* libcsupport/src/malloc_sbrk_helpers.c: Make
malloc_sbrk_initialize, malloc_sbrk_extend_and_allocate static.
* libcsupport/include/rtems/libio.h:
Make LIBIO_FLAGS_* defined unsigned (Avoid implicit sign
conversions).
* libcsupport/src/chown.c, libcsupport/src/lchown.c:
Include <unistd.h>. Cleanup included headers.
* libcsupport/src/termios.c: Remove unnecessary cast.
* libcsupport/src/termios.c: Make FL_* defines unsigned.
* libcsupport/src/getgid.c: Include <unistd.h>.
* libcsupport/src/setgid.c: Include <unistd.h>.
* libcsupport/src/getpgrp.c: Include <unistd.h>.
Remove unnecessary includes.
* libcsupport/include/rtems/libcsupport.h:
Add prototype of malloc_info().
* libcsupport/include/sys/termios.h: Add _POSIX_VDISABLE.
* libcsupport/src/open.c: Use va_arg(..., mode_t) to retrieve mode.
PR 1924/cpukit
* sapi/include/rtems/config.h: New fields stack_space_size,
unified_work_area, and stack_allocator_avoids_work_space in
rtems_configuration_table.
* sapi/include/confdefs.h: Removed rtems_unified_work_area (this is
now part of the Configuration). Separate work space and stack space
estimate. Added CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
configuration option.
* libmisc/shell/main_wkspaceinfo.c, score/src/wkspace.c,
libcsupport/src/malloc_initialize.c: Update due to API changes.
PR 1952/cpukit
* libcsupport/include/rtems/libio.h: Add return code for failure when
unable to write file.
PR1945/cpukit
* libcsupport/include/rtems/libio.h: Mark rtems_off64_t as
deprecated.
Replace rtems_off64_t with off_t.
* libcsupport/src/newlibc_exit.c: Don't undef __USE_INIT_FINI__.
* libcsupport/src/utimes.c (utimes): Remove casts to time_t.
* libcsupport/include/rtems/libio.h, libcsupport/src/termios.c:
Use size_t for sizes.
* libcsupport/src/termios.c,
libcsupport/include/rtems/termiostypes.h (rtems_termios_puts):
Use size_t for buffer size.
* libcsupport/src/termios.c: Remove meaningless typecast.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Added
init/fini array support for ARM EABI. The __libc_init_array() and
__libc_fini_array() functions are provided by Newlib.
PR 1839/filesystem
* libcsupport/include/rtems/libio_.h, libcsupport/src/fchdir.c,
libcsupport/src/fdatasync.c, libcsupport/src/fpathconf.c,
libcsupport/src/fsync.c, libcsupport/src/ftruncate.c,
libcsupport/src/read.c, libcsupport/src/readv.c,
libcsupport/src/write.c, libcsupport/src/writev.c: Some calls did not
return proper status for permission errors or incorrectly permissions
at all.
* libcsupport/include/rtems/libio_.h: Added
rtems_filesystem_is_root_location().
* libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_eval.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c: Use
PR 1838/filesystem
* libcsupport/src/fchmod.c: fchmod() does not need a writeable file
descriptor.
* libcsupport/src/malloc_report_statistics_plugin.c: Fixed format
specifiers.
* libcsupport/src/malloc_initialize.c: After discussion with Till
Straumann, revert the change from r1.12 to r1.13. This broke BSPs
with sbrk() support once the libbsp sbrk() framework was enhanced.
psim runs now.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
* libcsupport/include/rtems/libio.h, cpukit/libcsupport/src/termios.c:
Added const qualifier to rtems_termios_enqueue_raw_characters().
Removed superfluous cast.
* libcsupport/Makefile.am: Reformat.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* libcsupport/src/ioctl.c: Fixed integer type.
* libcsupport/src/mknod.c, libfs/src/rfs/rtems-rfs-inode.c: PR
1749. Fix the incorrect handling of the file type in the mode
value to reject invalid types as per the standard.
* libcsupport/src/sleep_noposix.c: Remove.
* libcsupport/Makefile.am: Reflect changes above.
* posix/src/sleep.c, posix/src/usleep.c: Remove.
* posix/Makefile.am: Reflect changes above.
* configure.ac: Error out if libc doesn't provide sleep, usleep.
* libcsupport/src/creat.c: Remove.
* configure.ac: Error out if libc doesn't provide creat.
* libcsupport/src/opendir.c, libcsupport/src/closedir.c,
libcsupport/src/readdir.c, libcsupport/src/rewinddir.c,
libcsupport/src/scandir.c, libcsupport/src/seekdir.c,
libcsupport/src/telldir.c: Remove.
* libcsuppport/Makefile.am: Reflect changes above.
opendir, closedir, readdir, rewinddir, scandir, seekdir,
telldir.
* libcsupport/include/sys/statvfs.h: Remove include <sys/cdefs.h>
(unused). Add C++ guards. Declare functions extern.
* libcsupport/include/clockdrv.h, libcsupport/include/console.h,
libcsupport/include/spurious.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/libcsupport.h: Add missing includes.
* libcsupport/src/rtems_heap_extend.c: New file.
* libcsupport/Makefile.am: Reflect change from above.
* libcsupport/include/rtems/malloc.h: Declare rtems_heap_extend().
* score/include/rtems/score/heap.h: Documentation.
* include/rtems/btimer.h: New.
* Makefile.am: Add rtems/btimer.h
* libcsupport/include/timerdrv.h: Reflect having split out functions
to rtems/btimer.h.
* libcsupport/src/printk.c: Fix typo.
* libcsupport/src/error.c: Scheduler Simulator compilation always
defines __RTEMS_VIOLATE_KERNEL_VISIBILITY__. So avoid redefinition
warning.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Revert
previous commit due to too many broken linker command files. The
HAVE_INITFINI_ARRAY is defined for nearly all targets by Newlib, but
only few linker command files respect this.
support for .preinit_array, .init_array and .fini_array sections.
PR 1717/cpukit
* libcsupport/src/gxx_wrappers.c: Free memory on error.
* libcsupport/src/putk.c: Remove useless variable initialization
pointed out by clang.
PR 1698/cpukit
* libcsupport/src/privateenv.c: Check return values of
rtems_filesystem_evaluate_path().
* libcsupport/src/privateenv.c: Add macro to test status when
RTEMS_DEBUG is enabled. Note than evaluation of root directory should
always work.
* libcsupport/src/getlogin.c: Modify to use strncpy() on all paths.
