* | score: Add and use rtems_assert_context | Sebastian Huber | 2013-02-12 | 1 | -1/+8 |
* | cpukit: Use Consistent Beginning of Doxygen Group Notation | Joel Sherrill | 2013-01-10 | 6 | -24/+14 |
| | | | | | This is the result of a sed script which converts all uses of @{ into a consistent form. | ||||
* | cpukit: Doxygen group fixes and many warnings addressed | Joel Sherrill | 2013-01-10 | 4 | -19/+25 |
| | | | | | | | The output of the modules.html is much improved. Most filesystem and POSIX API related groups are properly nested. Some formatting issues were addressed as were multiple inconsistencies. | ||||
* | libcsupport: Documentation | Sebastian Huber | 2013-01-09 | 1 | -6/+9 |
* | libcsupport: Documentation | Sebastian Huber | 2013-01-09 | 1 | -35/+22 |
* | libcsupport: Doxygen Clean Up Task #1 | Alex Ivanov | 2013-01-08 | 15 | -143/+162 |
* | Header File Doxygen Enhancement Task #1 | Alex Ivanov | 2012-12-28 | 3 | -4/+10 |
* | Header File Doxygen Enhancement Task #11 | Mathew Kallada | 2012-12-28 | 3 | -1/+5 |
* | Header File Doxygen Enhancement Task #7 | Mathew Kallada | 2012-12-28 | 5 | -12/+20 |
* | Header File Doxygen Enhancement Task #2 | Mathew Kallada | 2012-12-28 | 3 | -1/+7 |
* | Miscellaneous Doxygen clean-up | Joel Sherrill | 2012-12-28 | 1 | -1/+1 |
* | libcsupport: Add rtems_resource_snapshot_take() | Sebastian Huber | 2012-12-21 | 3 | -0/+215 |
| | | | | | | Add rtems_resource_rtems_api, rtems_resource_posix_api, rtems_resource_snapshot, rtems_resource_snapshot_equal(), and rtems_resource_snapshot_check(). | ||||
* | libcsupport: Update file header for termios.h to remove link, add description. | Gedare Bloom | 2012-12-15 | 1 | -1/+3 |
* | libcsupport: Doxygen Enhancement Task #8 | Alex Ivanov | 2012-12-15 | 25 | -101/+210 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7996208 | ||||
* | Fix spelling | Sebastian Huber | 2012-12-14 | 2 | -33/+33 |
* | Filesystem: Revert documentation changes | Sebastian Huber | 2012-12-14 | 2 | -39/+39 |
* | libcsupport: Doxygen enhancement task #9 | Alex Ivanov | 2012-12-13 | 17 | -74/+160 |
* | termios: Fix output flush | Sebastian Huber | 2012-12-13 | 1 | -0/+1 |
* | libcsupport: Revert termios Doxygen. Add file header. | Gedare Bloom | 2012-12-13 | 1 | -32/+3 |
* | termios: Implement tcflush() | Sebastian Huber | 2012-12-13 | 3 | -30/+46 |
| | | | | New IO control RTEMS_IO_TCFLUSH. | ||||
* | termios: Fix tcflow() error status | Sebastian Huber | 2012-12-13 | 1 | -0/+1 |
* | libcsupport: Revert documentation changes | Sebastian Huber | 2012-12-13 | 2 | -10/+10 |
* | misc: Header File Doxygen Enhancement Task #3 | Mathew Kallada | 2012-12-12 | 3 | -0/+6 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8006220 | ||||
* | libcsupport: Doxygen enhancement GCI task #6 | Alex Ivanov | 2012-12-11 | 22 | -58/+182 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992212 | ||||
* | libcsupport: Doxygen enhancement GCI task #4 | Alex Ivanov | 2012-12-11 | 26 | -116/+274 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8009205 | ||||
* | libcsupport: GCI Doxygen Task #7 | Alex Ivanov | 2012-12-11 | 25 | -62/+198 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7975223 | ||||
* | libcsupport: Doxygen enhancement task #5 | Alex Ivanov | 2012-12-10 | 25 | -54/+203 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992211 | ||||
* | libcsupport: Doxygen enhancement task #2 | Alex Ivanov | 2012-12-09 | 24 | -58/+209 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8017203 | ||||
* | libcsupport: Fix documentation | Sebastian Huber | 2012-12-09 | 1 | -9/+11 |
* | Filesystem: Revert documentation change | Sebastian Huber | 2012-12-09 | 1 | -1/+0 |
* | libcsupport: Doxygen Enhancement Task #3 | Mathew Kallada | 2012-12-08 | 25 | -39/+225 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7992210 | ||||
* | score: Add RTEMS_FATAL_SOURCE_ASSERT | Sebastian Huber | 2012-11-15 | 1 | -1/+1 |
* | Filesystem: Preserve source NULL pointer in mount | Sebastian Huber | 2012-11-13 | 1 | -4/+6 |
* | Filesystem: Use transient event | Sebastian Huber | 2012-10-30 | 4 | -22/+11 |
* | score: Work area initialization API change | Sebastian Huber | 2012-10-25 | 10 | -206/+171 |
| | | | | | | | | | | | | The work areas (RTEMS work space and C program heap) will be initialized now in a separate step and are no longer part of rtems_initialize_data_structures(). Initialization is performed with tables of Heap_Area entries. This allows usage of scattered memory areas present on various small scale micro-controllers. The sbrk() support API changes also. The bsp_sbrk_init() must now deal with a minimum size for the first memory chunk to take the configured work space size into account. | ||||
* | libcsupport: malloc_deferred_frees_initialize() | Sebastian Huber | 2012-10-25 | 3 | -12/+1 |
| | | | | Remove this function and statically initialize RTEMS_Malloc_GC_list. | ||||
* | libcsupport: Spelling | Sebastian Huber | 2012-10-15 | 1 | -3/+3 |
* | Filesystem: Rename function | Sebastian Huber | 2012-10-07 | 4 | -4/+4 |
| | | | | | | Rename rtems_filesystem_location_exists_in_same_fs_instance_as() into rtems_filesystem_location_exists_in_same_instance_as() for consistency with other file system instance related functions. | ||||
* | Filesystem: Rename function | Sebastian Huber | 2012-10-07 | 5 | -5/+5 |
| | | | | | | Rename rtems_filesystem_location_is_root() into rtems_filesystem_location_is_instance_root() to distinguish this from the file system root directory of the current task environment. | ||||
* | Filesystem: Reject removal of root nodes | Sebastian Huber | 2012-10-07 | 2 | -3/+14 |
| | | | | | | | Reject the removal of file system instance root nodes in rmdir() and unlink() and return the EBUSY error status. File system instances can be removed with unmount(). Remove root node special cases in IMFS, DOSFS, and RFS. | ||||
* | libcsupport: Add and use rtems_putc() | Sebastian Huber | 2012-08-20 | 3 | -9/+34 |
| | | | | This reduces code size and provides a function similar to fputc(). | ||||
* | score: Change greedy allocation API | Sebastian Huber | 2012-07-17 | 2 | -5/+12 |
* | libcsupport: C++ compatibility | Sebastian Huber | 2012-07-02 | 1 | -0/+8 |
* | libcsupport: Add rtems_printf_plugin() | Sebastian Huber | 2012-06-04 | 2 | -0/+34 |
* | Filesystem: Wait for unmount() to finish | Sebastian Huber | 2012-05-29 | 4 | -11/+79 |
* | libcsupport: Adjust malloc_walk() prototype | Sebastian Huber | 2012-05-16 | 3 | -3/+4 |
| | | | | | | | | The header file <rtems/malloc.h> provides now also the malloc_walk() prototype. The malloc_walk() prototype reflects now the _Protected_heap_Walk() API. The return status helps to print only in case of an error. | ||||
* | Filesystem: Add missing include file <stdint.h> | Sebastian Huber | 2012-05-15 | 1 | -0/+1 |
* | Filesystem: Change pathconf_limits_and_options | Sebastian Huber | 2012-05-15 | 3 | -4/+4 |
| | | | | | | The pathconf_limits_and_options field of rtems_filesystem_mount_table_entry_t is now a const pointer to reduce the read-write memory demands of file system instances. | ||||
* | Filesystem: Move operations to mount table entry | Sebastian Huber | 2012-05-15 | 26 | -51/+62 |
| | | | | | | | | | | | The scope of the file system operations is the file system instance. The scope of the file system node handlers is the file location. The benefit of moving the operations to the mount table entry is a size reduction of the file location (rtems_filesystem_location_info_t). The code size is slightly increased due to additional load instructions. Restructure rtems_filesystem_mount_table_entry_t to improve cache efficiency. | ||||
* | Filesystem: Add const qualifier to lock/unlock | Sebastian Huber | 2012-05-15 | 2 | -5/+5 |
