* libcsupport/include/rtems/malloc.h: Correct type of
rtems_malloc_dirty_helper so usable.
PR 1441/cpukit
* libcsupport/src/tcgetprgrp.c: Remove.
* libcsupport/src/tcgetpgrp.c: New (Renamed from
libcsupport/src/tcgetprgrp.c).
* libcsupport/Makefile.am: Add libcsupport/src/tcgetpgrp.c.
Remove libcsupport/src/tcgetprgrp.c.
Cherrypick from master 2009-09-15 05:32:49 UTC Ralf Corsepius <ralf.corsepius@rtems.org> '2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>':
c/src/lib/libbsp/arm/gba/console/defaultfont.h
c/src/lib/libbsp/arm/smdk2410/include/.cvsignore
c/src/lib/libbsp/m68k/genmcf548x/include/.cvsignore
c/src/lib/libbsp/m68k/mcf52235/include/.cvsignore
c/src/lib/libbsp/m68k/mcf5329/include/.cvsignore
c/src/lib/libbsp/mips/csb350/start/regs.h
c/src/lib/libbsp/mips/genmongoosev/start/regs.h
c/src/lib/libbsp/mips/hurricane/liblnk/regs.h
c/src/lib/libbsp/mips/jmr3904/start/regs.h
c/src/lib/libbsp/mips/rbtx4925/liblnk/regs.h
c/src/lib/libbsp/mips/rbtx4938/liblnk/regs.h
c/src/lib/libbsp/powerpc/mvme3100/include/.cvsignore
c/src/lib/libbsp/powerpc/virtex/include/.cvsignore
contrib/crossrpms/autotools/autoconf-sources.add
contrib/crossrpms/autotools/automake-sources.add
contrib/crossrpms/patches/gdb-6.5-bfinrtems-20090122.diff
cpukit/libcsupport/src/tcgetpgrp.c
Cherrypick from master 2008-09-28 16:36:13 UTC Ralf Corsepius <ralf.corsepius@rtems.org> 'New.':
c/src/lib/libbsp/bare/preinstall.am
PR 1376/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/memfile.c, libfs/src/nfsclient/src/nfs.c: lseek
handlers should return off_t.
PR 1359/cpukit
* libcsupport/src/libio.c: rtems_libio_allocate:
rtems_libio_iop_freelist incorrectly zeroed on semaphore error. Now
checks error and does not modify anything until sure it has created
semaphore.
PR 1364/cpukit
* libcsupport/src/gxx_wrappers.c: Fix compilation problems when
diagnostics enabled.
* libcsupport/src/ttyname.c: Correct prototype of ttyname_r() to use
size_t for third parameter.
PR 1333/cpukit
* libcsupport/include/rtems/termiostypes.h: Typo on type name -- should
be rtems_device_minor_number.
PR 1330/cpukit
* libcsupport/src/free.c: Should print begin field not start field.
* libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/stackchk/internal.h,
rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h,
score/include/rtems/score/bitfield.h, score/src/mpci.c,
score/src/objectextendinformation.c, score/src/threadmp.c: Remove
extraneous spaces.
* libcsupport/include/clockdrv.h: The Shared Memory Driver no longer
requires the special IOCTL in Clock_control. This was a hack which
has existed since before the Classic API Timer Manager was
implemented. All implementations of and references to Clock_control
were removed.
* libcsupport/src/assocnamebad.c: Correct file name in message.
* libcsupport/include/timerdrv.h: Rename timer driver methods to follow
RTEMS programming conventions.
* libcsupport/src/error.c, libmisc/dummy/dummy.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c: Add 0 for missing initializers.
PR 500/misc
* libcsupport/src/termios.c: Avoid potential buffer overflow.
* libcsupport/include/clockdrv.h: Add Clock_Exit prototype.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c,
libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h,
libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix
warnings.
* itron/include/rtems/itron/task.h, itron/src/def_cyc.c,
itron/src/task.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/sync.c, libfs/src/imfs/imfs_fchmod.c,
posix/include/rtems/posix/pthread.h, posix/src/pthread.c,
posix/src/sysconf.c, rtems/include/rtems/rtems/tasks.h,
rtems/src/tasks.c, score/include/rtems/score/stack.h,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl, score/src/threadhandler.c: Fix
various nested-externs warnings.
* libcsupport/Makefile.am, libcsupport/src/newlibc.c: Split libc_init()
into a separate file to avoid linkage dependencies on newlibc.c which
in turn pulls in fclose() and other C library methods.
* libcsupport/src/newlibc_init.c: New file.
* libcsupport/src/_rename_r.c: Fixed return code bug. Add a check
to see if the 'to' path was a directory and removed the directory.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added the mv command.
* libmisc/shell/main_mv.c, libmisc/shell/pathnames-mv.h: New.
PR 537/bsps
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c,
libcsupport/src/no_libc.c, libcsupport/src/unixlibc.c: Eliminate
vestiges of ticks_per_timeslice controlling newlib reentrancy. The
parameter was ignored in libc_init().
(shared handler and handler with a handle).
* cpukit/libcsupport/include/chain.h: Removed. Use the SAPI
interface that is supported.
* cpukit/libcsupport/Makefile.am,
cpukit/libcsupport/preinstall.am: Remove chain.h header
references.
* cpukit/sapi/include/rtems/chain.h,
cpukit/sapi/inline/rtems/chain.inl: New. A supported chains
interface.
* cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to
include the new chains interface.
* cpukit/libfs/src/imfs/imfs.h,
cpukit/libfs/src/imfs/imfs_creat.c,
cpukit/libfs/src/imfs/imfs_debug.c,
cpukit/libfs/src/imfs/imfs_directory.c,
cpukit/libfs/src/imfs/imfs_fsunmount.c,
cpukit/libfs/src/imfs/imfs_getchild.c,
cpukit/libfs/src/imfs/imfs_load_tar.c,
cpukit/libfs/src/imfs/imfs_rmnod.c,
cpukit/libfs/src/imfs/memfile.c,
cpukit/libfs/src/nfsclient/src/nfs.c,
cpukit/libcsupport/include/rtems/libio.h,
cpukit/libcsupport/src/malloc_deferred.c,
cpukit/libcsupport/src/mount.c,
cpukit/libcsupport/src/privateenv.c,
cpukit/libcsupport/src/unmount.c: Change to the new chains
interface.
* cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
references.
interface.
interface.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-task.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, score/include/rtems/score/thread.h,
score/src/threaddispatch.c, score/src/threadinitialize.c,
score/src/threadtickletimeslice.c: Add typedefs for cpu usage and
period timing statistics. Also renamed related variables and
structure members so they are the same whether you are using
nanosecond (e.g. struct timespec) or ticks (e.g. uint32_t)
granularity. This lays the groundwork for future cleanup.
* libcsupport/src/newlibc_exit.c: Only run the fini section on exit if
the target toolset uses init/fini sections.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Call
fini() as part of exit(). This avoids atexit() being a required
function.
reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
* libcsupport/src/termios_baud2index.c,
libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_num2baud.c,
libcsupport/src/termios_setinitialbaud.c: New files.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/include/rtems/termiostypes.h: Move termios helper
routines from libchip to libcsupport. Add routine which makes it easy
for a termios device driver to inform termios of its default baud
rate. This avoids inconsistencies in later termios settings changes.
* libcsupport/include/rtems/watchdogdrv.h: Finish writing comments.
* libcsupport/preinstall.am, sapi/include/confdefs.h: Add baseline
interface for Watchdog Driver.
* libcsupport/include/rtems/watchdogdrv.h: New file.
* libcsupport/Makefile.am, libcsupport/include/rtems/libio.h: Remove
rtems_termios_reserve_resources. It is obsolete.
* libcsupport/src/termiosreserveresources.c: Removed.
* libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_script.c: Add support to echo the commands to
stdout. This is useful with the -v script option to show commands
as the run. Also added support to chdir to the directory the task
invoking the script is in.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Update tro the latest FreeBSD version.
* libcsupport/Makefile.am, libcsupport/src/fchown.c: Add fchown
support.
* libcsupport/src/gxx_wrappers.c: Add rtems_gxx_mutex_destroy as needed
by gcc newer than the 4.3 release series.
* libcsupport/src/chroot.c: Formatting.
* libcsupport/include/motorola/mc68230.h: Prefix defines with
MC68230_ to avoid preprocessor clashes.
