path: root/cpukit/libcsupport (follow)
* 2003-09-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-152-2/+8
| | | | | | PR 489/rtems * src/newlibc.c: Reflect struct Thread_Control_struct.libc_reent having changed from void * to struct _reent*.
* 2003-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-132-5/+6
| | | | | * src/sync.c: Don't undef __STRICT_ANSI__. Use struct _reent (struct reent doesn't exist)
* 2003-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-132-4/+5
| | | | | PR 486/rtems * src/newlib.c: Unconditionally include <stdio.h>
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0495-94/+123
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/chain.h, include/clockdrv.h, include/console.h, include/iosupp.h, include/rtc.h, include/spurious.h, include/timerdrv.h, include/vmeintr.h, include/motorola/mc68230.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h, include/rtems/termiostypes.h, include/sys/termios.h, include/zilog/z8036.h, include/zilog/z8530.h, include/zilog/z8536.h, src/__brk.c, src/__gettod.c, src/__sbrk.c, src/__times.c, src/access.c, src/base_fs.c, src/cfgetispeed.c, src/cfgetospeed.c, src/cfsetispeed.c, src/cfsetospeed.c, src/chdir.c, src/chmod.c, src/chown.c, src/chroot.c, src/close.c, src/ctermid.c, src/dup.c, src/dup2.c, src/eval.c, src/fchdir.c, src/fchmod.c, src/fcntl.c, src/fdatasync.c, src/fpathconf.c, src/fs_null_handlers.c, src/fstat.c, src/fsync.c, src/ftruncate.c, src/getdents.c, src/getpwent.c, src/hosterr.c, src/ioctl.c, src/isatty.c, src/libio.c, src/libio_sockets.c, src/link.c, src/lseek.c, src/lstat.c, src/malloc.c, src/mallocfreespace.c, src/mkdir.c, src/mkfifo.c, src/mknod.c, src/mount.c, src/newlibc.c, src/no_libc.c, src/no_posix.c, src/open.c, src/pathconf.c, src/pipe.c, src/privateenv.c, src/read.c, src/readlink.c, src/rewinddir.c, src/rmdir.c, src/seekdir.c, src/stat.c, src/symlink.c, src/sync.c, src/tcdrain.c, src/tcflow.c, src/tcflush.c, src/tcgetattr.c, src/tcgetprgrp.c, src/tcsendbreak.c, src/tcsetattr.c, src/tcsetpgrp.c, src/telldir.c, src/termios.c, src/termiosinitialize.c, src/truncate.c, src/umask.c, src/unixlibc.c, src/unlink.c, src/unmount.c, src/utime.c, src/write.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-042-1/+13
| | | | | | | PR 479/rtems_misc * src/malloc.c: Per multiple standards realloc does not free the original memory if the allocation of the requested larger block fails.
* 2003-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-022-1/+5
| | | | * src/open.c: Fix typo.
* 2003-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-022-1/+4
| | | | * src/malloc.c: Remove test define left in.
* 2003-09-02 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2003-09-022-0/+7
| | | | | PR 472/filesystem src/malloc.c: Need to include apimutex.h when MALLOC_STATS is defined.
* Remove bogus file src/listRalf Corsepius2003-08-181-11/+0
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1815-23/+450
| | | | | | | | | | | | | | | | | PR 449/rtems: * src/getegid.c: New (Copied from ../posix/src). * src/geteuid.c: New (Copied from ../posix/src). * src/getgid.c: New (Copied from ../posix/src). * src/getgroups.c: New (Copied from ../posix/src). * src/getlogin.c: New (Copied from ../posix/src). * src/getpgrp.c: New (Copied from ../posix/src). * src/getpid.c: New (Copied from ../posix/src). * src/getppid.c: New (Copied from ../posix/src). * src/getuid.c: New (Copied from ../posix/src). * src/setpgid.c: New (Copied from ../posix/src). * src/setsid.c: New (Copied from ../posix/src). * src/no_posix: Remove getpid and _getpid_r. * Makefile.am: Reflect changes above.
* 2003-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-143-1/+75
| | | | | * Makefile.am: Add fileio to list of interactive tests. * src/sync.c: New file.
* 2003-08-05 Till Strauman <strauman@slac.stanford.edu>Jennifer Averett2003-08-052-0/+11
| | | | | PR 442/filesystem * src/open.c: file never closed if ftruncate() fails in open()
* CleanupRalf Corsepius2003-07-081-12/+0
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-082-0/+6
| | | | | PR 419/rtems * src/termios.c: Removed warning.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-084-94/+18
| | | | | | | * configure.ac: Remove (Merged-in into ../configure.ac) * Makefile.am: DOC_FILES = src/TODO src/CASES, Reflect having merged configure.ac into ../configure.ac. * src/config.h: New.
* Fixed formatting.Joel Sherrill2003-07-021-0/+1
* Patch by Chris Johns <cjohns@cybertec.com.au> adding the ↵Chris Johns2003-07-023-7/+34
| | | | rtems_termios_bufsize call.
* Merger from rtems-4.6-branchRalf Corsepius2003-05-303-5/+18
* 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-272-9/+6
| | | | | PR 409: * include/stdint.h: Include rtems/stdint.h
* 2003-04-17 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill2003-05-262-1/+12
| | | | | | | | PR 399/rtems_misc * src/termios.c: In canonical mode, when input is present in the input buffer that contains an EOL character and some following characters, a read call read data behind the EOL character, although it should stop reading with the EOL character.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-04-172-2/+6
* 2003-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2003-04-162-1/+11
| | | | | | PR 389/rtems * src/no_posix.c: Correct _kill_r() prototype and make it conditional on newlib.
* 2003-04-03 Eri Valette <eric.valette@free.fr>Joel Sherrill2003-04-032-1/+7
| | | | | | PR 381/core * src/newlibc.c: Switch from using _REENT_INIT to _REEINT_INIT_PTR to fix strange run-time problem where EIP was corrupted on pc386 BSP.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-255-1/+105
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-282-1/+7
* Remove corrupted ChangeLog entry.Ralf Corsepius2003-02-281-66/+0
* Patch against RTEMS-ss-20030128Joel Sherrill2003-02-203-2/+69
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Author: Till Straumann <strauman@slac.stanford.edu> 2003/2/11 This patch addresses the following issues: 2003-02-20 Till Straumann <strauman@slac.stanford.edu> PR 349/bsps * src/mount.c, src/privateenv.c: - mount() bugfix: allocated 'loc' node must be released if mount fails due to missing node_type_h - silence compiler warning about improper pointer type Index: cpukit/libcsupport/src/mount.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/rtems/src-20030128/cpukit/libcsupport/src/mount.c,v retrieving revision 1.1.1.2 diff -c -r1.1.1.2 mount.c *** cpukit/libcsupport/src/mount.c 29 Jan 2003 22:57:19 -0000 1.1.1.2 --- cpukit/libcsupport/src/mount.c 7 Feb 2003 20:47:49 -0000 *************** *** 142,147 **** --- 142,149 ---- mount_point, RTEMS_LIBIO_PERMS_RWX, &loc, TRUE ) == -1 ) goto cleanup_and_bail; + loc_to_free = &loc; + /* * Test for node_type_h */ *************** *** 155,161 **** * Test to see if it is a directory */ - loc_to_free = &loc; if ( loc.ops->node_type_h( &loc ) != RTEMS_FILESYSTEM_DIRECTORY ) { errno = ENOTDIR; goto cleanup_and_bail; --- 157,162 ---- Index: cpukit/libcsupport/src/privateenv.c =================================================================== RCS file: /afs/slac/g/spear/cvsrep/rtems/src-20030128/cpukit/libcsupport/src/privateenv.c,v retrieving revision 1.1.1.3 diff -c -r1.1.1.3 privateenv.c *** cpukit/libcsupport/src/privateenv.c 29 Jan 2003 22:57:20 -0000 1.1.1.3 --- cpukit/libcsupport/src/privateenv.c 30 Jan 2003 18:01:40 -0000 *************** *** 65,71 **** tmp->refcnt = 1; #endif ! sc = rtems_task_variable_add(RTEMS_SELF,(void*)&rtems_current_user_env,free_user_env); if (sc != RTEMS_SUCCESSFUL) { /* don't use free_user_env because the pathlocs are * not initialized yet --- 65,71 ---- tmp->refcnt = 1; #endif ! sc = rtems_task_variable_add(RTEMS_SELF,(void*)&rtems_current_user_env,(void(*)(void *))free_user_env); if (sc != RTEMS_SUCCESSFUL) { /* don't use free_user_env because the pathlocs are * not initialized yet
* 2003-02-20 Wolfram Wadepohl <W.Wadepohl@indumat.de>Joel Sherrill2003-02-202-1/+7
| | | | | | PR 357/rtems_misc * src/termios.c (rtems_termios_open): Fixed code the incorrectly checked that the wrong pointer during allocation was NULL.
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-062-1/+6
| | | | | * include/sys/ioccom.h: Include <sys/types.h> not <machine/types.h> so Linux port builds.
* 2003-02-05 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-052-5/+44
| | | | | PR 340/filesystem * src/fcntl.c: Add missing _fcntl_r assumed to exist by newlib.
* 2003-02-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-052-1/+11
| | | | | * include/sys/ioccom.h: Fix so not using internal RTEMS types in libc code.
* 2003-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-032-1/+7
| | | | | | PR 338/filesystem * src/unixlibc.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change).
* 2003-02-03 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-032-4/+12
| | | | | PR 339/filesystem * src/chroot.c: Fix violation of FS node object copy semantics.
* 2003-01-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-142-2/+5
| | | | * Makefile.am: Eliminate OBJS.
* 2003-01-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-102-4/+9
| | | | | * include/rtems/libio.h: Rename __dev_t to __rtems_dev_t to avoid conflict with GNU/Linux header files.
* 2003-01-03 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-01-031-0/+9
| | | | | | | | | * ChangeLog, base_fs.c, getpwent.c, privateenv.c Per PR303, Fix violation of node_access copy syemantics 2002-12-26 Till Straumann <strauman@slac.stanford.edu * src/fchdir.c: PR302 fix violation of FS node object copy semantics.
* 2003-01-03 Till Straumann <strauman@slac.stanford.edu>Jennifer Averett2003-01-033-32/+125
* 2002-12-26 Till Straumann <strauman@slac.stanford.eduJennifer Averett2002-12-261-2/+18
| | | | * src/fchdir.c - PR302 fix violation of FS node object copy semantics
* 2002-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-062-1/+7
| | | | | * src/malloc.c: Fixed code that incorrected did a disable dispatch instead of locking and unlocking the allocator mutex.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-063-11/+55
| | | | | * configure.ac: Add various checks to enhance portability. * src/termios.c: Reflect changes to configure.ac.
* 2002-12-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-023-1/+57
| | | | | | | | | * include/rtems/libio.h: Internally use a union of an unsigned64 and major/minor device so we don't get into trouble shifting. The h8300 seemed to be impossible to remove warnings otherwise. Eventually the structure definition of a dev_t might be better anyway. * include/sys/ioccom.h: Added casts to remove warnings on 16 bit targets.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-192-1/+5
| | | | * configure.ac: Cosmetical fixes.
| | | | * configure.ac: Fix package name.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-183-4/+27
| | | | | | | * configure.ac: Check for sys/cdefs.h, Add NEED_SYS_CDEFS_H. Add check for CHAR_BIT. * Makefile.am: Conditionally install sys/cdefs.h iff using newlib or if the host does not provide sys/cdefs.h (Fixes Linux/posix).
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-183-4/+17
| | | | | | * configure.ac: Remove -ansi -fasm. Add checks to diagnose potential system header conflicts. * Makefile.am: Unconditionally install sys/cdefs.h.
* 2002-11-07 <strauman@slac.stanford.edu>Joel Sherrill2002-11-112-1/+5
| | | | * src/mount.c: Per PR297, correct fs_mountme failure paths.
* 2002-11-07 <strauman@slac.stanford.edu>Jennifer Averett2002-11-071-5/+12
