Also updated licenses.
Closes #4400
Updates #3899
utimes() now calls utimensat() to update file access
and modification timestamps.
Updated license.
Closes #4398
utime() now calls utimensat() to update file access
Updated license.
Closes #4397
Created futimens.c and utimensat.c to add support for the POSIX
methods futimens() and utimensat().
utime() and utimes() are considered obsolote by POSIX, but RTEMS
will continue to support them.
Closes #4396
This change eliminates a system initialization dependentcy which resulted
in an application without a file system or console referencing errno being
forced to include the code to open(/dev/console), close(), atexit(),
and the unmount infrastructure.
Closes #4439.
Make sure all conditions to do a proper memory allocation are satisfied
before a zero size memory allocation is performed.
Update #4390.
In POSIX, zero size memory allocations are implementation-defined
behaviour. The implementation has two options:
https://pubs.opengroup.org/onlinepubs/9699919799/functions/malloc.html
https://pubs.opengroup.org/onlinepubs/9699919799/functions/posix_memalign.html
Linux and FreeBSD return a unique pointer for zero size memory
allocations. Return NULL on RTEMS to more likely catch the use of a
zero size memory area by erroneous applications.
Update #4390.
Move all error checks into posix_memalign() so that the returned memory
pointer is set to NULL under all error conditions except
memptr == NULL.
Use parameter names of POSIX documentation.
The zero size allocations had no consistent behaviour in RTEMS. For
example, malloc( 0 ) returned NULL and posix_memalign( &p, align, 0 )
returned in p a unique pointer (or NULL if no memory is available). In
allocations. Use this approach for RTEMS as well throughout the memory
allocation directives
Close #4390.
The 'sc' variable was originally storing the return value of mkdir().
This was causing an issue, so it was changed to make it to where we
ignored the return value with (void). The 'sc' variable was left in
by mistake.
The multiplication to calculate the length of the memory area to
allocate may overflow. Return NULL in case of an overflow.
Close #4389.
Move RTEMS_Malloc_Sbrk_amount to the only implementation file which uses
it and make it private to hide implementation-details from an API
header.
Move rtems_calloc() since it only depends on rtems_malloc(). This may
make it easier to customize the heap allocator.
Change licence to BSD-2-Clause according to file history.
Update #3053.
At this point in time, /etc can be created in multiple ways. There
is a discussion (#4354) that would define a mechanism for
instantiating a base file system with some flexibility for the
set of directories included. For now, this particular mkdir()
call can fail because /etc could already have been created by
at least an initial filesystem image, the shell, or libbsd.
closes #4382.
Removed the _Assert_unused_variable_equals macro due to /etc
having already been created by the network stack initialization
or an initial filesystem image.
Closes #4282
CID 1255518: Unchecked return value from library in pwdgrp_init().
Closes #4282
CID 1459004: Unchecked return value in endgrent().
Closes #4261
CID 1399710: Unchecked return value in printer_task().
CID 1472764: Unchecked return value in rtems_print_printer_task().
Closes #4258
CID 1437625: Unchecked return value from call to rtems_task_create().
CID 1472765: Unchecked return value from call to rtems_task_start().
Closes #4237.
- Move the heap sbrk code into a separate routnine.
- Update heap and workspace greedy allocators to use the common
sbrk greedy support.
Closes #3982
- Call the heap extend handler until all memory has been
requested.
Closes #3982
- Add the bool flag no_regular_file_mknod to the mount table so a file
system can indicate creating regular files is not done by
use the mknod handler. The file system will handle creating a
file node in the open handler.
- Note, the mount option is an enum which means there is only one
exclusive option supported. As a result no encapsulation is
provided and file systems need to set no_regular_file_mknod directly.
Closes #4222
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Fix linker errors in the minimum test program on some BSPs introduced by
ced28f2cfcee6d32ad7bb72e16b235212eb2eaaf.
This mutex is used to maintain termios internal data structures.
Only include the deferred free support if free() is actually used by the
application.
The free() implementation in RTEMS supports that allocated memory is
freed in interrupt context. Since the heap is protected by a mutex, the
frees issued in interrupt context cannot immediately be freed to the
heap, instead they are placed on a deferred free list. This list is
emptied by the core allocation function
rtems_heap_allocate_aligned_with_boundary(). This adds a dependency to
free() in rtems_heap_allocate_aligned_with_boundary(). In order to
better support applications which only allocate memory and never free
it, this dependency should be avoided. Provide a weak default
implementation of _Malloc_Process_deferred_frees() for
rtems_heap_allocate_aligned_with_boundary(). In the free() module
provide the strong implementation.
Close #4032.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
Merge the rtems_termios_isig_status_code and
rtems_termios_iproc_status_code enums into a single
rtems_termios_iproc_status_code which is now a part of the API.
Simplify rtems_termios_posix_isig_handler() to avoid unreachable code.
Close #3800.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3904.
There was a race conditon in the reference counting of file descriptors
during a close() operation. After the call to the close handler, the
rtems_libio_free() function cleared the flags to zero. However, at this
point in time there may still exist some holders of the file descriptor.
With RTEMS_DEBUG enabled this could lead to failed assertions in
rtems_libio_iop_drop().
Change the code to use only atomic read-modify-write operations on the
rtems_libio_iop::flags.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #3894.
Update #3053.
Update #3894.
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Move the default configuration to library files so that application
configurations do not include the definitions for the default case.
Update #3053.
Update #3875.
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Canonical input processing was broken by
667501a314ba75f80f1c13c6b43dd35d0a00efd1 as shown by test case
termios09.
Update #3800.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
The FACE Technical Standard, Edition 3.0 and later require the definition
of the subcommand SOCKCLOSE in <devctl.h>.
Reference: ​https://www.opengroup.org/face
closes #3856.
Update #3841.
Include right header file for kill().
This patch adds the ability for termios to send SIGINTR on receipt
of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on
a termios channel. Importantly, this patch does not alter the default
behavior or force POSIX signal code in just because termios is used.
The application must explicitly enable the POSIX behavior of generating
a signal upon receipt of these characters. This is discussed in the
POSIX standard:
https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html
Closes #3800.
Update #3666.
Ensure that the C++17 aligned new operator works.
Close #3666.
Close #3602.
