: RTEMS_TOP([..],[]). 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> * aclocal/rtems-top.m4: Add MULTISUBDIR. Add MULTIBUILDTOP. Add rtems_updir. Remove version.m4 check. Add PROJECT_ROOT/with_project_root processing. Add PROJECT_INCLUDE. Add PROJECT_LIB. * aclocal/env-rtemscpu.a4: Remove cpukit_topdir. Remove with_project_root processing. Remove PROJECT_INCLUDE, PROJECT_LIB. 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> * libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c, libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h, libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c, libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c, libmisc/monitor/monitor.h, libmisc/monitor/symbols.h, libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c, libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c, libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h, libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c, libmisc/stackchk/internal.h: Convert to using c99 fixed size types. 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> * itron/include/itronsys/mbox.h, itron/include/itronsys/types.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/semaphore.inl, itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c, itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c: Convert to using c99 fixed size types. 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> * posix/include/rtems/posix/cond.h, posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/src/cond.c, posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/killinfo.c, posix/src/mqueue.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuetranslatereturncode.c, posix/src/mutex.c, posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/psignal.c, posix/src/pthread.c, posix/src/ptimer1.c, posix/src/semaphore.c, posix/src/sysconf.c: Convert to using c99 fixed size types. 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> * score/include/rtems/system.h: include <stdint.h>. 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> PR/589 rtems * include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h). 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/src/malloc.c: Remove lvalue casts. 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org> * libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/ringbuf.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c, libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c, libcsupport/src/error.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c, libcsupport/src/no_libc.c, libcsupport/src/termios.c, libcsupport/src/termiosreserveresources.c: Convert to using c99 fixed-size types. 2004-03-22 Ralf Corsepius <ralf_corsepius@rtems.org> * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * libnetworking/net/radix.c: Remove warning. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * libmisc/shell/cmds.c: Remove warning. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * libnetworking/lib/ftpfs.c: Switch bcopy to memcpy. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/newlibc.c, libcsupport/src/sync.c: Eliminate warnings. Explicitly defeat __STRICT_ANSI__ since both legitimately use routines beyond ANSI. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * cpukit/libblock/src/bdbuf.c: Initialize pointer to avoid warning. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Add cast to avoid type punning warning in gcc 3.3. 2004-03-05 Joel Sherrill <joel@OARcorp.com> * 2004-03-05 Joel Sherrill <joel@OARcorp.com> * libblock/src/bdbuf.c, libblock/src/ramdisk.c, libcsupport/src/newlibc.c, libcsupport/src/sync.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c, libmisc/shell/cmds.c, libmisc/shell/shell.c, libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c, libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c, libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c, libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c, libnetworking/libc/res_send.c, libnetworking/libc/res_update.c, libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c, librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c, librpc/src/rpc/svc.c, sapi/include/confdefs.h, score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: 2004-02-26 Thomas Rauscher <trauscher@loytec.com. PR 584/RTEMS * rtems/src/eventtimeout.c: Fix critical section window. 2004-02-26 Joel Sherrill <joel@OARcorp.com> PR 582/core * posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueueunlink.c: Use memory from workspace to avoid use of mutex during dispatch disable critical section. Besides memory for object names should come from the Workspace anyway. 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/version.m4: 4.6.99.0. 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/Makefile.am: Remove ACLOCAL_AMFLAGS. 2004-01-30 Wilfried Busalski <w.busalski@lancier-monitoring.de> PR pppd/564 * libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the system use a slow baudrate for the modem or the tcp/ip-packet is fragmented. 2004-01-30 Joel Sherrill <joel@OARcorp.com> * ChangeLog, rtems/Makefile.am, rtems/include/rtems/rtems/support.h: Reverse developmental patches accidentally committed. 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * ChangeLog: Merge-in libnetworking/ChangeLog. * ChangeLog: Merge-in libcsupport/ChangeLog. * ChangeLog: Merge-in libblock/ChangeLog, libfs/ChangeLog. * ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog. * ChangeLog: Merge-in itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog, rtems/ChangeLog. * libblock/ChangeLog, libfs/ChangeLog, libcsupport/ChangeLog, libmisc/ChangeLog, librpc/ChangeLog, libnetworking/ChangeLog, itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog, rtems/ChangeLog: Remove. 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/rtems-top.m4: Remove PROJECT_ROOT. Prepend ../ to $1. * aclocal/env-rtemscpu.m4: Reworked. * configure.ac: RTEMS_TOP([.]). 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, itron/Makefile.am, posix/Makefile.am, score/Makefile.am, sapi/Makefile.am, rtems/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libblock/Makefile.am, libfs/Makefile.am, libcsupport/Makefile.am, libnetworking/Makefile.am: Add PREINSTALL_DIRS. 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Remove $(ARCH)/$(dirstamp). Add TMPINSTALL_FILES to CLEANFILES. * automake/local.am: Remove depend-am. * automake/subdirs.am: Remove depend-recursive. * score/Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. Add cpuopts.h to DISTCLEANFILES. * Makefile.am, itron/Makefile.am, posix/Makefile.am, sapi/Makefile.am, rtems/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libblock/Makefile.am, libfs/Makefile.am, libcsupport/Makefile.am, libnetworking/Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. * libnetworking/netinet/in_cksum.c: #include netinet/in_cksum_<cpu>.h. 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR/549 networking * libnetworking/netinet/in_cksum_powerpc.h: New (copy of in_cksum_powerpc.c). * libnetworking/netinet/in_cksum_i386.h: New (copy of in_cksum_i386.c). * libnetworking/netinet/in_cksum_arm.h: New (copy of in_cksum_arm.c). * libnetworking/netinet/in_cksum_m68k.c: New (copy of in_cksum_m68k.c). * libnetworking/netinet/in_cksum_i386.c, libnetworking/netinet/in_cksum_arm.c, libnetworking/netinet/in_cksum_powerpc.c, libnetworking/netinet/in_cksum_m68k.c: Remove. * libnetworking/netinet/Makefile.am: Reflect changes above. 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Requires automake >= 1.8.1. * score/cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU). PR 548/rtems * libcsupport/Makefile.am: Add src/envlock.c. 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT. Remove PROJECT_TOPdir (Unused). * aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE. Expand ${PROJECT_ROOT}. Remove RTEMS_ENABLE_BARE (Unused). Don't AC_SUBST RTEMS_BSP. * aclocal/enable-bare.m4: Remove (Unused). * aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4. Remove gnu-make endif HACK (Unused). * wrapup/Makefile.am: Include compile.am. Use TMP_LIBS instead of LIBS to avoid potential conflicts with auto*tools' LIBS. Reflect new locations of libscorecpu*.a. * Makefile.am: Remove AUTOMAKE_FILES. * automake/compile.am: Replace contents with contents of automake/amcompile.am. * automake/amcompile.am, automake/lib.am: Remove. * configure.ac, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4, aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING (deprecated in autoconf-2.59). * automake/local.am: Remove clean-local, depend-gcc. * itron/Makefile.am, posix/Makefile.am, score/Makefile.am: Include compile.am, again. * score/macros/rtems/score/README: Remove (Redundant with macros/README). * sapi/Makefile.am, rtems/Makefile.am: Include compile.am, again. * libmisc/Makefile.am: Include compile.am again. Misc fixes. * librpc/Makefile.am: Include compile.am, again. Put man-pages into EXTRA_DIST to work around automake not distributing conditionally installed *_MANS. Distribute include/rpcsvc. * libblock/Makefile.am: Include compile.am, again. Eliminate C_FILES. Reformat. * libfs/Makefile.am: Include compile.am, again. Reformat/Cleanup. * libcsupport/Makefile.am: Reformat, add UNUSED_FILES. * libcsupport/Makefile.am: Include compile.am, again. Eliminate DOC_FILES. * libnetworking/Makefile.am: Include compile.am, again. Cleanup. 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Cosmetics. * aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING). * aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING). * automake/amcompile.am: Remove $(ARCH). * wrapup/Makefile.am: Add $(ARCH). Remove compile.am, lib.am. Include amcompile.am. * wrapup/Makefile.am: Use ../*/*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a. * wrapup/Makefile.am: Reflect changes to libblock/Makefile.am. Reflect changes to libcsupport/Makefile.am. * itron/Makefile.am: Add libs to CLEANFILES. Set lib*_g_a_SOURCES = lib*_a_SOURCES. * itron/Makefile.am: Build libitron$(LIB_VARIANT).a instead of $(ARCH)/libitron.a. * posix/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * posix/Makefile.am: Build libposix$(LIB_VARIANT).a instead of $(ARCH)/libposix.a. * score/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * score/Makefile.am: Build libscore$(LIB_VARIANT).a instead of $(ARCH)/libscore.a. * sapi/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * sapi/Makefile.am: Build libsapi$(LIB_VARIANT).a instead of $(ARCH)/libsapi.a. * rtems/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * rtems/Makefile.am: Build librtems$(LIB_VARIANT).a instead of $(ARCH)/librtems.a. * libmisc/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * libmisc/Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a. * librpc/Makefile.am: Add libs to CLEANFILES. Set lib*_g_a_SOURCES = lib*_a_SOURCES. * librpc/Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a. * libblock/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * libblock/include/rtems/blkdev.h, libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c, libblock/src/ide_part_table.c, libblock/src/ramdisk.c: Switch to using c99 fixed size types instead of RTEMS-types. * libblock/Makefile.am: Build libblock$(LIB_VARIANT).a instead of $(ARCH)/libblock.a. * libfs/Makefile.am: Add libs to CLEANFILES. Set lib*_g_a_SOURCES = lib*_a_SOURCES. * libfs/Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a. * libcsupport/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * libcsupport/Makefile.am: Build libcsupport$(LIB_VARIANT).a instead of $(ARCH)/libcsupport.a. * libnetworking/Makefile.am: Remove *C_FILES. * libnetworking/Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES. * libnetworking/Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a. 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Reflect changes to library Makefile.ams. * automake/amcompile.am: New. * configure.ac: Add subdir-objects, AM_PROG_CC_C_O. * itron/Makefile.am, posix/Makefile.am, score/Makefile.am, sapi/Makefile.am, rtems/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libblock/Makefile.am, libfs/Makefile.am, libcsupport/Makefile.am, libnetworking/Makefile.am: Build library using EXTRA_LIBRARIES and automake rules. 2004-01-07 Joel Sherrill <joel@OARcorp.com> * aclocal/rtems-cpu-subdirs.m4, score/cpu/Makefile.am: mips64orion port removed as mips port more completely covers the MIPS family. * score/cpu/mips64orion/.cvsignore, score/cpu/mips64orion/ChangeLog, score/cpu/mips64orion/Makefile.am, score/cpu/mips64orion/asm.h, score/cpu/mips64orion/configure.ac, score/cpu/mips64orion/cpu.c, score/cpu/mips64orion/cpu_asm.S, score/cpu/mips64orion/cpu_asm.h, score/cpu/mips64orion/idtcpu.h, score/cpu/mips64orion/idtmon.h, score/cpu/mips64orion/iregdef.h, score/cpu/mips64orion/rtems/.cvsignore, score/cpu/mips64orion/rtems/score/.cvsignore, score/cpu/mips64orion/rtems/score/cpu.h, score/cpu/mips64orion/rtems/score/mips64orion.h, score/cpu/mips64orion/rtems/score/types.h: Removed. * libnetworking/rtems/rtems_bsdnet_internal.h: Include rtems/cdefs.h so things compile. 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs). 2003-12-17 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-20031217-test. 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 533/bsps * score/startup/linkcmds: Update linkcmds for gcc 3.3.2. 2003-12-16 Joel Sherrill <joel@OARcorp.com> PR 543/rtems * score/src/threadclose.c: Make the task delete extension run outside a dispatch disabled critical section so extensions can free resources. PR 542/filesystem * libcsupport/include/rtems/libio_.h: Add rtems_libio_iop_to_descriptor macro to convert iop to the corresponding integer file descriptor. 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB. * wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule. * aclocal/env-rtemscpu.m4: Add PROJECT_LIB. * wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib. 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, wrapup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * wrapup/Makefile.am: Reworked. * aclocal/lead-dot.m4: Remove (Use the version in automake-1.8). * automake/lib.am: Remove $(project_libdir)$(MULTISUBDIR). * aclocal/env-rtemscpu.m4: Reflect new definition of project_lib. * Makefile.am: Remove BUILT_SOURCES. * configure.ac: Require automake >= 1.8, autoconf >= 2.59. * itron/Makefile.am, posix/Makefile.am, score/Makefile.am, sapi/Makefile.am, rtems/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libblock/Makefile.am, libfs/Makefile.am, libcsupport/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * libcsupport/Makefile.am: Remove BUILT_SOURCES. * libnetworking/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/Makefile.am: Cosmetics. 2003-12-11 Joel Sherrill <joel@OARcorp.com> PR 540/rtems_misc * libmisc/cpuuse/cpuuse.c, libmisc/rtmonuse/rtmonuse.c: Correct object name printing. PR 531/rtems_misc * libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c: Correct indexing. 2003-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libblock/src/ata.c: Remove. 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Add $(ARCH)/$(dirstamp) rules. * wrapup/Makefile.am: Reflect $(dirstamp) changes. * Makefile.am: Add $(dirstamp) to preinstallation rules. * aclocal/lead-dot.m4: New (from automake-1.7f). * aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT. Add AC_SUBST(dirstamp). * itron/Makefile.am: Add $(dirstamp) to compilation rules. * itron/Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS. * posix/Makefile.am: Add $(dirstamp) to compilation rules. * posix/Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS. * score/Makefile.am: Add $(dirstamp) to compilation rules. * score/Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS. * sapi/Makefile.am: Add $(dirstamp) to compilation rules. Add AM_CPPFLAGS += -I$(top_builddir). * sapi/Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS. * rtems/Makefile.am: Add $(dirstamp) to compilation rules. Add AM_CPPFLAGS += -I$(top_builddir). * rtems/Makefile.am: Add $(dirstamp) to preinstallation rules. Remove MACROS. * libmisc/Makefile.am: Add $(dirstamp) to compilation rules. Fix misc. typos. * libmisc/Makefile.am: Add $(dirstamp) to preinstallation rules. * librpc/Makefile.am: Add $(dirstamp) to compilation rules. * librpc/Makefile.am: Add $(dirstamp) to preinstallation rules. * libblock/Makefile.am: Add $(dirstamp) to compilation rules. * libblock/Makefile.am: Add $(dirstamp) to preinstallation rules. * libfs/Makefile.am: Add $(dirstamp) to compilation rules. * libfs/Makefile.am: Add $(dirstamp) to preinstallation rules. * libcsupport/Makefile.am: Add $(dirstamp) to compilation rules. * libcsupport/Makefile.am: Add $(dirstamp) to preinstallation rules. * libnetworking/Makefile.am: Add $(dirstamp) to compilation rules. * libnetworking/Makefile.am: Fix libc_OBJS. * libnetworking/Makefile.am: Add $(dirstamp) to preinstallation rules. Restore libc/$(ARCH)/lib.a. 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Reflect having removed libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am. * configure.ac: Reflect changes to libmisc/*. * libmisc/Makefile.am: Reformat. * libmisc/capture/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/fsmount/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/serdbg/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am: Remove. * libmisc/Makefile.am: Merge-in the Makefile.ams above. * libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am: Remove. * libnetworking/Makefile.am: Merge-in the Makefile.ams above. 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Merge-in former libmisc/wrapup/Makefile.am. * configure.ac: Reflect changes to libfs Makefile.ams. Remove libmisc/wrapup/Makefile. * configure.ac: Use here-documents to generate cpuopts.tmp. Various fixes and changes to argument processing. Reflect changes to librpc Makefile.ams. * acinclude.m4: Use here-documents to generate cpuopts.tmp. * aclocal/check-itron.m4: Remove HAS_IRON_API. * aclocal/check-multiprocessing.m4: Remove HAS_MP. * aclocal/check-posix.m4: Remove HAS_POSIX_API. * libmisc/wrapup/Makefile.am, libmisc/wrapup/.cvsignore: Remove. * libmisc/Makefile.am: Reflect changes above. * librpc/src/rpc/Makefile.am, librpc/src/xdr/Makefile.am, librpc/src/Makefile.am: Removed. * librpc/Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am. Various fixes. Reformat. * librpc/include/rpc/rpc.hinclude/rpc/rpc.h: Rename struct rtems_rpc_task_variables into struct _rtems_rpc_task_variables (Avoid symbol conflict between struct and variable). struct _rtems_rpc_task_variables *rtems_rpc_task_variables; Reflect changes above. * librpc/src/rpc/clnt_perror.c, librpc/src/rpc/clnt_raw.c, librpc/src/rpc/clnt_simple.c, librpc/src/rpc/rpcdname.c, librpc/src/rpc/rtems_rpc.c, librpc/src/rpc/svc.c, librpc/ src/rpc/svc_auth.c, librpc/src/rpc/svc_raw.c, librpc/src/rpc/svc_simple.c: Reflect changes above. * libfs/Makefile.am: Merge-in src/Makefile.am, src/imfs/Makefile.am, src/dosfs/Makefile.am. * libfs/src/Makefile.am, libfs/src/imfs/Makefile.am, libfs/src/dosfs/Makefile.am: Removed. 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/canonicalize-tools.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rtems-debug.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/rtems-top.m4, aclocal/sysv-ipc.m4: Fix underquoting to silence automake-1.8. 2003-11-26 Joel Sherrill <joel@OARcorp.com> PR 524/filesystem * libcsupport/src/newlibc.c: Address 1K buffer leak from incomplete cleanup of newlib reentrancy handler. PR 523/filesystem * libcsupport/src/malloc.c: Make malloc family safer for use from ISRs and dispatching critical sections. If in a critical section while doing a free(), then the free is deferred until the next malloc() attempt. 2003-11-25 Joel Sherrill <joel@OARcorp.com> PR 526/rtems * score/src/threadcreateidle.c: Idle task name should be a string and PR484 broke this. 2003-11-25 Jennifer Averett <jennifer@OARcorp.com> PR 519/filesystem * libcsupport/include/rtems/libio_.h, libcsupport/src/eval.c, libcsupport/src/rmdir.c, libcsupport/src/unlink.c: Check write permissions in parent directory for file or directory delete. 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use RTEMS_INLINES instead of USE_INLINES. Elimimate INLINESdir. * aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS. * .cvsignore: Add config.h.in. 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Make RTEMS_DEBUG an RTEMS_CPUOPT. PR 525/rtems * score/include/rtems/system.h: Use RTEMS_INLINES instead of USE_INLINES. * score/include/rtems/score/chain.h, score/include/rtems/score/thread.h, score/src/chain.c, score/src/coremutexseize.c, score/src/threadget.c: Ditto. * score/Makefile.am: Don't use gmake to preinstall. * sapi/Makefile.am: Reworked. 2003-11-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Reflect having removed libnetworking/wrapup. * configure.ac: Ditto. * itron/Makefile.am, posix/Makefile.am, rtems/Makefile.am, libblock/Makefile.am: Reworked. * libcsupport/include/rtems/cdefs.h: Use _RTEMS_CDEFS_H guards. * libcsupport/include/rtems/cdefs.h: New. * libcsupport/Makefile.am: Completely reworked. * libnetworking/rtems/rtems_bsdnet_internal.h: Include rtems/cdefs.h instead of sys/cdefs.h (Nonportable). * libnetworking/wrapup/Makefile.am: Removed. * libnetworking/Makefile.am: Reworked. 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * acinclude.m4: New. * configure.ac: Don't use AUTOHEADER to generate cpuopts.h. Add local autoheader config.h. * aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST. * aclocal/enable-inlines.m4: Remove USE_MACROS (Unused). * itron/Makefile.am: Remove src/config.h. AM_CPPFLAGS += -I$(top_builddir). * posix/Makefile.am: Remove src/config.h AM_CPPFLAGS += -I$(top_builddir). * libmisc/capture/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/serdbg/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * libblock/Makefile.am: AM_CPPFLAGS += -I$(top_builddir). Use AM_CPPFLAGS instead of AM_CFLAGS. * libblock/src/ata.c: Include config.h. * libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/ide_part_table.c, libblock/src/ramdisk.c: Ditto. * libfs/src/dosfs/Makefile.am, libfs/src/imfs/Makefile.am: Remove config.h AM_CPPFLAGS += -I$(top_builddir). * itron/src/config.h, posix/src/config.h, libmisc/capture/config.h, libmisc/cpuuse/config.h, libmisc/devnull/config.h, libmisc/dummy/config.h, libmisc/dumpbuf/config.h, libmisc/monitor/config.h, libmisc/mw-fb/config.h, libmisc/rtmonuse/config.h, libmisc/serdbg/config.h, libmisc/stackchk/config.h, libmisc/shell/config.h, libmisc/untar/config.h, libfs/src/dosfs/config.h, libfs/src/imfs/config.h, libcsupport/src/config.h: Remove. * libcsupport/src/Makefile.am: AM_CPPFLAGS += -I$(top_builddir). 2003-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libfs/Makefile.am: Cosmetics. 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * rtems/src/regiongetsegment.c: Remove unneccessary typecast in assignment to thread->Wait.return_argment. 2003-10-22 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> PR 515/filesystem * libfs/src/dosfs/fat_fat_operations.c: Remove commented out code. 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 509/filesystem * libfs/src/dosfs/fat.c: _fat_block_read and _fat_block_write return error codes instead of -1 in case of errors, as they are supposed to do according to the comments documenting these functions. 2003-10-22 Joel Sherrill <joel@OARcorp.com> PR 512/core * rtems/src/tasks.c, rtems/src/taskvariabledelete.c: Run task variable destructor when task variable is deleted. Also some style cleanup. PR 440/filesystem * libfs/src/dosfs/fat_fat_operations.c: Improve write speed with FAT12 and FAT16 filesystems. Previously merged on 4.6 branch. * libfs/ChangeLog: Correct line length. PR 511/filesystem * libcsupport/src/malloc.c: Add deferred free and protect against C Program Heap operations while in a dispatch disable critical section or ISR. 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/check-posix.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/canonical-host.m4: Remove. * configure.ac: Remove RTEMS_CANONICAL_HOST. * aclocal/sysv-ipc.m4: Remove reference to RTEMS_CANONICAL_HOST. * aclocal/canonical-target-name.m4: Use AC_CANONICAL_HOST instead of AC_CANONICAL_TARGET. Use $host instead of $target. * aclocal/check-multiprocessing.m4: Add m4-quotes. Remove RTEMS_CHECK_CPU. * aclocal/check-itron.m4, aclocal/check-networking.m4: Add m4-quotes. Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU. * aclocal/check-cpu.m4: Remove. * aclocal/canonical-target-name.m4: Add m4-quotes. * configure.ac: Merge-in former aclocal/check-cpu.m4. * posix/src/cancelrun.c, posix/src/pthreadexit.c, posix/src/pthreadjoin.c, posix/ src/sigtimedwait.c: Remove unnecessary typecasts in assignments to thread->Wait.return_argument. * score/src/coremsgseize.c, score/src/coremsgsubmit.c: Remove unnecessary typecasts in assignments to thread->Wait.return_argument. * libmisc/capture/capture-cli.c: Reflect new rtems_monitor_command_arg_t. * librpc/src/rpc/Makefile.am, librpc/src/xdr/Makefile.am: Remove __P from AM_CPPFLAGS. Rely on sys/cdefs.h providing it. * libfs/src/dosfs/Makefile.am: noinst_HEADERS += fat.h. * libfs/src/dosfs/msdos_file.c (msdos_file_read, libfs/msdos_file_write): Use '0' as initial value for ret instead of RC_OK. * libfs/src/dosfs/msdos_conv.c: Remove isupper, islower, toupper, tolower (Unused). 2003-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Check for sys/cdefs.h. * aclocal/env-rtems-cpu.m4: Add project_includedir. Deprecate PROJECT_INCLUDE. Change project_includedir to $(PROJECT_ROOT)/include for multilibs. 2003-10-13 Joel Sherrill <joel@OARcorp.com> * posix/src/cleanuppop.c, posix/src/cleanuppush.c: Protect use of _Workspace_Allocate and _Workspec_Free. 2003-10-02 Phil Torre <ptorre@zetron.com> PR 504/rtems * score/include/rtems/score/coremutex.h: Add fatal error check for a task blocking on a mutex when thread dispatching is disabled. PR 504/rtems * libcsupport/src/newlibc.c: Fix memory allocation of libc extension so it is dispatch disabled safe See PR for detailed explanation. 2003-09-26 Till Strauman <strauman@slac.stanford.edu> PR 498/rtems * libcsupport/src/printk.c: RTEMS printk() does not support the %i format which is used by a lot of driver/BSP etc. code. The trivial patch allows %i/%I as an alias for %d/%D. 2003-09-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 495/rtems_misc * libmisc/capture/capture-cli.c, libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c, libmisc/monitor/monitor.h, libmisc/shell/cmds.c: Move to making libmisc 16/32 bit clean. 2003-09-26 Joel Sherrill <joel@OARcorp.com> * score/cpu/hppa1.1/.cvsignore, score/cpu/hppa1.1/ChangeLog, score/cpu/hppa1.1/Makefile.am, score/cpu/hppa1.1/configure.ac, score/cpu/hppa1.1/cpu.c, score/cpu/hppa1.1/cpu_asm.S, score/cpu/hppa1.1/rtems/.cvsignore, score/cpu/hppa1.1/rtems/score/.cvsignore, score/cpu/hppa1.1/rtems/score/cpu.h, score/cpu/hppa1.1/rtems/score/cpu_asm.h, score/cpu/hppa1.1/rtems/score/hppa.h, score/cpu/hppa1.1/rtems/score/types.h: Removed. PR 492/filesystem * libfs/src/dosfs/fat_file.c: Fix inconsistent types in va_args call. 2003-09-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, librpc/Makefile.am: Merge-in include/Makefile.am. * include/Makefile.am, librpc/include/Makefile.am: Remove. * configure.ac: Reflect having removed include/Makefile.am and librpc/include/Makefile.am. 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/monitor/monitor.h: Add rtems_monitor_commands[] (Illegally applied by shell/). Remove ifdef(__mips64) (Make broken code visible again). * libmisc/monitor/mon-command.c: Add several ifndef RTEMS_UNIX to avoid warnings. * libmisc/monitor/mon-monitor.c: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES (Make broken code visible again). * libmisc/shell/cmds.c: Remove local decls of rtems_monitor_commands[]. 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/monitor/monitor.h: Remove STREQ, STNEQ (pollute namespace), RTEMS_MONITOR_PROMPT (pollutes namespace, useless). * libmisc/monitor/mon-command.c: Add RTEMS_MONITOR_PROMPT. * libmisc/monitor/mon-monitor.c: Apply private version of STREQ. * libmisc/monitor/symbols.h: Convert to private header. * libmisc/monitor/monitor.h: Don't include symbols.h. Add forward decls. for symbols from symbols.h. * libmisc/monitor/Makefile.am: Don't install symbols.h. * libmisc/monitor/mon-symbols.c: Include "symbols.h". 2003-09-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 489/rtems * score/include/rtems/score/thread.h: Change struct Thread_Control_struct.libc_reent to using struct _reent*. * score/inline/rtems/score/thread.inl: Reflect change above. PR 489/rtems * libcsupport/src/newlibc.c: Reflect struct Thread_Control_struct.libc_reent having changed from void * to struct _reent*. 2003-09-15 Jay Monkman <jtm@smoothsmoothie.com> PR 482/networking * libnetworking/rtems/rtems_glue.c: Network interfaces can't be taken down. PR 481/networking * libnetworking/net/ethernet.h, libnetworking/net/if_arp.h, libnetworking/netinet/if_ether.h: Network structs should be packed. 2003-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libcsupport/src/sync.c: Don't undef __STRICT_ANSI__. Use struct _reent (struct reent doesn't exist). PR 486/rtems * libcsupport/src/newlib.c: Unconditionally include <stdio.h>. 2003-09-11 Joel Sherrill <joel@OARcorp.com> PR 488/rtems * rtems/src/taskcreate.c, rtems/src/tasks.c: Ensure notepads are zeroed. 2003-09-09 Ralf Corsepius <ralf_corsepius@rtems.com> PR 487/filesystem * libfs/src/dosfs/fat_file.c: Correct typing per gcc 3.3 warnings. 2003-09-08 Mikec Ivica <mikici@acm.org> * score/inline/rtems/score/userext.inl, score/macros/rtems/score/userext.inl: Add missing cast. 2003-09-08 Derick Hammond <derick@perkinstechnologies.com.au> PR 484/rtems * score/src/threadcreateidle.c: Idle task name was initialized incorrectly. 2003-09-04 Joel Sherrill <joel@OARcorp.com> * include/rtems/bspIo.h, include/rtems/fs.h, include/rtems/userenv.h, itron/include/itron.h, itron/include/itronsys/eventflags.h, itron/include/itronsys/fmempool.h, itron/include/itronsys/intr.h, itron/include/itronsys/mbox.h, itron/include/itronsys/msgbuffer.h, itron/include/itronsys/network.h, itron/include/itronsys/port.h, itron/include/itronsys/semaphore.h, itron/include/itronsys/status.h, itron/include/itronsys/sysmgmt.h, itron/include/itronsys/task.h, itron/include/itronsys/time.h, itron/include/itronsys/types.h, itron/include/itronsys/vmempool.h, itron/include/rtems/itron/config.h, itron/include/rtems/itron/eventflags.h, itron/include/rtems/itron/fmempool.h, itron/include/rtems/itron/intr.h, itron/include/rtems/itron/itronapi.h, itron/include/rtems/itron/mbox.h, itron/include/rtems/itron/msgbuffer.h, itron/include/rtems/itron/network.h, itron/include/rtems/itron/object.h, itron/include/rtems/itron/port.h, itron/include/rtems/itron/semaphore.h, itron/include/rtems/itron/sysmgmt.h, itron/include/rtems/itron/task.h, itron/include/rtems/itron/time.h, itron/include/rtems/itron/vmempool.h, itron/inline/rtems/itron/eventflags.inl, itron/inline/rtems/itron/fmempool.inl, itron/inline/rtems/itron/intr.inl, itron/inline/rtems/itron/mbox.inl, itron/inline/rtems/itron/msgbuffer.inl, itron/inline/rtems/itron/network.inl, itron/inline/rtems/itron/port.inl, itron/inline/rtems/itron/semaphore.inl, itron/inline/rtems/itron/sysmgmt.inl, itron/inline/rtems/itron/task.inl, itron/inline/rtems/itron/time.inl, itron/inline/rtems/itron/vmempool.inl, itron/macros/rtems/itron/eventflags.inl, itron/macros/rtems/itron/fmempool.inl, itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl, itron/macros/rtems/itron/msgbuffer.inl, itron/macros/rtems/itron/network.inl, itron/macros/rtems/itron/port.inl, itron/macros/rtems/itron/semaphore.inl, itron/macros/rtems/itron/sysmgmt.inl, itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl, itron/macros/rtems/itron/vmempool.inl, itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/cre_mbf.c, itron/src/cre_mbx.c, itron/src/cre_sem.c, itron/src/cre_tsk.c, itron/src/del_mbf.c, itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c, itron/src/dis_dsp.c, itron/src/ena_dsp.c, itron/src/eventflags.c, itron/src/exd_tsk.c, itron/src/ext_tsk.c, itron/src/fmempool.c, itron/src/frsm_tsk.c, itron/src/get_tid.c, itron/src/itronintr.c, itron/src/itronsem.c, itron/src/itrontime.c, itron/src/mbox.c, itron/src/mboxtranslatereturncode.c, itron/src/msgbuffer.c, itron/src/msgbuffertranslatereturncode.c, itron/src/network.c, itron/src/port.c, itron/src/prcv_mbf.c, itron/src/prcv_mbx.c, itron/src/preq_sem.c, itron/src/psnd_mbf.c, itron/src/rcv_mbf.c, itron/src/rcv_mbx.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c, itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c, itron/src/rot_rdq.c, itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/slp_tsk.c, itron/src/snd_mbf.c, itron/src/snd_mbx.c, itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/sysmgmt.c, itron/src/task.c, itron/src/ter_tsk.c, itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tslp_tsk.c, itron/src/tsnd_mbf.c, itron/src/twai_sem.c, itron/src/vmempool.c, itron/src/wai_sem.c, itron/src/wup_tsk.c, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/condmp.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mqueuemp.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/mutexmp.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/pthreadmp.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/semaphoremp.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/intr.inl, posix/inline/rtems/posix/key.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/intr.inl, posix/macros/rtems/posix/key.inl, posix/macros/rtems/posix/mqueue.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/pthread.inl, posix/macros/rtems/posix/semaphore.inl, posix/macros/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/kill.c, posix/src/killinfo.c, posix/src/mqueuetranslatereturncode.c, posix/src/pause.c, posix/src/pthreadattrdestroy.c, posix/src/pthreadattrgetdetachstate.c, posix/src/pthreadattrgetinheritsched.c, posix/src/pthreadattrgetschedparam.c, posix/src/pthreadattrgetschedpolicy.c, posix/src/pthreadattrgetscope.c, posix/src/pthreadattrgetstackaddr.c, posix/src/pthreadattrgetstacksize.c, posix/src/pthreadattrinit.c, posix/src/pthreadattrsetdetachstate.c, posix/src/pthreadattrsetinheritsched.c, posix/src/pthreadattrsetschedparam.c, posix/src/pthreadattrsetschedpolicy.c, posix/src/pthreadattrsetscope.c, posix/src/pthreadattrsetstackaddr.c, posix/src/pthreadattrsetstacksize.c, posix/src/pthreadcreate.c, posix/src/pthreaddetach.c, posix/src/pthreadequal.c, posix/src/pthreadexit.c, posix/src/pthreadgetcpuclockid.c, posix/src/pthreadgetcputime.c, posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c, posix/src/pthreadkill.c, posix/src/pthreadonce.c, posix/src/pthreadself.c, posix/src/pthreadsetcputime.c, posix/src/pthreadsetschedparam.c, posix/src/pthreadsigmask.c, posix/src/sigaction.c, posix/src/sigaddset.c, posix/src/sigdelset.c, posix/src/sigemptyset.c, posix/src/sigfillset.c, posix/src/sigismember.c, posix/src/signal_2.c, posix/src/sigpending.c, posix/src/sigprocmask.c, posix/src/sigqueue.c, posix/src/sigsuspend.c, posix/src/sigtimedwait.c, posix/src/sigwait.c, posix/src/sigwaitinfo.c, posix/src/ualarm.c, score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/copyrt.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/mppkt.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/objectmp.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/states.inl, score/inline/rtems/score/sysstate.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/threadmp.inl, score/inline/rtems/score/tod.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/watchdog.inl, score/inline/rtems/score/wkspace.inl, score/macros/rtems/score/address.inl, score/macros/rtems/score/chain.inl, score/macros/rtems/score/coremsg.inl, score/macros/rtems/score/coremutex.inl, score/macros/rtems/score/coresem.inl, score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl, score/macros/rtems/score/mppkt.inl, score/macros/rtems/score/object.inl, score/macros/rtems/score/objectmp.inl, score/macros/rtems/score/priority.inl, score/macros/rtems/score/stack.inl, score/macros/rtems/score/states.inl, score/macros/rtems/score/sysstate.inl, score/macros/rtems/score/thread.inl, score/macros/rtems/score/threadmp.inl, score/macros/rtems/score/tod.inl, score/macros/rtems/score/tqdata.inl, score/macros/rtems/score/userext.inl, score/macros/rtems/score/watchdog.inl, score/macros/rtems/score/wkspace.inl, score/src/apiext.c, score/src/chain.c, score/src/coremsg.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/coremutexsurrender.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemseize.c, score/src/coresemsurrender.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c, score/src/heap.c, score/src/heapallocate.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetinfo.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c, score/src/interr.c, score/src/isr.c, score/src/iterateoverthreads.c, score/src/mpci.c, score/src/object.c, score/src/objectallocate.c, score/src/objectallocatebyindex.c, score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetbyindex.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectidtoname.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectshrinkinformation.c, score/src/thread.c, score/src/threadchangepriority.c, score/src/threadclearstate.c, score/src/threadclose.c, score/src/threadcreateidle.c, score/src/threaddelayended.c, score/src/threaddispatch.c, score/src/threadevaluatemode.c, score/src/threadget.c, score/src/threadhandler.c, score/src/threadidlebody.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqtimeout.c, score/src/threadready.c, score/src/threadreset.c, score/src/threadresettimeslice.c, score/src/threadrestart.c, score/src/threadresume.c, score/src/threadrotatequeue.c, score/src/threadsetpriority.c, score/src/threadsetstate.c, score/src/threadsettransient.c, score/src/threadstackallocate.c, score/src/threadstackfree.c, score/src/threadstart.c, score/src/threadstartmultitasking.c, score/src/threadsuspend.c, score/src/threadtickletimeslice.c, score/src/threadyieldprocessor.c, score/src/userext.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c, score/src/wkspace.c, sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/include/rtems/mptables.h, sapi/include/rtems/sptables.h, sapi/include/rtems/sptables.h.in, sapi/inline/rtems/extension.inl, sapi/macros/rtems/extension.inl, sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, rtems/include/rtems.h, rtems/include/rtems/rtems/asr.h, rtems/include/rtems/rtems/attr.h, rtems/include/rtems/rtems/cache.h, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/config.h, rtems/include/rtems/rtems/dpmem.h, rtems/include/rtems/rtems/event.h, rtems/include/rtems/rtems/eventmp.h, rtems/include/rtems/rtems/eventset.h, rtems/include/rtems/rtems/intr.h, rtems/include/rtems/rtems/message.h, rtems/include/rtems/rtems/modes.h, rtems/include/rtems/rtems/mp.h, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/options.h, rtems/include/rtems/rtems/part.h, rtems/include/rtems/rtems/partmp.h, rtems/include/rtems/rtems/ratemon.h, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/rtemsapi.h, rtems/include/rtems/rtems/sem.h, rtems/include/rtems/rtems/semmp.h, rtems/include/rtems/rtems/signal.h, rtems/include/rtems/rtems/signalmp.h, rtems/include/rtems/rtems/status.h, rtems/include/rtems/rtems/support.h, rtems/include/rtems/rtems/taskmp.h, rtems/include/rtems/rtems/tasks.h, rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h, rtems/inline/rtems/rtems/asr.inl, rtems/inline/rtems/rtems/attr.inl, rtems/inline/rtems/rtems/dpmem.inl, rtems/inline/rtems/rtems/event.inl, rtems/inline/rtems/rtems/eventset.inl, rtems/inline/rtems/rtems/message.inl, rtems/inline/rtems/rtems/modes.inl, rtems/inline/rtems/rtems/options.inl, rtems/inline/rtems/rtems/part.inl, rtems/inline/rtems/rtems/ratemon.inl, rtems/inline/rtems/rtems/region.inl, rtems/inline/rtems/rtems/sem.inl, rtems/inline/rtems/rtems/status.inl, rtems/inline/rtems/rtems/support.inl, rtems/inline/rtems/rtems/tasks.inl, rtems/inline/rtems/rtems/timer.inl, rtems/macros/rtems/rtems/asr.inl, rtems/macros/rtems/rtems/attr.inl, rtems/macros/rtems/rtems/dpmem.inl, rtems/macros/rtems/rtems/event.inl, rtems/macros/rtems/rtems/eventset.inl, rtems/macros/rtems/rtems/message.inl, rtems/macros/rtems/rtems/modes.inl, rtems/macros/rtems/rtems/options.inl, rtems/macros/rtems/rtems/part.inl, rtems/macros/rtems/rtems/ratemon.inl, rtems/macros/rtems/rtems/region.inl, rtems/macros/rtems/rtems/sem.inl, rtems/macros/rtems/rtems/status.inl, rtems/macros/rtems/rtems/support.inl, rtems/macros/rtems/rtems/tasks.inl, rtems/macros/rtems/rtems/timer.inl, rtems/src/attr.c, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/clocktick.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/intr.c, rtems/src/intrbody.c, rtems/src/intrcatch.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c, rtems/src/msgqsubmit.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionreturnsegment.c, rtems/src/rtclock.c, rtems/src/rtemsidtoname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmode.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c, rtems/src/taskvariableget.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserver.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, libmisc/cpuuse/cpuuse.c, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.c, libmisc/devnull/devnull.h, libmisc/dummy/dummy.c, libmisc/dumpbuf/dumpbuf.c, libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h, libmisc/serdbg/serdbgio.c, libmisc/serdbg/termios_printk.c, libmisc/stackchk/check.c, libmisc/stackchk/internal.h, libmisc/stackchk/stackchk.h, libmisc/untar/untar.c, libmisc/untar/untar.h, libblock/include/rtems/ide_part_table.h, libblock/src/ata.c, libblock/src/ide_part_table.c, libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h, libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_handlers_dir.c, libfs/src/dosfs/msdos_handlers_file.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c, libfs/src/dosfs/msdos_node_type.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_chown.c, libfs/src/imfs/imfs_config.c, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/imfs_fcntl.c, libfs/src/imfs/imfs_fdatasync.c, libfs/src/imfs/imfs_free.c, libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_getchild.c, libfs/src/imfs/imfs_gtkn.c, libfs/src/imfs/imfs_handlers_device.c, libfs/src/imfs/imfs_handlers_directory.c, libfs/src/imfs/imfs_handlers_link.c, libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_link.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_mount.c, libfs/src/imfs/imfs_ntype.c, libfs/src/imfs/imfs_readlink.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/imfs_symlink.c, libfs/src/imfs/imfs_unixstub.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/imfs_unmount.c, libfs/src/imfs/imfs_utime.c, libfs/src/imfs/ioman.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/memfile.c, libfs/src/imfs/miniimfs_init.c, libcsupport/include/chain.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/rtc.h, libcsupport/include/spurious.h, libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/termios.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libcsupport/src/__brk.c, libcsupport/src/__gettod.c, libcsupport/src/__sbrk.c, libcsupport/src/__times.c, libcsupport/src/access.c, libcsupport/src/base_fs.c, libcsupport/src/cfgetispeed.c, libcsupport/src/cfgetospeed.c, libcsupport/src/cfsetispeed.c, libcsupport/src/cfsetospeed.c, libcsupport/src/chdir.c, libcsupport/src/chmod.c, libcsupport/src/chown.c, libcsupport/src/chroot.c, libcsupport/src/close.c, libcsupport/src/ctermid.c, libcsupport/src/dup.c, libcsupport/src/dup2.c, libcsupport/src/eval.c, libcsupport/src/fchdir.c, libcsupport/src/fchmod.c, libcsupport/src/fcntl.c, libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c, libcsupport/src/fs_null_handlers.c, libcsupport/src/fstat.c, libcsupport/src/fsync.c, libcsupport/src/ftruncate.c, libcsupport/src/getdents.c, libcsupport/src/getpwent.c, libcsupport/src/hosterr.c, libcsupport/src/ioctl.c, libcsupport/src/isatty.c, libcsupport/src/libio.c, libcsupport/src/libio_sockets.c, libcsupport/src/link.c, libcsupport/src/lseek.c, libcsupport/src/lstat.c, libcsupport/src/malloc.c, libcsupport/src/mallocfreespace.c, libcsupport/src/mkdir.c, libcsupport/src/mkfifo.c, libcsupport/src/mknod.c, libcsupport/src/mount.c, libcsupport/src/newlibc.c, libcsupport/src/no_libc.c, libcsupport/src/no_posix.c, libcsupport/src/open.c, libcsupport/src/pathconf.c, libcsupport/src/pipe.c, libcsupport/src/privateenv.c, libcsupport/src/read.c, libcsupport/src/readlink.c, libcsupport/src/rewinddir.c, libcsupport/src/rmdir.c, libcsupport/src/seekdir.c, libcsupport/src/stat.c, libcsupport/src/symlink.c, libcsupport/src/sync.c, libcsupport/src/tcdrain.c, libcsupport/src/tcflow.c, libcsupport/src/tcflush.c, libcsupport/src/tcgetattr.c, libcsupport/src/tcgetprgrp.c, libcsupport/src/tcsendbreak.c, libcsupport/src/tcsetattr.c, libcsupport/src/tcsetpgrp.c, libcsupport/src/telldir.c, libcsupport/src/termios.c, libcsupport/src/termiosinitialize.c, libcsupport/src/truncate.c, libcsupport/src/umask.c, libcsupport/src/unixlibc.c, libcsupport/src/unlink.c, libcsupport/src/unmount.c, libcsupport/src/utime.c, libcsupport/src/write.c, libnetworking/rtems/mkrootfs.c, libnetworking/rtems/mkrootfs.h: URL for license changed. PR 479/rtems_misc * libcsupport/src/malloc.c: Per multiple standards realloc does not free the original memory if the allocation of the requested larger block fails. 2003-09-03 Joel Sherrill <joel@OARcorp.com> * libfs/msdos_create.c: Remove unused variable warning. 2003-09-02 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/open.c: Fix typo. * libcsupport/src/malloc.c: Remove test define left in. 2003-09-02 Jiri Gaisler <jiri@gaisler.com> PR 476/networking * libnetworking/machine/in_cksum.h: Fix in_cksum calculation on SPARC. 2003-09-02 Ilya Alexeev <ilya@continuum.ru> PR 472/filesystem src/malloc.c: Need to include apimutex.h when MALLOC_STATS is defined. 2003-08-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/rtems-top.m4: Add RTEMS_API. AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]). 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/rtems-debug.m4: Remove. * aclocal/enable-rtems-debug.m4, aclocal/check-rtems-debug.m4: New (Split out from rtems-debug.m4). * automake/local.am: Remove "debug". PR 449/rtems: * posix/src/getegid.c, posix/src/geteuid.c, posix/src/getgid.c, posix/src/getgroups.c, posix/src/getlogin.c, posix/src/getpgrp.c, posix/src/getpid.c, posix/src/getppid.c, posix/src/getuid.c, posix/src/setpgid.c, posix/src/setsid.c: Remove (Moved to ../libcsupport/src). * posix/Makefile.am: Reflect changes above. PR 449/rtems: * libcsupport/src/getegid.c, libcsupport/src/geteuid.c, libcsupport/src/getgid.c, libcsupport/src/getgroups.c, libcsupport/src/getlogin.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/getuid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c: New (Copied from ../posix/src). * libcsupport/src/no_posix: Remove getpid and _getpid_r. * libcsupport/Makefile.am: Reflect changes above. 2003-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/fsmount/Makefile.am: Fix path to automake-includes. 2003-08-14 Joel Sherrill <joel@OARcorp.com> * posix/src/mqueuenametoid.c, posix/src/semaphorenametoid.c: Added ID to name lookup service and changed name of id/name translation status code. This propagated to multiple functions. The user API service added was rtems_object_id_to_name(). PR 92/rtems * posix/Makefile.am, posix/src/alarm.c, posix/src/psignal.c: Added ualarm() and usleep(). * posix/src/ualarm.c, posix/src/usleep.c: New files. * score/Makefile.am, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/src/objectmp.c, score/src/objectnametoid.c: Added ID to name lookup service and changed name of id/name translation status code. This propagated to multiple functions. The user API service added was rtems_object_id_to_name(). * score/src/objectidtoname.c: New file. PR 408/filesystem * score/score/Makefile.am, score/score/include/rtems/score/thread.h: Added sync() service. As part of adding this service, the new RTEMS service rtems_iterate_over_all_threads() was also added. This new service makes it easier to iterate over all the tasks/threads in a system and perform an action on them. * score/score/src/iterateoverthreads.c: New file. * score/ChangeLog: Fixed screwup. * sapi/src/extensionident.c, rtems/Makefile.am, rtems/include/rtems.h, rtems/include/rtems/rtems/status.h, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c: Added ID to name lookup service and changed name of id/name translation status code. This propagated to multiple functions. The user API service added was rtems_object_id_to_name(). * rtems/src/rtemsidtoname.c: New file. PR 408/filesystem * libmisc/cpuuse/cpuuse.c: Added sync() service. As part of adding this service, the new RTEMS service rtems_iterate_over_all_threads() was also added. This new service makes it easier to iterate over all the tasks/threads in a system and perform an action on them. This change is to use the new thread iteration service. * libcsupport/Makefile.am: Add fileio to list of interactive tests. * libcsupport/src/sync.c: New (Copied from ../posix/src). New file. 2003-08-13 Joel Sherrill <joel@OARcorp.com> * libmisc/fsmount/.cvsignore: New file. 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use rtems-bugs@rtems.com as bug report email address. 2003-08-11 Joel Sherrill <joel@OARcorp.com> * configure.ac: Removed duplicate entry. 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Add libmisc/fsmount/Makefile. 2003-08-06 Till Strauman <strauman@slac.stanford.edu> PR 435/networking * libnetworking/rtems/rtems_showifstat.c: rtems_showifstat misses printing the netmask. 2003-08-06 Thomas Doerfler<Thomas.Doerfler@imd-systems.de> PR 369/filesystem * libmisc/Makefile.am, libmisc/shell/cmds.c, libmisc/wrapup/Makefile.am: sample application to show the use of the DOSFS functions. * libmisc/fsmount/Makefile.am, libmisc/fsmount/README, libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: New files. 2003-08-05 Till Strauman <strauman@slac.stanford.edu> PR 436/rtems_misc * libmisc/monitor/mon-monitor.c: monitor registered commands list manipulation bugs. PR 442/filesystem * libcsupport/src/open.c: file never closed if ftruncate() fails in open(). 2003-08-05 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> PR 440/filesystem * libfs/src/dosfs/fat_fat_operations.c: Improve write data speed for DOSFS FAT12/FAT16 systems. PR 439/filesystem * libfs/src/dosfs/fat_file.c: flush temporary buffer when closing files. 2003-08-05 <djc915@mail.usask.ca> PR 443/filesystem * libfs/src/imfs/deviceio.c: deviceio.c mishandles return codes. 2003-08-04 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> PR 441/filesystem * libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_mknod.c: add rename support to DOSFS. 2003-07-24 Jennifer Averett <jennifer.averett@OARcorp.com> PR 434/filesystem * libfs/src/imfs/imfs_init.c, libfs/src/imfs/miniimfs_init.c: Modified to return error code. * libfs/src/imfs/imfs_initsup.c: Modified to set error upon memory failure. 2003-07-18 Till Straumann <strauman@slac.stanford.edu> PR 430/rtems * score/include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should be a VOLATILE variable. * score/src/watchdoginsert.c: 'restart' algorithm needs to enforce reloading the list head in case a TICK interrupt during ISR_Flash() modified the list. This is achieved by a proper VOLATILE cast. Also _Watchdog_Sync_count++ should be protected by _ISR_Disable (prevent corruption in case ISR calls watchdoginsert). * score/src/watchdogadjust.c: ISR protection added. * score/src/watchdogtickle.c: ISR protection added. NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED to maintain _ISR_Nest_level. See also PR288 which provides fixes for the affected BSPs distributed with RTEMS. 2003-07-16 Joel Sherrill <joel@OARcorp.com> * libfs/ChangeLog: Correct format. 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Remove '/' after $(DESTDIR). * wrapup/Makefile.am: Remove bogus $(MULTISUBDIR). 2003-07-15 Chris Johns <cjohns@cybertec.com.au> PR 431/filesystem * libfs/src/dosfs/msdos.h: MSDOS Volume semaphore timeout is now NO TIMEOUT. MSDOS volume opertations will wait for ever. 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Merge-in librpc/configure.ac. * Makefile.am: Add librpc to SUBDIRS. Remove @subdirs@. * configure.ac: Merge-in libcsupport/configure.ac. * Makefile.am: Add libcsupport to SUBDIRS. * configure.ac: Merge-in posix/configure.ac. Merge-in itron/configure.ac. Misc. cosmetical changes. * Makefile.am: Add posix, itron to SUBDIRS. * configure.ac: Merge-in libnetworking/configure.ac. Remove "rtems-" from RTEMS_VERSION. Add AC_CHECK_FUNCS([strsep strcasecmp snprintf]). * Makefile.am: Add libmisc to SUBDIRS. * configure.ac: Merge-in libmisc/configure.ac. * Makefile.am: Add libmisc to SUBDIRS. * configure.ac: Merge-in libfs/configure.ac. * Makefile.am: Add libfs to SUBDIRS. * configure.ac: Merge-in libblock/configure.ac. * Makefile.am: Add libblock to SUBDIRS. * configure.ac: Merge-in ada/configure.ac. * Makefile.am: Add ada to SUBDIRS. * itron/configure.ac: Remove (Merged-in into ../configure.ac). * itron/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * itron/src/config.h: New. * posix/configure.ac: Remove (Merged-in into ../configure.ac). * posix/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * posix/src/config.h: New. * score/cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU). * libmisc/configure.ac: Remove (Merged into ../configure.ac). * libmisc/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * libmisc/capture/config.h: New. * libmisc/capture/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/cpuuse/config.h: New. * libmisc/cpuuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/devnull/config.h: New. * libmisc/devnull/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/dummy/config.h: New. * libmisc/dummy/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/dumpbuf/config.h: New. * libmisc/dumpbuf/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/monitor/config.h: New. * libmisc/monitor/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/mw-fb/config.h: New. * libmisc/mw-fb/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/rtmonuse/config.h: New. * libmisc/rtmonuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/serdbg/config.h: New. * libmisc/serdbg/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/shell/config.h: New. * libmisc/shell/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/stackchk/config.h: New. * libmisc/stackchk/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/untar/config.h: New. * libmisc/untar/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * libmisc/wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/cpuuse/cpuuse.c, libmisc/devnull/devnull.c, libmisc/dummy/dummy.c, libmisc/dumpbuf/dumpbuf.c, libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c, libmisc/monitor/mon-manager.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c, libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c, libmisc/monitor/mon-task.c, libmisc/mw-fb/mw_fb.c, libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c, libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbgio.c, libmisc/serdbg/termios_printk.c, libmisc/shell/cmds.c, libmisc/stackchk/check.c, libmisc/untar/untar.c: Add config-header support. * librpc/configure.ac: Remove (Merged-in into ../configure.ac). * librpc/Makefile.am, librpc/include/Makefile.am, librpc/src/Makefile.am, librpc/src/rpc/Makefile.am, librpc/src/xdr/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * libblock/configure.ac: Remove (Merged into ../configure.ac). * libblock/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * libfs/configure.ac: Remove (Merged-in into ../configure.ac). * libfs/Makefile.am, libfs/src/Makefile.am, libfs/src/dosfs/Makefile.am, libfs/src/imfs/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * libfs/src/dosfs/config.h: New. * libfs/src/dosfs/Makefile.am: Add config.h. * libfs/src/imfsfs/config.h: New. * libfs/src/imfs/Makefile.am: Add config.h. Remove COMMON_C_FILES, DOC_FILES (Unused). * libfs/src/dosfs/fat.c: include config-header "config.h". * libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_conv.c: Ditto. * libcsupport/configure.ac: Remove (Merged-in into ../configure.ac). * libcsupport/Makefile.am: DOC_FILES = src/TODO src/CASES, Reflect having merged configure.ac into ../configure.ac. * libcsupport/src/config.h: New. * libnetworking/configure.ac: Remove (Merged into ../configure.ac). * libnetworking/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/lib/Makefile.am, libnetworking/wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac. * libnetworking/kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease. 2003-07-08 Joel Sherrill <joel@OARcorp.com> PR 419/rtems * libcsupport/src/termios.c: Removed warning. 2003-07-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/configure.ac: Remove RTEMS_BSP from RTEMS_CHECK_MULTIPROCESSING. 2003-07-07 Joel Sherrill <joel@OARcorp.com> PR 417/rtems * score/src/coresemsurrender.c: Correct incorrect check for maximum_count reported by Sergei Organov <osv@topconrd.ru>. 2003-07-03 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20030703. 2003-07-02 Chris Johns <cjohns@cybertec.com.au> * libfs/src/dosfs/Makefile.am, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_misc.c: Patch from Victor V. Vengerov <vvv@oktet.ru> to remove Linux code. * libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Comment have been updated. * libcsupport/include/rtems/libio.h, libcsupport/src/termios.c: Add the rtems_termios_bufsize call. 2003-06-13 Joel Sherrill <joel@OARcorp.com> * score/src/threadloadenv.c: Removed warnings. 2003-06-12 Joel Sherrill <joel@OARcorp.com> * score/src/objectmp.c, rtems/include/rtems/rtems/msgmp.h, rtems/include/rtems/rtems/partmp.h, rtems/include/rtems/rtems/regionmp.h, rtems/include/rtems/rtems/semmp.h, rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/semmp.c: Removed warnings. 2003-06-10 Phil Torre <ptorre@zetron.com> PR 411/filesystem * libfs/src/imfs/imfs_unlink.c: Fix bug where renaming a memfile and then unlinking it causes a memory leak. 2003-06-04 Joel Sherrill <joel@OARcorp.com> * libmisc/stackchk/check.c, libblock/src/ide_part_table.c: Removed warnings. 2003-05-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * rtems/include/rtems/rtems/types.h: Include stdint.h. * libcsupport/Makefile.am: Conditionally install stdint.h/inttypes.h. * libcsupport/configure.ac: Check for system-stdint.h/inttypes.h. 2003-05-29 Joel Sherrill <joel@OARcorp.com> * libnetworking/rtems/rtems_syscall.c: Removed warnings. 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 409/core * include/Makefile.am: Add rtems/stdint.h. * include/rtems/stdint.h: New. PR 321/bsps * aclocal/env-rtemscpu.m4: Remove support for profile-variant. * automake/compile.am, automake/local.am: Ditto. PR 409: * rtems/include/rtems/rtems/types.h: Include rtems/stdint.h. Apply c99-types to typedef rtems_[un]signed[8|16|32|64]. PR 409: * libcsupport/include/stdint.h: Include rtems/stdint.h. 2003-05-15 cjohns@cybertec.com.au <cjohns@cybertec.com.au> * libnetworking/netinet/in.h: PR406 - Added INET_ADDRSTRLEN per the SUSv3 standard. 2003-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Remove LIBSUFFIX_VA (unused). 2003-05-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/env-rtemscpu.m4: Merge-in env-rtemsbsp.m4. * aclocal/env-rtemsbsp.m4, aclocal/enable-rtemsbsp.m4: Remove. * aclocal/env-rtemscpu.m4: Remove stray '/' in setting up project_libdir. 2003-04-17 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> PR 399/rtems_misc * libcsupport/src/termios.c: In canonical mode, when input is present in the input buffer that contains an EOL character and some following characters, a read call read data behind the EOL character, although it should stop reading with the EOL character. 2003-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/dummy/Makefile.am: Remove stray dummy.rel. * libcsupport/src/no_posix.c: include <reent.h> instead of <sys/reent.h>. 2003-04-17 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20030417. 2003-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 389/rtems * libcsupport/src/no_posix.c: Correct _kill_r() prototype and make it conditional on newlib. 2003-04-15 Joel Sherrill <joel@OARcorp.com> PR 388/networking * libnetworking/kern/kern_sysctl.c: Revert previous patch and use strlcpy() now that it is available. Also fixed some warnings. 2003-04-11 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20020411. 2003-04-03 Eri Valette <eric.valette@free.fr> PR 381/core * libcsupport/src/newlibc.c: Switch from using _REENT_INIT to _REEINT_INIT_PTR to fix strange run-time problem where EIP was corrupted on pc386 BSP. 2003-03-27 Joel Sherrill <joel@OARcorp.com> * libblock/Makefile.am: ATA code depends upon libchip/ide which is not allowed in the cpukit source code since it must be buildable independent of any BSP. These files were moved to libchip/ide. * libblock/include/rtems/ata.h, libblock/include/rtems/ata_internal.h, libblock/src/ata.c: Removed. * libnetworking/kern/kern_sysctl.c: Converted from BSP strlcpy() to strncpy(). 2003-03-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> PR 367/filesystem * libblock/Makefile.am, libblock/include/rtems/ide_part_table.h, libblock/src/ata.c, libblock/src/ide_part_table.c: Some bugs were still present in the DOSFS implementation: - FAT12 did not work properly on Big-Endian machines - Some synchronization and error handling problems were present - Some legal codings for EOC were not recognized. PR 367/filesystem * libfs/src/dosfs/Makefile.am, libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c: Some bugs were still present in the DOSFS implementation: - FAT12 did not work properly on Big-Endian machines. - Some synchronization and error handling problems were present. - Some legal codings for EOC were not recognized. 2003-03-25 Joel Sherrill <joel@OARcorp.com> * libnetworking/rtems/rtems_bsdnet_malloc_starvation.c: Fixed name of include file. 2003-03-18 Till Straumann <strauman@slac.stanford.edu> PR 356/bsps * score/src/threadhandlerc: This patch makes RTEMS/PowerPC eabi compliant. Let Thread_Handler verify that _init/_main are non-NULL before calling them (gives the linker script/user more freedom to handle special cases). PR 356/bsps * libnetworking/sys/linker_set.h: This patch makes RTEMS/PowerPC eabi compliant. Declare all linker-script defined addresses as variables of unknown size and not as short objects like 'int', 'void*' etc. Since only addresses are used and never those variable's values, the type used in a declaration is not important. 2003-03-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libcsupport/configure.ac: AC_CHECK_FUNCS(strlcpy strlcat). * libcsupport/src/strlcat.c, libcsupport/src/strlcpy.c: New (extracted from pppd/utils.c). * libcsupport/Makefile.am: Add BSD_C_FILES, strlcat.c, strlcpy.c. 2003-03-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Remove '/' after $(DESTDIR) to work around Cygwin mistreating paths. 2003-03-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Reflect changes to project_libdir. * aclocal/env-rtemscpu.m4: Remove obsolete comment. Add MULTISUBDIR to project_libdir. * aclocal/env-rtemscpu.m4: Remove RTEMS_ROOT (Unused). * aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT (Unused). Remove RTEMS_PROJECT_ROOT (Unused). * aclocal/tool-paths.m4: Delete. 2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove AC_CONFIG_AUX_DIR. * aclocal/rtems-top.m4: Add AC_CONFIG_AUX_DIR. * configure.ac: AC_PREREQ(2.57). * configure.ac: Remove sptables.h.in. * itron/configure.ac: Remove AC_CONFIG_AUX_DIR. * sapi/Makefile.am: Remove stray reference to sptables.h.in. * sapi/include/rtems/sptables.h: New. * sapi/include/rtems/sptables.h.in, sapi/include/.cvsignore, sapi/include/rtems/.cvsignore, sapi/inline/.cvsignore, sapi/inline/rtems/.cvsignore, sapi/macros/.cvsignore, sapi/macros/rtems/.cvsignore, sapi/src/.cvsignore: Remove. * libmisc/configure.ac, libblock/configure.ac, libfs/configure.ac, libcsupport/configure.ac, libnetworking/configure.ac: Remove AC_CONFIG_AUX_DIR. * libnetworking/netinet/in_chksum.c: Remove duplicate case to include in_chksum_arm.c. 2003-02-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove AC_SUBST(RTEMS_VERSION). AC_DEFINE(RTEMS_VERSION) to propagate it through cpuopts.h. * sapi/include/rtems/sptables.h.in: Remove RTEMS_VERSION (Moved to cpuopts.h). 2003-02-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_SUBST(RTEMS_VERSION,_RTEMS_VERSION). 2003-02-20 Wolfram Wadepohl <W.Wadepohl@indumat.de> PR 357/rtems_misc * libcsupport/src/termios.c (rtems_termios_open): Fixed code the incorrectly checked that the wrong pointer during allocation was NULL. 2003-02-20 Till Straumann <strauman@slac.stanford.edu> PR 351/networking * libnetworking/nfs/bootp_subr.c: Fix ridiculous leak in bootp and use strdup_bootp_realloc() everywhere for sake of consistency. 2003-02-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/gcc-isystem.m4: New. * aclocal/gcc-specs.m4: Remove. * aclocal/prog-cc.m4: Remove RTEMS_GCC_SPECS. Add RTEMS_GCC_ISYSTEM. Reformat setting up RTEMS_CPPFLAGS. * automake/local.am: Introduce depend-gcc. Remove ${ARCH}. * automake/compile.am: Remove GCCSPECS, GCC_SPECS, CONFIG.CC, CC, CPP. Add ${ARCH}. depend-gcc. * aclocal/prog-cc.m4: Set up RTEMS_CPPFLAGS. * aclocal/env-rtemscpu.m4: Remove GCC_SPECS. * aclocal/env-rtemsbsp.m4: Remove GCC_SPECS. capture/capture-cli.c: Add proper definition to avoid compiler warnings. Apply int = getchar(). * libcsupport/src/privateenv.c: Fix prototype for free_user_env. 2003-02-14 Till Straumann <strauman@slac.stanford.edu> PR 352/rtems_misc * libmisc/shell/shell.c: make rtems_shell main task an FP enabled task. 2003-02-14 Joel Sherrill <joel@OARcorp.com> AMD a29k declared obsolete. * score/cpu/Makefile.am: Removed reference. * score/cpu/a29k/.cvsignore, score/cpu/a29k/ChangeLog, score/cpu/a29k/Makefile.am, score/cpu/a29k/amd.ah, score/cpu/a29k/asm.h, score/cpu/a29k/configure.ac, score/cpu/a29k/cpu.c, score/cpu/a29k/cpu_asm.S, score/cpu/a29k/pswmacro.ah, score/cpu/a29k/register.ah, score/cpu/a29k/sig.S, score/cpu/a29k/rtems/.cvsignore, score/cpu/a29k/rtems/score/.cvsignore, score/cpu/a29k/rtems/score/a29k.h, score/cpu/a29k/rtems/score/cpu.h, score/cpu/a29k/rtems/score/cpu_asm.h, score/cpu/a29k/rtems/score/types.h: Removed. 2003-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/canonical-target-name.m4: Transform tic4x -> RTEMS_CPU=c4x. 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * itron/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * itron/configure.ac: AC_PREREQ(2.57). * posix/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * posix/configure.ac: AC_PREREQ(2.57). * librpc/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * librpc/configure.ac: AC_PREREQ(2.57). * libblock/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * libblock/configure.ac: AC_PREREQ(2.57). * libfs/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * libfs/configure.ac: AC_PREREQ(2.57). * libcsupport/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * libcsupport/configure.ac: AC_PREREQ(2.57). * libnetworking/configure.ac: AM_INIT_AUTOMAKE([1.7.2]). * libnetworking/configure.ac: AC_PREREQ(2.57). 2003-02-11 Mike Siers <mikes@poliac.com> * libnetworking/rtems/rtems_glue.c: A small patch to the network daemon task code. I just added code to check the return value of the rtems_bsdnet_event_receive function. Only when this function returns a SUCCESSFUL status, will the event flags be checked. This is more of a code cleanup issue than a bug. The patch will just ensure the ipintr() and arpintr() functions are only called when a event is signaled. 2003-02-06 Mike Siers <mikes@poliac.com> PR 342/networking * libnetworking/kern/uipc_mbuf.c: The RTEMS version of the m_copyback is changing the m_len value of the mbuf. I looked into the source from another BSD system and the mbuf length is not changed inside this function. The m_copyback function is only being used in the net/rtsock.c file. So I think this problem is only visable under certain routing table conditions. 2003-02-06 Joel Sherrill <joel@OARcorp.com> * libcsupport/include/sys/ioccom.h: Include <sys/types.h> not <machine/types.h> so Linux port builds. 2003-02-05 Till Straumann <strauman@slac.stanford.edu> PR 340/filesystem * libcsupport/src/fcntl.c: Add missing _fcntl_r assumed to exist by newlib. 2003-02-05 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> PR 341/networking * libnetworking/lib/ftpfs.c: Account for NULL at end of strings when malloc()'ing memory. 2003-02-05 Joel Sherrill <joel@OARcorp.com> * libcsupport/include/sys/ioccom.h: Fix so not using internal RTEMS types in libc code. 2003-02-03 Till Straumann <strauman@slac.stanford.edu> PR 339/filesystem * libcsupport/src/chroot.c: Fix violation of FS node object copy semantics. 2003-02-03 Steven Johnson <sjohnson@neurizon.net> PR 338/filesystem * libfs/src/imfs/ioman.c: Fix reentrancy problem with rtems_io_lookup_name() (API change). 2003-02-03 Joel Sherrill <joel@OARcorp.com> PR 338/filesystem * sapi/include/rtems/io.h, sapi/src/io.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). PR 338/filesystem * libcsupport/src/unixlibc.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). 2003-01-28 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20030128. * libnetworking/Makefile.am: Add kern/kern_sysctl.c to Makefile.am so networking tests build. This was subsequently reported as PR337 before I committed the fix. 2003-01-27 Till Straumann <strauman@SLAC.Stanford.edu> * libnetworking/libc/getproto.c, libnetworking/libc/getprotoname.c: modification to call getprotoent_static() if fopen() on /etc/protocols fails. 2003-01-27 Juan Zamorano <jzamora@fi.upm.es> * posix/src/ptimer1.c: Correct problem which could lead to overflow in time math. 2003-01-27 Eugeny S. Mints <Eugeny.Mints@oktet.ru> * libblock/src/blkdev.c: Per PR331 fix bug which is tripped by writing 512 byte blocks to 512 byte aligned positions. 2003-01-27 Dan Smisko <dan@balanced.com> * libmisc/stackchk/check.c: Fix problem where _Objects_Get_information() will dereference a null pointer when checking the interrupt stack. If there's something at 0, you may be ok at run time but it is wrong. * libmisc/monitor/mon-command.c: Correct two potential NULL references. 2003-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/local.am: Remove distclean-local. Remove PROJECT_TOOLS. 2003-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Remove CLEAN_DEPEND (Unused). Remove CLOBBER_DEPEND (Unused). 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/netinet/tcp_subr.c, libnetworking/netinet/udp_usrreq.c: Add args to INP_INFO_RLOCK, INP_INFO_RUNLOCK, INP_LOCK, INP_UNLOCK macros. 2003-01-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libcsupport/Makefile.am: Eliminate OBJS. 2003-01-10 Joel Sherrill <joel@OARcorp.com> * score/src/objectmp.c: Corrected use of name parameter to reflect that it is actually the name not a pointer to the name. * rtems/src/msg.c, rtems/src/part.c, rtems/src/sem.c, rtems/src/tasks.c: Correct object class control structure initialization for multiprocessing configurations. * libcsupport/include/rtems/libio.h: Rename __dev_t to __rtems_dev_t to avoid conflict with GNU/Linux header files. 2003-01-03 Till Straumann <strauman@slac.stanford.edu> PR 303 * libcsupport/src/base_fs.c, libcsupport/src/getpwent.c, libcsupport/src/privateenv.c: Fix violation of node_access copy symantics. 2003-01-03 Joel Sherrill <joel@OARcorp.com> * posix/ChangeLog: Corrected entry for sysconf.c which did not include PR. 2003-01-03 Jitendra Vegiraju <jvegiraju@netscape.net> * libnetworking/sys/queue.h: Fix alignment problem on ARM. 2003-01-03 Jay Monkman <jtm@smoothsmoothie.com> * posix/src/mqueueopen.c: Actually open the message queue descriptor so it is available for others to use. 2003-01-03 Eugeny S. Mints <Eugeny.Mints@oktet.ru> * libblock/src/ata.c, libblock/src/bdbuf.c: Correct invocation of rtems_task_mode() so the task's preemption mode setting is properly maintained. * libfs/src/dosfs/msdos_initsupp.c: Specify inherited priority as 0 since this is a FIFO queuing semaphore. 2003-01-03 Chris Johns <cjohns@cybertec.com.au> * libnetworking/Makefile.am: Added sys/linker_set.h. * libnetworking/kern/Makefile.am: Added kern_mib.c and kern_sysctl.c. * libnetworking/kern/uipc_socket.c: OID changed from KERN_SOMAXCONN to KIPC_SOMAXCONN. * libnetworking/kern/uipc_socket2.c: OID changed from KERN_MAXSOCKBUF to KIPC_MAXSOCKBUF. * libnetworking/net/if_ethersubr.c: FreeBSD 2.2.2 does not have a _net_link node while 5.0 does. * libnetworking/net/if_ppp.c: Removed the TEXT_SET define as these macros are now implemented. * libnetworking/net/rtsock.c: Enable sysctl support plus fix the bug with the lastest FreeBSD sysctl header file. * libnetworking/netinet/icmp_var.h: FreeBSD 2.2.2 does not have a _net_inet_icmp node while 5.0 does. * libnetworking/netinet/if_ether.c: FreeBSD 2.2.2 does not have a _net_link_ether node while 5.0 does. * libnetworking/netinet/igmp_var.h: FreeBSD 2.2.2 does not have a _net_inet_igmp node while 5.0 does. * libnetworking/netinet/in_pcb.c: Fixed the arguments to the sysctl call. Add inp_gencnt and ipi_count. These are used when listing connections. * libnetworking/netinet/in_pcb.h: Added counters to aid the listing of connections. * libnetworking/netinet/in_var.h: Provide the _net_inet_ip and _net_inet_raw nodes. * libnetworking/netinet/ip_fw.c: Disable the firewall sysctl calls. * libnetworking/netinet/tcp_subr.c: Merge tcp_pcblist from the lastest FreeBSD source. * libnetworking/netinet/tcp_var.h: Add structures needed by net-snmp to list connections. * libnetworking/netinet/udp_usrreq.c: Merged udp_pcblist from the lastest FreeBSD source. * libnetworking/netinet/udp_var.h: Added the sysctl id UDPCTL_PCBLIST. Used by net-snmp. * libnetworking/rtems_glue.c: Call sysctl_register_all when initialising the network stack to register all the sysctl calls. These are in the special sections and required an updated linker script. * libnetworking/rtems/rtems_syscall.c: Add the sysctl call. * libnetworking/sys/kernel.h: Use the lastest FreeBSD method of handling sysctl structures. This now held in the sys/linker_set.h file. * libnetworking/sys/queue.h: This is from the lastest FreeBSD code with the circular code merged back in as it is not used in the lastest FreeBSD kernel. * libnetworking/sys/sysctl.h: The lastest sysctl. This was needed to use with the new linker set method. The FreeBSD 2.2.2 version has asm hacks. The lastest version of the FreeBSD does not have these hacks. It uses gcc attribute directives. 2002-12-26 Till Straumann <strauman@slac.stanford.edu * libcsupport/src/fchdir.c: PR302 fix violation of FS node object copy semantics. 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Remove $(RTEMS_BSP_CFLAGS). 2002-12-18 Eric Norum <eric.norum@usask.ca> * libnetworking/Makefile.am: Include netinet sources. 2002-12-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in from the 2002-12-12 patch). 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Fix typo in yesterday's patch. 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Don't create $ARCH. Use install-data-local to install librtemscpu.a. * wrapup/Makefile.am: Add libmisc. * configure.ac: Add AC_CONFIG_SUBDIR(libmisc). * itron/Makefile.am, posix/Makefile.am: Don't create $ARCH as side-effect of compilation. * score/Makefile.am: Don't create $ARCH. * sapi/Makefile.am: Don't create $ARCH as side-effect of compilation. * rtems/Makefile.am: Don't create $ARCH as side-effect of compilation. Re-order all-local. * libmisc/configure.ac: Require autoconf-2.57+automake-1.7.2. * libmisc/capture/Makefile.am: Eliminate C_O_FILES. * libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/serdbg/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am: Ditto. * libmisc/mw-fb/Makefile.am: Eliminate C_O_FILES. Eliminate SRCS. Moving libmisc from rtems/c/src to rtems/cpukit. * libmisc/Makefile.am: Reflect new path. * libmisc/configure.ac: Reflect new path. Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP. Remove RTEMS_PROJECT_ROOT. * libmisc/capture/Makefile.am: Reflect new path. Remove OBJS from all-local. * libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/serdbg/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am: Ditto. * libmisc/wrapup/Makefile.am: Reflect new path. * libblock/Makefile.am: Eliminate C_O_FILES. Eliminate SRCS. * libfs/src/imfs/Makefile.am: Eliminate C_O_FILES. * libfs/src/dosfs/Makefile.am: Ditto. * libnetworking/Makefile.am: Merge-in kern/Makefile.am, net/Makefile.am, netinet/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am. * libnetworking/kern/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems/Makefile.am: Remove. * libnetworking/wrapup/Makefile.am: Reflect changes above. * libnetworking/configure.ac: Ditto. 2002-12-11 Vladimir Nesic <vnesic@dkts.co.yu> * posix/src/cancelrun.c, posix/src/cleanuppop.c: Get the last real node not the permanent null last node. 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/kern/Makefile.am: Remove C_O_FILES. Don't let all-local depend on $OBJS). * libnetworking/lib/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems/Makefile.am: Ditto. 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. * libmisc/capture/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/serdbg/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am, libmisc/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg. 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4: Remove RTEMS_CHECK_CUSTOM_BSP. * aclocal/check-bsps.m4: Remove. * wrapup/Makefile.am: Remove *_OBJS, use LIBS+= instead. * configure.ac: Require autoconf >= 2.54, automake-1.7.2. * wrapup/Makefile.am, configure.ac: Reflect changes to score/. * wrapup/Makefile.am, configure.ac: Reflect changes to sapi/. * configure.ac: Add AC_SUBST(INLINEdir). * wrapup/Makefile.am, configure.ac: Reflect changes to rtems/. * wrapup/Makefile.am: Reflect changes to posix/. Reflect changes to itron/. * itron/include/Makefile.am, itron/inline/Makefile.am, itron/macros/Makefile.am, itron/src/Makefile.am: Remove. * itron/Makefile.am: Merge-in removed Makefile.ams. * itron/configure.ac: Reflect changes above. * posix/include/Makefile.am, posix/inline/Makefile.am, posix/macros/Makefile.am, posix/src/Makefile.am: Remove. * posix/Makefile.am: Merge-in removed Makefile.ams. * posix/configure.ac: Reflect changes above. * score/Makefile.am: Fix macro-file installation. * score/Makefile.am: Move include/rtems/score/cpuopts.h to STD_H_FILES. * score/include/Makefile.am, score/inline/Makefile.am, score/macros/Makefile.am, score/src/Makefile.am: Remove. * score/Makefile.am: Merge-in removed Makefile.ams. * sapi/include/Makefile.am, sapi/inline/Makefile.am, sapi/macros/Makefile.am, sapi/src/Makefile.am: Remove. * sapi/Makefile.am: Merge-in removed Makefile.ams. * rtems/include/Makefile.am, rtems/inline/Makefile.am, rtems/macros/Makefile.am, rtems/src/Makefile.am: Remove. * rtems/Makefile.am: Merge-in removed Makefile.ams. 2002-12-06 Vladimir Nesic <vnesic@dkts.co.yu> * posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl: Implemented PTHREAD_COND_INITIALIZER support. Vladimir implemented the inline version and Joel adapted it to the macro version. 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Rework *FLAGS, AM_*FLAGS handling. * automake/multilib.am: Don't include @RTEMS_BSP@.cfg. * automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Hard-code RTEMS_CFLAGS_PROFILE = -pg. * aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4. Remove GCCSED. * aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. * aclocal/rtems-flags.m4: New. * libcsupport/configure.ac: Add various checks to enhance portability. * libcsupport/src/termios.c: Reflect changes to configure.ac. 2002-12-06 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/malloc.c: Fixed code that incorrected did a disable dispatch instead of locking and unlocking the allocator mutex. 2002-12-02 Joel Sherrill <joel@OARcorp.com> * posix/include/rtems/posix/timer.h, posix/src/keygetspecific.c, posix/src/posixtimespecsubtract.c, posix/src/ptimer1.c, posix/src/semunlink.c: Added casts to eliminate warnings on 16-bit targets like the h8300. * score/include/rtems/score/object.h, score/include/rtems/score/tod.h, rtems/include/rtems/rtems/support.h: Added casts to eliminate warnings on 16 bit targets like the h8300. * libmisc/stackchk/check.c: Better handling of task name. * libblock/src/bdbuf.c: Added cast to remove warning. * libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h: Added casts to remove warnings on 16 bit targets like the h8300. * libcsupport/include/rtems/libio.h: Internally use a union of an unsigned64 and major/minor device so we don't get into trouble shifting. The h8300 seemed to be impossible to remove warnings otherwise. Eventually the structure definition of a dev_t might be better anyway. * libcsupport/include/sys/ioccom.h: Added casts to remove warnings on 16 bit targets. 2002-11-29 Eric Norum <eric.norum@usask.ca> PR 316 * posix/src/sysconf.c: Add support for _SC_GETPW_R_SIZE_MAX. Return error rather than panic if argument is unsupported. 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V (Unused). * aclocal/sysv-ipc.m4: Adaptation to autoconf-2.5x. * aclocal/check-newlib.m4: Sync with ../aclocal/check-newlib.m4. * itron/configure.ac: Cosmetical fixes. * itron/configure.ac: Fix package name. * posix/configure.ac: Cosmetical fixes. * posix/configure.ac, librpc/configure.ac, libblock/configure.ac: Fix package name. * libfs/configure.ac: Cosmetical fixes. * libfs/configure.ac: Fix package name. * libcsupport/configure.ac: Cosmetical fixes. * libcsupport/configure.ac, libnetworking/configure.ac: Fix package name. 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rtems/libio_.h: Remove. * libcsupport/configure.ac: Check for sys/cdefs.h, Add NEED_SYS_CDEFS_H. Add check for CHAR_BIT. * libcsupport/Makefile.am: Conditionally install sys/cdefs.h iff using newlib or if the host does not provide sys/cdefs.h (Fixes Linux/posix). * libcsupport/configure.ac: Remove -ansi -fasm. Add checks to diagnose potential system header conflicts. * libcsupport/Makefile.am: Unconditionally install sys/cdefs.h. * libnetworking/Makefile.am: Merge-in HEADER-handling from net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am. * libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am: Remove *_HEADERS. 2002-11-18 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20021118. 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rtems/userenv.h: Rely upon <limits.h> for _POSIX_LOGIN_NAME_MAX. * aclocal/prog-cc.m4: Acknowledge configuration-time CFLAGS. * automake/compile.am: Acknowledge configuration-time CFLAGS. Remove CFLAGS_DEFAULT. * libmisc/monitor/mon-commands.c: Removed warnings for RTEMS_UNIX. * libblock/src/diskdevs.c: Include <unistd.h> to remove warning. * libnetworking/Makefile.am: Merge-in arpa/Makefile.am, machine/Makefile.am, sys/Makefile.am, vm/Makefile.am. Add . to SUBDIRS. * libnetworking/arpa/Makefile.am, libnetworking/machine/Makefile.am, libnetworking/sys/Makefile.am, libnetworking/vm/Makefile.am: Remove. * libnetworking/configure.ac: Reflect changes above. 2002-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/capture/Makefile.am, libmisc/serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS. * libmisc/serdbg/serdbgio.c: Add #include <unistd.h>. * libmisc/shell/Makefile.am, libmisc/wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional. * libmisc/configure.ac: Check for stdio assignments. Add RTEMS_LIBSHELL conditional. 2002-11-14 Joel Sherrill <joel@OARcorp.com> * score/macros/rtems/score/object.inl: Keep consistent with inline version. 2002-11-13 Paul Whitfield <paulw@microsol.iinet.net.au> * rtems/src/regionreturnsegment.c: When RTEMS_REGION_SHRED_ON_FREE is set, there should have been an & in front of size. 2002-11-11 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20021111. 2002-11-07 <strauman@slac.stanford.edu> * libcsupport/src/mount.c: Per PR297, correct fs_mountme failure paths. 2002-11-06 Chris Johns <ccj@acm.org> * libnetworking/sys/select.h: Add C++ to C external. 2002-11-04 Joel Sherrill <joel@OARcorp.com> * librpc/src/rpc/pmap_rmt.c: Removed warnings. 2002-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/kern/uipc_mbuf.c: Comment out m0 in m_copydata to suppress warning. 2002-11-01 Joel Sherrill <joel@OARcorp.com> * ChangeLog, posix/ChangeLog: Corrected. * libmisc/stackchk/check.c: Removed warnings. * libcsupport/ChangeLog, libnetworking/ChangeLog: Corrected. 2002-11-01 Eric Norum <eric.norum@usask.ca> * libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c: Till Straumann's patch (PR295) to use bootp option 129 to get command line string. Till Straumann's patch to change inet_ntoa->inet_ntop. 2002-10-31 Joel Sherrill <joel@OARcorp.com> * score/src/heapgetinfo.c: Fixed comment. * score/src/mpci.c: Removed warning. * rtems/src/regiongetinfo.c: Corrected return value check. * libmisc/stackchk/check.c: Removed warning. * librpc/src/rpc/svc_run.c: Remove warning. * libcsupport/src/mallocfreespace.c: Corrected sense of status check to match change inside RTEMS. * libcsupport/src/newlibc.c: Removed warning. * libnetworking/libc/rcmd.c, libnetworking/netinet/in_cksum_arm.c: Removed warnings. 2002-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/check-bsp-cache.m4: Remove. 2002-10-30 Eric Norum <eric.norum@usask.ca> * include/rtems/bspIo.h: Add vprintk function for kernel printing from routines which have already obtained the va_list pointer. * posix/src/psignal.c: Fix counting problem which resulted in too many entries being in the POSIX signals default behavior table. * posix/src/psignal.c: Reflect changes to signal names in newlib. * libcsupport/src/printk.c: Add vprintk function for kernel printing from routines which have already obtained the va_list pointer. 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER. 2002-10-28 Joel Sherrill <joel@OARcorp.com> * score/src/threadhandler.c: Prototype _init() and _main() if they are needed to avoid a warning. * rtems/src/timerserver.c: Add useless return to avoid warning. * librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtime.c, librpc/src/rpc/svc_tcp.c: Add include of <sys/select.h> to eliminate warning. * librpc/src/rpc/rpcdname.c: Add prototype of getdomainname() to eliminate warning. * libcsupport/include/rtems/libio.h: Change rtems_filesystem_node_types_t from enumeration to int to eliminate warnings when values are overridden. * Pass to eliminate warnings. * libnetworking/kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__. Fix return statement without a value. * libnetworking/lib/ftpfs.c: read and write filesystem routines return ssize_t. * libnetworking/lib/syslog.c: Add include of <string.h> to eliminate warning. * libnetworking/lib/tftpDriver.c: read and write filesystem routines return ssize_t. * libnetworking/libc/gethostbydns.c: Prototype abort(). * libnetworking/libc/inet_ntoa.c: Prototype strcpy(). * libnetworking/libc/rcmd.c: Add include of <sys/select.h>. * libnetworking/net/if_loop.c: Turn token at end of endif to comment. * libnetworking/net/rtsock.c, libnetworking/nfs/bootp_subr.c: Conditional SYSINIT() usage on __rtems__. * libnetworking/rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>. * libnetworking/rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and memset() since the BSD code tries to avoid using libc .h files since it is used to being in the kernel. * libnetworking/rtems/rtems_syscall.c: read and write filesystem routines return ssize_t. 2002-10-28 Eugeny S. Mints <Eugeny.Mints@oktet.ru> * libblock/*: Added ATA support. * libblock/include/rtems/blkdev.h: Added last IO status. * libblock/include/rtems/ata.h, libblock/include/rtems/ata_internal.h, libblock/include/rtems/ide_part_table.h, libblock/src/ata.c, libblock/src/ide_part_table.c: New files. 2002-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/monitor/mon-command.c: Don't build rtems_monitor_line_editor for RTEMS_UNIX to avoid gcc warning. 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac, itron/configure.ac, posix/configure.ac, librpc/configure.ac, libblock/configure.ac, libfs/configure.ac, libcsupport/configure.ac, libnetworking/configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. * libnetworking/Makefile.am: Remove bogus reference to CHANGELOG. 2002-10-24 Fabrizio Pirovano <pirovano.thysys@tiscalinet.it> * libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c: Patch to remove problems introduced by object name rework. 2002-10-24 <strauman@slac.stanford.edu> * libcsupport/src/eval.c: Per PR293, added freenode calls for evaluate link failures. 2002-10-23 <strauman@slac.stanford.edu> PR 290 * src/mount.c: Add check for ops->node_type_h. PR 291 * src/mknod.c: Remove erroneous call to freenod. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore, itron/.cvsignore, posix/.cvsignore, libmisc/.cvsignore, librpc/.cvsignore, libblock/.cvsignore, libfs/.cvsignore, libcsupport/.cvsignore, libnetworking/.cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-10-21 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-20021021-test. 2002-10-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/net/if_ethersubr.c: Add comments to #endif NETATALK to stop gcc from complaining. 2002-10-07 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20021007. 2002-10-07 Eric Norum <eric.norum@usask.ca> * libnetworking/netinet/tcp_var.h: Corrected typo in ARM alignment patch which broke all other ports. 2002-10-04 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-JUNK. * aclocal/version.m4: Updated to rtems-ss-20021004. 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com> * libnetworking/netinet/in_cksum.c, libnetworking/netinet/ip_icmp.h, libnetworking/netinet/ip_input.c, libnetworking/netinet/tcp_input.c, libnetworking/netinet/tcp_subr.c, libnetworking/netinet/tcp_var.h, libnetworking/sys/queue.h: Address alignment requirements for the ARM. * libnetworking/rtems/rtems_glue.c: Add IP aliasing ioctls SIOCAIFADDR and SIOCDIFADDR. 2002-10-02 Joel Sherrill <joel@OARcorp.com> * libnetworking/kern/uipc_socket.c: Make sure that small non-zero delays work. Suggested cleanup from Eric Norum. 2002-10-02 Jennifer Averett <jennifer@OARcorp.com> * libfs/src/imfs/memfile.c: Fixed case where last close of unlinked file did not remove the resources associated with that file. Reported by Till Straumann <strauman@slac.stanford.edu> on the mailing list. 2002-10-02 Eric Norum <eric.norum@usask.ca> * libcsupport/src/getpwent.c: Per PR283, reimplement to address reentrancy problems. * libcsupport/src/getgrent.c: Removed as functionality is now just a wrapper for common routines in src/getpwent.c. * libcsupport/Makefile.am: Reflect file removal. * libnetworking/rtems/mkrootfs.c: As part of PR283, remove redundant code that creates /etc/passwd and /etc/group. 2002-09-16 Joel Sherrill <joel@OARcorp.com> * libnetworking/netinet/Makefile.am, libnetworking/netinet/udp_usrreq.c: Back off some of the IP_FORWARD patch as it appears to not compile in the current tree. 2002-09-14 Vyacheslav V. Burdjanadze <wr@zelax.ru> * libnetworking/kern/uipc_mbuf.c, libnetworking/sys/mbuf.h, libnetworking/netinet/udp_usrreq.c: Add optional UDP broadcast forwarding support. * libnetworking/netinet/Makefile.am: Defined FORWARD_PROTOCOL to enabled UDP broadcast forwarding. 2002-09-14 Joel Sherrill <joel@OARcorp.com> * posix/src/psignal.c: Remove duplication from rtems/posix/psignal.h. * rtems/src/dpmemcreate.c, rtems/src/dpmemident.c, rtems/src/msgqcreate.c, rtems/src/msgqident.c, rtems/src/partcreate.c, rtems/src/partident.c, rtems/src/ratemoncreate.c, rtems/src/ratemonident.c, rtems/src/regioncreate.c, rtems/src/regionident.c, rtems/src/semcreate.c, rtems/src/semident.c, rtems/src/taskcreate.c, rtems/src/taskident.c, rtems/src/timercreate.c, rtems/src/timerident.c: Added casts to Objects_Name to eliminate warnings. * libfs/src/dosfs/fat.c, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/memfile.c: Eliminated warnings. A lot of this focus was on changing read and write entry points to return ssize_t as read(2) and write(2) now do. * libcsupport/include/rtems/libio.h: Change rtems_filesystem_read_t and rtems_filesystem_write_t to return ssize_t to match read(2) and write(2) respectively. * libnetworking/kern/uipc_socket.c: Fix case on SO_RCVTIMEO and SO_SNDTIMEO where conversion into ticks can result in a 0 ticks timeout which is the same as requesting no timeout. Reported by Sergei Organov <osv@javad.ru>. 2002-09-14 Eric Norum <eric.norum@usask.ca> * libcsupport/src/readdir_r.c: New file. * libcsupport/Makefile.am: Reflect above. 2002-09-07 Joel Sherrill <joel@OARcorp.com> * libblock/src/bdbuf.c: Previous fix for PR282 regressed mutex changes. 2002-09-06 Alexander M. Kukuta <kam@oktet.ru> * libblock/src/bdbuf.c: Per PR282, correct problem in function rtems_bdbuf_read() where device ioctl() is called with the logical device number used instead of corresponding physical device number. 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/netinet/in_cksum.c: #include <string.h> for puts in generic routines. 2002-08-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/shell/shell.c: #include <time.h>. * libmisc/wrapup/Makefile.am: Eliminate LIBNAME. 2002-08-30 Joel Sherrill <joel@OARcorp.com> * sapi/src/io.c: Fixed some spacing. 2002-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/Makefile.am: Remove cpuopt.h generation. * configure.ac: Correct package name. Don't build ada if POSIX is disabled. Generate cpuopt.h on the fly, filter out autoconf-2.53 PACKAGE crap. * aclocal/prog-gnat.m4: New. * configure.ac: Add ada subdir handling. 2002-08-21 Joel Sherrill <joel@OARcorp.com> * posix/src/adjtime.c: New file -- adjtime() support required by the Network Time Protocol (NTP) port to RTEMS. * posix/src/Makefile.am: Modified to reflect above. 2002-08-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/bsp-alias.m4: Remove. 2002-08-20 Joel Sherrill <joel@OARcorp.com> * librpc/src/xdr/xdr_stdio.c: Per PR268, add include of <netinet/in.h> to avoid warning on ntohl(). 2002-08-20 Eric Norum <eric.norum@usask.ca> * libnetworking/rtems/rtems_glue.c: Per PR270, the BSD network code expects that the value of the number of seconds since boot is non-zero. The RTEMS network initialization code assures this by waiting for a second. A more efficient technique is to simply wait until the number of seconds since boot is non-zero. 2002-08-14 Joel Sherrill <joel@OARcorp.com> * score/macros/rtems/score/coremsg.inl: Add <string.h> to remove warning. * score/src/threadidlebody.c: Add return 0 to avoid warning. 2002-08-12 Eric Norum <eric.norum@usask.ca> * libcsupport/src/write.c (_write_r): Change prototype to match newlib's reent.h. 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/capture/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/serdbg/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am: Use .$(OBJEXT) instead of .o. * librpc/src/rpc/rtems_portmapper.c: include <stdlib.h> (Get rid of gcc31 warnings about abort/exit). 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/shell/Makefile.am: Remove shell.h from EXTRA_DIST. 2002-08-09 Joel Sherrill <joel@OARcorp.com> * posix/src/cancelrun.c: Remove check for PTHREAD_CANCELED not being defined to ensure that newlib patch includes it. * libnetworking/libc/getservent.c: Per PR265, add #include <netinet/in.h> for ntohl() function. 2002-08-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Add missing ',' to librpc activation. Add AC_MSG_CHECKING/AC_MSG_RESULT. * aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU. * configure.ac: Fix bug in librpc activation, having introduced by yesterday's patch. 2002-08-07 Joel Sherrill <joel@OARcorp.com> * aclocal/version.m4: Updated to rtems-ss-20020807. * libnetworking/netinet/in.h: Per PR263, added include of <machine/endian.h> to <netinet/in.h> so it includes prototypes of ntohl() family of routines. 2002-08-07 Chris Johns <ccj@acm.org> * score/src/coretodset.c: Correct calculation of ticks until next section boundary. It was incorrectly based upon current time not the time that is being set. 2002-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP. * aclocal/env-rtemscpu.m4: Remove RTEMS_CONFIG_PER_BSP. Use AS_IF instead of if/then/else/fi. 2002-08-06 Joel Sherrill <joel@OARcorp.com> * configure.ac, librpc/configure.ac: or32 does not currently support librpc. 2002-08-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Use librtems.a. * wrapup/Makefile.am: Use libsapi.a. * sapi/src/Makefile.am: Add libsapi.a. * rtems/src/Makefile.am: Add librtems.a. * libnetworking/wrapup/Makefile.am: Don't install. 2002-08-01 Joel Sherrill <joel@OARcorp.com> * libmisc/cpuuse/cpuuse.c (CPU_usage_Dump) : Corrected so it honors when an object name is raw versus being a string. * libnetworking/machine/param.h, libnetworking/sys/syslimits.h: In the continued effort to eliminate .h conflicts between newlib and RTEMS, these were moved to newlib. * libnetworking/machine/Makefile.am, libnetworking/sys/Makefile.am: Reflect above. 2002-07-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Use libscore.a. * aclocal/canonicalize-tools.m4, automake/lib.am: Remove LD. * Makefile.am: Put preinstall-stamp into CLEANFILES. * aclocal/rtems-top.m4: Use with_project_root and MULTIBUILDTOP to compose PROJECT_TOPdir (Fixes hppa1.1/genoffset problem). * wrapup/Makefile.am: LIBBLOCK_OBJS = ../libblock/$(ARCH)/libblock.a. * posix/src/mqueuecreatesupp.c: #include <stdlib.h> (malloc). * score/src/Makefile.am: Build into libscore.a. * libblock/Makefile.am: Merge src/Makefile.am. * libblock/src/Makefile.am: Remove. * libblock/configure.ac: Remove src/Makefile.am. * libfs/wrapup/Makefile.am, libfs/wrapup/.cvsignore: Remove. * libfs/Makefile.am: Remove wrapup SUBDIR. * libfs/configure.ac: Remove wrapup/Makefile. 2002-07-31 Joel Sherrill <joel@OARcorp.com> * aclocal/rtems-cpu-subdirs.m4: Removed the or16 port was just a stub and only the OR32 port is getting worked on. 2002-07-30 Joel Sherrill <joel@OARcorp.com> * libmisc/stackchk/check.c: Don't reference the RTEMS allocated interrupt stack if the port doesn't configure using it. * libcsupport/include/sys/utime.h: Removed as file is now part of the RTEMS newlib support. * libcsupport/Makefile.am: Reflect above. * libcsupport/include/rtems/termiostypes.h: Avoid use of __P. * libnetworking/sys/param.h: Removed as a simpler version of this file is now part of the RTEMS newlib support. * libnetworking/sys/Makefile.am: Modified to reflect above. * libnetworking/machine/types.h: Removed as a simpler version of this file is now part of the RTEMS newlib support. * libnetworking/machine/Makefile.am, libnetworking/machine/endian.h, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/Makefile.am, libnetworking/sys/systm.h: Minor modifications to use the simpler machine/types.h. Mostly more complete sets of #include's to account for machine/types.h no longer doing this. 2002-07-30 Jay Monkman <jtm@smoothsmoothie.com> * libnetworking/netinet/in_cksum.c, libnetworking/netinet/in_cksum_arm.c: Added ARM in_cksum support. 2002-07-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * librpc/src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am. * librpc/include/Makefile.am: Merge include/rpc/Makefile.am. Merge include/rpcsvc/Makefile.am. * librpc/include/rpc/Makefile.am, librpc/include/rpcsvc/Makefile.am, librpc/src/rpc/PSD.doc/Makefile.am: Remove. * librpc/configure.ac: Remove duplicate AC_PROG_RANLIB. Remove include/rpc/Makefile. Remove include/rpcsvc/Makefile. Remove src/rpc/PSD.doc/Makefile. 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am: Use .$(OBJEXT) instead of .o. 2002-07-24 Joel Sherrill <joel@OARcorp.com> * libmisc/wrapup/Makefile.am: Temporarily don't include serdbg since it causes some BSPs to not link "main(){}" as required by autoconf. * libnetworking/sys/select.h: Add a prototype of select() to avoid warnings. In particular a C++ application using select() required a prototype. * libnetworking/Makefile.am, libnetworking/libc/res_send.c: Do not install or use <poll.h> since RTEMS does not support it. 2002-07-23 Joel Sherrill <joel@OARcorp.com> * librpc/src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h. 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use project_libdir instead of $(PROJECT_RELEASE)/lib. Eliminate LIBNAME. Pickup *.o's instead of *.rels for CPU_OBJS. Manually create $(project_libdir)$(MULTISUBDIR). * automake/lib.am: Use project_libdir instead of $(PROJECT_RELEASE)/lib. * aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE. Add project_libdir, libdir. New GCC_SPECS. Various cleanups. * aclocal/rtems-top.m4: New PROJECT_ROOT handling. * automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK, references to bsp_specs. Use project_libdir instead of $(PROJECT_RELEASE)/lib. * itron/src/Makefile.am: Use .$(OBJEXT) instead of .o. * itron/src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES. * posix/src/Makefile.am: Use .$(OBJEXT) instead of .o. * posix/src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES. * score/src/Makefile.am, sapi/src/Makefile.am, rtems/src/Makefile.am, librpc/src/xdr/Makefile.am, librpc/src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o. * librpc/src/xdr/Makefile.am, librpc/src/rpc/Makefile.am: Eliminate LIBNAME. * libblock/src/Makefile.am: Use .$(OBJEXT) instead of .o. * libblock/src/Makefile.am: Eliminate LIBNAME. Cosmetical cleanups. * libcsupport/Makefile.am: Use .$(OBJEXT) instead of .o. * libcsupport/Makefile.am: Eliminate LIBNAME. Use AM_CPPFLAGS instead of INCLUDES (Upcoming automake standard). * libnetworking/kern/Makefile.am: Use .$(OBJEXT) instead of .o. * libnetworking/lib/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/wrapup/Makefile.am: Ditto. * libnetworking/kern/Makefile.am: Eliminate LIBNAME. * libnetworking/lib/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems/Makefile.am: Ditto. * libnetworking/wrapup/Makefile.am: Use project_libdir instead of $(PROJECT_RELEASE)/lib. 2002-07-22 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/score/apimutex.h (_API_Mutex_Lock): Per PR253 add the missing _ISR_Disable. This fix was already applied to the old location (c/src/exec/score/...). 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/capture/capture.c, libmisc/capture/capture-cli.c: include <string.h> for memset. 2002-07-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/rtems-top.m4: Reflect relocation of c/src/exec to cpukit. * aclocal/check-cpu.m4, aclocal/check-bsps.m4: Ditto. 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com> * libnetworking/netinet/in.h, libnetworking/netinet/ip.h, libnetworking/netinet/ip_var.h, libnetworking/netinet/tcp.h: Modified to added packed attribute.o. 2002-07-16 Joel Sherrill <joel@OARcorp.com> * score/macros/rtems/score/object.inl: Corrected typos in _Objects_Open, _Objects_Close, and _Objects_Namespace_remove. 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/multilib.am: Add install-multi. * aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting version.m4. Add --with-project-root. Reflect --with-project-root to setting up PROJECT_ROOT. * aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK). * aclocal/check-cpu.m4, aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir. * configure.ac: RTEMS_TOP(..). * itron/configure.ac, posix/configure.ac, librpc/configure.ac, libblock/configure.ac, libfs/configure.ac, libcsupport/configure.ac, libnetworking/configure.ac: RTEMS_TOP(../..). 2002-07-05 Joel Sherrill <joel@OARcorp.com> * posix/include/rtems/posix/cancel.h, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/mqueue.c, posix/src/pthread.c, posix/src/semaphore.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/testcancel.c: Per PR164, corrected the behavior of thread cancellation and did some cleanup as a side-effect. * score/macros/rtems/score/object.inl: Corrected implementation of _Objects_Open, _Objects_Close, and _Objects_Namespace_remove to be consistent with the inline implementation. * rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/timerident.c: Corrected use of name parameter to be consistent with fixes implemented to string name processing which were committed with the POSIX Message Queue update. 2002-07-04 Joel Sherrill <joel@OARcorp.com> * Jump table for single entry point removed. * sapi/include/rtems/directives.h, sapi/src/entrytable.c: Removed. * sapi/include/Makefile.am, sapi/src/Makefile.am, sapi/src/exinit.c: Modified to reflect above. 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Install by using cpulibdir, cpulib_DATA. * aclocal/check-bsp-cache.m4: Remove RTEMS_BSP_FAMILY. * configure.ac: Remove RTEMS_PROJECT_ROOT. * aclocal/project-root.m4: Remove. * aclocal/enable-multiprocessing.m4: Fix typo. * aclocal/prog-cc.m4: Remove obsolete comments. Comment out GCCSED. * itron/configure.ac, posix/configure.ac, librpc/configure.ac, libblock/configure.ac, libfs/configure.ac, libcsupport/configure.ac, libnetworking/configure.ac: Remove RTEMS_PROJECT_ROOT. 2002-07-01 Joel Sherrill <joel@OARcorp.com> * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * itron/src/cre_mbf.c, itron/src/cre_sem.c, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c, itron/src/msgbuffer.c, itron/src/port.c, itron/src/task.c, itron/src/vmempool.c: Modified as part of above. * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * posix/include/rtems/posix/key.h, posix/src/cond.c, posix/src/condinit.c, posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/killinfo.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mutex.c, posix/src/mutexinit.c, posix/src/psignal.c, posix/src/pthread.c, posix/src/semaphore.c, posix/src/semaphorecreatesupp.c: Modified as part of above. * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * score/include/Makefile.am, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/object.h, score/include/rtems/score/threadq.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/thread.inl, score/macros/rtems/score/object.inl, score/src/Makefile.am, score/src/coremsg.c, score/src/coremutex.c, score/src/coresem.c, score/src/mpci.c, score/src/objectcomparenameraw.c, score/src/objectextendinformation.c, score/src/objectinitializeinformation.c, score/src/objectnametoid.c, score/src/thread.c, score/src/threadclose.c, score/src/threadget.c, score/src/threadq.c, score/src/threadqextractwithproxy.c: Modified as part of above. * score/include/rtems/score/apimutex.h, score/src/objectgetnoprotection.c: New files. * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * sapi/include/confdefs.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c: Modified as part of above. * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * rtems/include/rtems.h, rtems/inline/rtems/rtems/region.inl, rtems/macros/rtems/rtems/region.inl, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/msg.c, rtems/src/msgqcreate.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/ratemon.c, rtems/src/ratemoncreate.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionreturnsegment.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/taskcreate.c, rtems/src/taskident.c, rtems/src/tasks.c, rtems/src/timercreate.c: Modified as part of above. * libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h: Corrected use of _Objects_Information_table now that it is a two dimensional array based upon API and class. In addition, in the monitor, corrected an error which occured when a target has 64 bit pointers. * libmisc/stackchk/check.c: Corrected use of _Objects_Information_table now that it is a two dimensional array based upon API and class. * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * libblock/src/bdbuf.c: Modified as part of above. * libcsupport/src/__times.c: Corrected from previous attempt to cleanup. 2002-06-28 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/__times.c: Cleaned up comments, return more information, and eliminated the fatal error on clock not set since it cannot occur. 2002-06-27 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> * Addition of a ftp client filesystem, comparable to the tftp one. * libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h: New files. * libnetworking/lib/Makefile.am, libnetworking/rtems/Makefile.am: Modified to reflect above. 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/prog-ccas.m4: New. * aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP. RTEMS_GCC_PRINT. * aclocal/check-multiprocessing.m4: Fix typo. * automake/compile.am: Remove CXX support. Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES. * configure.ac: Use AC_CONFIG_AUX_DIR(..). * itron/configure.ac, posix/configure.ac, librpc/configure.ac, libblock/configure.ac, libfs/configure.ac, libcsupport/configure.ac, libnetworking/configure.ac: Use AC_CONFIG_AUX_DIR(../..). Add AC_PROG_RANLIB. 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove references to RTEMS_BSP. * aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP. Allow building w/ --enable-multiprocessing --enable-multilib. * aclocal/enable-multiprocessing.m4: Eliminate RTEMS_HAS_MULTIPROCESSING. * itron/configure.ac: Remove references to RTEMS_BSP. * itron/src/Makefile.am: Add libitron.a. * posix/configure.ac: Remove references to RTEMS_BSP. * posix/src/Makefile.am: Add libposix.a. * libmisc/wrapup/Makefile.am: Don't preinstall libmisc.a. * libblock/src/Makefile.am: Don't preinstall libblock.a. * libfs/wrapup/Makefile.am: Don't preinstall libfs.a. * libnetworking/wrapup/Makefile.am: Don't preinstall libnetworking.a. 2002-06-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> * With the addition of serdbg, the standard polled I/O functions for gdbstub and/or printk are optionally routed to any termios-aware device driver, that supports polled mode. See libmisc/serdbg/README. * libmisc/serdbg/Makefile.am, libmisc/serdbg/README, libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/serdbgio.c, libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h, libmisc/serdbg/termios_printk_cnf.h, libmisc/serdbg/.cvsignore: New files. * libmisc/configure.ac, libmisc/Makefile.am, libmisc/wrapup/Makefile.am: Modified to reflect addition. 2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Fix stupid typo in previous patch. * configure.ac: Add librpc. AC_PROG_RANLIB. * wrapup/Makefile.am: Add librpc. Use relative path to lib*.a for POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS. * librpc/configure.ac: RTEMS_TOP(../../../..). AC_CONFIG_AUX_DIR(../../../..). Remove RTEMS_CANONICAL_HOST. Use RTEMS_ENV_RTEMSCPU. Add AC_PROG_RANLIB. * librpc/include/rpc/Makefile.am, librpc/include/Makefile.am, librpc/include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am. * librpc/Makefile.am: Include $(top_srcdir)/../automake/*.am. ACLOCAL_AMFLAGS = -I ../aclocal. * librpc/src/rpc/PSD.doc/Makefile.am, librpc/src/rpc/Makefile.am, librpc/src/xdr/Makefile.am, librpc/src/Makefile.am: Include $(top_srcdir)/../automake/*.am. 2002-06-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * aclocal/subdirs.m4: Remove. 2002-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Use relative path to lib*.a for LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS. * libblock/Makefile.am: Merge-in include/Makefile.am. * libblock/include/Makefile.am: Remove. * libblock/configure.ac: Reflect changes above. * libnetworking/Makefile.am: Remove commented out net-apps. 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Include $(top_srcdir)/automake/*.am. Use aclocal. * sapi/include/Makefile.am, sapi/Makefile.am, sapi/inline/Makefile.am, sapi/macros/Makefile.am, sapi/src/Makefile.am, score/include/Makefile.am, score/Makefile.am, score/cpu/Makefile.am, score/inline/Makefile.am, score/macros/Makefile.am, score/src/Makefile.am, wrapup/Makefile.am, include/Makefile.am, rtems/include/Makefile.am, rtems/Makefile.am, rtems/inline/Makefile.am, rtems/macros/Makefile.am, rtems/src/Makefile.am: Include $(top_srcdir)/automake/*.am. * aclocal/bsp-alias.m4: Copied over from aclocal/. * aclocal/canonical-host.m4, aclocal/canonical-target-name.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-bsps.m4, aclocal/check-cpu.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtemsbsp.m4, aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/project-root.m4, aclocal/rtems-cpu-subdirs.m4, aclocal/rtems-debug.m4, aclocal/rtems-top.m4, aclocal/subdirs.m4, aclocal/sysv-ipc.m4, aclocal/tool-paths.m4, aclocal/version.m4: Ditto. * itron/include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * itron/Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * itron/inline/Makefile.am, itron/macros/Makefile.am, itron/src/Makefile.am, posix/include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * posix/Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * posix/inline/Makefile.am, posix/macros/Makefile.am, posix/src/Makefile.am, libblock/include/Makefile.am: Include $(top_srcdir)/../automake/*.am. * libblock/Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * libblock/src/Makefile.am, libfs/src/dosfs/Makefile.am, libfs/src/Makefile.am, libfs/src/imfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. * libfs/Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * libfs/wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am. * libcsupport/Makefile.am: Merge src/Makefile.am. * libcsupport/configure.ac: Reflect changes above. * libcsupport/src/Makefile.am: Remove. * libcsupport/Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * libcsupport/src/Makefile.am, libnetworking/arpa/Makefile.am, libnetworking/kern/Makefile.am: Include $(top_srcdir)/../automake/*.am. * libnetworking/Makefile.am: Include $(top_srcdir)/../automake/*.am. Use ../aclocal. * libnetworking/lib/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/machine/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/sys/Makefile.am, libnetworking/vm/Makefile.am, libnetworking/wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am. 2002-06-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * automake/compile.am, automake/lib.am, automake/local.am, automake/multilib.am, automake/subdirs.am: Copied over from automake/. * Makefile.am: Add automake/*.am. 2002-06-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/rtems/Makefile.am: include multilib.am instead of RTEMS_BSP.cfg. 2002-05-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/configure.ac: Remove RTEMS_CHECK_POSIX_API. Remove RTEMS_ENABLE_POSIX. Remove RTEMS_CHECK_CUSTOM_BSP. Remove RTEMS_ENABLE_POSIX. 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Add libnetworking. * wrapup/Makefile.am: Ditto. Relocate c/src/libnetworking. * libnetworking/Makefile.am: Reflect moval. * libnetworking/machine/Makefile.am, libnetworking/net/Makefile.am, libnetworking/lib/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/vm/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/sys/Makefile.am, libnetworking/arpa/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/kern/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/configure.ac: Ditto. * libnetworking/wrapup/Makefile.am: Ditto. Remove references to networking apps. 2002-05-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/configure.ac, libmisc/Makefile.am: Remove references to rootfs. 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Add libblock. Add libfs. Add AM_CONDITIONAL(UNIX). * wrapup/Makefile.am: Add libblock, libfs/dosfs, libfs/imfs. * libblock/configure.ac, libblock/Makefile.am, libblock/include/Makefile.am, libblock/src/Makefile.am: Reflect move from c/src/libblock to c/src/exec/libblock. * libfs/configure.ac: Reflect move from c/src/libfs to c/src/exec/libfs. * libfs/Makefile.am, libfs/src/Makefile.am, libfs/src/dosfs/Makefile.am, libfs/src/imfs/Makefile.am, libfs/wrapup/Makefile.am: Ditto. * libnetworking/rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>. 2002-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/rootfs/.cvsignore, libmisc/rootfs/Makefile.am, libmisc/rootfs/mkrootfs.h, libmisc/rootfs/mkrootfs.c: Remove. * libmisc/configure.ac: Remove rootfs and NETWORKING macros. * libmisc/wrapup/Makefile.am: Remove rootfs and HAS_NETWORKING. * libnetworking/rtems/mkrootfs.c: Add (relocated from libmisc/rootfs). * libnetworking/rtems/mkrootfs.h: Ditto. * libnetworking/rtems/Makefile.am: Reflect changes above. 2002-05-16 Chris Johns <ccj@acm.org> PR 194 * libmisc/*: Added the Capture engine. * libmisc/capture/Makefile.am, libmisc/capture/README, libmisc/capture/capture-cli.c, libmisc/capture/capture-cli.h, libmisc/capture/capture.c, libmisc/capture/capture.h, libmisc/capture/.cvsignore: New files. * libmisc/Makefile.am, libmisc/configure.ac, libmisc/wrapup/Makefile.am: Modified to reflect addition. 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Add libcsupport. * wrapup/Makefile.am: Ditto. * Makefile.am: Add preinstall-stamp. 2002-05-15 Chris Johns <ccj@acm.org> * score/include/rtems/score/thread.h, score/inline/rtems/score/thread.inl, score/src/threaddispatch.c, score/src/threadinitialize.c: Move the C library re-enterrant support directly into the thread dispatch code. RTEMS needs libc and so requiring libc to use a user extension with its overhead is not the best solution. This patch lowers the overhead to 2 pointer moves. 2002-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/sys/ioctl.h, libnetworking/sys/sockio.h, libnetworking/sys/filio.h: Remove. * libnetworking/sys/Makefile.am: Reflect changes above. 2002-05-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/Makefile.am: Work-around to autoconf-2.53 adding PACKAGE_* to autoheaders - sed out *PACKAGE* from cpuopts-tmp.h. 2002-05-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * posix/include/sys/utsname.h: Remove. * posix/include/Makefile.am: Reflect changes above. * posix/src/utsname.c: Remove. * posix/src/Makefile.am: Reflect changes above. 2002-05-01 Eric Norum <eric.norum@usask.ca> * libnetworking/machine/in_cksum.h: Per PR200 fix multi-line inline assembly to satisfy gcc 3.1 and newer. 2002-04-26 Eric Norum <eric.norum@usask.ca> * libnetworking/netinet/in_cksum_i386.c: Add volatile so the more agressive optimization in gcc 3.1 does not reorder things. 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Remove targopts.h. * libnetworking/pppd/utils.c: Adapt to gcc-3.x. 2002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Add the sparc to the target supporting multlibs. 2002-04-16 Chris Johns <ccj@acm.org> * score/src/threadinitialize.c: Per PR181, clear the array of user extension pointers. This lets user extensions that have hooked the switch handler know if a task has been processed by the user extension before. If a user extension is created after a task is started it may not know it. 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove ENABLE_GCC28. 2002-04-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Add i386 to multilib-able targets. 2002-04-11 Chris Johns <ccj@acm.org> PR 59/networking * libnetworking/c/src/libnetworking/rtems/rtems_bsdnet.h: Add the drv_ctrl driver control block field to the ifconfig network driver structure. This field is needed by the i82586 driver which was ported from NetBSD as it had better hardware abstraction. 2002-04-10 Victor V. Vengerov <vvv@oktet.ru> PR 385/filesystem * libblock/src/ramdisk.c: The "from" and "to" locations are calculated as the start of the block within the ram that data is to be transferred from/to for reads and writes respectively. However, within the loops, the "from" and "to" locations are never updated. The loop should have been updated as: from += rd->block_size; and to += rd->block_size; within the for loops in the ramdisk_read and ramdisk_write routines, respectively. 2002-04-08 Chris Johns <ccj@acm.org> * Per PR142, make task switch extension its own list. * posix/src/pthread.c (_POSIX_Threads_User_extensions): Reflect above. * Per PR141 and PR174, make task switch extension its own list and fix all odd problems introduced by providing macro version. * score/inline/rtems/score/userext.inl: Fix. * Per PR142, make task switch extension its own list. * score/include/rtems/score/userext.h: Reflect above by adding User_extensions_Switch_control and adding it to User_extenions_Control. * score/inline/rtems/score/userext.inl: Allocate all memory in one chunk to minimize overhead. Address processing dedicated switch chain. * Per PR142, make task switch extension its own list. * score/include/rtems/score/userext.h: Reflect above by adding User_extensions_Switch_control and adding it to User_extenions_Control. * score/inline/rtems/score/userext.inl: Allocate all memory in one chunk to minimize overhead. Address processing dedicated switch chain. * Per PR142, make task switch extension its own list. * rtems/src/tasks.c (_RTEMS_tasks_User_extensions): Reflect above. 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rtems/bspIo.h: Fix cpp-guards, remove references to i386. * posix/src/psignal.c: Include <stdlib.h>. * libblock/src/ramdisk.c, libblock/src/blkdev.c, libfs/src/imfs/imfs_getchild.c: include <string.h>. * libfs/src/imfs/imfs_gtkn.c, libfs/src/imfs/ioman.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/memfile.c: Include <string.h>. * libnetworking/ChangeLog: Fix dates. 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/monitor/mon-monitor.c: Replace done with return (gcc3). * libfs/src/dosfs/fat.h: Include <string.h>. Remove DBG1 and DBG2 (unused). * Per PR169. * libfs/src/dosfs/config.h.in, libfs/src/dosfs/stamp-h2.in: Removed from CVS. 2002-04-03 Alexander Kukuta <kam@oktet.ru> * libblock/include/rtems/bdbuf.h: Address PR168 by changing bdbuf_buffer.avl.bal and bdbuf_buffer.avl.cache to signed char instead of char. 2002-04-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * posix/src/getegid.c: Remove <errno.h>. * posix/src/geteuid.c, posix/src/getgid.c, posix/src/getuid.c: Ditto. * posix/src/getlogin.c: Move <errno.h>. 2002-03-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/libc/rcmd.c: Replace __rtems w/ __rtems__. 2002-03-27 Thomas.Doerfler@imd-systems.de PR 144 * libnetworking/nfs/bootp_subr.c bootpc_init(): Performs a write to memory address 0 when called for the first time. This is done when trying to clear the variable "dhcp_hostname". 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am, Makefile.am, wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. * itron/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * itron/include/Makefile.am, itron/Makefile.am, itron/inline/Makefile.am, itron/macros/Makefile.am, itron/src/Makefile.am: Remove AUTOMAKE_OPTIONS. * posix/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * posix/src/Makefile.am, posix/Makefile.am, posix/include/Makefile.am, posix/inline/Makefile.am, posix/macros/Makefile.am, score/cpu/Makefile.am, score/src/Makefile.am, score/Makefile.am, score/include/Makefile.am, score/inline/Makefile.am, score/macros/Makefile.am, sapi/Makefile.am, sapi/include/Makefile.am, sapi/inline/Makefile.am, sapi/macros/Makefile.am, sapi/src/Makefile.am, rtems/Makefile.am, rtems/include/Makefile.am, rtems/inline/Makefile.am, rtems/macros/Makefile.am, rtems/src/Makefile.am: Remove AUTOMAKE_OPTIONS. * libmisc/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * libmisc/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rootfs/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/shell/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am, libmisc/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. * librpc/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * librpc/include/rpc/Makefile.am, librpc/include/Makefile.am, librpc/include/rpcsvc/Makefile.am, librpc/Makefile.am, librpc/src/rpc/PSD.doc/Makefile.am, librpc/src/rpc/Makefile.am, librpc/src/xdr/Makefile.am, librpc/src/Makefile.am: Remove AUTOMAKE_OPTIONS. * libblock/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * libblock/include/Makefile.am, libblock/Makefile.am, libblock/src/Makefile.am: Remove AUTOMAKE_OPTIONS. * libfs/src/dosfs/fat_file.c: Remove bsp.h. fat_file_write(.. const char*buf ..). * libfs/src/dosfs/fat_file.h: fat_file_write(.. const char*buf ..). * libfs/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * libfs/src/dosfs/Makefile.am, libfs/src/Makefile.am, libfs/src/imfs/Makefile.am, libfs/Makefile.am, libfs/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. * libnetworking/configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * libnetworking/arpa/Makefile.am, libnetworking/kern/Makefile.am, libnetworking/Makefile.am, libnetworking/lib/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/machine/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, libnetworking/sys/Makefile.am, libnetworking/vm/Makefile.am, libnetworking/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-03-27 Ilya Alexeev <ilya@continuum.ru> PR 162 * libnetworking/net/if_ppp.c ppp_txdaemon(), libnetworking/net/if_pppvar.h pppstart(): Local variables must not be used in a device write routines. Now ppp_softc structure have own character for writing to device (sc_outchar). I think that converting local variables to static is not a right solution, because problems will occur in the case of two or more ppp instances. * libnetworking/net/ppp_tty.c pppstart(): Type of the ioffset variable must be u_long, otherwise in the case of the big output packet endless loop may occur. 2002-03-25 Eric Norum <norume@aps.anl.gov> PR 374/networking * libnetworking/Makefile.am, libnetworking/rtems/rtems_bsdnet.h, libnetworking/rtems/rtems_glue.c: The patch sent as part of PR270 got applied to the wrong place. The effect was that (1) startup was no faster than before and (2) malloc starvation messages came way too quickly. The attached patch fixes both these problems and also provides a mechanism for applications to handle malloc starvation conditions as they see fit. * libnetworking/rtems/rtems_bsdnet_malloc_starvation.c: New file. 2002-03-21 Ilya Alexeev <ilya@continuum.ru> * libnetworking/net/if_ppp.c, libnetworking/net/ppp_tty.c: Initial preparations for multiple PPPD connections. 2002-03-21 Alexander Kukuta <kam@oktet.ru> * libblock/src/bdbuf.c (avl_insert, libblock/avl_remove): Reimplemented from scratch to avoid using GPLed sources in RTEMS core. * libblock/src/bdbuf.c, libblock/include/rtems/bdbuf.h: Remove "binary tree" implementation which was used for debugging only. 2002-03-20 Chris Johns <ccj@acm.org> PR 192 * libmisc/monitor/mon-command.c: The RTEMS monitor makes everything lowercase. The capture engine need to set triggers or watches on task with uppercase names. Also stop the monitor repeating command when enter is pressed. PR 148. * libmisc/monitor/mon-prmisc.c: Fixed to print task states correctly. 2002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 140 * libfs/src/dosfs/config.h.in, libfs/src/dosfs/stamp-h2.in: Removed. * libfs/.cvsignore: Add config.h*, stamp-h*. * libfs/configure.ac: Remove AC_SRC_DIR(.../dosfs.h). Remove AM_CONFIG_HEADER(src/dosfs/config.h). Remove AM_CONFIG_HEADER(src/imfs/config.h). Add AM_CONFIG_HEADER(config.h). * libfs/src/dosfs/Makefile.am, libfs/src/imfs/Makefile.am: INCLUDES = -I../... 2002-03-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> PR 130 * libfs/src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX. * libfs/wrapup/Makefile.am: Disable dosfs for UNIX. 2002-03-13 Victor V. Vengerov <vvv@oktet.ru> * libblock/src/bdbuf.c (find_or_assign_buffer, libblock/rtems_bdbuf_read, libblock/rtems_bdbuf_sync, libblock/rtems_bdbuf_syncdev, libblock/bdbuf_swapout_task): Fix bug: disable interrupts and set level properly before _CORE_mutex_Seize invocation). 2002-03-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Add __RTEMS_REVISION__. 2002-03-01 Eric Norum <eric.norum@usask.ca> * posix/src/pthreadonce.c: Task is not preemptable while running a pthread_once init function. This is slightly less heavy handed than disabling dispatching and seems better than consuming a mutex. 2002-02-28 Victor V. Vengerov <vvv@oktet.ru> * DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * libfs/src/dosfs, libfs/src/dosfs/Makefile.am, libfs/src/dosfs/stamp-h2.in, libfs/src/dosfs/config.h.in, libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_handlers_dir.c, libfs/src/dosfs/msdos_handlers_file.c, libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c, libfs/src/dosfs/msdos_node_type.c, libfs/src/dosfs/.cvsignore: New files. * libfs/configure.ac, libfs/src/Makefile.am, libfs/wrapup/Makefile.am: Modified to reflect addition. 2002-02-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Add __RTEMS_MAJOR__, __RTEMS_MINOR__. 2002-02-28 Joel Sherrill <joel@OARcorp.com> * Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * libblock/ChangeLog, libblock/Makefile.am, libblock/README, libblock/configure.ac, libblock/include/Makefile.am, libblock/include/rtems/bdbuf.h, libblock/include/rtems/blkdev.h, libblock/include/rtems/diskdevs.h, libblock/include/rtems/ramdisk.h, libblock/include/rtems/.cvsignore, libblock/include/.cvsignore, libblock/src/Makefile.am, libblock/src/bdbuf.c, libblock/src/blkdev.c, libblock/src/diskdevs.c, libblock/src/ramdisk.c, libblock/src/.cvsignore, libblock/.cvsignore: New files. 2002-02-27 Ilya Alexeev <ilya@continuum.ru> * libnetworking/net/if_ppp.c, libnetworking/pppd/auth.c, libnetworking/pppd/chat.c, libnetworking/pppd/pppd.h, libnetworking/pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings. 2002-02-27 Eric Norum <eric.norum@usask.ca> * libnetworking/net/radix.c: Properly handle fetching the default route when there is no route. This was a bug in the original FreeBSD code and this fix is from an updated version of their code. 2002-02-16 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.clib/tftpDriver.c: Fix TFTP block number checking. 2002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * posix/src/getegid.c: Add #include <rtems/userenv.h>. Remove #include <rtems/libio_.h>. * posix/src/geteuid.c, posix/src/getgid.c, posix/src/getlogin.c, posix/src/getuid.c: Ditto. 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Readded reference to wrapup. * posix/configure.ac: AC_CONFIG_SRCDIR([src/pthreads.c]). * posix/src/psignal.c: #include <string.h>. * libnetworking/pppd/sys-rtems.c: Remove unused variable status from dodefaultroute. 2002-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/lib/tftpDriver.c: Remove set_errno_and_return_minus_one, include <rtems/seterr.h>. 2002-02-01 Mike Siers <mikes@poliac.com> * libnetworking/pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link. 2002-01-31 Mike Siers <mikes@poliac.com> * libnetworking/pppd/rtemsdialer.h: New file missed in previous commit. * libnetworking/*: Update of PPPD support which eliminates the requirement that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * libnetworking/Makefile.am, libnetworking/configure.ac, libnetworking/net/Makefile.am, libnetworking/net/bpf.h, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if.h, libnetworking/net/if_arp.h, libnetworking/net/if_dl.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_llc.h, libnetworking/net/if_loop.c, libnetworking/net/if_ppp.h, libnetworking/net/if_pppvar.h, libnetworking/net/if_types.h, libnetworking/net/netisr.h, libnetworking/net/ppp-comp.h, libnetworking/net/ppp_defs.h, libnetworking/net/pppcompress.h, libnetworking/net/radix.c, libnetworking/net/radix.h, libnetworking/net/raw_cb.c, libnetworking/net/raw_cb.h, libnetworking/net/raw_usrreq.c, libnetworking/net/route.c, libnetworking/net/route.h, libnetworking/net/rtsock.c, libnetworking/pppd/Makefile.am, libnetworking/pppd/README, libnetworking/pppd/STATUS, libnetworking/pppd/auth.c, libnetworking/pppd/cbcp.c, libnetworking/pppd/ccp.c, libnetworking/pppd/ccp.h, libnetworking/pppd/chap.c, libnetworking/pppd/chap.h, libnetworking/pppd/chap_ms.c, libnetworking/pppd/chap_ms.h, libnetworking/pppd/chat.c, libnetworking/pppd/demand.c, libnetworking/pppd/fsm.c, libnetworking/pppd/fsm.h, libnetworking/pppd/ipcp.c, libnetworking/pppd/ipcp.h, libnetworking/pppd/ipxcp.c, libnetworking/pppd/ipxcp.h, libnetworking/pppd/lcp.c, libnetworking/pppd/lcp.h, libnetworking/pppd/magic.c, libnetworking/pppd/magic.h, libnetworking/pppd/options.c, libnetworking/pppd/patchlevel.h, libnetworking/pppd/pathnames.h, libnetworking/pppd/pppd.8, libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c, libnetworking/pppd/rtemspppd.c, libnetworking/pppd/rtemspppd.h, libnetworking/pppd/sys-rtems.c, libnetworking/pppd/upap.c, libnetworking/pppd/upap.h, libnetworking/pppd/utils.c, libnetworking/pppd/example/README, libnetworking/pppd/example/netconfig.h, libnetworking/wrapup/Makefile.am: Modified. * libnetworking/net/bsd-comp.c, libnetworking/net/if_ppp.c, libnetworking/net/ppp-deflate.c, libnetworking/net/ppp.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/zlib.c, libnetworking/net/zlib.h: New file. * libnetworking/modem/, libnetworking/modem/.cvsignore, libnetworking/modem/Makefile.am, libnetworking/modem/ppp.c, libnetworking/modem/ppp.h, libnetworking/modem/ppp_tty.c, libnetworking/modem/pppcompress.c: Subdirectory removed. 2002-01-29 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/score/watchdog.h: Added WATCHDOG_MAXIMUM_INTERVAL. 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/shell/shell.c: Remove #undef __STRICT_ANSI__. 2002-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/configure.ac: Fix tests for GCC. 2002-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/configure.ac: Add check for weak function attribute. Remove AM_CONDITIONAL([RTEMS_LIBSHELL]. Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG). * libmisc/capture/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/rtmonuse/Makefile.am: Use *.a instead of *-tmp.a. * libmisc/serdbg/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSERDBG is true. * libmisc/shell/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSHELL is true. * libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am: Use *.a instead of *-tmp.a. * libmisc/wrapup/Makefile.am: Reflect changes above. 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/rtems_telnetd/pty.c: Move config.h to were it belongs. Remove printf (Reported by Till Straumann <strauman@SLAC.Stanford.EDU>). 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Fix typo in yesterday's change: RTEMS_MULTILIBS. 2002-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Apply @subdirs. Remove POSIX_SUBDIRS. Remove ITRON_SUBDIRS. * configure.ac: Rework enable_unixlib handling. Add RTEMS_MULTILIBS to cpuopts.h. * include/Makefile.am: Add rtems/fs.h, rtems/userenv.h. Add $(PROJECT_INCLUDE)/rtems. Remove libio_.h. 2002-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/Makefile.am: Add install-hook. Remove SIZE_RTEMS. * include/rtems/fs.h: New, extracted from libio_.h. * include/rtems/userenv.h: New. extracted from libio_.h. * libmisc/rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES. * libfs/src/imfs/imfs_load_tar.c: Add include <sys/types.h>. Add include <sys/stat.h>. Add include <fcntl.h>. * libfs/src/imfs/imfs_rmnod.c: Add include <stdlib.h>. 2002-01-07 Joel Sherrill <joel@OARcorp.com> * posix/optman/, posix/optman/.cvsignore, posix/optman/Makefile.am, sapi/optman/, sapi/optman/.cvsignore, sapi/optman/Makefile.am, sapi/optman/no-ext.c, sapi/optman/no-io.c, rtems/optman/, rtems/optman/.cvsignore, rtems/optman/Makefile.am, rtems/optman/no-dpmem.c, rtems/optman/no-event.c, rtems/optman/no-mp.c, rtems/optman/no-msg.c, rtems/optman/no-part.c, rtems/optman/no-region.c, rtems/optman/no-rtmon.c, rtems/optman/no-sem.c, rtems/optman/no-signal.c, rtems/optman/no-timer.c: Removed entire contents of optman/ directory since it has been moved. 2002-01-06 Joel Sherrill <joel@OARcorp.com> * wrapup/.cvsignore: Readded. * include/.cvsignore: New file. 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/seterr.h: Add do {..} while (0) in defines. Rename set_errno_and_return_minus_one into rtems_set_errno_and_return_minus_one. * libmisc/mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one. * libfs/src/imfs/imfs_eval.c, libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_readlink.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/imfs_link.c, libfs/src/imfs/imfs_chown.c, libfs/src/imfs/ioman.c, libfs/src/imfs/imfs_mount.c, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/imfs_symlink.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/linearfile.c, libfs/src/imfs/imfs_unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * libfs/src/imfs/imfs.h: Apply rtems_set_errno_and_return_minus_one. Comment out increment_and_check_linkcounts. 2002-01-04 Joel Sherrill <joel@OARcorp.com> * Makefile.am, configure.ac: Remove references to wrapup subdirectory. 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am, sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h, include/rtems/libio_.h: Relocated from lib/include. * posix/configure.ac: Remove optman/Makefile from CONFIG_FILES. * posix/Makefile.am: Remove optman from SUBDIRS. 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/posix/Makefile.am, wrapup/itron/Makefile.am, wrapup/rtems/Makefile.am, Makefile.am, itron/src/Makefile.am: Add multilib support. * posix/optman/Makefile.am: Add multilib support. Remove ASM4FLAGS. * posix/src/Makefile.am: Add multilib support. * score/inline/rtems/score/object.inl, score/macros/rtems/score/object.inl: Add add casts to Objects_Id in _Objects_Build_ids to avoid implicit typecasts from enum to int16 on bit16 targets (here: h8300). * score/src/Makefile.am, sapi/optman/Makefile.am, sapi/src/Makefile.am, rtems/src/Makefile.am, rtems/optman/Makefile.am: Add multilib support. 2001-12-18 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.c: Allow chdir() to work on TFTP `directories' (path names with a / at the end) while disallowing open() operations on TFTP `directories'. 2001-12-07 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.c: Restore write capability. 2001-11-29 Victor V. Vengerov <vvv@oktet.ru> * AVL trees implementation added. 2001-11-28 Joel Sherrill <joel@OARcorp.com>, PR 91 * score/include/rtems/score/isr.h, score/inline/rtems/score/isr.inl, score/macros/rtems/score/isr.inl: Modified to allow any port to provide its own implementation of the macro _ISR_Is_in_progress. If the port overrides this macro, it must provide a non-inlined function implementation. 2001-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libfs/wrapup/Makefile.am: Remove HAS_IMFS. 2001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libfs/src/imfs/Makefile.am: Cleanup. * libnetworking/arpa/Makefile.am: Remove stray lines. 2001-11-20 Joel Sherrill <joel@OARcorp.com> * score/src/threadhandler.c: When __USE__MAIN__ is defined by the toolset, invoke the global constructors via __main. Reported as tested by Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov <vvv@oktet.ru> in conjunction with a new set of tool RPMs (gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84. 2001-11-16 Victor V. Vengerov <vvv@oktet.ru> * libblock/include/rtems/bdbuf.h, libblock/src/bdbuf.c(rtems_bdbuf_syncdev): New. 2001-11-07 Victor V. Vengerov <vvv@oktet.ru> * libblock/ChangeLog: New file. * libblock/src/, libblock/include/, libblock/include/rtems/: New directories. * libblock/README, libblock/configure.ac, libblock/Makefile.am, libblock/src/Makefile.am, libblock/include/Makefile.am, libblock/include/rtems/bdbuf.h include/rtems/blkdev.h include/rtems/diskdevs.h include/rtems/ramdisk.h src/bdbuf.c src/blkdev.c src/diskdevs.c src/ramdisk.c: New files. 2001-11-07 Joel Sherrill <joel@OARcorp.com> Discovered while fixing PR36 reported by Todor.Todorov@barco.com. * itron/include/rtems/itron/object.h: Corrected _ITRON_Objects_Get() to use _Objects_Get_by_index(). PR 36 (Reported by Todor.Todorov@barco.com) * score/include/rtems/score/object.h: Added prototype for _Objects_Get_by_index(). * score/src/objectget.c, score/src/objectgetisr.c: Corrected procedure for getting index from Id so it is correct and optimal for both single and multiprocessor configurations. 2001-11-07 Jennifer Averett <jennifer@OARcorp.com> Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR49. * libfs/ src/imfs/imfs_directory.c: Do not calculate the offset twice. 2001-10-26 Victor V. Vengerov <vvv@oktet.ru> * libfs/src/imfs/imfs_load_tar.c: Minor modification so this will compile with gcc-2.95.3 with the arguments "-m5200 -O4". 2001-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * rtems/macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in previous patch). 2001-10-23 Joel Sherrill <joel@OARcorp.com> * rtems/macros/rtems/rtems/asr.nil: Fixed typo. 2001-10-22 Joel Sherrill <joel@OARcorp.com> * score/src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI pollutes the application namespace. 2001-10-18 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.c: Properly handles ../ components in chdir() and open() operations within the TFTP file system. 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Use RTEMS_CPU_SUBDIRS to make autoconf-2.52 happy. * configure.ac: Use AC_CONFIG_SUBDIRS for posix and itron. Reflect changes to configuration of rtems, score and sapi subdirs. * Makefile.am: require automake-1.5. * itron/include/itronsys/Makefile.am, itron/include/rtems/Makefile.am, itron/include/rtems/itron/Makefile.am, itron/inline/rtems/Makefile.am, itron/inline/rtems/itron/Makefile.am, itron/macros/rtems/Makefile.am, itron/macros/rtems/itron/Makefile.am: Remove. * itron/include/Makefile.am, itron/inline/Makefile.am, itron/macros/Makefile.am: handle subdirs. * itron/configure.ac: Reflect changes above. * posix/include/sys/Makefile.am, posix/include/rtems/Makefile.am, posix/include/rtems/posix/Makefile.am: Remove. * posix/include/Makefile.am: Handle subdirs. * posix/inline/rtems/Makefile.am, posix/inline/rtems/posix/Makefile.am: Remove. * posix/inline/Makefile.am: Handle subdirs. * posix/macros/rtems/Makefile.am, posix/macros/rtems/posix/Makefile.am: Remove. * posix/macros/Makefile.am: Handle subdirs. * posix/configure.ac: Reflect changes above. * score/include/rtems/Makefile.am, score/include/rtems/Makefile.am: Remove. * score/include/Makefile.am: Handle subdirs, require automake-1.5. * score/macros/rtems/Makefile.am, score/macros/rtems/score/Makefile.am: Remove. * score/macros/Makefile.am: Handle subdirs, require automake-1.5. * score/inline/rtems/Makefile.am, score/inline/rtems/score/Makefile.am: Remove. * score/inline/Makefile.am: Handle subdirs, require automake-1.5. * score/Makefile.am: require automake-1.5. * sapi/include/rtems/Makefile.am: Remove. * sapi/include/Makefile.am: Handle subdirs, require automake-1.5. * sapi/inline/rtems/Makefile.am: Remove. * sapi/inline/Makefile.am: Handle subdirs, require automake-1.5. * sapi/macros/rtems/Makefile.am: Remove. * sapi/Makefile.am: require automake-1.5. * rtems/include/rtems/Makefile.am, rtems/include/rtems/rtems/Makefile.am: Remove. * rtems/include/Makefile.am: Handle subdirs, require automake-1.5. * rtems/inline/rtems/Makefile.am, rtems/inline/rtems/rtems/Makefile.am: Remove. * rtems/inline/Makefile.am: Handle subdirs, require automake-1.5. * rtems/macros/rtems/Makefile.am, rtems/macros/rtems/rtems/Makefile.am: Remove. * rtems/macros: Handle subdirs, require automake-1.5. * rtems/Makefile.am: require automake-1.5. 2001-10-16 Joel Sherrill <joel@OARcorp.com> * score/.cvsignore: Add stamp-h.in. * score/include/Makefile.am: Fixed path to cpuopts-tmp.h. 2001-10-16 Chris Johns <ccj@acm.org> * sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/io.h, sapi/optman/no-io.c, sapi/src/exinit.c, sapi/src/io.c: Added a device driver register/unregister interface to allow device drivers to be installed and removed at runtime. This means you do not need devices present in the device table when you build. * libfs/imfs/imfs_load_tar.c: Changed the code around to remove an internal compiler error on the Coldfire target. 2001-10-12 Mike Siers <mikes@poliac.com> * Update to stable working state. * libnetworking/modem_example/16550.h, libnetworking/modem_example/README, libnetworking/modem_example/modem.c, libnetworking/modem_example/modem.h, libnetworking/modem_example/ppp.c, libnetworking/modem_example/ppp.h, libnetworking/modem_example/pppcompress.c: Files removed. * libnetworking/pppd/example/pppd.options: New file. * libnetworking/pppd/README, libnetworking/pppd/STATUS, libnetworking/pppd/cbcp.c, libnetworking/pppd/cbcp.h, libnetworking/pppd/chat.c, libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c: Updated. 2001-10-12 Joel Sherrill <joel@OARcorp.com> * sapi/include/rtems/directives.h, libmisc/rootfs/mkrootfs.c, libmisc/rootfs/mkrootfs.h: Fixed typo. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. * itron/.cvsignore: Add autom4te.cache for autoconf > 2.52. * itron/configure.in: Remove. * itron/configure.ac: New file, generated from configure.in by autoupdate. * posix/.cvsignore: Add autom4te.cache for autoconf > 2.52. * posix/configure.in: Remove. * posix/configure.ac: New file, generated from configure.in by autoupdate. * libmisc/.cvsignore: Add autom4te.cache for autoconf > 2.52. * libmisc/configure.in: Remove. * libmisc/configure.ac: New file, generated from configure.in by autoupdate. * librpc/.cvsignore: Add autom4te.cache for autoconf > 2.52. * librpc/configure.in: Remove. * librpc/configure.ac: New file, generated from configure.in by autoupdate. * libfs/.cvsignore: Add autom4te.cache for autoconf > 2.52. * libfs/configure.in: Remove. * libfs/configure.ac: New file, generated from configure.in by autoupdate. * libnetworking/.cvsignore: Add autom4te.cache for autoconf > 2.52. * libnetworking/configure.in: Remove. * libnetworking/configure.ac: New file, generated from configure.in by autoupdate. 2001-10-10 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/imfs_getchild.c: Correct length of static string as reported by Ibragimov Ilya <ibr@oktet.ru>. 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/score/Makefile.am, score/include/rtems/Makefile.am, score/inline/rtems/score/Makefile.am, score/macros/rtems/score/Makefile.am, sapi/include/rtems/Makefile.am, sapi/include/Makefile.am, sapi/inline/rtems/Makefile.am, sapi/macros/rtems/Makefile.am, rtems/include/rtems/rtems/Makefile.am, rtems/include/Makefile.am, rtems/inline/rtems/rtems/Makefile.am, rtems/macros/rtems/rtems/Makefile.am, libmisc/untar/Makefile.am, libmisc/monitor/Makefile.am, libmisc/shell/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/rootfs/Makefile.am, librpc/include/rpc/Makefile.am, libfs/src/imfs/Makefile.am: Use 'PREINSTALL_FILES ='. 2001-09-28 Joel Sherrill <joel@OARcorp.com> * posix/src/mqueueopen.c, posix/src/semopen.c: Clarify type on va_arg. * libmisc/dummy/dummy.c: Now a useful configuration that starts main(). * libmisc/wrapup/Makefile.am: Include a base level configuration in RTEMS library. 2001-09-27 Joel Sherrill <joel@OARcorp.com> * libmisc/ChangeLog: Fixed typo in date. 2001-09-27 Eric Norum <eric.norum@usask.ca> * score/src/threadhandler.c: Now process C++ global constructors (_init) as part of the first task execution not in BSP space. This depends on the toolset defining USE_INIT_FINI so you have to have the right toolset version. * libnetworking/lib/tftpDriver.c: Add limited chdir() support to the TFTP filesystem. 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * itron/include/itronsys/Makefile.am, itron/include/rtems/itron/Makefile.am, itron/include/Makefile.am, itron/inline/rtems/itron/Makefile.am, itron/macros/rtems/itron/Makefile.am, posix/include/sys/Makefile.am, posix/include/rtems/posix/Makefile.am, posix/include/Makefile.am, posix/inline/rtems/posix/Makefile.am, posix/macros/rtems/posix/Makefile.am, score/include/rtems/score/Makefile.am, score/include/rtems/Makefile.am, score/inline/rtems/score/Makefile.am, score/macros/rtems/score/Makefile.am, libnetworking/machine/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/vm/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/sys/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/arpa/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems_webserver/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='. 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/rtems/Makefile.am: Fix comments to make automake-1.5 happy. * itron/src/Makefile.am: Revamp INCLUDES handling to make automake-1.5 happy. * posix/optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5 happy. * posix/src/Makefile.am: Adapt INCLUDES to make automake-1.5 happy. * sapi/optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5. * libfs/src/imfs/Makefile.am: Revamp INCLUDES handling to make automake-1.5 happy. * libnetworking/Makefile.am: Use PREINSTALL_FILES = to make automake-1.5 happy. 2001-09-21 Joel Sherrill <joel@OARcorp.com> * libmisc/configure.in, libmisc/rootfs/Makefile.am: Added conditional to make sure rootfs does not get built with networking is disabled. Also added include of compile.am to rootfs/Makefile.am. * libmisc/wrapup/Makefile.am: Added rootfs conditionally if networking enabled. 2001-09-19 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.c: Add some debugging capability. 2001-09-19 Chris Johns <ccj@acm.org> * Added support for populating the initial "root" filesystem with information obtained via the DHCP response. * libmisc/rootfs: New directory. * libmisc/rootfs/.cvsignore, libmisc/rootfs/Makefile.am, libmisc/rootfs/mkrootfs.c, libmisc/rootfs/mkrootfs.h: New files. * libmisc/configure.in, libmisc/Makefile.am: Modified to reflect addition. * nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h, rtems/rtems_bsdnet_internal.h Added support for populating the initial "root" filesystem with information obtained via the DHCP response. 2001-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * libmisc/aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * libmisc/aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS. * libmisc/aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * libmisc/aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * libmisc/aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS. 2001-09-14 Fernando Ruiz <fernando.ruiz@ctv.es> * rtems/src/tasks.c: Dereference pointer passed to destructor. * libmisc/shell/shell.c: Don't close file it wasn't open. 2001-09-13 Joel Sherrill <joel@OARcorp.com> * posix/src/sysconf.c: Fix typo syntax error accidentally committed. * posix/src/mprotect.c: New file. Stub required by some gcc's to pass tests. In particular, about 350 ACATS tests fail if this is not present. * posix/src/getpagesize.c: Ditto. * posix/src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required to pass about 350 ACATS test cases. * posix/src/Makefile.am: Added new files. * libmisc/devnull/devnull.c: Eliminate warning. 2001-08-30 Joel Sherrill <joel@OARcorp.com> * posix/macros/rtems/posix/mqueue.inl: Add cast so negation works. * score/ src/coremutex.c, score/src/coremutexseize.c, score/src/coremutexsurrender.c, score/inline/rtems/score/coremutex.inl: The per thread field resource_count should only be manipulated when a mutex is priority ceiling or priority inherit. This was reported by Chris Johns <ccj@acm.org> who also noticed that the use of switches for all disciplines generated less efficient code than using explicit tests for the one or two cases we were really interested in. Further review of his modifications made it apparent that the "isa" methods to test mutex discipline were not being used so this modification was swept into the code as well. * score/src/coremutexseize.c: Add missing code for proper handling of nesting acquisitions. This only impacts building with inlines disabled on the source with the "fast mutex" optimizations. This was post the 4.5 branch and did not impact released versions. * rtems/inline/rtems/rtems/attr.inl: Correct typo and use correct attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>. 2001-08-16 Mike Siers <mikes@poliac.com> * libnetworking/pppd/STATUS: Updated by Joel based upon email from Mike. * libnetworking/pppd/cbcp.c, libnetworking/pppd/cbcp.h: Readded files. These support callback functionality that has not even been compiled under RTEMS yet. * libnetworking/pppd/*: Update of PPPD to 2.3.11 from 2.3.5 and addition of an example application. - renamed error() function because of namespace problems. - removed calls to the exit() function. - removed extra files from the pppd source directory. - defined pppd task constant values in rtemspppd.h. - modifyied example code to get actual tick per second value. - placed the pppd 2.3.11 man page file (pppd.8) into the pppd directory. * libnetworking/pppd/cbcp.c, libnetworking/pppd/cbcp.h, libnetworking/pppd/main.c, libnetworking/pppd/ppp_tty.c, libnetworking/pppd/pppmain.c, libnetworking/pppd/rtems-ppp.c, libnetworking/pppd/rtems-ppp.c: Deleted. * libnetworking/pppd/pppd.8, libnetworking/pppd/rtemsmain.c, libnetworking/pppd/rtemspppd.c, libnetworking/pppd/rtemspppd.h, libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c, libnetworking/pppd/example/Makefile, libnetworking/pppd/example/README, libnetworking/pppd/example/init.c, libnetworking/pppd/example/netconfig.h, libnetworking/pppd/example/ppp.conf, libnetworking/pppd/example/pppdapp.c, libnetworking/pppd/example/system.h: New files. * libnetworking/modem/ppp_tty.c, libnetworking/net/if_ppp.h, libnetworking/pppd/Makefile.am, libnetworking/pppd/README, libnetworking/pppd/STATUS, libnetworking/pppd/auth.c, libnetworking/pppd/ccp.c, libnetworking/pppd/ccp.h, libnetworking/pppd/chap.c, libnetworking/pppd/chap.h, libnetworking/pppd/chap_ms.c, libnetworking/pppd/chap_ms.h, libnetworking/pppd/chat.c, libnetworking/pppd/demand.c, libnetworking/pppd/fsm.c, libnetworking/pppd/fsm.h, libnetworking/pppd/ipcp.c, libnetworking/pppd/ipcp.h, libnetworking/pppd/ipxcp.c, libnetworking/pppd/ipxcp.h, libnetworking/pppd/lcp.c, libnetworking/pppd/lcp.h, libnetworking/pppd/magic.c, libnetworking/pppd/magic.h, libnetworking/pppd/options.c, libnetworking/pppd/patchlevel.h, libnetworking/pppd/pathnames.h, libnetworking/pppd/pppd.h, libnetworking/pppd/upap.c, libnetworking/pppd/upap.h: Modified. 2001-08-16 Joel Sherrill <joel@OARcorp.com> * posix/src/mqueuesendsupp.c: Account for possibly blocking during the core send operation. * score/src/coremutexsurrender.c: Use holder thread not executing thread because even though they may and often are the same it is not guaranteed unless the proper attribute is set. * score/include/rtems/score/coremsg.h, score/src/coremsgsubmit.c: Add a new return status to account for blocking sends. Otherwise, the caller will think that the returned message status will have the ultimate results of the operation. If the send times out, the final status will be in the return_code of the thread. * rtems/src/msgqsubmit.c: Add a comment indicating that we do not have to account for possibly blocking during the core send operation because Classic API message queue send is always non-blocking. * libnetworking/pppd/example/Makefile: Removed. * libnetworking/pppd/example/Makefile-user: Added was Makefile. Renamed to avoid bootstrap -c clobbering it. * libnetworking/rtems_telnetd/.cvsignore: New file. 2001-08-09 Keith Outwater <vac4050@cae597.rsc.raytheon.com> * libmisc/monitor/mon-command.c: Add support for partial command matching. The monitor used to have this functionality before it was overhauled to support addition of user commands. 2001-08-09 Joel Sherrill <joel@OARcorp.com> * itron/src/snd_mbx.c, itron/src/tsnd_mbf.c, posix/src/mqueuesendsupp.c, score/include/rtems/score/coremsg.h, score/inline/rtems/score/coremsg.inl, score/src/coremsgsubmit.c, rtems/src/msgqsubmit.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>. 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com> * libmisc/shell/pty.c: Moved to libnetworking/rtems_telnetd. * libmisc/shell/Makefile.am, libmisc/shell/README, libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h: Updates. * libfs/src/imfs/imfs_eval.c: The CD_UP problem in imfs_eval has been touched. The order of the questions is the key. * libnetworking/Makefile.am, libnetworking/configure.in, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_servers/telnetd.c, libnetworking/rtems_servers/telnetd.h, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_telnetd/README, libnetworking/rtems_telnetd/icmds.c, libnetworking/rtems_telnetd/pty.c, libnetworking/rtems_telnetd/pty.h, libnetworking/rtems_telnetd/telnetd.c, libnetworking/rtems_telnetd/telnetd.h, libnetworking/wrapup/Makefile.am: - pty and telnetd have a new subdir rtems_telnetd to avoid the side effect when ftpd change. - the tcp/ip stats have been implemented into icmds.c and started when telnetd daemon is started. * libnetworking/rtems_servers/telnetd.c, libnetworking/rtems_servers/telnetd.h: Removed. * libnetworking/rtems_telnetd: New directory. * libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_telnetd/README, libnetworking/rtems_telnetd/icmds.c, libnetworking/rtems_telnetd/pty.c, libnetworking/rtems_telnetd/pty.h, libnetworking/rtems_telnetd/telnetd.c, libnetworking/rtems_telnetd/telnetd.h: New files. 2001-07-06 Thomas Doerfler <Thomas.Doerfler@imd-systems.de> * libfs/src/imfs/deviceio.c: Make sure errno gets set to reflect the status from the driver. 2001-06-14 Joel Sherrill <joel@OARcorp.com> * libmisc/shell/telnetd.c, libmisc/shell/telnetd.h: Moved to libnetworking/rtems_servers so the network stack to address network depenendency. * libmisc/shell/Makefile.am: Modified to reflect above. * libnetworking/rtems_servers/telnetd.c, libnetworking/shell/telnetd.h: Moved from libmisc/shell so the network stack to address network depenendency. * libnetworking/rtems_servers/Makefile.am: Modified to reflect above. 2001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/rtems_servers/Makefile.am: Deleted blank lines. 2001-05-25 Sergei Organov <osv@javad.ru> * score/macros/rtems/score/coresem.inl, score/inline/rtems/score/coresem.inl: Cut and paste problem incorrectly enabled interrupts twice with the first time being too early. 2001-05-25 Joel Sherrill <joel@OARcorp.com> * libmisc/shell/cmds.c: Removed code from inappropriate source. * libfs/src/imfs/imfs_initsupp.c: Create the root node with the desired permissions. Nodes should be created with the right permissions because chmod() is not supported by the miniIMFS so changing after creation is not possible. 2001-05-24 Joel Sherrill <joel@OARcorp.com> * libcsupport/src/.cvsignore: New file. 2001-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es> * posix/src/getegid.c, posix/src/geteuid.c, posix/src/getgid.c, posix/src/getlogin.c, posix/src/getuid.c: Now save their values in private user environment. * libmisc/monitor/mon-prmisc.c: Correct print line. * libmisc/shell/Makefile.am: Added new file telnetd.c. * libmisc/shell/telnetd.c, libmisc/shell/telnetd.h, libmisc/shell/pty.c: New files. * libmisc/shell/shell.c, libmisc/shell/cmds.c, libmisc/shell/shell.h: Numerous improvments: - The shell_init has a new parameter 'forever' because in /dev/console you need that this process runs forever but in tcp/ip not. (respawn?) - A new task for every session opened trought tcp/ip telnet client. (the chargen,daytime and more are possible of implementation but I ask me if they are necesary) - Exit from the session delete the task and when the client fails too. - More cmds have been implemented. (very reduced version of these) umask, chmod, id, whoami, rm, cat, ... - A reduced line edit has been implemented. Ctrl-C abort the input, Ctrl-d in the first position gives EOF (logout). '\b' and DEL makes the rubout operation. I think that readline() for every session spents a lot of resources. 2001-05-17 Joel Sherrill <joel@OARcorp.com> * posix/macros/rtems/posix/mqueue.inl: Implemented missing routines to support message queue FDs. * score/macros/rtems/score/thread..inl: Implemented missing routines for new libc reentrancy support. 2001-05-14 Till Straumann <strauman@slac.stanford.edu> * score/src/threaddispatch.c, score/src/threadhandler.c: Per PR211 fix saving/restoring floating point context. The fpsave and fprestore routines are only used in a executing context which _is_ fp and hence has the FPU enabled. The current behavior required the FPU always to be on which is very dangerous if lazy context switching is used. [Joel Note: Some ports explicitly enabled the FPU in the FP save and restore routines to avoid this.] The patch also makes sure (on powerpc only) that the FPU is disabled for integer tasks. Note that this is crucial if deferred fp context switching is used. Otherwise, fp context corruption may go undetected! Also note that even tasks which merely push/pop FP registers to/from the stack without modifying them still MUST be FP tasks - otherwise (if lazy FP context switching is used), FP register corruption (of other, FP, tasks may occur)! Furthermore, (on PPC) by default, lazy FP context save/restore is _disabled_. 2001-05-14 Joel Sherrill <joel@OARcorp.com> * libmisc/dummy/Makefile.am, libmisc/wrapup/Makefile.am: Fixed to generate a library of the same name. * libnetworking/ChangeLog: Corrected -- entry should have been in libchip. 2001-05-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/score/.cvsignore: Add stamp-h, cpuopts.h, cpuopts.h.in, cpuopts-tmp.h. * libnetworking/libc/Makefile.am: Remove -D__STRICT_ANSI__. 2001-05-09 Joel Sherrill <joel@OARcorp.com> * sapi/src/exinit.c: Slightly rework initialization so there is a valid thread as _Thread_Executing when the pre_tasking hook is called. This allows one directives and malloc to potentially use mutex protection. 2001-04-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/shell/cmds.c, libmisc/shell/shell.c: Remove fileno-hacks. * libmisc/monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__. 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.in, itron/configure.in, posix/configure.in, libfs/configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET. 2001-04-26 Joel Sherrill <joel@OARcorp.com> * posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/mqueue.inl, posix/src/mqueue.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueueopen.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c: Per PR81 reworked to add a message queue descriptor separate from the underlying message queue. This allows non-blocking to follow the "open" not the underlying queue. * score/src/objectcomparenamestring.c: Fix typos. * score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/ src/objectcomparenamestring.c: Address PR81 that reworked POSIX message queues to add a descriptor separate from the underlying message queue. This allows non-blocking to follow the "open" not the underlying queue. As part of debugging this it became clear that _Objects_Compare_name_string was broken and a simple version using strncmp() was substituted. 2001-04-24 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/memfile.c (memfile_open): Did not set iop->size and thus the value was incorrect. Before this field was cleared, this resulted in the value from the last time that IOP was used being still in place. Discovered by Andrew Bythell <abythell@nortelnetworks.com>. 2001-04-24 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/rtems_bsdnet_ntp.c: Modifications to make the RTEMS NTP synchronization a little more robust -- no NTP daemon yet, but at least it trys a little harder when the primary NTP server is down. 2001-04-22 Joel Sherrill <joel@OARcorp.com> * itron/src/task.c (_ITRON_Task_User_extensions): Add new fields to be correct in respect to newly added fields for separate switch list. 2001-04-20 Radzislaw Galler <rgaller@et.put.poznan.pl> * libnetworking/modem/ppp.c, libnetworking/pppd/main.c, libnetworking/pppd/pppmain.c, libnetworking/pppd/rtems-ppp.c, libnetworking/pppd/modem_example/modem.c, libnetworking/pppd/modem_example/ppp.c: Translated Polish comments and other strings into English. * libnetworking/pppd/STATUS: updated to reflect the changes. 2001-04-20 Joel Sherrill <joel@OARcorp.com> * libmisc/devnull/devnull.c (null_initialize): Added check to ensure that the driver is only initialized once. Otherwise, it will abort when the device /dev/null is present. (null_write): Do not dereference a NULL pointer. * libfs/src/imfs/imfs_debug.c (IMFS_print_jnode): Modified to print only information that does not vary based on target or memory configuration. The old prints are still there in case they are needed in the future to debug. Printing target dependent addresses makes the test output vary by target unnecessarily. 2001-04-20 Jake Janovetz <janovetz@uiuc.edu> * libnetworking/rtems_servers/ftpd.c: Correct argument so hooks work again. 2001-04-20 Fernando Ruiz Casas <correo@fernando-ruiz.com> * Added initial shell functionality. * libmisc/Makefile.am, libmisc/configure.in, libmisc/wrapup/Makefile.am: Reflect having added shell. * libmisc/shell/.cvsignore, libmisc/shell/Makefile.am, libmisc/shell/README, libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h: New files. 2001-04-16 Joel Sherrill <joel@OARcorp.com> * sapi/include/confdefs.h: Fix real-time clock support. 2001-04-11 Joel Sherrill <joel@OARcorp.com> * score/macros/rtems/score/userext.inl: Now works after merging patch for functionality requested in PR174. * score/inline/rtems/score/userext.inl: Added a comment explaining the order in which routines appear since it is not the obvious order. 2001-04-08 Joel Sherrill <joel@OARcorp.com> * score/macros/rtems/score/object.inl: Corrected arguments. * score/macros/rtems/score/userext.inl: Updated to reflect modifications to inline version from PR142. * score/inline/rtems/score/userext.inl: Cleanup as side-effect of above. * rtems/src/tasks.c: Pre-initialized switch extension for list. * rtems/macros/rtems/score/timer.inl: Corrected typo on end of line. 2001-04-04 Joel Sherrill <joel@OARcorp.com> * libfs/src/dosfs/Makefile.am: Per PR129 do not install as many files to the $(includedir). 2001-03-29 Joel Sherrill <joel@OARcorp.com> * Per PR126, configuration structures now match docs. * sapi/include/rtems/config.h: Use public data types. * Per PR126, configuration structures now match docs. * rtems/include/rtems/rtems/config.h: Use public data types. * Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * rtems/include/rtems/rtems/timer.h, rtems/src/timerreset.c, rtems/src/timerserver.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c: Broke up the "reset server" routine into a set of very specific routines that allowed the server to be unscheduled, timer chains to be "synchronized" with the current time before inserting a new timer. 2001-03-28 Joel Sherrill <joel@OARcorp.com> * PR132 requested some tinkering ot lower memory. * sapi/include/confdefs.h: Lowered footprint of device driver table and statically configure user extensions. Now if no static extensions are configured, then the table is not instantiated. 2001-03-26 Zoltan Kocsi <zoltan@bendor.com.au> * rtems/src/eventsurrender.c: Clear event condition when task is unblocked. This makes sure that subsequent event send thinks the task is still blocked and overwrites the initial events received. 2001-03-23 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/memfile.c: Reapply fix from bug report from Jose Sturniolo <jsturnio@nec.com.ar> where NULL pointer was dereferenced when freeing a triply indirect file. The fix was applied to the 4.5 release branch and not the development branch. 2001-03-20 Till Straumann <strauman@SLAC.Stanford.EDU> * PR158 * libnetworking/libc/rcmd.c, libnetworking/libc/rcmd.c: Enable the rcmd() library call by commenting out the parts that deal with signals. This enables RTEMS to 'rsh' command to a server connecting fd to remote stdio. The 'server-side' parts of this file which deal with authentication are disabled since they are not needed. 2001-03-19 Joel Sherrill <joel@OARcorp.com> * posix/sys/utsname.h: Added C++ wrapper. 2001-03-15 Ralf Corsepius <corsepius@faw.uni-ulm.de> * libnetworking/include/.cvsignore: Remove dangling file. 2001-03-15 Joel Sherrill <joel@OARcorp.com> * sapi/src/extension.c: Split to reduce minimum code size per PR134. * sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c: New files. src/Makefile.am: Modified to reflect above. 2001-03-01 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/.cvsignore: Added stamp-h1.in. 2001-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.in: AC_DEFINE RTEMS_UNIX if RTEMS_CPU=unix. 2001-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libmisc/monitor/mon-command.c: Use #if defined(RTEMS_UNIX). 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * itron/include/Makefile.am, itron/include/itronsys/Makefile.am, itron/include/rtems/itron/Makefile.am, itron/inline/rtems/itron/Makefile.am, itron/macros/rtems/itron/Makefile.am, posix/include/Makefile.am, posix/include/rtems/posix/Makefile.am, posix/include/sys/Makefile.am, posix/inline/rtems/posix/Makefile.am, posix/macros/rtems/posix/Makefile.am: Apply include_*HEADERS instead of H_FILES. * include/rtems/Makefile.am, include/rtems/score/Makefile.am, inline/rtems/score/Makefile.am, macros/rtems/score/Makefile.am Apply include_*HEADERS instead of H_FILES. * sapi/include/Makefile.am, sapi/include/rtems/Makefile.am, sapi/inline/rtems/Makefile.am, sapi/macros/rtems/Makefile.am, rtems/include/Makefile.am, rtems/include/rtems/rtems/Makefile.am, rtems/inline/rtems/rtems/Makefile.am, rtems/macros/rtems/rtems/Makefile.am, rtems/ rtems/optman/Makefile.am, libmisc/untar/Makefile.am, libmisc/monitor/Makefile.am, libmisc/dummy/Makefile.am, libmisc/devnull/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/mw-fb/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/cpuuse/Makefile.am, librpc/include/rpc/Makefile.am, libfs/src/imfs/Makefile.am, libnetworking/Makefile.am, libnetworking/arpa/Makefile.am, libnetworking/machine/Makefile.am, libnetworking/net/Makefile.am, libnetworking/ netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/ rtems_servers/Makefile.am, libnetworking/rtems_webserver/Makefile.am, libnetworking/sys/Makefile.am, libnetworking/vm/Makefile.am: Apply include_*HEADERS instead of H_FILES. * libnetworking/include/Makefile.am: Remove. * libnetworking/Makefile.am: Add handling of *.h files. * libnetworking/configure.in: Remove include/Makefile. 2001-01-31 Sergei Organov <osv@javad.ru> * libnetworking/rtems_servers/ftp.d: Following changes: - Hacks with current dir and root dir removed in favor of new libio support for task-local current and root directories. - Bug in `close_data_socket()' introduced by previous change fixed. - `command_pasv()' changed to set timeout on socket we are listening on and code fixed to don't close socket twice on error. - `serr()' changed to clear `errno'. - `data_socket()' changed to clear `errno' before `bind()'. - `session()' changed to clear `errno' before processing session. - `close_data_socket()' fixed to close both active and passive sockets. - Initialize info->data_socket to -1 in `daemon()'. - Initialize `fname' to empty string in `exec_command()'. 2001-01-31 Joel Sherrill <joel@OARcorp.com> * rtems/include/rtems/rtems/timer.h: Missed merging these modifications in previous merge of new timer functionality. 2001-01-29 Joel Sherrill <joel@OARcorp.com> * score/src/objectextendinformation.c: Added include of string.h to eliminate warning. * Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * src/timerserver.c, include/rtems/rtems/timer.h, * rtems/src/timergetinfo.c: New file. * rtems/src/Makefile.am: Modified to reflect above. 2001-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.d> * sapi/include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not using NEWLIB, cleanup related comment. 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * sapi/include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull. 2001-01-25 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.c: Reduce first timeout interval. This improves throughput on systems which are dropping packets. Only the first timeout is reduced. This keeps the number of extra packets down on networks that are very busy and dropping lots of packets. 2001-01-24 Sergei Organov <osv@javad.ru> * libnetworking/rtems_servers/ftpd.c, libnetworking/rtems_servers/ftpd.h: - Timeouts on sockets implemented. 'idle' field added to configuration. No timeout by default to keep backward compatibility. Note: SITE IDLE command not implemented yet. - Basic global access control implemented. 'access' field added to configuration. No access limitations by default to keep backward compatibility. - Anchor data socket for active mode (using self IP and port 20.) - Fixed default data port support (still not tested). - Don't allow IP address different from originating host in PORT command to improve security. - Fixed bug in MDTM command. - Check for correctness of parsing of argument in command_port(). - Fixed squeeze_path() to don't allow names like 'NAME/smth' where 'NAME' is not a directory. - Command parsing a little bit improved: command names are now converted to upper-case to be more compatible with RFC (command names are not case-sensitive.). - Reformat comments so that they have RTEMS look-and-feel. - Fixed DELE, SITE CHMOD, RMD, MKD broken by previous changes. - True ASCII mode implemented (doesn't work for hooks and /dev/null) - Passive mode implemented, PASV command added. - Default port for data connection could be used (untested, can't find ftp client that doesn't send PORT command). - SYST reply changed to UNIX, as former RTEMS isn't registered name. - Reply codes reviewed and fixed. 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * posix/configure.in: Add src/config.h. * posix/src/Makefile.am: Add INCLUDES += -I. to pickup config.h. * posix/src/.cvsignore: Add config.h and stamp-h. * posix/src/*.c: Add config.h support. 2001-01-23 Joel Sherrill <joel@OARcorp.com> * posix/src/alarm.c: Eliminated use of C++ style comments. 2001-01-22 Michael Hamel <mhamel@adi.co.nz> * posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/semaphore.inl, posix/ src/ptimer1.c, posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/semaphore.inl, posix/src/alarm.c, posix/src/ptimer1.c, posix/src/semaphorenametoid.c, posix/src/semopen.c, posix/src/semunlink.c, rtems/include/rtems.h, rtems/src/signalcatch.c: Modifications to make CodeWarrior happy. 2001-01-22 Joel Sherrill <joel@OARcorp.com> * rtems/include/rtems/rtems/timer.h, rtems/src/timerserver.c: Add priority argument to rtems_timer_initiate_server(). 2001-01-18 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/system.h, rtems/include/rtems/system.h: Only include cpuopts.h when building a multilib configuration. Some ports still need targopts.h but this small modification lets those ports work non-multilib while fixing being fixed for multilib. 2001-01-17 Joel Sherrill <joel@OARcorp.com> * ChangeLog: Deleted duplicate blank line. 2001-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libfs/configure.in: Add src/imfs/config.h. * libfs/src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h. * libfs/src/imfs/.cvsignore: Add config.h and stamp-h. * libfs/src/imfs/*.c: Add config.h support. 2001-01-16 Joel Sherrill <joel@OARcorp.com> * posix/inline/rtems/posix/mutex.inl (_POSIX_Mutex_Get_support): Corrected name of routine in header. * rtems/Added task-based timers to the Timer Manager. This added three new directives: - rtems_timer_initiate_server - rtems_timer_server_fire_after - rtems_timer_server_fire_when In the process of doing this, a number of cleanups were made. * rtems/src/timerserver.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c: New files. * rtems/include/timer/timer.h: Added new prototypes and supporting types. * rtems/inline/rtems/rtems/timer.h, rtems/macros/rtems/rtems/timer.h: Enhanced _Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK. * rtems/src/Makefile.am: Accounted for new files. * rtems/src/rtemstimer.c: Added initialization of _Timer_Server variable. * rtems/src/timercancel.c, rtems/src/timerreset.c: Account for addition of timer classes. Also corrected the headers. * rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/ src/timerfireafter.c, rtems/src/timerident.c: Corrected header. * rtems/src/taskmode.c: Ensure the this service does not dispatch before tasking is enabled at initialization time. 2001-01-12 Sergei Organov <osv@javad.ru> * libnetworking/rtems_servers/ftpd.c, libnetworking/rtems_servers/ftpd.h: - use pool of pre-created threads to handle sessions instead of creating/deleting threads on the fly. - LIST output is now similar to what "/bin/ls -al" would output, thus FTP clients such Netscape are happy with it. - LIST NAME now works (both for files and directories) - added support for NLST, CDUP, and MDTM FTP commands to make more FTP clients happy . - keep track of CWD for every session separately. - ability to specify root directory name for FTPD in configuration table. FTPD will then create illusion for FTP clients that this is actually root directory. - ignore options sent in commands, thus LIST -al FILE works and doesn't try to list "-al" directory. - buffers are allocated on stack instead of heap where possible to eliminate malloc/free calls (avoid possible heap fragmentation troubles). - drop using of task notepad to pass parameters - use function arguments instead. - use snprintf() instead of sprintf() as the latter is unsafe. - use of PF_INET in socket() instead of AF_INET. 2001-01-12 Joel Sherrill <joel@OARcorp.com> * posix/src/clockgetres.c: Fixed match problem. We are not converting an interval to a timespec -- it is actually a real number of microseconds. * posix/src/README.mqueue: Enhanced example. 2001-01-12 Jake Janovetz <janovetz@uiuc.edu> * libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/memfile.c, libfs/src/imfs/miniimfs_init.c: Final developmental update to "tarfs". When rtems_tarfs_load() is called, it checks the permissions on each file. If there is write permission, it just creates a standard file using "creat()" and therefore, uses the IMFS MEMORY_FILE. If there is no write permission, it creates a LINEAR_FILE node with the appropriate properties. If the permission is ever changed to writeable, IMFS_fchmod converts it to a regular memory file. 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/src/threadinitialize.c: Removed warning. 2001-01-08 Joel Sherrill <joel@OARcorp.com> * score/src/threadinitialize.c: Fix my bad hack of Ralf's fp_area warning removal patch. :(. 2001-01-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * itron/configure.in: Add src/config.h. * itron/src/Makefile.am: Add INCLUDES += -I. to pickup config.h. * itron/src/.cvsignore: Add config.h and stamp-h. * itron/src/*.c: Add config.h support. 2001-01-05 Joel Sherrill <joel@OARcorp.com> * libmisc/devnull: New addition. Moved from libcpu/sh. * libmisc/devnull/devnull.c, libmisc/devnull/devnull.h, libmisc/devnull/.cvsignore, libmisc/ devnull/Makefile.am: New files. * libmisc/Makefile.am, libmisc/configure.in, libmisc/wrapup/Makefile.am: Modified to reflect addition of above. 2001-01-03 Joel Sherrill <joel@OARcorp.com> * score/src/isr.c: Modify to properly dereference _ISR_Vector_table now that it is dynamically allocated. 2001-01-02 Joel Sherrill <joel@OARcorp.com> * libnetworking/CHANGELOG: Removed. * libnetworking/README: Merged CHANGELOG contents as initial changes. 2000-12-19 Joel Sherrill <joel@OARcorp.com> * posix/src/pthreadgetschedparam.c: Do not set output parameters if the pointers are NULL. * score/src/isr.c: Allocate the _ISR_Vector_table all the time not just when we are allocating an interrupt stack. 2000-12-14 Eric Norum <eric.norum@usask.ca> * libnetworking/lib/tftpDriver.c: Added write capability. 2000-12-13 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/score/isr.h, score/src/isr.c: Allocate it from the workspace rather than explicitly declaring it. This allows the size to be a non-constant from the perspective of score/cpu. 2000-12-12 Jake Janovetz <janovetz@uiuc.edu> * libfs/src/imfs/linearfile.c, libfs/src/imfs/imfs_load_tar.c: New files. * libfs/src/imfs/Makefile.am, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/miniimfs_init.c: Added "tarfs". This is not really a tar filesystem. It is a way to load a tar image into the IMFS but actually leave bulky file contents in the original tar image. It essentially adds the linear file type and associated support and a loader routine. 2000-12-08 Joel Sherrill <joel@OARcorp.com> * libnetworking/libc/linkaddr.c: Initialized variable to remove warning. * libnetworking/modem/ppp.c, libnetworking/modem/ppp_tty.c: Made numerous variable declarations conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables that were not used because the code using them was commented out. Removed totally unused variables. * libnetworking/modem/pppcompress.c: Added parentheses to avoid warnings. * libnetworking/pppd/pppmain.c: Removed numerous warnings. 2000-12-06 Joel Sherrill <joel@OARcorp.com> * posix/src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to eliminate warning. * rtems/src/regiongetinfo.c: Removed unused variable to eliminate warning. 2000-12-01 Joel Sherrill <joel@OARcorp.com> * configure.in: Removed error check for enabling macros with either POSIX or ITRON API. * Added macro support to ITRON API. This is known to compile. * itron/Makefile.am: Added macros directory. * itron/configure.in: Removed error check for enabling macros. * itron/macros/.cvsignore, itron/macros/Makefile.am, itron/macros/rtems/.cvsignore, itron/macros/rtems/Makefile.am, itron/macros/rtems/itron/.cvsignore, itron/macros/rtems/itron/Makefile.am, itron/macros/rtems/itron/eventflags.inl, itron/macros/rtems/itron/fmempool.inl, itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl, itron/macros/rtems/itron/msgbuffer.inl, itron/macros/rtems/itron/network.inl, itron/macros/rtems/itron/port.inl, itron/macros/rtems/itron/semaphore.inl, itron/macros/rtems/itron/sysmgmt.inl, itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl, itron/macros/rtems/itron/vmempool.inl: New files. * posix/include/rtems/posix/cond.h: #if 0'ed out prototype of _POSIX_Condition_variables_Get to avoid conflict with macro implementation. * Added macro support to POSIX API. This is known to compile. * posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/intr.inl, posix/macros/rtems/posix/key.inl, posix/macros/rtems/posix/mqueue.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/priority.inl, posix/macros/rtems/posix/pthread.inl, posix/macros/rtems/posix/semaphore.inl, posix/macros/rtems/posix/timer.inl: New files. * posix/configure.in: Removed error check for enabling macros. * posix/rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines since you cannot have prototypes for macros. * posix/macros/rtems/posix/Makefile.am: Added files. * score/macros/rtems/score/coresem.inl: Removed comments since convention calls for comments to be in inline versin. * score/macros/rtems/score/object.inl (Objects_Get_local_object): Fixed style to use _ prefix on variable names and use parentheses. * score/macros/rtems/score/object.inl (_Objects_Namespace_remove): Added. 2000-11-30 Joel Sherrill <joel@OARcorp.com> * posix/inline/rtems/posix/mqueue.inl: Removed explicit dependency on abs(). * General effort to make things compile with macros not inlines * score/inline/rtems/score/coremutex.inl: Added comment indicating for macros there is another copy of _CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c. * score/src/coremutexseize.c: Added body of _CORE_mutex_Seize_interrupt_trylock() for macro case. * score/macros/rtems/score/coremutex.inl: Added prototype for _CORE_mutex_Seize_interrupt_trylock() since there is a real body when macros are enabled. * score/macros/rtems/score/coresem.inl: Added macro implementation of _CORE_semaphore_Seize_isr_disable. * score/macros/score/Makefile.am: Fixed typos. * score/rtems/score/address.inl: Correct macro implementation of _Addresses_Is_aligned() so it would compile. * score/macros/rtems/score/coremsg.inl: Added closing parentheses. * rtems/src/msgqsubmit.c: Modified multiprocessing conditional so this would compile with both macros and inlines. * rtems/macros/rtems/rtems/sem.inl: Added macro implementation of _Semaphore_Get_interrupt_disable(). * libmisc/mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>. * libnetworking/modem/ppp_tty.c: Changed to include <rtems/termiostypes.h> since that is an RTEMS specific header file. * libnetworking/sys/ttycom.h: Moved to lib/include/sys. * libnetworking/Makefile.am: Modified to reflect above. 2000-11-28 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/memfile.c: Bug report from Sturniolo Jose <jsturnio@nec.com.ar> where NULL pointer was dereferenced. 2000-11-28 Chris Johns <ccj@acm.org> * score/src/heapallocate.c: Do not allow the size to overflow when adjusting it. A test allocated a stack of -1 (~0). This actually resulted in a stack being allocated but with a size of 0xb. The allocator did not test the size to see if it rolled through 0 and so allowed the allocation to happen, the thread to get created. The task crashed as you would expect. 2000-11-27 Joel Sherrill <joel@OARcorp.com> * posix/src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX. * libnetworking/libc/res_init.c: Fix typo - adding missing # on include. 2000-11-25 Eric Norum <eric.norum@usask.ca> * libnetworking/libc/res_init.c: Move include to avoid compiler dumping core. 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com> * libnetworking/wrapup/Makefile.am, libnetworking/configure.in, libnetworking/Makefile.am: Added modem subdir. * libnetworking/net/Makefile.am: Added if_pppvar.h, pppcompress.h. * libnetworking/pppd/Makefile.am: Added pppmain.c (which needs work). * libnetworking/pppd/chat.c, libnetworking/pppd/fsm.c, libnetworking/pppd/fsm.h, libnetworking/pppd/ipxcp.c, libnetworking/pppd/main.c, libnetworking/pppd/ppp_tty.c, libnetworking/pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c. 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> * libfs/src/imfs/imfs_eval.c: Always return imaginary node at mount points. 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, itron/Makefile.am, posix/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libfs/Makefile.am, libnetworking/Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, itron/Makefile.am, posix/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libfs/Makefile.am, libnetworking/Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. 2000-11-02 Joel Sherrill <joel@OARcorp.com> * score/include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API) so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(), POSIX_BOTTOM_REACHED() are actually included. * score/include/rtems/system.h: Add prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(), POSIX_BOTTOM_REACHED() removed from newlib. 2000-11-01 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/Makefile.am, libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs_chown.c, libfs/src/imfs/imfs_config.c, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/imfs_free.c, libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_gtkn.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_link.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_mount.c, libfs/src/imfs/imfs_readlink.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/imfs_symlink.c, libfs/src/imfs/imfs_unixstub.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/imfs_unmount.c, libfs/src/imfs/imfs_utime.c, libfs/src/imfs/ioman.c, libfs/src/imfs/memfile.c, libfs/src/imfs/miniimfs_init.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Now we do not have to reach up and over to libc to pick them up. 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * posix/configure.in: Cleanup comments. 2000-10-30 Joel Sherrill <joel@OARcorp.com> * posix/include/Makefile.am: Updated to reflect files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * posix/include/unistd.h: Removed. Now use newlib's. * posix/include/rtems/posix/mqueue.h: Add include of <signal.h>. * posix/include/rtems/posix/threadsup.h: Add include of <sys/signal.h>. * posix/src/execv.c, posix/src/execve.c, posix/src/execvp.c: Corrected prototype to agree with newlib. * posix/src/psignal.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. * posix/src/pthreadkill.c, posix/src/sigaction.c: Added include of <signal.h>. * posix/src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * sapi/include/confdefs.h: Replaced include of <sys/siginfo.h> with <signal.h> since that file no longer exists. * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * librpc/src/rpc/Makefile.am, librpc/src/rpc/auth_time.c, librpc/src/rpc/clnt_simple.c, librpc/src/rpc/clnt_tcp.c, librpc/src/rpc/clnt_udp.c, librpc/src/rpc/clnt_unix.c, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_clnt.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c, librpc/src/rpc/pmap_rmt.c, librpc/src/rpc/rtime.c, librpc/src/rpc/svc_tcp.c, librpc/src/rpc/svc_udp.c, librpc/src/rpc/svc_unix.c: Use of _read, _write, and _close as macros conflicted with newlib's use of these as routine names. They were renamed to include "_RPC_" prefix. * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * libnetworking/machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync with newlib's <machine/types.h>. * libnetworking/rtems/rtems_bsdnet_internal.h: newlib now includes definition of struct itimerval in <sys/time.h>. 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am, itron/Makefile.am, posix/Makefile.am, libmisc/Makefile.am, librpc/Makefile.am, libnetworking/Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libfs/Makefile.am, libfs/configure.in: Introduce GNU canonicalization to libfs/. The approach is currently a bit of a hack as GNU canonicalization does not support the per-BSP build some of the other directories require. As more of the tree is converted, this will become less of an issue. 2000-10-24 Joel Sherrill <joel@OARcorp.com> * libfs/src/imfs/imfs_config.c: New file containing IMFS configuration information split from libc/base_fs.c. * libfs/src/imfs/ioman.c: New file. Moved from lib/libc. Missed previously. * libfs/src/imfs/Makefile.am: Added imfs_config.c and ioman.c. 2000-10-19 Joel Sherrill <joel@OARcorp.com> * libfs/.cvsignore, libfs/src/.cvsignore, libfs/src/imfs/.cvsignore, libfs/wrapup/.cvsignore: New files. 2000-10-19 Antti P Miettinen <anmietti@trshp.ntc.nokia.com> * libnetworking/lib/tftpDriver.c: add comments to handlers struct function pointers. * libnetworking/rtems/rtems_glue.c: move pointer arithmetic to be _after_ pointer has been checked against NULL. 2000-10-18 Nick Simon <Nick.SIMON@syntegra.bt.co.uk> * score/src/heapgetinfo.c, score/include/rtems/score/heap.h, score/src/Makefile.am: Added _Heap_Get_information() and information control block. * score/src/heapgetinfo.c: New file. 2000-10-18 Joel Sherrill <joel@OARcorp.com> * sapi/include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0 if there is no Classic API Initialization Tasks Table defined. * sapi/include/confdefs.h: Modified code that accounts for initialization task/threads with greater than minimum stack sizes so it would compile even if optional APIs are disabled. * rtems/src/regiongetinfo.c, rtems/include/rtems/rtems/region.h, rtems/include/rtems/rtems/types.h, rtems/src/Makefile.am: Added region_get_information() and information control block. * rtems/src/regiongetinfo.c: New file. 2000-10-18 Chris Johns <ccj@acm.org> * libfs created. * libfs/src, libfs/src/imfs, libfs/wrapup: New directories. * libfs/ChangeLog, libfs/Makefile.am, libfs/README, libfs/configure.in, libfs/src/Makefile.am, libfs/wrapup/Makefile.am: New files. * libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs_getchild.c, libfs/src/imfs/imfs_readlink.c, libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_gtkn.c, libfs/src/imfs/imfs_rmnod.c, libfs/src/imfs/imfs_chown.c, libfs/src/imfs/imfs_handlers_device.c, libfs/src/imfs/imfs_stat.c, libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_handlers_directory.c, libfs/src/imfs/imfs_symlink.c, libfs/src/imfs/imfs_debug.c, libfs/src/imfs/imfs_handlers_link.c, libfs/src/imfs/imfs_unixstub.c, libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_unmount.c, libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/imfs_initsupp.c, libfs/src/imfs/imfs_utime.c, libfs/src/imfs/imfs_fcntl.c, libfs/src/imfs/imfs_link.c, libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_fdatasync.c, libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/miniimfs_init.c, libfs/src/imfs/imfs_free.c, libfs/src/imfs/imfs_mount.c, libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_ntype.c: New files. Moved from libc. * libnetworking/pppd/ipxcp.c: Fixed a typo. 2000-10-12 Joel Sherrill <joel@OARcorp.com> * sapi/include/confdefs.h: Account for initialization tasks and threads which use larger than minimum stack sizes. 2000-09-29 Stephan Merker <merker@decrc.abb.de> * rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c: Add next_length field so period length can be changed by the the sequence period(X), period(not X) with no intervening cancel or expiration. 2000-09-28 Joel Sherrill <joel@OARcorp.com> * sapi/include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * sapi/src/io.c: Accounted for above. * libmisc/monitor/mon-driver.c: Accounted for addition of "_entry" to fields in rtems_driver_address_table. * libnetworking/rtems_webserver/Makefile.am, libnetworking/rtems_webserver/base64.c, libnetworking/rtems_webserver/base64.c: Renamed base64.c to wbase64.c. * libnetworking/rtems_webserver/sock.c: Added file missed in merger. 2000-09-25 Joel Sherrill <joel@OARcorp.com> * score/rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not targopts.h to reduce dependency on BSP. 2000-09-22 Joel Sherrill <joel@OARcorp.com> * librpc/src/xdr/xdr_float.c: Added A29K support. * libnetworking/machine/types.h, libnetworking/pppd/pppd.h, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h. 2000-09-20 Joel Sherrill <joel@OARcorp.com> * score/src/objectgetbyindex.c: Do not enable dispatching on an error path it was not disabled on. 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/rtems/Makefile.am: Use PROJECT_TOPdir in path to size_rtems. * libnetworking/ChangeLog: Cleanup. 2000-09-05 Joel Sherrill <joel@OARcorp.com> * libnetworking/rtems/rtems_syscall.c: Changed from O_NONBLOCK to internal RTEMS_LIBIO_FLAGS_NO_DELAY to avoid O_NONBLOCK/O_NDELAY confusion and to work with the converted flags. 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * wrapup/itron/Makefile.am, wrapup/posix/Makefile.am, wrapup/rtems/Makefile.am, itron/src/Makefile.am, posix/src/Makefile.am, posix/optman/Makefile.am, score/src/Makefile.am, sapi/src/Makefile.am, sapi/optman/Makefile.am, rtems/optman/Makefile.am, rtems/src/Makefile.am, libmisc/cpuuse/Makefile.am, libmisc/dummy/Makefile.am, libmisc/dumpbuf/Makefile.am, libmisc/monitor/Makefile.am, libmisc/rtmonuse/Makefile.am, libmisc/stackchk/Makefile.am, libmisc/untar/Makefile.am, libmisc/wrapup/Makefile.am, libmisc/mw-fb/Makefile.am, librpc/src/rpc/Makefile.am, librpc/src/xdr/Makefile.am, libnetworking/kern/Makefile.am, libnetworking/lib/Makefile.am, libnetworking/libc/Makefile.am, libnetworking/net/Makefile.am, libnetworking/netinet/Makefile.am, libnetworking/nfs/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/rtems/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_webserver/Makefile.am, libnetworking/wrapup/Makefile.am: Include compile.am. 2000-09-01 Rosimildo daSilva <rdasilva@connecttel.com> * libnetworking/emfdb.c: Removed stray semi-colon. Reported on GoAhead mailing lists by Jim Rudnicki <jdrudnicki@yahoo.com>. 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * libnetworking/netinet/tcp_input.c: Spelling corrections. 2000-08-31 Joel Sherrill <joel@OARcorp.com> * Merged version 2.1 of GoAhead webserver. This update was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>. * libnetworking/NOTES, libnetworking/base64.c, libnetworking/ejIntrn.h, libnetworking/emfdb.c, libnetworking/emfdb.h, libnetworking/md5.h, libnetworking/md5c.c, libnetworking/ um.c, libnetworking/um.h: New files. * libnetworking/wbase64.c: Removed. * libnetworking/Makefile.am, libnetworking/asp.c, libnetworking/balloc.c, libnetworking/default.c, libnetworking/ej.h, libnetworking/ejlex.c, libnetworking/ejparse.c, libnetworking/ form.c, libnetworking/h.c, libnetworking/handler.c, libnetworking/mime.c, libnetworking/misc.c, libnetworking/ringq.c, libnetworking/rom.c, libnetworking/security.c, libnetworking/ socket.c, libnetworking/sym.c, libnetworking/uemf.c, libnetworking/uemf.h, libnetworking/url.c, libnetworking/value.c, libnetworking/webcomp.c, libnetworking/webmain.c, libnetworking/ webpage.c, libnetworking/webrom.c, libnetworking/webs.c, libnetworking/webs.h, libnetworking/websuemf.c, libnetworking/wsIntrn.h: Modified. 2000-08-30 Joel Sherrill <joel@OARcorp.com> * posix/Many files, score/Many files, libmisc/Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. * libmisc/mw-fb/.cvsignore, libnetworking/rtems_webserver/license.txt: New file. 2000-08-30 Joel Sherrill <joel.sherrill@OARcorp.com> * rtems/taskstart.c: Removed 1st cut at rtems_task_start_main_style. Only committed this so it could be easily revisited as we discussing moving main() to user space from BSP space. * rtems/taskstart.c: Added 1st cut at rtems_task_start_main_style. 2000-08-26 Rosimildo da Silva <rdasilva@connecttel.com> * Added generic Micro FrameBuffer interface for MicroWindows. This interface allows MicroWindows to under RTEMS. A sample driver has been developed for the pc386 BSP. See pc386/fb_vga.c as a sample. * Added Uniform Input Device interface for MicroWindows. See PC386 bsp for sample drivers for mouse and keyboard (console). * libmisc/mw-bf: New directory. * libmisc/Makefile.am, libmisc/configure.in, libmisc/wrapup/Makefile.am: Account for mw-fb. * libmisc/mw-fb/Makefile.am, libmisc/mw-fb/mw_fb.c, libmisc/mw-fb/mw_fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h: New file. 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com> * posix/inline/rtems/posix/timer.inl, posix/include/rtems/posix/timer.h, posix/ inline/rtems/posix/Makefile.am, posix/src/ptimer1.c: Redid the style of src/ptimer1.c. Continued effort to make the POSIX Timer implementation match that of other managers. Added data structures required to use SuperCore Object Handler. 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * score/include/rtems/system.h: Include cpuopts.h for __i386__. 2000-08-15 Joel Sherrill <joel@OARcorp.com> * posix/src/ptimer1.c: Minor formatting fixes. * posix/src/ptimer1.c: Removed unused routine PRINT_ERRNO_S. * posix/src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S and used structure copy instead. * posix/src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control. * posix/include/rtems/posix/timer.h: Ditto. * posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one() to ensure that errno was always set. * posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get to use SuperCore _TOD_Current variable. 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog, itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog, rtems/ChangeLog, libmisc/ChangeLog, librpc/ChangeLog, libnetworking/ChangeLog: New file.
* 2007-04-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-04-141-2/+2
| | | | | * posix/src/usleep.c, libcsupport/src/readlink.c: Update API to SUSv3.
* 2007-04-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-04-091-2/+2
| | | | | | | * libcsupport/src/newlibc.c: Add __ATTRIBUTE_IMPURE_PTR__ (Fixes "relocation truncated to fit: R_MIPS_GPREL16" agains impure_ptr bug). Fix abuse of _REENT_INIT().
* 2007-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-04-021-23/+1
| | | | | | | | | | | | | | | | | | | | | | * itron/src/itrontime.c, libcsupport/src/__gettod.c, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/src/clockgettime.c, posix/src/clocksettime.c, posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c, posix/src/ptimer1.c, posix/src/sleep.c, rtems/Makefile.am, rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h, rtems/include/rtems/rtems/types.h, rtems/src/clockget.c, rtems/src/clockset.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c, score/Makefile.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c, score/src/coretodset.c: Convert from Classic API style TOD_Control as fundamental time structure to POSIX struct timespec. Add clock_get_uptime(). * rtems/src/clockgetuptime.c, score/src/coretodget.c, score/src/coretodgetuptime.c: New files. * score/src/coretodtickle.c, score/src/coretodtoseconds.c, score/src/coretodvalidate.c: Removed.
* 2007-04-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-04-021-8/+1
| | | | * libcsupport/src/printk.c: Add %p support.
* 2007-03-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-301-0/+4
| | | | * libcsupport/src/__assert.c: Add HAVE_CONFIG_H.
* 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-291-1/+1
| | | | * libcsupport/src/getpwent.c: Remove bogus cast to long.
* 2007-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-282-1/+22
| | | | | | | PR 1234/cpukit * libcsupport/Makefile.am: Provide printk() based implementation of __assert() to reduce dependencies in executables. * libcsupport/src/__assert.c: New file.
* 2007-03-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-281-4/+4
| | | | | * libcsupport/include/sys/sockio.h: Partial update from FreeBSD.
* 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-271-6/+2
| | | | * libcsupport/src/scandir.c: Eliminate __P().
* 2007-03-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-261-15/+83
| | | | | * libcsupport/include/rtems/assoc.h: Pick up the include file changes associated with the file splitting.
* 2007-03-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-261-1/+9
| | | | | * libcsupport/Makefile.am: Pick up the Makefile changes associated with the file splitting.
* 2007-03-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-2618-305/+583
| | | | | | | | | | | | | | | | | | | * libcsupport/src/assoc.c, libcsupport/src/libio.c, libcsupport/src/write.c: Split files to shrink minimum.exe. Hopefully this will not be deemed necessary to commit to the 4.7 branch. * libcsupport/src/assoclocalbyname.c, libcsupport/src/assoclocalbyremote.c, libcsupport/src/assoclocalbyremotebitfield.c, libcsupport/src/assocnamebylocal.c, libcsupport/src/assocnamebylocalbitfield.c, libcsupport/src/assocnamebyremote.c, libcsupport/src/assocnamebyremotebitfield.c, libcsupport/src/assocptrbylocal.c, libcsupport/src/assocptrbyname.c, libcsupport/src/assocptrbyremote.c, libcsupport/src/assocremotebylocal.c, libcsupport/src/assocremotebylocalbitfield.c, libcsupport/src/assocremotebyname.c, libcsupport/src/libio_init.c, libcsupport/src/write_r.c: New files.
* Updated copyright date.Joel Sherrill2007-03-261-1/+1
* 2007-03-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-261-10/+3
| | | | | | * libcsupport/src/__gettod.c: Replace incorrect comment about timezone support and remove deadcode. Replace with comment explaining that behavior is compatible with GNU/Linux per Eric Norum.
* 2007-03-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-172-24/+24
| | | | | | * libcsupport/include/rtems/termiostypes.h, libcsupport/src/termios.c: Prefix linesw, struct linesw, nwlinesw with rtems_termios_*.
* 2007-03-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-03-131-5/+2
| | | | | * libcsupport/src/assocnamebad.c: Remove dead code. Use PRI* macros to fix warnings.
* 2007-02-22 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2007-02-221-2/+2
| | | | | * libcsupport/Makefile.am: Move getpagesize.c to newlib-only compiled files.
* 2007-02-06 Till Straumann <strauman@slac.stanford.edu>Till Straumann2007-02-061-13/+22
| | | | | | * libcsupport/src/gxx_wrappers.c: fix PR#690. Supply taskvar dtor to plug memory leak. Applied patch attached to PR#690.
* Add getpagesize.c.Ralf Corsepius2007-02-061-1/+1
* New (moved from posix/src).Ralf Corsepius2007-02-061-0/+24
* 2007-01-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-01-091-3/+0
| | | | | * libcsupport/src/error.c: rtems_progname is no longer defined in the BSP startup since it never held a meaningful value.
* Regenerate.Ralf Corsepius2007-01-081-3/+3
* Use size_t instead of uint32_t for read/write count-args.Ralf Corsepius2006-12-082-4/+4
* Fix typo in yesterday's patch.Ralf Corsepius2006-11-191-1/+1
* Use uintmax_t instead of uint64_t for MALLOC_STATS statistics.Ralf Corsepius2006-11-181-10/+22
| | | | Use inttypes.h PRIxXXX macros for printing.
* 2006-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-11-171-4/+8
| | | | * libcsupport/src/sync.c: Do not dereference NULL reent.
* 2006-11-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2006-11-151-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h, sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/corerwlock.h, score/include/rtems/score/threadq.h, score/src/corerwlockobtainread.c, score/src/threadqenqueue.c, score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks, and partial implementation of POSIX rwlocks. * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/spinlock.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/spinlock.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/pbarrier.c, posix/src/pbarrierdestroy.c, posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c, posix/src/prwlock.c, posix/src/prwlockdestroy.c, posix/src/prwlockinit.c, posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c, posix/src/pspin.c, posix/src/pspindestroy.c, posix/src/pspininit.c, posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c, posix/src/pspintrylock.c, posix/src/pspinunlock.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
* 2006-11-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-11-122-575/+0
| | | | | * libcsupport/include/stdint.h, libcsupport/include/inttypes.h: Remove.
* 2006-10-25 Jennifer Averett <jennifer@oarcorp.com>Joel Sherrill2006-10-251-1/+1
| | | | | | | | | | * libcsupport/src/termios.c: Change attribute of semaphore. It was counting interrupts not acting as a condition synchronization mutex. Since the caller did not always need to obtain the semaphore, it was not being decremented until there was no data. This could occur after hours of running a system and thousands of interrupts. The code in fillBufferQueue would spin until it had consumed all of those semaphore counts.
* *** empty log message ***Joel Sherrill2006-09-011-1/+2
* 2006-09-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-09-011-9/+9
| | | | | | * libcsupport/src/malloc.c, libnetworking/rtems/rtems_glue.c, libnetworking/sys/mbuf.h: Remove warnings -- use uintptr_t or properly sized integers.
* 2006-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-08-312-2/+7
| | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits.
* 2006-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-08-301-1/+1
| | | | | | | | | | | | | | * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement.
| | | | | | * libcsupport/src/utsname.c, libnetworking/libc/res_debug.c, libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c, librpc/src/rpc/svc_simple.c: Remove printf format warnings.
* applied patches for PR1117/1118/1119/1120Thomas Doerfler2006-07-091-0/+4
* 2006-06-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-06-231-8/+10
| | | | * libcsupport/include/rtems/cdefs.h: Partial update from freebsd.
* PR 1101/rtemsJoel Sherrill2006-06-221-1/+0
| | | | * libcsupport/src/base_fs.c: Remove extra endif.
* 2006-06-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-06-221-21/+4
| | | | | | PR 1101/rtems * libcsupport/src/base_fs.c, rtems/src/taskcreate.c, rtems/src/tasks.c, score/src/coremutex.c: Remove dead code.
