Declaration provided by Newlib since 2014.
Update #3409.
This function is provided by Newlib since 2000.
Update #3409.
Update #3409.
These functions are provided by Newlib since 2000.
Update #3409.
These functions are provided by Newlib since 2002.
Update #3409.
Close #3546.
Close #3545.
Wait for one tick in case no character is available after a call to
getchark(). Otherwise the system is constantly busy within an input
loop (for example in the RTEMS shell). The polled Termios driver uses
the same approach.
Use return value of memset() to enable tail call optimizations.
Use RTEMS_OBFUSCATE_VARIABLE() instead.
Update #3530.
Update #3533.
Update #3433.
Update #3320.
An invalid heap usage such as a double free is usually a fatal error
since this indicates a use after free. Replace the use of printk() in
free() with a fatal error.
Update #3437.
Close #3320.
Update #2840.
Update #2840.
The previous rtems_panic() implementation was quite heavy weight. It
depended on _exit() which calls the global destructors. It used
fprintf(stderr, ...) for output which depends on an initialized console
device and the complex fprintf().
Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic()
and output via vprintk().
Update #3244.
Add a default implementation of _arc4random_getentropy_fail with an
internal error.
Update #3239.
In canonical mode, input is made available line by line. We must stop
the canonical buffer filling upon reception of an end-of-line character.
Close #3218.
Update #3170.
Update #3199.
The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
Update #2740.
Close #3179.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
Reduce size of pthread_once_t and make it zero-initialized.
Update #3142.
Update #3122.
Update #3136.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Update #3132.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Rename rtems_libio_check_permissions_with_error() in
rtems_libio_check_permissions().
Update #3132.
Remove rtems_libio_check_permissions() and convert single user to
rtems_libio_check_permissions_with_error().
Update #3132.
This simplifies error handling later.
Update #3132.
Remove the file descriptor validation. This is the job of
rtems_libio_check_fd(). Use an inline function instread of a macro.
Update #3132.
Close #3134.
The top-level IO library structures should contain no special-case data.
Update #2859.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Newlib uses _times_r() in clock(). The problem is that the _times_r()
clock frequency is defined by sysconf(_SC_CLK_TCK). The clock frequency
of clock() is the constant CLOCKS_PER_SEC.
FreeBSD uses getrusage() for clock(). Since RTEMS has only one process,
the implementation can be simplified.
Update #3121.
An integer overflow may still happen, however, only after 68 years of
system uptime.
Close #2135.
